Dodge Dakota
13468911
  • dodgeramdodgeram Member Posts: 202
    Omly with the four full doors. But the 2000 Ram will have a 5inch increase to it's quad cab making it more comfortable in the rear.
  • alandedm1alandedm1 Member Posts: 1
    An article in the latest Auto
    Week, indicates the new
    Dakota four door will be a full
    crew cab with a 5" 3" bed and
    available with a 4.7 or a 5.9.
  • astaasta Member Posts: 122
    Re last post: What is the current door configuration on the '99 Dakota? Is it a 3 door? The above-mentioned vehicle - 4 door with a 5'3" bed and the Jeep's 4/7 V8 (a great engine from what I've heard) is that what the 2000 Dakota will have and if so when will it be available? Does anyone know if the 4 door Dakota will be available with a bigger bed than 5'3"? I priced out the invoice costs on a '99 Dakota with the small V8 and plenty of options (no leather) vs. the '99 Dodge Ram with roughly the same and the Ram is about 3K more. Seems kinda worth it to spend the extra $, but what's everyone else's take on the Ram 1500 4-dr 6.5 bed vs the Dakota? I won't be doing much towing, but plenty of off-roading in Baja, mountain driving in snow and ice, and I'll need the bed for surfboards, snowboards, misc. gear and hauling around town etc. I live in the city so parking space is a concern.
  • DmatDmat Member Posts: 43
    Latest news:
    I just got ou t of a 3 hour training session, and have some updates. Hold off thinking that the 5.2 and 5.9 are gone. Both engines have preformed great for years. The 4.7 has been delayed for a while. Chrysler is using C.A.T.I.A. to work out the bugs. Don't expect it in 2000.
    Yes four full doors on the Dak. They are not suicide. I begged the trainer to do the same on the Ram :)
    There will not be a significant loss of bed length since we do offer the longest bed to begin with.
    Hope that this helps you all out. If I find out any more I'll be sure to post.
    Matt D
    http://members.xoom.com/99overNvoice/Index.htm
  • hurtn4certnhurtn4certn Member Posts: 9
    I bought my 1998 Dakota Club Cab 4X4 back in Oct 1997, after having many problems with a 1997 Nissan 4X4. Have to admit that I was a little weary about buying "American", after the late 70's and early 80's experience. But I have been completely impressed with the quality and performance of my Dakota truck.
    I now have 33,000 miles, with one round trip from Seattle, WA to Minerva, OH. The only problem encountered was a cracked front drive shaft yoke, which dodge replaced no questions asked. (no, I wasn't 4 wheel'n!) 31 inch tires and a 3.9 V6 isn't the best combo for performance. but my truck has logged several +20 mpg runs. I've added a K&N airfilter and ram air intake, which seems to increase power also. Some savolon engine oil additive has also been added. Average city fuel consumption is +16 mpg, depending upon how late I am!
    One question though. Why have American auto manufacturers not figured out the benefits of being able to turn on the AC along with the defroster?? I live in Tacoma WA, where windows are always fogged up.
    Does anyone not like the fact that the fog lights automatically turn off with the bright headlamps?? There is an easy fix for that. One ground wire under the hood.
    Was thinking about replacing the 31X10.5 tires with smaller, 235/75's. Better gas mileage with the smaller tire, but there is something sad about a truck with small wheels. Especially with all that wheel well space.
  • durbiendurbien Member Posts: 10
    This is for pttaylor (msg #141) or anyone else with Base model Dakotas:
    Saw your post and had a few questions.
    Here in So. Cal. all the dealers have are Dakota Sport Club Cabs. Did you have to special order your Base Model? I'm assuming that's what you got and not a Sport without options. If so, how long was the wait? Did your dealer try to charge more for the order?
    Does the interior look cheap and plasticky or is it heavy duty-durable? I work in muddy construction areas a lot and don't really need a carpeted interior, but I don't want it to look crappy, either.
