Chevy/GMC Owners
Dealers have allocations. If you happen to order a truck that has already been allocated you could get it earlier. They have the ability to make adjustments in those allocations to fit your needs as they did with mine.
On Monday that will be 15 weeks!
did you try kelley blue book?
www.kbb.com
tow a light (2,500 lbs) camper in the summer. I can get an aftermarket bar for about $120.00, no drilling to install.
I think it is 245 hp I'LL get back latter
you might have to wait a day to someone sees it. Pretty sure it 245 hp and maybe 375lbs torque Nice Truck how many miles are on it?
GM would laugh hard at this complaint. Lights flicker at 80MPH what is the posted speed limit. Bet a bundle they for sure wouldn't warrenty that complaint.
I know there is a rev limiter on the vehicles that retards the timing. Don't know if that is what the computer is doing, in the course of things it is also screwing the lights up.
We get complaints in our dealership (mostly vette owners) that there car has some glitch at like 85mph only at 85mph or above. Guesss what we legaly can not reproduce that problem. It is illegal to go over posted speed limit ecspecially with clients car. We all know that we do it and drivers do it but warrenty will not pay for it if it is at such a high rate of speed. Just the facts whether you like it or not.
It may be difficult for the dealer to reproduce but should be worked on! Seems like GM engineers
would have some ideas if there is any way to get them involved?
I live next to Mont. and drive through yearly. They start handing tickets out to people going over 80mph. Besides what does driving 50mph in a 35mph zone have to do with anything. Sounds like you may have a grudge.
I do not want to have to defend myself or anyone else in this post I was just stating the problem you will have getting this fixed.
pcommer
Hate to say it but there is no way for me to describe what needs to be done over this post. Usual a auto tech. would run a systems check with a Tech 2(gm hand held computer used to interface with the car computers). More then likely that would check out ok. Is my guess seeing how it happens at such a high speed.
What you may try to do is talk to your dealer. There is an on board recorder they can let you use to record what is going on. It will have a button you push when your problem acures. The recorder then records so many minutes before and after you push the button. I forget how many snap shots you can take about three or so. Hope that helps. *Note not every dealer has this recorder yet. It is fairly new.
I have a question for you since we have the same type of truck. Before you had the ECM reprogrammed on your truck did you have a problem with slow release on the throttle? As in, take your foot off the gas and wait for the engine to slow down? I have had this problem in my truck since it had about 5K miles (now 40K) and GMC claims there is nothing wrong. I have checked NHTSA and have found about a dozen complaints about this problem. I am running a tuned MagnaFlow muffler now, and you can both see on the tach as well as hear when the engine releases. The floor mat recall has already been done. The throttle is mechanically returning to idle, but the fuel injection goes into a rich state and holds the engine speed up.
Jim
there will be a major recall coming foreward in regards to unsafe seats for the gm products.
after 3 years and 30,000 emails-GOLIATH GM is about to meet their waterloo. gm is replacing an average 1,000 seat repairs a month.
thanks for the info from you mother truckers!!!
Back in the days when a carb did not refur to California Air Resources Board ;-) I had a car with a gulp valve (EGR) that caused a slow throttle release. After giving enough pedal to start from a stop and then releasing, as for traffic interruptions, it would continue to rev for at least five seconds. Had it not been a four speed, there would have been many incidences of a severe pucker factor.
Is there still a semblance of those wonderful “gulp valves”?
By the way, the part was made by GM and used as part of the SMOG system on many imports. Mine was a BMW 2002.
If your lucky it reproduces on the lift. It sounds as of it may.
From hearing what you said about the speedo being weird makes me lean toward spending some time on checking the bcm or ecm. I forget which controls the speedo. But what happens is it gets a signal from the wheel speed sensor(s) and then sends out a signal to your cluster. Which in turn gives you your speed.
But other then that info I have no idea as to what else I can tell you to help. Like I said before, the Tech 2 is what is really needed to begin solving this problem.
If the dealer dosn't have the snap-shot tool. See if they will find someone who does or call around and find a dealer that does. GM or Chevy.
Good luck>
Jim
Stevek, I called the 1-800 number and they won't do anything until a dealer has looked at the vehicle. I think that approach is perfectly understandable from their point of view.
26Andrew1, the guy on the 1-800 number gave me another 1-800 number of where I can buy a copy of the service manual which does have all the wiring diagrams at a cost of $96.00. I will purchase that if the dealer can't fix my problem. I did notice this morning, however, that the needle does have problems when the headlights are on but only when the lights are flickering. The needle deflects by as much as 2-3 mph which I think is a bit much for a speedometer. You mentioned a cluster, are you talking about the instrument cluster? What are the "bcm" and "ecm"?
bcm=body control module
ecm=egine control module
I mentioned your problem to one of our 20 years in the business techs. He said he remebered something about that the s-10 would cut power once it hit a certain rpm or mph. Not sure which.
