Visitor Agreement.
1st tank [298 miles] 19.9 mpg highway 80%/around town 20% no AC driving VERY conservatively.
2nd tank [570] 20.1 mpg interstate 90%/ around town 10% some AC driving VERY conservatively
3rd tank [630] 26.7 mpg interstate 90%/ town 10% some AC less conservatively BUT filled in NJ by attendant - may not have topped??
All manually calculated...actually, the computer is saying less...
So far, so good... Basically what my 6 cyl. LLBean Outback gets! :-)
On a another subject the first 05 MDX rolled off the assembly line on Sept.27 , 2004
Also I just had a repair done because the gas pedal was sticking and the SUV was reving the engine by itself when in park. I was terrified driving when this happened, lucky I was near home and turned back. Called Roadside service, and they were great and towed it to the dealer. The engine light did come on and the repair involved some valve that controls the idol. I hope this does not happen to many people, it was very scary to have my car excelerate on it's own.
What finally resolved my problem was a simple solution my dad gave me. Silicon spray on a rag and wiping down the weather stripping twice a year. It makes it stick better and then no noise.
If you can demonstrate the problem it should not matter if there is a fault code. If not, the dealer has nothing on which to base a repair.
If you can demonstrate and it is abnormal for the model (sounds like it is) and the dealer still won't address the problem contact Acura. If no help all you have left is your state's lemon law and maybe arbitration or a court case.
My 02 has, in the 40-45 mph range, lugged. Can't call it shuttering or jerking, but it was like the transmission was in too high a gear. The hesitations to accelerate have been annoying and happen only with very light gas pedal pressure. mild. More aggressive use of the gas pedal eliminates the problem on mine. 26k on my 02 and I first noticed this characteristic (slow tranny downshift with light gas pedal) about 20k ago. Mine has had the recall's addition of the extra oil line.
Good luck...
HSJ
There is a TSB for the brake clunk, check with your dealer to install the shims.
Most car gives out that sulfer oder when you push it hard. If that is not your case, then try switching feul brand. Some gasoline contain more sulfer than others, sounds like your car cannot cleanly burn off all the feul. Are you using preimum gas?
This lasted for a few seconds, and then it drove fine. Five minutes later, gears started slipping, rpm's dropped, and it was making some strange noises. It was was clear I was loosing my transmission. This kept happening every 5 minutes or so.
Countless others have had the same problem, and although Acura has had a recall on certain year and model transmissions, they are making it extremely difficult to qualify for this recall, and are not paying for replacement parts or labor if your car is out of warranty. In order to confuse the consumer, they talk in "codes". If your car didn't have the right "code" when it was serviced, then you do not qualify for the recall? Does anyone know about these codes? I am pushing me dealer to help me interpret these codes.
I believe my car, and coutless others, are part of this transmission defect recall (recall number 04V-176.) Why are so many of us having transmission problems?
There may be a class action filed through the Center For Auto Safety. I will keep this board posted.
I am interted in hearing from anyone who has had major transmission problems (Slippage, Noises, Locking up) with their Acura's.
When I tried it via the separate remote, it never stayed flashed to indicate it's a rolling code either. Has anyone successfully programmed their Homelink w/recent Craftsman's opener?
(#1) I purchased Honda #06435-S3V-A01 SHIM KIT for the REAR. Will this help "eliminate" the REAR BRAKE CLUNKING that plagues the MDX's ?? Where can I find the correct T.S.B. or Service Bulletin including part numbers and "correction procedures"?? So far all I located was a HONDA (Pilot/Odyssey) Service Bulletin #04-019 (dated March 23,2004)
(#2) What are the "best" BRAKE PADS (FRONT & REAR) for "heavy footed" driving ?? I used CERAMACOOL's on the TL and after initial break-in (about 300 miles) they were the BEST brakes I have had in the past 20 years. I remember "Repco" made great pads in my distant past, and recently I hear a lot of talk about AXXIS pads ???? ANY COMMENTS ?? Please jump in and help !! THANKS !!
My new 05 MDX only makes the chimes if the driver does not buckle up. Apparently it doesn't care whether passengers are wearing their seatbelts. I would suggest going to a salvage yard and cutting a buckle (male end) from a wrecked MDX and insert it indefinitely into your passenger seatbelt receptacle. I imagine that would fool big brother and solve your problem.
Never drive without mine...law or not...
I am 90% sure you can fit a full size under there. You can order a rim/tire from Hondacuraworld.com for $200 and then get a tire somewhere.
If you really have to drive without a seatbelt, I suggest 2 things. Go to a junk yard as suggested (don't give up, for $100 they will search and get you one) or find the speaker and cut the wires. It has to be coming from somewhere.
My advice: if you experience this "rumble strip" issue or having other issues with the transmission, get in and get it replaced. The last remaining issue may be that we will be trying to demand a recall on these, considering that they have a faulty design. Lastly, they are dangerous. A friend of mine read to me the review and stories of an MDX owner that had the same problem, and who nearly lost control as the vehicle dramatically downshifted uncontrollably and he was able to stay on the road because he was a ex-fighter jet pilot with specialized training and split-second reactions. Will anyone die before these are replaced?
My question has to do with not paying too high a price for the '05 MDX with the touring package. MSRP is somewhere between $42,000 & $43,000. Where can I find the Invoice price for this car? Is it printed anywhere for the customer to see. If the salesman is asked for that number must he show it to you?
Appreciate hearing from someone.
Do you notice it under specific conditions?