    Did you opt for the cloth bench seating or did you stick with vinyl? I hate my car's leather seating, but I don't know what the upcharge is for the cloth seats. Are they comparable to the Sport's split bench (with center console) or are they just cloth covered versions of the Base's bench? (I suspect the latter) Again, without any Base model Regular Cabs to look at, it's hard to compare.
    Have you experienced any of the transmission and/or braking problems discussed on this board? This is a major concern for me, as my present car has had numerous problems and I don't want to spend more $$$ and not improve my transportation situation.
    What kind of bedliner did you get "thrown in"? I too live in salt water conditions (though I would never actually be in it as you are!) and I'm
    concerned about rust. I've heard bad things about the drop-in plastic type, but the idea of spraying in gunk doesn't sound too pleasant either. Do you recommend having the dealer install it or go with aftermarket?
    Does anyone on this list recommend the HD Service group, Tire and Handling Group, or exotic axle ratios for someone who is using the truck mainly for commuting and occasional light hauling? (no towing, offroading, or beds full of gravel) Once in a while there will be hardwood or tools in the back (I'm a cabinetmaker), but nothing approaching max payload weight. Do I need the rear stabilizer? Are Base tires sufficient?
    Sorry for the rambling,
    durbien@lib.occ.cccd.edu
  • poconojoepoconojoe Member Posts: 42
    I own a 98 2WD dakota sport w/3.9 & 5speed.The trucks been a great commuter, work & play vehicle. 24 MPG while commuting and enough power for hauling firewood. Winters in PA. have been rough with 2WD. I'm going to trade up to a 99 4WD ext cab dakota.
    My questions are if the 3.9 engine is sufficient with a this setup.(MPG's are important) Dodge is offering a free 8cyl upgrade. Also is limited slip differential necessary w/ 4WD. its a $242 option. Whats your opinion on 235 tires or the 31x10.5
  • rmccrawrmccraw Member Posts: 1
    I'm getting ready to order a Dakota and am trying to decide if I want the 4-wheel ABS. It looks like 2-wheel ABS is supposed to solve the problem of having the truck swap ends under hard braking. But wouldn't maximum braking still lock the front wheels? I'd prefer to be able to steer during maximum braking -- we have a lot of moose around here.
    So it seems to me I'd have to pump the brakes with rear-only ABS. I have ABS on our other vehicles and I've trained myself to use it as designed. I'd prefer not to have a truck that requires me to use the brakes differently in a panic situation.
    Any thoughts? Thanks for the help.
    (This post is over on the ABS discussion, too.)
  • ladyblueladyblue Member Posts: 326
    rmccraw:
    Pumping the brakes with ABS actually disables the ABS whether its rear wheel only or 4 wheel. Constant, steady pressure is all you need and the ABS will do its job.
    Under most driving conditions, rear wheel ABS should be adequate. I would recommend 4W for heavy loads, towing and, in your case, frequent moose avoidance.
  • smlemairesmlemaire Member Posts: 1
    I just bought a 1989 Dakota last Saturday at a State of Michigan auction on a whim. I am puzzled about one thing though. On the dashboard is a button labeled "O/D." Is this supposed to be "overdrive" or something else. I would appreciate anyone's help with this.
    yes it is overdrive. My 94 ram has the same button.
    Does anyone have an opinion on Mopar accessories? I know a lot of you have aftermarket products. Was this because the OEM stuff was unacceptable quality-wise or was it way overpriced? I'm specifically looking at bedliners, hard tonneau covers,running boards, and mirrors. I've heard people say you could have such things "thrown in" to your deal for less $$, but are they worth it? Does the value of the truck improve with OEM vs. aftermarket parts or is customization so prevalent nowadays it doesn't matter? Does having such aftermarket products installed void the warranty?
    Durbien:
    I just ordered a bedliner, chrome steps, window guards and bug deflector. The Mopar prices were WAY overblown. Getting the dealer to give you a break on these depends on how generous they feel. I shopped around and ended up getting mine from a truck accessory store. They're also putting a cap on for me.
    It was explained to me by the dealer that the OEM stuff would be warrantied along with the truck. However, it wasn't worth it to me price-wise.