I didn't have time today to look it up but will try tomorrow.
I know the owner of the dealership won't own an s-10 because of the limiter.(LEAD FOOT). He has a burban big block instead.
I apparently also have a heavy foot and my truck of choice was the 99 silverado extended cab. Unfortunately the wallet wouldn't reach that far.
I checked with the dealer and they don't have the snapshot capability. Any information you can give me might help. I had to postpone my visit to the dealer until the 15th so that gives me a little more time to document it. I am hoping that by documenting it I can see a pattern emerge. So far it has only been highway driving, at that speed.
thanks again
I still maintain you have an open ground intermittent some place, that could be why it affects more than one system. Why don't you pull the fuse for the headlamps, and see if the speedometer still gets whacky at 79-80 mph. (Bet it doesn't) Put the fuse back in, and check the headlamp relay coil circuit with the truck on jackstands so you can simulate the speed. Use an oscilloscope, not a logic analyser. Isolate the possibilities by breaking down the problem into parts. If the headlamp goes off but the relay stays on, then the problem is an intermittent in the headlamp circuit itself. The disturbance could easily be enough to upset the speedometer. If you really believe the speedometer circuit is causing the problem, why not just unplug the input from the speed sensor at the back of the transmission, and run it up to speed again.
As I said before I am a failure analyst by trade so determining exactly what is failing won't be a problem once I have the wiring diagrams. The first problem is, that it is a brand new truck with less than 3K miles on it and I don't want to void any warranty issues. I first noticed and began documenting the problem at around 1100 miles. I have to give the dealer ship the opportunity to fix it first.
The second thing is that if it were a loose or bad ground connection it would appear at almost any speed and especially on any rough road conditions. Even the dealer agreed with me on that. Here in Massachusetts, better known as "Pot Hole City" the only roads that are smooth are the highways and even that isn't exactly smooth. This time of year I think the off road conditions would be a little smoother.
The reason I came to this board was more for research. I was hoping someone else had already been through this problem with this truck and could shed some light. This board has actually helped me locate the wiring diagrams, although I'm not ready to shell out $90 for them yet. I truly am not limiting my possibilities to just the speedometer it just seems to be another way this problem is showing up. Without those diagrams I don't know what else may be common to the circuit. It could be a relay, a crack on the dashboards circuit board or a module somewhere, or a sensor, or a computer glitch. It truly could be anything but without the diagrams I can't see what can be ruled out. Believe it or not it could even be a cracked vacuum line which is causing a sensor to send erroneous signal back through the system. I can't rule out anything yet.
I can fix this myself. I just have to give the dealer a chance first.
I've been waiting for these to hit the dealerships for 2 years, but my first look at them almost made me sick. The mechanicals of the new design look very good, but the styling doesn't do anything for me. And 3 doors! The design team must have been on vacation that year.
I don't think I would ever buy a Dodge, but the Ford is looking awfully good. Plus, Ford offers some interesting options like the Sport truck (with no chrome).
Apparently, Chevy is having trouble selling the Silverados. The lots around here are stacked with new Silverados and the January sales report shows GM with the only big 3 decrease in truck sales.
I'm going to look carefully at the new Tundra this spring and try to wait until fall to see if Chevy can fix any of their mistakes - then, I'm going to buy something.
This morning I spoke with the technical specialist
at a large GM dealer in the Austin, Tx area. Here
are the questions and the answers I was given.
1. The engine rattles when it is started. Longer
when cold, but on any start after it has been
sitting for more than an hour.
ANSWER: The noise is from the lifters bleeding
down and is typical of roller lifters. GM sees
this as no cause for concern as long as the rattle
stops within a minute.
2. The throttle does not return to idle when
released. The vehicle will continue at speed for
several seconds, and at speeds under 50MPH will not slow down without substantial application of the brakes.
ANSWER: GM has advised that THIS IS THE NORMAL
OPERATION OF THIS TYPE OF FUEL INJECTION AND HAS NO PLANS TO CORRECT SOMETHING THAT THEY DO NOT FEEL IS MALFUNCTIONING. ???!!!
Hmmm. I don't like these answers. The lifters
are bleeding down prematurely. The fact that they
are roller lifters has nothing to do with the
problem. And I cannot believe that GM thinks I am
stupid enough to believe that unresponsive throttle operation is normal! I have owned two vortec 4.3L with the CPI fuel injection system and neither of them had this attribute. Time to escalate the issue.
Jim
While cleaning my truck following an off-road
expedition, I noticed that the inside of the rear
bumper had a thin coat of rust. Is this normal?
I was shocked to find this on a new truck. Does anyone have any suggestions?
My experience is the factory bumpers last alot longer before rusting than the aftermarket bumpers. You could always clean it really good with a steam cleaner and spray on a can of undercoat.
