Infiniti G35 Maintenance and Repair
1192022242558
  • kgtripskgtrips Member Posts: 5
    I stand corrected. The maxima is a front wheel drive and still sucks in the snow. Must be the all seasons which really don't do the job when there's snow on the road.The car has been very dependable though with virtually no mechanical probs ( its auto).knock on wood!Hence my optimism that I will somehow be as fortunate with the g35.
    I do plan on drivung the g35 year round ,very carefully in winter, with good snow tires.
    Quite frankly once you're dropping the bucks you have to spend for the car the extra ,1000-1500$ for snows to protect it ( and you) is something I can live with. Just keep reading the press about how this car should cost $10,000 more than it does and the $ for snows doesn't seem like such a hard pill to swallow.
    as for the kids , mine are 6 and 8 so a booster is the worst thing I have to deal with at this point.
  • pesce02pesce02 Member Posts: 2
    I don't know what the fuss is about with the coupe in snow.
    So far, and mind you I've only had opportunity to test in light snow, my AT coupe handles the snow considerably better than any FWD car I've driven.
    I know that a lot of the complaints are from those with the 18's and summer pilots, but I've read a number of complaints or concerns about the 17's as well. In my experience thus far, I'm pleasantly surprised by the poise of the coupe in the snow with the a/s goodyear's.
    BTW, my last car was a rwd 90 300zx, and the G coupe is far superior in its winter handling capability.
  • pearl2004pearl2004 Member Posts: 3
    This is my first experience with performance tires. After I left the dealership, I learned that performance tires are summer tires! I ordered winter tires with rims and will travel to PA Tuesday to have them installed. It was cheaper buying tires and rims than purchasing a used car to use during inclement weather (property tax and insurance). Next time I might forego performance tires unless between now and then someone invents an all weather performance tire.
    Other than the tire issue, I love the car. I plan to go to Summit, WVA this spring and learn what Pearl is really made of!
  • adrian8adrian8 Member Posts: 12
    Have a 2003 G35 sedan, 8500 miles, and like everything except the excess brake dust and the grabby brakes. I took care of this by having a set of Morse ceramic brake pads. part #526C installed on the front. There is absolutely no brake dust and the brakes are much more progressive. I did not want the dealer to put on new crappy pads. $150.00 all fixed.
  • gabmangabman Member Posts: 284
    I am not sure if you hav heard that Infiniti have introduced a warranty on both brake pads and rotors. They are both now warranteed for 3 years.
    While I understand your desire to get rid of brake dust and hence you do not mind paying for your own pads, I have a feeling that you will be voiding the warrantee on the rotors by using after market pads. I have already gone thru two sets of front pads and one set of back pads along with having to change front rotors. All this with only 34,000 miles on my car. Initially prior to warrantee being introduced on brakes I was out of pocket $750.00 for these repairs. Once Infiniti introduced the warrantee they refunded every penny back to me. Got the cheque before x-mas
    The early pads that they were using would become much more grabby as the pads wore down. The latest pads along with the new rotors have cleared up this problem.
    I have heard that ceramic pads will damage the rotors so you may want to look into this before you are faced with having to pay big bucks for new rotors as infiniti will not warantee the rotors due to ceramic pads.
    Thanks for the concern, but I have used the ceramic pads on my past Infiniti with no problems, and great rusults. Drivers have warped their rotors with the OEM pads, so I believe it is the driver and their habits; not the pad.
  • blerner1blerner1 Member Posts: 12
    what happens after the 3 year warranty extension on the brakes.
    This is just a patch warranty extension. Someone ought to seek out a class action to have this brake problem resolved or extend the warranty to 100,000 miles no time limit.
  • woojacwoojac Member Posts: 6
    I just drove an '04 6MT sedan and was surprised at the high effort clutch. I have driven full size pickups that require less pedal effort.
    It also seemed that there was a very small engagement range making it tricky to get smooth changes.
    Is this normal for this car? It may colour my decision on buying this car.
    Thanks for any feedback.
  • robertrrobertr Member Posts: 125
    I have over 13K miles on my 2003 G35S 6MT and think the clutch effort is just right - not too stiff, and not too light. It provides good feedback and control. Overall, the clutch and shifter are the best I've ever driven. Very short throws, precise, good feel, easy to make quick and smooth upshifts and double-clutched downshifts once it is broken in and you are experienced with it.
