KarenS
Owners Clubs
I just had my 98 Forester go through it's first emissions test here in Cali. Most emissions test here only test at idle and 2500RPM without a dyno.
My results were very similar to yours, IIRC. There was basically little or no emissions measured. Remember, the emissions tests have a lot of grandfathering involved so they need to pass properly maintained vehicles from the last 10 years. It kind of shows you how clean running today's engines have become.
Ken
Cheers!
Paul
-juice
I have not been here in a while. In any case my 01 Outback makes a minor noise when the coil spring compresses and releases. Like going into a driveway. I know the strut is fine. Just sounds like the rubbing of the rubber against the spring. You really have to listen for it. Nonetheless I hear it. Any tips on it. I am afraid if I take it to the dealer he will laugh at me and say it is normal. Welcome the opinions. Thanks
What does the rubbing of the rubber against the spring sound like? Continuous? Abrupt?...
-Dave
If you have an AWD vehicle and it is put on a Dyno, you can count on problems with your transmission clutches (auto). With more AWD vehicles on the road, the whole process should be evaluated again. Make sure you ask - no matter what State and stick to your guns with refusing to have it done. Each State is provided with VIN descriptions from manufacturers that should over-ride their system requirements, but you have to be careful. Rick and Pete can discuss this issue tomorrow night if you want!
Patti
Juice: Shoot, and me with my suicidal tendencies. ;~)
Patti: I was concerned about bringing my AWD into a service shop (non-Subaru) for inspection. Figuring some stooge was going to put it on the dyno. Luckily, (1) It probably takes some skills to run the inspection system, and (2) RI just started stringent emissions testing 2 years ago (slow-pokes), so the system is fairly new and may throw the red flag...
-Tony
It is not abrupt or continuous. You only hear it when the spring compresses and expands like going into a drive way if there is a dip or hump in the drive way from the street level. If the car is stopped and someone goes out and pushes down on the fender and releases repeatedly, it sounds like wet sneakers on a dry, clean shiny floor. Know what I mean. It is not loud and it is only on the drivers side. It is WEIRD. But the strut reacts fine. It may just be the rubber housing. Anyone have any ideas???
I regret missing all the fun here but have been busy. I know I keep saying I am back but one thing leads to another. Now that we finally bought a house here in Eureka I have been busy getting it ready to move in. First wood floors needed refinishing, then some drywall work, resetting a sliding glass door, etc. Next comes the studio/shop I am going to (help) build off the back of the garage. Anyway, one of these days I will really be back and will really send Pat his seat pockets.
My 01 GT wagon is still the best car I have owned. Have had zero problems. Perhaps a little clutch chatter now and then when it is cold but nothing to complain about. Just good times all the time.
bit
Good to hear from you! How are things up there?
As for Mobil 1, you can run either 5W30 or 10W30 since it doesn't get too cold where you are. 5W30 may result in slightly better fuel milage. Unless you really drive agressively, either should suit you well. Just remember that even though synthetics can go longer between changes, your oil filter can't.
Ken
Patti
Steve
First, that won't be normal [layman's assessment].
You could try the WD-40 treatment as Steve had experienced with good result.
By any chance your OB has this guard installed around the front springs from a recent recall?
-Dave
Mine is a 2001 Forester with the large wheels.
I get a very consistent single clunk by the driver's side front wheel. It happens generally when the weight is on the left wheels: On right hand turns, on right hand long access ramps or when there is a positive change of level under the front wheels.
I took it to the dealer the first time and he replaced the stabilizer clamps or something for the purpose. It lasted 9 months. I took it to him again and he said they re-seated the assembly and cleaned some rust protection coatings. The fix lasted only two days.
Anybody has any clue what it may be and how to fix it? I'm afraid my guarantee will expire before it's fixed.
