Ken
-mike
-mike
Ross
I got a flat tire over the weekend so I replaced the tire
with the (full size) spare. I remember reading that the
tread wear on all the tires should be the same on Subaru
vehicles. How important is that? If I can't repair the
flat tire, do I have to buy all new tires? When do tires
usually need replacing?
I have a 2001 Forester S with just over 30,000 miles on it.
bit
Mike - This could be a long story but let me see if I can help, and be brief. Generally a cooler running engine will run better, to a point. The trick is to be at a high enough temp for the ECU to go into "closed loop" mode, where it is actively gathering info and making decisions about adjusting things.
In "open loop" the system operates off of a fixed set of parameters and makes no decisions. These parameters are for things like injector pulse width and ignition timing, and are far from optimal. The system starts in "open loop" and switches to "closed loop" at a predetermined temperature. You need to be above this temp for the system to work correctly and actively.
Practically speaking engines run too hot. They usually have about a 195 degree F. thermostat and run about 200 to 205 because of system dynamics and the control system (fans etc.). They do this for emissions because a hot engine is cleaner on average.
A 180 degree thermostat used to be considered "normal" and a 160 "cold". Today a 160 probably would be too cold, but a 180 works very well. I have put one in my Dakota. One big benefit is more tolerance for pinging. With "colder" coolant around the heads and combustion chamber, the "delta T" is greater so the heat transfer is better. The peak combustion temperature is the same but it dissipates faster to equilibrate with its surroundings, so less "hot spots" causing problems.
With a cooler engine anything bolted to it is cooler also, so there is some benefit from the intake manifold and fuel rail being cooler too. Under hood temps will be lower all over.
Hope this helps a bit, sorry for not being brief.
Frank
-mike
Ross
Tbe temperature in a proper functioning system will never go more than 10 degrees or so above the thermostat rating. In your extreme case, an engine with a 120 degree thermostat will _never_ get to 175 or 185.
The curves _are_ the same below the threshold temp, but the lower one "flat lines", more or less, after that. There is no more rise, so yeah, it will take a lot longer to get to a "normal" temp, close to forever.
Frank
Ross
..Mike
Frank
Is that why they call you "big" frank?:)
-mike
I am part Italian so I have to wave my arms around while I type. It takes me a long time to write a message.
Frank
SubaruParts.com $4.49 + $6.95 shipping
Tischer Subaru, Silver Spring, MD $5.98 , $5.39 qty 12 (10% discount).
Fitzgerald Auto Mall, Rockville, MD $5.98 , $4.79 qty 10 (20% discount).
I'll probably buy a case (12, I think).
..Mike
..Mike
Greg
FYI, I bought my car because of the loyalty of Subaru owners. It doesn't seem like just a reliable car - it seems like one that people are happy to own. I'm looking forward to feeling the same!
PureONE PL14460; regular L14460
Here's a USMB discussion about oil filters.
..Mike
..Mike
..Mike
..Mike
-Frank P.
Ross
2) I race the car, so I want make performance, not really too concerned with the enviromental impact of my 1 little XT6 which gets better milage than my Trooper, so if it blows up, I'd be driving that the same miles and it gets much worse milage than the xt6
I'm also not positive that it will increase the emissions beyond the normal range, even if I did have an emissions test to do. Thanks for all the input though.
-mike
I'll call Conley Subaru.
I bought a Forester S. I love it so far, but I'm having what I hope is just a little glitch. The light that tells me that doors are open stays on even after all the doors are shut. Am I just not being forceful enough when I shut them?
Greg
You'll understand soon enough
Ross
-Frank P.
Frank
Any thoughts regarding the origin and required service for this problem?
In looking at replacement thermostats, I noticed that the one recommended for Subarus seems to be a two stage unit. This type is a bit unusual, so I wonder if it is available in different temperature values.
This is what I don't get... why insist on emissions testing for newer models but exempt older ones when it's the older ones that are far more likely to pollute? Also, here in metro Atlanta, there is a ceiling on the amount that a driver has to spend trying to fix the problem. After spending $300, the vehicle is passed regardless of how much oily black smoke is belching from the tail pipe!
-Frank P.
AT OIL TEMPerature warning light (for AT vehicles)
If this light comes on when the engine is running, it may indicate that the automatic transmission fluid temperature is too hot. If the light comes on while driving, it is unnecessary to stop the vehicle, but avoid driving up steep grades or in stop and go traffic.
Automatic transmission control system warning
If the light flashes after the engine starts, it may indicate that the auto-matic transmission control system is not working properly. Contact your nearest SUBARU dealer for service immediately.
