Pickup Truck Accessories
Thanks for any help!
is a retractable truck canopy which consists of
the following:
-a black marine-grade canvas canopy (other colours
optional) supported by powder coated metal bows
and frame which ride on rollers along stainless
steel box rails.
-rear tempered glass window with lock and a front
window (clear or sliding)incorporated into a
cabspoiler which can be painted to match the
truck.
-It is supposed to fit 1973 to 1998 Ford & GM
fullsize trucks and 1983 to 1998 Dodges.
This canopy is supposed to be one of the first to
offer the design, appearance, strength and
durability people want.
Prices listed in the newspaper article I saw were
$1295 (SB) and 1395 (LB)-Canadian prices I
believe.
Has anyone had any experiences with this product
and where did they purchase it?
ranger.
...and just be mindful of the top rails 'til I get the cover or cap?
Any advice will be appreciated.
http://www.acetruckbox.com/homebody.html
I believe stanford was talking about a fith wheel hook up ( forget the name ). My father-in-law has a short bed Dodge and just recently had a goose neck ball placed in his truck to pull a camper trailer that had a gooseneck hookup. The ball is centered on the the axel and he has no problems pulling this trailer.
cw
thanks,
-Mark
Most camper shells are light enough to lift off by yourself, but they are very ockward to handle alone. I had a cab high fiberglass shell that was light enough for me to slide it back,set one end on the ground and then lift the other end up and off of the truck. Getting it back on, however, required two people ...unless I wanted to scratch the hell out of my truck and shell.
I used to have a Brahma plastic cab high cap. They are quite popular on the west coast. Very easy to maintain and just barely light enough for one strong person. A lot lighter than my new fiberglass Leer cap. I'm not sure if anyone else is making plastic tops. Anyone know?
TK
Does anyone know how much a fiber glass cap weighs? Currently I'm thinking of aluminum. Anyone know a good aluminum cap for a dakota (6.5 foot bed)?
thanks again.
I've got a fairly light 8' pop-up slide in camper that will work fine on short beds - talked to a few who own that type of set up and the camper dealers. I'm getting a 3/4 ton Silverado.
I'm taking off and travelling for a couple of years and will basically be living out of the camper. I didn't want to give up the turning radius I'd have to with a longer wheel base as I will be on back roads and I'm sure to be doing my share of turning around in tight places.
I was quoted $650 + tax for an A.R.E. lid. I like the A.R.E., but I went with an Astro - Euro Series because it is a little easier to take off and on. I could be wrong, but I think most fiberglass lids are adequate. It's just a matter of preference based on looks, functionality, etc.
It sounds like the quoted price for the ARE is about right. I live in NJ and paid what bri was quoted, but I had also priced them in AZ last summer when I was there. They were more in Phoenix, but the explanation from the dealer here in NJ is that the difference is probably shipping costs. ARE is in Ohio, and Ohio is closer to NJ than it is to AZ; therefore, ARE products are cheaper in NJ. It's a good-looking lid and I'm very satisfied with it.
Colin Walker
cwalker@digimarc.com
TIA
J
thanks,
rm
JTO
Thanks for any and all responses.
Please do share the info if you find someone that manufacture headrest for 99 F150. I too have been looking for a one for about 6-8weeks now, as I do occationally haul my two kids around from time to time on short trips. No luck so far. I am starting to wonder if it would be easier to just swap a rear bench seat from a SUV like windstar. Any info on that would also be greatly appreciated. Thanks
I believe if you order the factory cab steps, the mud flaps are deleted. Why, I do not know. I have a '99 Lariat Flareside 4wd with dealer installed cab steps. I made sure they left the factory mud flaps on and there is plenty of room and they look fine.
Tim
Good luck with your new Silverado,,,they do look good.
Any luck with finding headrest for the backseats of our F-150? I've been looking/asking around too. Please advise if any luck,ok? I'll surely do the same.
jjson,
thanks for the mudflaps info, ...so I did go out after and bought a pair from my dealer and you were right, it did fit with no problems! Thanks AGAIN!
If you don't anticipate hauling gravel, angle iron, etc., why get a spray-on liner? They're a bit expensive and, once applied, are permanent.
I too just bought a new Silverado LT and I am looking hard at the molded carpet bedliners (either Bedrug or similar). Cost about $250-350.
Since I plan to install a roll-top cover(probably Pace-Edwards) at the same time, the carpet liner will be protected from the elements and will be suitable for the light-medium duty uses I have. Plus, it's non-skid w/o being abrasive.
And it is non-permanent. It was my first choice, but my truck came with a drop-in bed-liner so the choice was made for me.