    I've been in a few expressway traffic jams caused by construction and/or accidents (and the blackout in Detroit) that were over an hour of stop and crawl and repeat and the clutch was very tolerable.
    Try driving a late 1960's to early 70's Detroit musclecar to see what a stiff clutch really is.
  • cheerioboy26cheerioboy26 Member Posts: 412
    My service dealership (Passport, Alexandria VA) advisor posted on another forum that the brake pad part numbers changed, so he thinks that the pad may be different (and assumedly impoved).
  • zumbalakzumbalak Member Posts: 3
    i have a sedan 6mt, the clutch at first took some time to get used to, as i think it was stiff, and after about 2k miles either i got used to it or it got smoother i don't know. now i feel like driving a regular clutch without a problem. if you are used to driving soft clutch cars like honda, toyota, mazda, audi then the clutch of infiniti definitely is stiffer. i drove many cars with different clutch sensitivity and infiniti was one of the most stiffer ones i think, except a renault 12 i used to drive when i was living abroad and it was like 10 years ago.
    just give it a little time and once you get used to it you will realise it is a lot of fun, short throws, and you can turn the vcd off, entering a curve in a street downshift floor the gas with clutch not fully released and spin your tires and your back a little bit, it is such a fun car to drive with the manual transmission.
    (the above statement is not intendend for advice purposes, i sometimes do it in slow speeds, and i don't accept any responsibility or any wrongdoing in any circumstances, use it on your own risk, actually do not use it at all.)
  • wallyg35wallyg35 Member Posts: 11
    ANYONE HAD ANY PROBLEMS WITH THEIR SEATS
    WEARING? I HAVE 28,000 MILES ON MY G
    AND THE DRIVER SEAT IS SHOWING VERY POOR
    WEAR, CRACKING AND JUST PLAIN WEARING OUT.
  • carnaughtcarnaught Member Posts: 3,608
    Amen....my seats at 23,000 mi. are wearing poorly also....very disappointing with a so-called luxury division.
  • dklaneckydklanecky Member Posts: 559
    Leather interiors require maintenance in order to look good and wear well. Nissan interiors wear extremely well if properly maintained.
    What are you doing to maintain the car?
    Here's a source for some really good info on the topic.
    http://www.leatherique.com/
  • chrisbothchrisboth Member Posts: 493
    Just bought some as I dont think mink oil works that well. It was 16 bucks for the cleaner which conditions and 16 more to ship - jeez. Also, I doubt you'd need the restorer for another 30 bucks unless you have more than some minor wear issues or its harder than hell. right?
  • infinityfaninfinityfan Member Posts: 7
    The brakes on my brand-new G35 sedan are squeaking a little bit. Is this normal break-in behavior?
    Thanks to anyone who knows the answer!
    car is now at the dealer the last three days. The car suspension felt detached from the car with a horrible rattling noise. The service manager tells me the rear stabilizers were "dry" and there was a problem with the front struts. Now after the three days, he tells me the noise is better but still there. I'm picking it up this afternoon. Stay tuned......
    Anyone else have this problem?
  • frozefroze Member Posts: 40
    I too had a problem with strut noise coming from the drivers side. Dealer replaced the strut & sway bar end link. It helped but did not completely get rid of the rattle. I've more or less learned to live with the noise. Now, if I could just learn to live with the uncomfortable driver's seat!
    Doesn't say much for the car. If you had to do it again, would you buy another G?
  • lyddslydds Member Posts: 2
    Thinking of buying the 2004 AWD G35X. But after reading all of these problems, I am not so sure. Should i continue with the purchase??
    There are 8000 G members on another site and noone has mentioned the suspension becoming detached from the car...this is not an issue for 99.99% of us.
    And at 6'5" 240 I am very comfy in the seats - but I had the seat control tsb..
    my car back yesterday afternoon from the dealer service dept. as posted previously. I must say that the car rides like new. Oh, btw it did also have the front seat track problem noted by others on this board. Also I had the recent engine light recall (I think my 8th recall since buying) taken care of.
    Thus far I'm satisfied with the dealer svc. even though I think there have been too many "issues" since I've had the car.