You mentioned it was flashing - I'd take it to a dealer to get checked out. What year is your subie? How did it happen? Has it gone off at all?
Bad experience with the dealer you bought it from? Maybe there's another dealer nearby that you could try.
-Brian
-mike
-mike
Vehicles less than 5 or more than 25 years old are exempt from emissions testing here... the concept being that a newer car will usually pass anyway, and there aren't enough older cars out there to make enough of an air quality difference anyway. Cost is 12 bucks every 2 years. Haven't had the pleasure of running the OB through the test yet. My 69 PowerWagon passed with no problem before it earned the exemption.
Cheers!
Paul
The car, Legacy, has around 175k or so on it. So most likely the injectors need to be rebuilt or replaced, and I'm going to suggest they do all 4, rather than just the one.
Any one have any experience with dealers or independant shops in that area, that you can recommend. I'd prefer independant, as they are usually less expensive, but any info is greatly appreciated.
Josh
I am in no way affiliated with Baldwin and am not trying to sell thier filters, just trying to run my own show.
Next I called the Purolator Hotline 1 800 526 4250 and they put me onto Tech support 1800 848 3783. I talked with Chuck Smith and told him what I had found out from Baldwin and asked him if he would check the SOA part numbers and tell me which filters they crossed to. Now here is where it gets interesting (as least to me). He said the two Subaru part numbers both cross to the same filter, which is Purolator L14460. He said the subs used to use the L14459 but have recently changed to L14460. He said the only difference in the two filters is the L14459 has an anti drainback valve and the L14460 does not. They both have 8 to 10 psi pressure relief valves. So naive me asked the obvious--Why have different part numbers if they are the exact same filter. You have probably guessed the answer. To keep selling Subaru filters for as long as possible.
Needless to say, I traded by Baldwin B227's for B301's and now have one on the car (coming up on 10k).
The one thing I still don't understand is why did Subaru change from a filter with and anti drainback valve to one without it. Especially silnce the filter on the H-6 is perfectly horizontal. How is the filter oriented on the H-4? When I mentioned this to Chuck Smith he said, "good question".
Anyway I've rambled to long. Bottom line -- Purolator L14460 is the filter for H-6 engine if you like purolator (and I do believe it's an excellent filter)
Guy
It's probably time to hook up the computer for a diagnostic reading.
-mike
Thanks for sharing the info on the oil filters.
FYI, the oil filters in the H4 mount vertically.
Ken
Most if not all horizontal filter applications, that I know of, have anti-drainback valves. This is because a horizontal filter could empty itself, depending on the rest of the system configuration, when the engine is off. You don't want to refill the filter at every start. You have no oil pressure without a filled filter.
A vertical filter, open end up, only, as used on the H4 cannot empty, so it would be less important to have the valve. I do not know if the filters for the H4 have them or not.
Frank
Now if Chuck Smith was giving me the right info, logic would dictate using the L14460 on the H-4 (no drainback), and using the L14459 on the H-6 (drainback). When I told Chuck that the filter was mounted horizontally on the H-6 he immediately said it should have a drainback valve and he didn't understand why SOA would specify a filter that didn't have it.
Now I am again wondering if there is in fact a difference in the two filters. There always seems to be one more thing to know (or two or five).
Anyway I'm coming up on 10k (I did the change at 7500) and since the changes are free on the Bean to 30k, I'll take it in and let them change it. That will give me a little more time to ponder this. Also it's only a matter of time till the various filter manufacturers list a cross for the H-6.
I gave the info as I received it but must admit that now I have misgivings about it. Buy your filters from a Sub dealer and you can't go wrong. (don't you just hate it when you can't fight city hall :-)
Guy
The car is red, so I named it "Big Red Forester". These are the options: Compact Disc Player and cassette player, Automatic 4-Speed Transmission (an essential in Atlanta traffic , Heated Front Seats (will I use them?), Heated Power Mirrors, Leather Seats, and Skid Plates (I will use those, Atlanta has streets like Medellin). I would have liked the tow package, but this one had everything else I wanted and used Foresters don't last long on the market here. I am the envy of my friends. Considering my last car, though, it's about time.
I'll tell the guys at Conley Subaru about the light. Maybe they can give it a tweak.
Thanks for the advice. Sorry about the Dave thing.
The heated seats are good for weary bones on a chilly morning (if there is such a thing in Atlanta).
..Mike
..Mike
Ross (middle name David)
-- Just another one of those Daves
