Found this on http://www.sidc.co.uk/faq.htm#2.4
"..The ECU is reset (the dealer uses either a diagnostics computer called a "Select Monitor" to zero all memory settings, or he disconnects the battery for long enough to allow the back up capacitor to drain). After this has happened, the ECU reverts to factory settings and has no previous history of limits learnt from the knock points of previous fuel grades... "
-Dennis
I'll probably wind up resetting the ECU when I do work on the PS pump motor cause the battery will be disconnected for that.
-mike
-juice
Some Miata buyers actually seek out pre-ODB cars because they are much easier to tinker with. Try to find one turbocharged 2.5l Subaru engine that doesn't have the CEL taped over.
-juice
Conversely, where would one place jack stands on the opposite side from the floor jack?
I'm wanting a convenient way to get all four wheels off the garage floor, so I can rotate and clean the wheels. I can add wooden blocks to back up the jack.
Theo in Colo.
To get all four off the ground, I would probably put jack stands at the left/front and right/front positions, and then use the jack on the rear diffy.
Never get under the car, though. For that I use ramps.
-juice
You bet US dealers can clear the ECU's error codes with the select tool. A hobbyist can do the same with a wide variety of OBDII tools, which are all about 5-10% the cost of the $1200 Subaru select tool. The select tool can do some unique stuff, like cycle the ABS pump to bleed the brakes and display max speed attained. (which isn't cleared after a reset!)
-Colin
-juice
It's done it once before, once out of the blue when I was filling up the gas tank. Weird. Any help is appreciated.
Oh, and the car is off and the keys are out when this is happening.
Jeannette
If you choose the latter, let it cool, and then disconnect the negative battery terminal. Wait 30 minutes, reconnect, then start the car and let it idle for a few minutes.
That ought to clear the codes. I'd suggest that the Volvo owner get a stick next time, so they can push start it. :-)
-juice
How did you connect the jumper cables during the jump start?
-Colin
-mike
Patti
now if it had the piston slap today during the warm temps, I'd be concerned and would be parking it at the dealer as we speak.
almost time for the chat...
-Brian
mike k
-Brian
My piston slap is not evident above about 60 Fahrenheit, but below that temp I think I am starting to hear it even after an hour on the freeway. If it is below 60, it is very noticeable for at least 10-15 minutes after startup. I frequently have passengers ask "What's that noise?" It's started to get on my nerves.
I'm curious how many late-model subaru owners DON'T have piston slap. Seems like everyone is chiming in with: "Me, too."
-a piston slap-free juice
picked up a rear hatch bar for the Legacy, will attempt to mount onto the Forester some time soon. Looks like it will fit... Want a way to verify that the hatch latched without turning the key to check the idiot light on the dash...
Ross
-juice
Ron
I've used 15" Nokias on my '98 Forester, but I intend to move on to a Subaru that uses 16' tires ('03 Forester, Legacy, or Outback models with 16" tires).
The Nokias have a a lot of tread left, and, due to the expense of new tires, wheels, etc. I would hate to have to sell them to get new 16" version of the Nokia when I get a new Subie.
I understand that t some U.S. versions of Outbacks and Foresters get 16" wheels/tires, while other countries may get 15" as standard.
So, my question is: Even if I get a US version of an '03 Forester, Legacy or Outback, with 16' tires as standard equipment, would I be doing any harm to the suspension, handling, etc. if I were to continue using the 15" Nokias that I have?
I know my odometer would clock faster, but I wonder, again, if suspension, handling, and clearance would be a problem?
I am posting this on other Subaru Crew boards, so excuse me if you see this post elsewhere.
Steve
bird19 (yet another Dave!): the overall diameter on the 15" rim is still the same, because the tire has a higher profile.
However, my concern would be having enough clearance for the brakes. The front rotors are bigger on all the cars you mentioned. So my guess is probably not.
-juice
-juice
I actually mounted it a bit higher than I needed to, but it still looks ok. I needed to stay clear of the key lock mechanism.
Actually access on the '01 was incredibly easy - I didn't even have to remove the inside cover on the hatch, since we have the lights mounted on the hatch as well as outboard, I just reached inside the light bulb access panel. Two holes drilled, and 123, we had a hatch bar.
-juice
http://www.imagestation.com/album/?id=4291908425
-juice
PS I finally caved and opened an account
Thanks!!
Jon
-mike
-Brian
-mike
-juice
BTW irvine Subaru has a house-cleaning thread on that other board that includes a SYMS Forester grille for $200
I like my grille - it was the only stock Forester ever not to get any chrome on it. I like it better than any OE grille to date.
-juice
I'm not sure if Flemington does inspections. I doubt NJ will get an AWD dyno anytime soon. The current inspection situation is a big mess.
-Dennis
-juice
There's inspection in Wisconsin? Is it just a Milwaukee area thing? I've never heard of it or done it.
--Jay
in norhtern WI
if it's as non-intrusive as my last check was (just hooking up the OBDII and downloading), then it doesn't bother me that much. probably only took a few minutes to do, while the aging Dodge Caravan next to me was on the dyno 2 times and failed both.
-Brian
Jon
It's funny how the subject of inspections came up here today, as I just had my '01 Forester in for it's first inspection this morning. Just look at these numbers:
HC PPM Idle: 0 (allowable = 220)
HC PPM 2500 RPM: 0 (allowable = 220)
CO % Idle: 0.0 (allowable = 1.20)
CO % 2500 RPM: 0.02 (allowable = 1.20)
Can these be real, or did someone botch the test???
-Tony
I don't know about you, but I'm glad to be doing my part, so to speak, driving a car that a) burns less fuel to begin with, and b) burns what fuel it does use very cleanly. Emissions standards are "parts per volume" requirements, so total consumption matters too. We have tried to "arrange our lives" if you will, so as to minimize our driving as well. We put 12k a year on, including extensive family vacations (25% of total miles).
Nice to know your '01 is still running so well.