    >>Thinking of buying the 2004 AWD G35X. But after reading all of these problems, I am not so sure. Should i continue with the purchase?? <<
    Oh most definitely! I'm a very satisfied owner; I'm just trying to find out about the little squeak in my brakes. Speaking of squeaky things, just remember this is a small universe on this particular board, talking about whatever problems they seem to be having. It's not necessarily representative of the G35 universe.
  • coreywcoreyw Member Posts: 17
    Hi All,
    I seen some great information on the NHTSA website (http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm) that people have mentioned that they take with them to Infiniti Service regarding various problems found with the G35.
    But, what do you actually take in? For example, if you do a search on "Vehicle -> 2003 -> Infiniti -> G35 -> SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER, you do get (what I think) is the infamous rocking seat TSB. It refers to Service Bulletin Number '061003'. Is the number 061003 what you take to the dealer to prove to them the problem exists (if they deny it?).
    Or is there more detail that you have to pay $$$ to get?
    Thanks in Advance.
    Corey.
  • msisengmsiseng Member Posts: 369
    You do not need to pay anything for this information. It is provided via United States Citizens paying taxes and receiving this service. More detail exists internally and often is not released to the public. A "TSB" is issued by the manufacturer and is not mandated via the NHTSA. I see that you are Canadian. Is there an equivalent in Canada?
    Sometimes things are not filed in the appropriate folder on the NHTSA site. This is because the complainant erroneously mis-classifies his/her issue. The NHTSA does not make a change because they want the complaint to remain in an original state without modification. This helps with subsequent investigations.
    The people working at the NHTSA do not care where the issue is placed; however, they do care about the complaints themselves. They then pressure the manufacturer to make changes when necessary. Some very nice and caring people work there. The NHTSA pressured Infiniti to offer the same brake warranty in The United States that is offered elsewhere.
    Here's the approach that I have used for several years that has always (well, almost always) proven effective in getting my issues (or even suspected issues addressed by a TSB) resolved.
    I read the TSB symptoms described in pretty decent detail by Nissan on NISSAN's technical web site for free.
    If I think it sounds like an issue I'm having with my vehicle, then I write up (nothing verbal here as you want to maintain a written record of the issue, dates, etc) a complaint about the vehicle that almost matches exactly the description of the TSB and ask the dealer if they can look into fixing the issue.
    I wait for the dealer's response about the issue and let them see if they find and fix the issue or identify the TSB.
    I don't start mentioning TSB's to them unless and until the fail to find it on their own or I get the infamous (unable to replicate the problem).
    I try to avoid the adversarial/confrontational method of addressing issues unless they can't fix-find the issue.
    Then I'll maybe ask them if they checked for TSB's.
    That virtually always gets them to identify and resolve the issue(s), although it does take two visits occasionally.
    hey dklanechy: you sure there's (free) access to Infiniti TSB's? The www.nissan-techinfo.com website says:
    Online Subscriptions
    Purchase an Online Viewing Subscription for access to our extensive online library of Infiniti publications.
    Unlimited online access to Infiniti Service Manuals, Technical Service Bulletins, Interactive Online Training, and more for the duration of your online viewing subscription....
    What website are you looking at?
    Also, in my previous posting about the TSB's on NHTSA, is the Service Bulletin number given the Infiniti reference number?
    Thanks guys!
    Corey.
  • kdleekdlee Member Posts: 6
    As reported several times before, I also noticed there is a gas pedal vibration at low rpm range (1200-2200). It has nothing to do with ABS or self-test. Does anyone have update on this issue? Or, have you felt this?
    This vibraion may be due to too sensitive shift down with little touch on the gas pedal at low speed. Do you have the same problem?
  • bobb2111bobb2111 Member Posts: 7
    Years ago I had a Vette & experienced accellaration while braking. Audi spent millions unsuccessfully trying to resolve that complaint with their cars. I changed my shoes & the issue was resolved. For those with the problem, try different shoes. It might work.
  • vinu_neurovinu_neuro Member Posts: 22
    I am considering getting the G35 coupe, but am not sure as to how it handles in the snow because of rear wheel drive. Any input would be appreciated.
