-juice
Take care!
Patti
I did the 30k myself, Darlene sourced all the parts. I ought to call her to see how they're doin'.
-juice
So, right or wrong, that's the way I drive and, as I said, I think my take-offs are pretty smooth and I experience no clutch chatter (so far). I did try ONE lower rpm take off last night, as others seem to recommend (1000-1200 rpm), but the engine lugged horribly and the clutch slipped/lurched enough that I won't try that experiment again (not on MY car anyway). I also think I caught my first ever whiff of that burned-fish-clutch-smell...or perhaps it was just the tuna sandwich my daughter left on the back seat.
YetAnotherDave
Sounds like you're taking off at a pretty high rpm to me.
-Colin
Ross
-mike
-juice
On a separate matter, I sure wish cough*juice*cough the "legacy - typical high mileage repairs" board was active. Here's what's happening in my neck-o-the-woods...
1994 Legacy Turbo, 85,000 miles, just developed an oil leak. Thought it was a bad filter, the oil change place replaced it, leak got worse. Really
bad this morning. (total elapsed time = maybe a week) Just took it to a dealer. Says could be the crank and/or cam seals, but they were replaced at 60k for the timing belt, so they doubt it. Says it's probably the oil pump seals. Suggests oil pump seal replacement, water pump replacement, timing belt since we are in there along with the timing belt tensioner that I've seen mentioned before. I am thinking I might replace the valve
cover gaskets because I have some seapage on one side. I know I won't be saving myself any money, but I will kill two birds with one stone convenience wise. All together looks like $700-800, sound reasonable? I'm not the least bit mechanical, so shadetree stuff is pretty much
out of the question. Anything I'm forgetting or should consider?
Jim
with a more aggressive clutch you'll find that any sort of very slow takeoff is difficult. the more brutal the clutch, the worse it is.
I had an old Camaro with a 3 puck unsprung McCleod clutch... it was impossible to get moving surging ahead at an immediate 15-20 mph or so.
Anyway, slipping the clutch slightly may help with some clutches. Try it on yours, get to the start of the engagement point and pause while the vehicle gets rolling.
-Colin
2000RPMs do sound high. I also engage around 1200RPM myself. Have you tried letting the clutch up just to the catch point and then giving it just enough throttle?
Ken
-juice
-mike
Brian
-juice
So 50k trouble-free miles sounds good to me. A stock clutch should last 100k without trouble though, IMO.
-Colin
-juice
-Colin
A warm 2.5 liter engine has adequate torque to gently launch my empty Forester on level ground from 600 rpm. This is a big engine for this car. The rest of the world makes do with 2.0 liters. I don't see the harm here.
I saw a video of an Audi Quattro laying four solid patches of rubber around a turn in Greece. That took a little over 500 bhp.
My Forester doesn't have the brute power for this trick, so where the Rally-spec Quattro dissipates the slip in its system through its tires, high-rev starts come out of the hide of the clutch in lesser 4WD cars.
This is why I engage at the absolute lowest engine speeds at all times. I need to drive the car for many years.
Thanks to the person who suggests uneven wear on the clutch plate. This sounds best for now.
-mike
-juice
Get the parts and we'll figure something out.
-juice
PS Actually I bet she turns the wrenches, we baby sit! LOL
BTW, with my Forester (same engine but geared lower, and its lighter) I "take-off" in the 1600-2000 range, unless I'm in a hurry. With my old Legacy (2.0L), I often took off in second gear, such was the difference in weight and gearing. Finally, I was being a bit hyperbolic with my original figures for the OB, actually, my revs are in the 1800-2500 range for most take offs, but certainly well above what many would recommend.
Thanks for the interesting discussion all,
YetAnotherDave
-mike
Again, if 2600 rpm (as Mike states, above) is optimal for all upshifts, why would 2000 rpm be "too harsh" for take offs? Perhaps the more critical issue is how smoothly/quickly you get the clutch to engage and then get your foot off the pedal: under 1 second should keep the wear and tear to a minimum, whatever your revs. But if your car is lurching from clutch chatter, you are almost certainly going to wear down your clutch before "its time".
YetAnotherDave
I tried Colin's tip of not adding throttle until the clutch is completely released, and it does yield smoother launches.
-juice
Well, last week the symptoms occured here at sea-level and I rushed to the dealer. I caught the last mechanic as he was leaving to go home at 6 pm and he looked at the car and admitted there was a problem and he would notify the service manager. He told me they would likely replace the clutch master and slave cylinders under warranty. My car has about 50k miles, so I am still under the powertrain warranty.