    As far as how these add-ons affect the value of the truck, I guess it depends on lease vs. buy. If you're leasing, it's like throwing money away unless you intend to purchase the truck at the end of the lease. Also, you have to be careful not to damage the truck if you're leasing, i.e. screw holes or accessories that can't be easily removed. The dealer isn't going to give you any cash for add-ons at lease end, and may even penalize you for altering the vehicle.
    After market adds value to the truck. A bed liner cover, shell, all are extras that should be taken into account when you trade it in.
    My appraiser doesn't ask me how my customer bought the vehicle. That's not his job. He's only concerned with what the units wholesale number is, and how easy or difficult it would be to sell it on the used car side. Any extras make a vehicle more sellable, especially a bed liner.
    Go non-mopar, they're too pricy for my tastes. There are plenty of after market companies out there.
    Matt D
    Thanks for the extra info, Matt. I only have experience with leasing, not trading in.
    No, thank you. Your one of the reasons why I stick around. Plus your posts always have a good point to them.
    Matt D
    Matt:
    Thanks for the beautiful rose and compliment. (blush) :-)
  • mjnakmjnak Member Posts: 7
    I'm in the market for a midsized PU. I'm leaning towards the Dakota. I'm looking for a 4x2, auto, extended cab.
    I'm concerned about the reliability and resale of the Dakota. The 97 and 98 models were rated less reliable. Are the ratings wrong?
  • SCHUURSCHUUR Member Posts: 10
    Sorry, Dodge, you lost a future Dakota sale. I have been waiting for the rear door option for the Club Cab. When I saw that it is going to be much more like a "crew-cab" with regular opening doors in the back, I was disappointed. So I went out and bought a Ford F150 with the "suicide doors". It is my belief that most people buy the extra cab pickups for one of two reasons: either to throw stuff in the back or to put the rare passenger (mostly kids) there. The suicide doors are much more convenient for that use. You don't have to go out and around the back door to get in once you have thrown your stuff in the back. Also, you don't have to worry about kids and locks, etc. I love my F150 and I love the suicide doors. If I were to regularly haul passengers in the back, then I could see having the crew-cab setup. But that is not what I think most club cabbers are doing. Too bad, because I really like the size and setup of the Dakota otherwise.
    You bought a F150, thats not a compact truck, you bought. If you wanted the suicide dorrs, why not the ram quad cab, it has more interior room than the F150, which you state that your concerned about (room).
    + we offer 4 doors, and more interior room.
    Matt D
    I'm considering leasing a Dakota Sport Club Cab 4X4. Two questions:
    1. Any good deals out there?
    2. What about long term reliability? I have a 1993 Pathfinder which is extremely reliable-even at 107,000 miles. The local Dodge dealer service department is composed of individuals with room temperature IQs so I want to avoid visiting them if at all possible.
  • stanfordstanford Member Posts: 606
    If you're leasing, why worry about long-term reliability? If you're planning on purchasing after the lease is up anyway, you're better off buying from the start.
    If I like it, I will keep it. Depends on the lease deal and other factors. Now that the obvious has been restated, perhaps someone can address the questions I posed.
  • ervilervil Member Posts: 4
    What is the best axle ratio for towing a boat or hauling firewood? Expect to purchase new Dakota.
    div2,
    motorweek did a long term test of the dakota 4x4 club cab, and said at the end of the year that it was the most trouble free long term test vehicle they have ever tested, the only fault was a sensor that got stuck on. Besides that no problems. Go to motorweek website to see if that test is still there.
    Thanks, dodgeram. I'll check it out.
  • PlacemanPlaceman Member Posts: 44
    If interested. That review's URL is
    www.mpt.org/mpt/motorwk/reviews/dakota97.html
    I is for the 97 model, though.
  • dpattondpatton Member Posts: 14
    Hey folks. I'm looking into getting Dakota V6 manual. I test drove one the other day. Noticed that transmission slipped a little bit or the engine was rough, and there was a lot of vibration being translated to the stick. It was visibly shaking. The dealer told me that was common for brand new V6's and that it would smooth out over 5000 miles. I have no idea if he's blowing smoke or not. Your inputs would be greatly appreciated. Thanks.