    I have a G35 sedan with the all-season tires. Just had another snowstorm Friday. It handles fine in snow if you are skilled driving RWD and don't expect it to drive like FWD. However, it will not climb a slippery incline as easily as a FWD car and it is more likely to get stuck in a parking lot if a heavy snow happens while it is parked. I have not been stuck yet with the G but did get stuck once or twice in 6 years with a 300ZX. Remenber that most cars used to be RWD until recent years and people drove them without any problems. Also German cars (Mercedes, BMW, Porsche)are still and will remain RWD (excluding their SUVs they sell in US) and Germany is a snowy country.
  • hughjsackhughjsack Member Posts: 5
    For the G35, can anyone advise the exact tire provided in Infiniti's "all-season" designation?
    Perhaps more important, can anyone comment as to whether - and to what degree - sport performance might suffer with the all-seasons in normal conditions?
    This concerns the RWD of course, w/ sport-tuned suspension. Although in the Northeast U.S., I'd prefer not to have the all-seasons, but the model I'll probably be buying has them. I'm too cheap to buy a summer set unless performance is appreciably hampered by them! I've never had all-seasons and I don't want to spoil the ride.
    Much thanks.
  • tonyg24tonyg24 Member Posts: 11
    can infiniti put all season tires on the 18 inch rims..or they have to be 17 inch rims...right now a car in which i have a deposit on has the sport package ..i am guessing they have the summer tires which are most likely not even good in one to 2 inches of snow...and one more thing..is infiniti still repairing rotors and brake pads..i read they were, then in the forums i read they no longher are...whats the letest on this...i want to make sure i have all the fine print down before i sign anything...is there any documents i need to bring in, incase they say that they are not replacing anymore
  • mbednorzmbednorz Member Posts: 63
    RE: 18" sport package on the coupe. (you're talking coupe, right?) These are "summer only" tires from the factory. Below 45 deg F they loose almost all adhesion, snow or no. You do NOT want to drive these in cold weather. Everybody's having trouble finding a snow tire or even an all-season tire in the correct size. For snow, most folks are getting a set of 17" rims and snow tires.
    I don't know which all-seasons Infiniti provides. In general, an all-season radial is going to give up a small amount of adhesion, and will lose a little turn-in sharpness, as compared to a pure "sport" tire. If you are a "string-back glove" kind of driver that wants the last 5% of performance and road-feel, you'll care. Otherwise, it'll probably never affect your enjoyment of the car. For what it's worth, I've got the coupe with the 17" Goodyear RS-A, a "high-performance all-seasons", and I'm very impressed with their performance.
    Thanks mbednorz..I thought so.
    Tony, re. the brake replacement, I'm told they are still, but not on the Brembro's. If you are in fact getting the coupe, you may well be getting the Brembro's (are they standard w/ the coupe?)so check. I guess the rationale is that if you're getting those brakes, you know what you're getting into. Glad you mentioned it, my dealer WILL now be putting what he said in writing.
    By the way, if you ARE getting the coupe w/ Brembro's, that's not such a bad problem to have! I'd have done the same, but alas, my customers are not small enough to fit back there, and my company'd probably have fired me for spending their dime on a coupe for a company car! It was still tempting though...("but boss, it DOES have a backseat!") but the sedan's not a bad 2nd choice (and yeah, I could have had that "other" sedan just as well, but in all honesty, its "B" feels more like "Boring" than "Bayerische"!
    yes, guys sorry i was talking about the coupe...I am not sure if I am getting the Brembro's or not..i have to ask the dealership...so if i get those brakes they are not replacing them? are they still known for wearing excessively with the rotors? and as for the coupe they have in stock they said it has the sport package which i believe has the 18inch rims and the sport tires...that doesnt seem to be a good way for me to go since i live in NY and have to deal with snow driving and weather under 45 degrees...so maybe i should see if they can put the 17inch rims on the car with all season tires...how much $ shdould be taken off the price...right now the deal is for 4500 down and 440 a month for 39 months..a lease...all options..with navi and all..i am assuming the 18 inch rims have to cost more than if i got the 17 inch rims
  • rflax104rflax104 Member Posts: 3
    You will find that NO ONE offers all season radials to fit the front. If you need winter tires Bridgestone Blizzaks make both sizes, and maybe Dunlop. However, I did not want to get started on changing tires every six months in the midwest, and I did not want to give up the Michelin's...so--I had Michelin Pilot Sport A/S 245 R45-18 (same as factory size) all season put on the rear, and still have the 225 R45-18 summer factory tires on the front. You maybe could have the Pilot 235 R40-18's put on the front, but I decided not to do that because the ride gets worse the lower the ratio of the tires. I am waiting for Michelin to come out with the fronts-I have emailed Michelin on its web site begging that they start making the all season size for the front since they already obviously make the performance tire.