The following week I brought the car in and they replaced the clutch master and said if the problem persisted, to bring it back and they would then replace the slave. So far it seems OK.
The problem now is that I am told that the clutch hydraulics are not covered under the powertrain warranty! They offered to pay for the parts but I had to pay the labor. How can it be that the clutch hydraulics are not covered under the powertrain warranty? They are an integral part of the transmission, they are not a "wear" item like the clutch itself, and they should last far longer than 50k miles. This is clearly a defective item. Not to mention the mechanic told me the warranty would cover it before I had the work done.
So, where do I go from here? I would really like Subaru to do the right thing and refund labor costs to me. It is not a large sum of money, but to a graduate student every cent counts. Is it true that the clutch hydraulics are not part of the powertrain?
Ueyn
A mechanic who is a former Subaru master mechanic listened to the sound and said it was possibly a worn throw-out bearing. He said the problem wasn't uncommon and that repairs could end up being expensive if the inside case was worn. He referred me to the Subaru dealer to see if warranty would cover repair.
The Subaru dealer said they couldn't help on warranty because we're outside of the warranty period. They also said that our service records were archived and while there is a record in the computer of the recall work, there is no record of the earlier report of clutch noise.
Question: Does anyone know of this being a common problem? Would a throw-out bearing (and any associated repairs) be covered under the 5 year/60K powertrain warranty? If so, I may give the 800-SUBARU3 number a try regarding the apparently lost/undocumented complaint made at 53K/2 years. (I've also noticed from reviewing posts that "Patti" at Subaru seems to be helpful to Town Hall users.)
Or would this be covered under some other portion of the warranty where 53K would be past the coverage?
Daryl: in your case, you're at 5 years, 7 months, so I can see what they would not cover that. Otherwise why would people opt for an extended warranty?
Call Patti anyway, perhaps they can work something out for you as a good gesture, but IMO anything they do is beyond the call of duty. Good luck.
-juice
Theo in Colo.
I just phoned back and informed them that I got the new clutch master cylinder and was charged for labor. I asked why the powertrain warranty didn't cover it and was told that the master/slave cylinders are only covered under the 3/36k warranty likely because they are not "internal" to the transmission. Oh well, looks like that's that. Let's hope the problem really wasn't with the slave cylinder.
At least the powertrain warranty should cover a new short block when the piston slap I hear every morning for 15 minutes gets worse. It's really too bad because I absolutely LOVE this car except for the piston slap and clutch issues (hydraulics and weakness of clutch itself).
Thanks for everyone's responses.
-Ueyn
Ueyn: how much labor are we talking about? A new clutch costs $400-700, so I just hope you didn't fork out that kind of dough.
-juice
Somewhere around 1988 IIRC the car developed an engine slap(different engine - I know). It was brutal and the sum total of the professional advice I received from three good Subaru mechanics was "It's probably a valve something or other." "Pay us to tear the engine down to see what it is or live with it."
They recommended living with it. Okay. I did.
I'm certain it wasn't the timing belt or the tensioner or a bad plug or a wire - because I had those problems too at other times and the engine noise continued.
But the car ran just fine until a year or so ago when the front sub-frame rusted out.
Oh, and mine didn't just slap for a few minutes after start-up - it did it all of the time for the last 11 or 12 years I owned it.
The mechanic I sold it to fixed the front end and put it back on the road. I haven't seen it in 3 months, but it's still out there on the same engine.
John
The labor wasn't too bad, only about $100-$150 (I don't have the invoice in front of me).
As for new clutches, I bought this car used. The first owner went through a clutch in about 25k miles. At that point he and his wife moved overseas and gave the car to his sister. She went through the second clutch by 45k. She had the whole clutch assembly replaced and that is when I bought the car. I'm hoping I can do better than the last two. Part of me thinks this hydraulics issue has always been present and made it difficult for the previous owners to shift well, thus speeding up clutch wear. Now that I've hopefully got the hydraulics fixed, we'll see if the current clutch lasts longer.
-Ueyn
-juice
-Dennis
mikek
-Brian
-mike
-Brian
I don't think it has had a tune-up in a while, although it did have replacement wires so it definitely isn't the original plugs and wires. Nice thing is that even though it's a 6, I was able to change everything w/o removing any other parts. Although I need to figure out where to put the PCV valve at some point.
-mike
Don't dealers do this sometimes after the major maintenance?
-Dennis
The PCV valve should be on the heads somewhere, because they vent gasses from the heads.
-juice