    DP
  • dms1dms1 Member Posts: 6
    I bought a '99 Dak with a 5-speed just over a month ago - got a little over 3700 miles on the clock as of this morning. Haven't noticed any clutch slippage, but the clutch throw is really long on the 5-speeds (both for the V-6 and V-8; I tested both) and the V-6 does tend to shake more than the V-8. It has smoothed out some since I first got it - most of the shaking was at idle, now the stick just sorta jiggles from the engine vibrations - doesn't act like it's about to stall which it did initially. My read is that he's being square with you on this - which isn't to say that he might not pull a fast one later, of course. :-)
    DMS1
    Thanks for your input dodgeram and Dmat, but you did not address my complaint of the Dakota decision to opt for regular doors on their supercab. Mark my words, I feel it is a mistake that only time will prove. Anyway, in response as to why not the Ram, I liked the looks and feel of the F150 better, and I felt it would hold it's value better in the short run until I decide what I really want. Also, after reading all the posts in here of the reliability of Dodges and their problems, I did not even consider their products other than I really like the concept of the Dakota for size, power, etc. It is a nice truck. Too bad they are going to garbage it up with those doors (PLUS shortening the bed which is a really silly idea).
    Ervil, on 4X2 3:21 is better mpg's. on 4X4 3:55 better mpg's 3:92 for hauling.
    It all comes down to personal preference. If we did suicide doors I'm sure that I would hear complaints from others asking why we diddn't to it the other way.
    I had a lady last week looking for a baby yellow interior to match the exterior. I have helped people who hated the tires, the rims, etc. I aided a person who wanted the shift in the center as opposed to on the steering column. It seems to me that no matter what we do as a company, someone will have a problem with something. That is precisely why my job is so difficult.
    I'm sure if I went to the Ford F-150 page I'd read alot of complaints about the truck. In fact, if I went to any vehicles page I bet you I could find a post about how someone was dissatisfied. I seem to remember something about lug nuts. When a person is unhappy they are going to tell as many people as they can. I choose to ignore these posts. I think of the entire numbers produced that year for the line and am reading a couple of disgruntled opinions. Not bad odds that I'm going to get a reliable vehicle from any company. I have also found that some people, who thought that they were cheated in some way by the dealer make up problems with their vehicles. I guess to cash in on the warrenty.
    As for resale values, I think that the Dodge still retains the highest resale #'s in the short and long run. Remember, we don't put 100,000+ units in the fleet market, we let the others do that to become the #1 selling truck in America. However, the body styles look more like a Dodge every day. Maybe their new looks will inspire an executive to try to change the name of the company. I'd vote for FRodge. :)
    Matt D
  • rayp8893rayp8893 Member Posts: 11
    I'm thinking of buying a 99 Dakota, but I have a few questions. Is it possible to get a Dakota SLT without the 2-tone paint? I like the chrome grill and bumpers, but I'm not a fan of the 2-tone paint job. If not, what accent color would come with the driftwood SLT?
    Is there any chance that Dodge will come out with better looking wheels next year? In my opinion they're way behind most of the competition in that area.
    I want to get the Club Cab and I only plan to do light hauling and very little off-roading. Are there any features that you'd still consider a "must have"?
    Thanks for the input. How do you like the truck?
    DP
    You can get a Dakota SLT in a solid color. You do not have to opt for the two tone. If you do get two tone, your bottom color (lower brake) is Driftwood.
    Haven't heard anything about the tires or rims being changed next year.