    I am very pleased with the G35 coupe with 6 speed, and would buy it again.
    Richard
  • cleon21cleon21 Member Posts: 1
    I have a one month old G35X with less than 1,000 miles on it. I live in CT where it's been pretty cold. The ride seems extremely harsh, especially over highway seams. I know this is meant to "feel the road" but this is extreme -- I wince every time I see a bump ahead. I've had Maximas before and never felt this. Dealer says its just a firm-riding car, nothing wrong, and the all-wheel suspension is a little stiffer for the added weight of the ATESSA Sytem.
    Have others experienced this? Could it be break-in period? Cold weather? Any after-market solutions?
    Wow you may have bought the wrong car
    I think it may be a bit of your expectations (it will be stiffer than a Maxima - I have a 2000 SE) and the cold. The suspension IMO just doesn't work as well when it's 10 degrees out! I have a RWD G, so I can't comment on AWD differences.
    I have a G35 Coupe MT6. I put Blizzak 17" on front & back. Yes it required me to buy a set of wheels, as my car came with 18" wheels. Today the roads are "bad" & I didn't have to drive my truck & leave the car I love to drive at home. I've lived in upstate New York all my life. I've put snow tires on cars since my 1st in the late 60's. It's a price I pay for driving a RWD car, which I prefer. I've owned 1 FWD. It was an Integra GSR. It was fun but it's not a G35. If you want a real sport car feel, at a very reasonable price, relative to the compatition,the G35 Coupe MT6 is a great choice!
    You're getting, as standard equipment, Brembro brakes & 18" rims if you're buying the G35 Coupe MT6. If you're buying the automatic you'll get 17" wheels & lesser brakes.
  • rderizansrderizans Member Posts: 15
    I've got a new G35x (about 100 miles on it) and noticed a bit of that ride harshness. The suspension definitely will settle a bit over the first 1k miles or so. However, it will always be fairly firm, I think (and hope). It helps to keep the car controlled over those bumps and keeps squat/dive/roll to a minimum. Part of the reason for getting a G.
    One thing you might want to check is your tire pressure. Make sure it matches the 30psi recommended at all four corners (I think). Should be a cold pressure, meaning the tires haven't been driven a lot prior to checking, but that doesn't mean at 5 degrees like we've had here in NY. If it's really cold out (below freezing, shoot for 28 or 29psi, I'd say...no lower!). Tire pressure can make a huge difference in ride quality over expansion joints, etc. More so than the suspension tuning, in my experience.
    Good luck and enjoy the car!
  • jpdrainjpdrain Member Posts: 4
    get the snow tires. it's well worth the peace of mind and they rock this time of year. even if it is only a couple days here or there...pays to be safe when they are the only thing your machine touches the ground with. summer tires are in the garage just waiting for warmer weather!
  • wibblewibble Member Posts: 569
    They are standard on 6MT coupes. You can't get them on automatics or sedans.
    I keep seeing complaints about the hard ride on Infinitis (especially the FX and the G) all over the place. Do people really spend anywhere from $30K up to $55K on these cars without test driving them properly first? If you're going to drop that sort of money on a car then you really should test drive it for at least 15 miles first over all sorts of road surfaces. If the dealer objects then vote with your feet and walk.
  • anf1anf1 Member Posts: 2
    Now, all of these complaints regarding the G35 are all really nit picky. As for me i have not had a problem with the car and am satisfied with the ride. You know, this is a firm riding sports sedan. If you want a cushy ride buy a lexus! As for the leather seats wearing badly, just mainting them properly. Mostly everything else that everyone beens complaining about is nothing that should hinder your descision if you want to purchase a G. And come on guys, no car is going to be absolutley perfect, and keep in mind, while this car isnt cheep, this is no pricey high end luxury vehicle either. It was a great value all in all, and anyone in the market for a moderatley priced sport sedan should find this Infiniti to meet your needs.
