To change the ATF in the tranny and the diff -
You only have to refill thru the tranny dipstick hole with about 3.7L. Yes or No.
I wonder?? The screen is a little tuff to effectively clean. Would it be better to replace it next time?
The Big Question??? where is the Diff Drain plug?? I didnt do this, and after seeing the other notes now relize I have a incomplete transmission service.
There has got to be a way to change out all the fluid at once! Frustrating.
Guys thanks for all your help!
You can get a pan gasket/filter kit for about $30. I just clean mine with parts cleaner, blow dry with my compressor, then clean again using ATF. My complete service is under $20 with 3 gallons of fluid and a pan gasket.
Good Luck
In my 2002, I got out about 5 quarts of ATF. But don't go by that figure--use your dipstick.
Other pts: The fill for both AT and differential is the AT dipstick tube (fill slowly). Check for fluid at the differential by not tightening that plug until new fluid is present. Torque on the plugs is 33 [ft-lbs]. 10-mm Allen wrench...
Warehouse clubs have cases of ATF at prices around $1.15/qt. You can use the extra quarts for your power steering fluid flush :-0
I'm planning on putting on 4 speedbleeder valves, to save work in the long run. ( www. speedbleeder.com ) They have no listing of the valve sizes...
How DO you do a PS flush, and why?
I have flushed my power steering pump. Put the wheels on jackstands and pull a little fluid out of the reservoir. Remove the top hose from the reservoir and use a 1/2 male hose barb to another 1/2 ID hose that goes to you waste bucket. Then, with the engine running, get some one to turn the wheel back and forth to full stop, while you add fresh fluid. Sooner or later the new fluid will make it out the return. You can also add a secion of the 1/2 ID tubing to the reservoir to prevent a mess....
As you can tell from my previous posts - I am a little anal about my maintenance....
Is this an 8mm socket or an allen?
I'm going to try this when the snow melts.
55,000 miles - I think I should look at my front pads now.
DEAR ????,
TOYOTA DOESN'T USE A TRANSMISSION FILTER LIKE CHEVY AND FORD DOES. OURS IS MORE LIKE THE SCREEN ON A WINDOW. IT IS METAL AND CAN BE CLEANED.
FOR TRANS SERVICES WE SIMPLY REPLACE THE FLUID.
As for "simply replacing the fluid" I suggest you find a different repair shop as they fail to understand why the screen is there and that it does in fact need to be flushed/cleaned.
On the lower left corner (from memory) there is a drain at the radiator. I also have rear air, so I also pulled the hose just under the passenger side seat to allow the old fluid to drain at that point too. I don't know of any other tricks, as your described method is very similar to my own.
The hose you speak of for the rear air ware is that located? Under the seat on the outside so you would need to crawl under the car OR on the inside under the seat. Also, did you do anything with the block drains. Thanks for any input.
I had no trouble with my Accord; the drum was pulled off easily
Has anyone done this already, please give me advice. Thanks.
Don't you wish there was a Haynes repair manual for the Sienna's?
These manuals have been an excellent resource for troubleshooting
and repairing my other cars, but Haynes has yet to publish one for
the Sienna. Now there's a new model (2004), and the first Sienna's
are almost out of their 5 year warrenty, perhaps there is a market
for the manuals?
I wrote to Haynes when I first acquired our '99 CE van in 2001 (it
had 310,000 km on it!!!) and asked if they were planning to publish
one. They wrote back and said "not yet", but keep checking our web-
site.
Why don't we all write to Haynes and ask them about the repair
manual...maybe they'll realise there's a market for it? Write to
info@ haynes.com
Or visit:
http://haynes.com/na.html and click on Ask Haynes about our manuals
Paul
'99 Sienna CE
323,000 km / 202,000 Mi (no problems)
after searching edmund's townhall.
In my case, the rear drums were stuck to the center hubs because of rust, not because the shoes were tight against the drums or the rear parking brakes were engaged.
To remove the rear drum, I threaded a bolt (don't know the size) into one of the 2 holes on the face of the drum.
The bolt forced the hub to separate from the drum and in the process broke the bond caused by rust.
I turned the bolt a little on one hole until I saw some slight separation, then switch the bolt the other hole and repeated that until I could remove the drums.
Ideally, it would be faster if I had to 2 bolts.
But my question is, when is a routine fuel injector cleaning call for? Is it a matter of time or miles or should I wait until the engine is showing some performance problem?
The simple test is to closely calculate MPG. If it stays high and efficient, no need for cleaning. Or...occasionally put premium tankful in gas tank....or...occasionally get Chevron fuel injector cleaner and place in almost empty gas tank. IMHO, this injector cleaning thaaang is one more profit task for dealers...it joins "oil flushes, tranny flushes and such" as pretty much cosmetic money makers for dealers.
I got 26 MPG on that trip, so probably my fuel injectors are fine.
By the way, my dealer wanted $129.95 for the fuel injector cleaning.
Thanks for the advice.
The vehicle still rides like new !!
You also have to pull the small panels that are on the left and right of the rear window to reveal additional bolts (from memory.)
I would say that if it is not obvious how to remove this panel, then you should get a professional to do the work for you. Not trying to be a smart-[non-permissible content removed], but this is pretty simple for a backyard mechanic. Take a look at it and if you have further questions, I can look at my van this evening (my wife drives it) and give you a little better info.
Good Luck
Is this a good idea if I plan to keep the Sienna ten years?
I'm just wondering if anyone knows where the fuel filter is mounted on the 2001 Toyota Sienna. Also, is there is a scheduled interval for changing it out? My van has almost 40K and I think it is about time.
Does anyone have an idea why they don't list the fuel filter in the scheduled maintenance?
I suggest you change it at a minimum 60,000 miles.
Other than that, honestly, I pamper the van!
At this point, I’m very stressed. The car dealer refuses to look into. The noise is bothersome and I have fear for our family’s safety.
Please give me some advice. What should I do?
When the recall first came out, I read about it on these boards. I happened to be going in for my firt oil change to a dealership here in Northern Va. I asked the service guy if he could look up my vin and see if it was affected by the recall. He didn't seem that concerned about it, and when he came to get me when the oil change was done, he did not say a word. I assumed my vehicle was not affected.
However, when I got home I called the Toyota customer service #. The nice customer service rep did inform me that my van was part of the campaign. He understood my urgency to get it taken care of and emailed a different dealership per my request. That dealership's rep was very prompt in calling me to get me updated on when the replacement tank was in stock and could be installed.
I was very happy with the second dealership, even though it is smaller and older. I will never go back to the other dealership that is bigger and newer. Another lesson in "don't judge a book by its cover". (I bought my van out of state)