Patti
XT6 AT: 90/10 or 95/5
XT6 MT: 50/50 or 30/70
SVX: 90/10 or 80/20 or 50/50
-mike
Steve's suggestion sounds interesting, but I'll try lithium grease. WD40 can make the rubber deteriorate over time. They sell spray cans of lithium grease at auto shops.
Hey bit, nice to see you. Yeah, the Subaru filter is a Purolater and rated highly on that oil filter study where they tore them apart. Don't forget a 17mm crush washer.
mac: your problem is registered, so I doubt you'd have a problem getting it covered. I'm sure Patti will help out if you need it.
-juice
Cheers!
Paul
Cheers Pat.
Thanks in advance,
Brett
That shows the new one right next to the old one. Open the gas filler cap to release pressure in the system. I also "pinched" the fuel line with a clamp, just be careful not to puncture it. It's really easy, a couple of bolts, pull two hoses, swap it out.
-juice
2000 Outback uses an NGK V-Power BKR6E -- they are pregapped to 1mm and have a guard sleeve but you can check yourself to be sure.
-Colin
-Brett
-Colin
Thanks in advance
My first two vehicles were AT, but since '77 always MT. I've never had to replace a clutch. Had 105k on an '87 Subaru, currently 97k on a '93 Civic, and still <1k on the new Forrester.
I do lots of short trips around town, with some occasional long road trips.
The mechanic that works on the Civic told me a couple years ago that I'd need a new clutch eventually, but said get as many miles as possible out of this one, and don't worry until it starts slipping. It hasn't yet.
As I noted, I have a '98 Forester L, and I had a rattle in the area just under the upper left dash. It sounded like loose screws; actually it was like two parts were touching each other and not secured. The rattle/buzzing lasted about six thousand miles and seemed to have ceased in November, 2001. What;s strange is that the noise has not recurred...yet!
My hunch is that when the weather starts to warm up considerably, the buzzing will return.
I looked and probed around underneath the dash, but could not locate anything that might be vibrating.
I hope this helps! If you find out what's causing it, please post your findings.
Good luck!
A couple thousand miles later I had an alignment check done on it by an independent shop, who found the settings within factory recommendations. They found no other problems, but theorized the tires could cause the pulling. Since I didn't like the stock tires, I purchased some new Continentals. The car continued to pull.
The pulling became much worse after a little while, so I took it to my local dealer. I made three visits for this problem:
- Visit 1: Dealer insisted on performing an alignment. Said there was a small deviation in the driver-side front wheel. Charged me $90 and said everything was great. When I picked it up, I drove fifteen feet and realized they hadn't fixed the problem; it was still pulling.
- Visit 2: Showed up and was told the mechanics were unavailable. They couldn't help me.
- Visit 3: Mechanics were actually there. Told me my passenger-side control arm was bent and that I would have to pay $370 to replace it. The warranty would not apply.
By this point I was furious. I baby my cars, and am extremely careful with potholes and other obstructions since I hate paying for alignments. There was no other damage anywhere else on the vehicle. The stock tires, rims, and undercarriage were in pristine condition. The dealership automatically assumed I abused the car, and completely ignored the possibility of a weak or improperly installed control arm.
In my opinion, if an impact is strong enough to bend a sound control arm, then it will do other damage, or at least throw off that wheel's alignment.
I called Subaru and filed a claim number. They contacted the service manager of the dealership, who said they would not warranty it.
What do I do? Who is in the right? Do you think Subaru should warranty the repair?
I bent the control arm on my '88 XT6. But that was when I hit a 9" concrete curb @ 55mph! Bent the control arm and pushed my tire into the fender. In my case I can't blame subaru for my own musings, but if I bent mine hitting a curb at 55 I'd think that you would have known if you hit something that caused yours to bend.
-mike
tyguy: odds are the previous owner hit something. Where did you buy it, though? If the dealer sold you the car, they should cover it. It should actually have been fixed before delivery.
If you bought it elsewhere, I would not expect it to be covered by Subaru, but perhaps you could pursue it with the person/business that sold it to you. But it would be hard to prove, so you're probably outta luck.