    Matt D
    Dmat-
    You are obviously a Dodge salesman .... skirt the issues and throw our unsupportable verbage. The issue is that I don't think that putting in four full doors on a "supercab" type truck at the cost of bed length is a good idea. My point is that most people that buy a supercab do so not for the same reason they buy a four door car -- they are not hauling people all the time. They are throwing their "stuff" in the back, and it is a lot more convenient in the suicide set-up. If I am wrong, the why did Dodge use this setup on their big Ram???? A mini-crew cab with four full doors is just a bad idea. By the way, why do you think that so many companies choose the Ford for their fleet vehicles anyway? Better value. I am still very much a fan of the Dakota (even to the point that I may buy one BEFORE they come out with the new configuration). I am a salesman's wet dream ... I have had 33 vehicles in the last 34 years (all brand new).
    Of course, this is why other companies are coming out with both -- the F150 extended cab is available now with four doors (two suicide), and the F150 crew cab is coming with four fullsize doors. Both models have their uses.
    Question for the salesmen: Is the Dakota extended cab (in the size we know it now) being discontinued in favor of the Dakota crew cab? Or being augmented by it?
    schuur:
    I agree with you on one point - I think the Dakota crew cab is a silly idea. Not because of the doors, but because they intend to shorten the bed length (am I correct it will only be 4.5'?). At that length, it's no longer a pickup truck but a car with a useless open cargo area in the back. Sort of defeats the purpose of having a truck.
    But on the issue of suicide-type doors vs. regular doors, there's pros and cons to both. I DO carry a lot of passengers and the suicide doors create some problems. It can be a bother opening the front doors to let rear passengers in and out, and in tight parking spaces you have to do some clever maneuvering to gain access with both doors open. I agree that they're more convenient for loading stuff into the rear seat area, but beyond that they're a pain.
    And stanford is right: there is already a choice with the Ford crew cab, but for some reason the price of these is much higher than the quad cab.
    BTW, keep in mind that Dmat is a salesman - he doesn't design these trucks. We can hardly blame him for any design issues we may have. He's merely choosing to avoid either defending or bashing a product he sells and believes in. I think the public's reaction to the new Dakota will determine if it's a good idea or not. I'm annoyed that Chevy didn't put a fourth door on their new Silverado and I'm letting them know by getting a Dodge.
  • ridgerunnerridgerunner Member Posts: 1
    What information does anyone have on the reliability of the 1997 Dakota? Have an opportunity to purchase a Dakota Club Cab 4X4 (Sport) model, one owner, with almost 45,000 on it. It's fully equipped with the Sport plus package and all the other bells and whistles.
    Would appreciate any info. you may have. I'm buying from the original owner who has had no problems. Just trying to get some reliability & price info. before making a decision.
    Ladyblue,
    The length of the box is actully 5ft something, i can't remember, but I think the idea of the crew cab dakota is a good one. It only is a foot or so shorter than a 6.6ft box, so thats not very much.
    How many times do you think you will ever need that extra ft. If you do just pop the tail gate down and use the tie down to hold what ever your hauling. This way you can pick up the kids at school, and carry quite abit of cargo at the same time. Going on a long trip? Would you want to go in a quad cab, or a crew cab. Through the gear in the box, and put 5 people in the cab with room to spare. I think that s the idea for the crew cab dakota.
  • wpeng1wpeng1 Member Posts: 12
    dms1:
    Do you have any idea about the 5sp on Ram? do they share the same tranny? I am looking for a 99ram 2wd. 5.2 5sp, and want to see if it shifts smoothly compared to competitors. I've never own a truck before. How "long" is the throw? Much worse than common cars'?
    would appreciate any comment.
    dodgeram:
    I stand corrected on the bed length. And the Dakota is perfect for someone with "smaller" hauling needs than I have. Which is why I opted for the full size with an 8 ft. bed. Guess I'd rather sometimes have room left over than often not have enough room. As I always say, to each his own. :)
    stanford has an excellent question that I have not seen an answer to yet (but I fear I know the answer). Is the current Dakota extended cab being discontinued in favor of the crew cab? Hope not, but they probably will. And, dodgeram, when you haul a load of bark or topsoil, you can't just "pop the tailgate down" for your load. I guess I still look at trucks as utilitarian, and not people haulers. I guess I'm wasting my breath talking to a salesman. I still think the "dinky" bed will be a problem. And if they decide to fix that by stretching the whole vehicle, then why even have a Dakota concept. Get a full sized truck. The Dakota should not be looked at as a people hauler. It is a compact truck. If you are worried about hauling people, get a station wagon or a minivan. By the way, love my f150, just was hoping to find something a little smaller than full size and a little bigger than the Ranger I traded. Gosh, that sounds like a Dakota.