-juice
-Dennis
tyguy: That sounds very frustrating. Juice brings up a good point though -- did you buy the vehicle used as-is?
Ken
-Dennis
The independent shop found no problems with the alignment and suspension upon inspection, and the dealer only found a slight deviation in the DRIVER-side suspension. It was on the third dealer visit they told me about the bent control arm in the PASSENGER-side suspension. So, there wasn't a problem when I purchased the vehicle.
Obviously something happened between the first and third dealer visits (about a month apart because of my heavy travel schedule). Since I was the only one to drive it in that time, it happened on my watch. But I can't imagine anything significant happening during that time period that would bend a control arm.
If the dealer claimed the car was in good condition, then you might want to do the same with them.
I can't imagine a control arm bending from normal driving.
Ken
-juice
Juice: My wife drives it about 5% of the time. She and I have talked the situation over, and she's positive she didn't hit anything. She's even more careful about her driving than I am, so I'm absolutely confident she's not responsible.
I know I'm biased in this situation, which is why I brought it up here, to get unbiased feedback. In my opinion, the burden of proof lies on Subaru to show the arm bent because of abuse. Until that happens, I assume I have an improperly manufactured part that failed during normal driving.
Thanks for the comments, everyone! Keep them coming.
Maybe Subaru will feel sorry for you and get you the part cheap, but I doubt the dealer will do much on the labor. Again, no one can prove their position here IMO, which leaves you unfortunately holding the bag.
You'll never be able to prove that it bent during normal driving... and the statement alone seems hard to believe. There's a far higher probability that it bent because someone hit something. We don't have proof about anything, but consider the result and consider which is more likely: bent somehow due to defective part while travelling over normal roads, or it bent due to striking a roadhazzard of some kind (huge pothole, curb, etc). The control arm absolutely is designed to bend under stress, saving the unit body and other expensive / irreplacable bits.
-Colin
-mike
I'm almost thinking your collision insurance ought to cover that type of thing, but it's so low it's probably less than your deductible.
I'd shop wholesalers on line, or even check out junk yards that sell Subie parts, and get the parts cheap. Darlene's prices were about 15-20% below retail, so you can cut down that repair cost significantly.
-juice
Once again, I'm sorry for the problem.
Patti
BTW, what are you doing up so early? Go to sleep! :-)
Ty
I recently came into a 1998 Outback Auto with 61K.
I drive quite a bit on dirt roads in upstate NY and twice in the last three days (Only on dirt roads)I've had this noise. Seems to be coming from the passenger side. It's a metallic grinding/vidration type noise. I'm not sure exactly where it is coming from. I was afraid it was the transmission but noise continued when I put tranny in neutral. It almost feels like the brakes on that side or maybe one wheel are engaged. I wsa able to make the problem go away 2 out of 3 times by stopping and engaging/releasing the parking brake. What seems to precipitate it is hitting a bump/pothole/puddle with the right/passenger side of the car. It really is a very scary noise. This only has occured once on Saturday and twice last night. Again, only on dirt roads. I also commute on a rough dirt road and it hasn't happened there (I tried).
On another note I got the car on a Wednesday and Saturday the timing belt broke! But everything was cool. I really miss the 5-spd from my last car. The auto feels looser? Prolly the different AWD system.
Any thoughts would be appreciated. Sorry about the long post.
Gremlin
I have two questions regarding the grinding noise:
1. Would it go away if you tapped the brakes instead of stopping and engaging/releasing the parking break?
2. Does the grinding noise increase in pitch the faster you go?
-Dave
Anyone else?
-Dennis
The first thing I would think of given your noise and the dirt roads would be a bit of gravel getting stuck between the dust shield and rotor.
Rally drivers remove the dust shields, but then again they service their brakes more regularly than normal people. It's also possible you're hearing something else, noises are very difficult to troubleshoot remotely. If you tap the brake and the noise changes it's a pebble alright.
-Colin