    I agree with schuur on the door issue. The full size doors on the extended cab will probably only appeal to people who are already in the market for a crew cab type vehicle, but don't want a full sized truck.
    I think Dodge is making a big mistake if that's the only type of extended cab they offer. I would take no doors over the full sized doors any day.
    As it is, I'm already giving up 1.5 feet going with the short bed, because I think the 8 ft bed on the extended cab makes the truck too long. Losing another foot is just too much to give up.
  • tarvertarver Member Posts: 7
    Here's my 2 cents (and free at that). I think the new four door dakota will fill a particular niche very nicely. I've been driving a extended toyota 4x4 (4 cyl) for about 5 years. Easy to drive, substantial 4x4 performance, and unchallenged reliability. BUT..... what don't I have.... room for more than two people or power for more than a small sailboat. The 4-dakota will be able to move four people comfortably, haul most of my weight needs, have enough bed space for my bikes and utility needs, and have enough power for whatever driving I may be doing. If you ask me... it's the perfect SUV for me. I've been talking about a 4-door dakota for about three years now, and finally.... it's here. I agree with the comment that if all you're going to put in the back seat is your bags and groceries, you don't need four doors. But I gave up counting the number of times we've had to take somebody elses vehicle 'cause we couldn't put more than two people in my toyota. Yes the bed space will be smaller, but it's pretty rare that I'm hauling plywood and other large items. (Well, maybe it was three cents).
    One more penny... I was at the local autoshow and the dodge rep's told me that the 5.9l is now available outside of the RT, meaning you can get it in a 4x4 (1999). I haven't found anything on the net about it, so if anybody has any info, I'd sure appreciate it.
  • tstrong1tstrong1 Member Posts: 1
    Am considering 99 Dakota Sport Club 4X4. Questions:
    1. If Dakota will have 4.7L engine as option in 2000, maybe I"ll wait until then. What's the likelyhood this will really be available?
    2. I like the Tire and Handling Group, with 15X8 tires and wheels, but is this more susceptible to tire wear, cupping, poor corner handling, compared to normal wheels and suspension?
    3. Do the wheel flares (only available with the Tire and Handling Group) give substantial stone protection from the wheels?
    4. Are there good aftermarket mudflaps, that fit the Dakota (both flared and non-flared wheelwells) that can substantially reduce the stone and paint chip damage?
    5. Are all these problems I see listed in this chatsite with the auto transmission something to worry about, or is it a very low % of the users that experience this? It concerns me, and my wife would rather not have a manual trans.
    6. I should know this, but what axel ratio makes the engine turn slower (the 3.2, 3.55, or 3.9)? I'm more concerned about 75 mph speeds, than pulling some big trailer up a mountain.
    Thanks, anyone who can help.
    Love the new truck - haven't encountered ANY of the problems posted on the Web. About the closest thing I've encountered to a problem is a plastic drain plug in the bed that keeps popping out. Since my next purchase for the truck will be a shell & carpet kit, I doubt that will pose much of a problem. On an average commute (80% highway/ 20% city for 26 miles) I get about 19.5 m.p.g. according to the trip meter on the trip computer. Yesterday on open highway travelling I was getting about 21.3 m.p.g. Little lower than others, but mine has the 3:55 rear end and limited-slip differential, so it's not unexpected.
    Most posters seems to feel that the 5.2L engine is the way to go - for me, the 3.9L does just fine. I'm not prone to blowing away the modified Integras, Preludes, etc. so the extra oopmh from the 5.2 doesn't do me a lot of good. Gets on the highway just fine, passing power is adequate (I'll typically drop it to 4th to pass - not unexpected) and mileage is pretty good. Count me as a happy camper!
    DMS1
