Subaru Crew Problems & Solutions
1166167169171172385
  • hypovhypov Member Posts: 3,068
    Jim-
    Car:
    -Buzzing from right edge of dash, hit a slight  bump in the highway, buzzzz for several minutes  after. Hwy a little less than smooth, bzzzzzz.
    -Buzzy rattly noise from right side, mid to  rear,door window, frame, I can't tell.
    There are 2-1/2 obvious places that would make the buzzing noises.
    The infamous seat belt against the B pillar.
    The other, wires behind steering column cover, or your keys themselves.
    Warbling- This may sound weird but I swear there is some kind of high pitched hummy, warbly chuffing sound when I am going at higher speeds, 50-60 or so. It's like a dull ringing, I'll have to try the am radio station thing because maybe that describes what I'm hearing. I swear I am not making this up.
    Probably is the fuel pump you're hearing.
    If it whoops and tail off into a whine, it's the a/c compressor ;-)
    Vibration-
    -This is the worst discovery. When in any gear but Park or Neutral I feel like I'm holding onto a pad sander. There is a fine high speed vibration that travels from the lower frame into the seat and steering wheel. It makes your teeth buzz. I got the automatic because of the problmes with the manual clutch. Do all automatics do this? This could get old on a long drive and unfortunately I do a lot of long haul driving.
    I had that with my '98 OB Ltd. Don't know if it holds water, the vibrations I get intermittently went away after changing over to synthetic ATF. Then again, when they drained the ATF, the AT was 2 quarts short.
    -Dave
  • jlawton2jlawton2 Member Posts: 25
    thanks all,
    I didn't know you could inflate the tires that much. I forget where I saw the 29/30 . I thought it was in the manual somewhere.
    on the rattling
    It's not anything in the steering column area although the plastic cover around the column is alot squeakier on this 03 than on my 98.
    Not the seatbelt either more like 2 parts that don't quite fit. I had something like this on the dashboard of our little pickup and had a penny stuffed between the 2 plastic parts to keep them from rubbing. I think it's behind the dash or inside the door or B pillar so the penny solution is out on this.
    On the whuffing warble- I don''t have the ac on, good guess though! I think I'm just hearing the operation of the car magnified by the fact that it's hard inside the cabin acoustically speaking. We got a little spoiled with the leather interior on the Outback, the sound was much better amongst all that padding.
    Well at least I can get into this car without knocking myself on the bean and I think we have a reasonable chance of crossing a busy intersection without the transmission throwing a hissy fit.
  • junkherjunkher Member Posts: 27
    Well, According to Subaru, the FUEL TRIM sensor ( one for high trim, one for low) has been out of whack on my particular vehicle. It SHOULD turn on the engine light I am told, but for some reason does not. When the low trim is out of adjustment, it screws up the fuel injection giving to little fuel. The computer senses a dying motor and tries to correct by giving it more fuel, whalla- takes off rapidly by itself! Scary as hell when it does it too!
    Perhaps others with cars dying, chugging, etc. should have this checked as it IS a VERY dangerous situation to have a car self accelerate.
  • jesmcjesmc Member Posts: 1
    My 2001 Forester has only 4,000 more miles until it goes out of warranty. I've already had left rear wheel bearings replaced twice. Now I often hear and feel a distinct "clunk" when I start the car. Of course, this never happens when a mechanic is starting it. Any one have this problem or ideas of what it could be? I take the car back to the dealer in 2 days.
    Jes
  • jamieeijamieei Member Posts: 1
    I'm thinking of purchasing a used 2000 Forester
    I read an article saying there was a recall but can't remember if it was for the 2000 or 2001.
    On the discussion board I see comments on air sensor replacements and figure it's the same thing but don't see anything about recall and replacement by manufacturer.
    Anybody know anything about this?
    If anybody has words of advise re: things to look out for on a 2000 Forester, it would be very much appreciated.
  • lark6lark6 Member Posts: 2,565
    I have a 2000 Forester S which I bought new in January 2000. I now have 54K miles on the car.
    The major issues with this car have been premature failure of rear wheel bearings (on many cars) and leaky head gaskets (on some cars). Both are correctable problems which can be addressed by a dealer. If you are buying the car from a dealer you may want that to be taken care of prior to purchase.
    My car also had a defective fuel gauge sender, replaced under warranty at approximately 8000 miles. It would not read full when the car was full, which in hindsight was better than not reading empty when the car was empty.
    There was an oxygen sensor recall for these cars. I had the recall work done but did not have any problems with the original sensor.
    Other than the problems described above the car has been great. Not to minimize the impact of those problems but again, there are fixes for them that can keep them from recurring.
    Hope this helps.
    Ed
  • weppersonwepperson Member Posts: 9
    The handling on my VDC sedan is disappointing compared to my previous Audi A4, but the most bothersome thing is that the tires "cup" wear badly. I'm becoming convinced this is a characteristic of the Subie AWD system. Our old '97 Legacy did it badly, our '03 WRX does it to a degree, and my VDC with 15K miles on it has tire noise that can't be drowned out with the McIntosh cranked up. Any remarks/suggestions? It can't be entirely my driving habits, because the Legacy and WRX were/are wife-cars.
  • dcm61dcm61 Member Posts: 1,567
    I replied to your post in the Legacy/Outback forum but here it is again:
    My '96 Outback H4 AT went 69k miles on the original Michelin XW4's and 58k miles on Bridgestone Dueler H/L's (tires probably had another 10k left but I traded the car in) and never experienced any cupping.
    My '03 Outback H4 AT has 13.5k miles on the original Bridgestone Potenza RE92's and appear to be wearing evenly.
    I rotate the tires (front to rear / rear to front) every 7500 miles. Are you rotating your tires?
    DaveM
  • originalbitmanoriginalbitman Member Posts: 920
    My RE92s on my 01 Legacy GT wagon went 30K miles with no cupping. The RE950s I replaced them with are pushing 15K and no cupping. I rotate every oil change (3K).
    bit
  • bkaiser1bkaiser1 Member Posts: 464
    My OEM Firestones lasted 30K miles with no cupping, but the outside edges of all 4 tires were bald so I replaced the set with Dunlop SP Sport A2's and had the alignment done just to be safe. Within a few thousand miles, the Dunlops were cupped really badly and no amount of rotation was able to stop the wear...they were shot within 18K miles. The cupping was very pronounced with this set of tires, so much so that the tire dealer replaced the set free and only charged me the difference between the dunlops and the michelin mxv4's that I replaced them with.
    No one's really sure what caused the severe cupping. The alignment was fine, and they were rotated every 6K miles. Their best guess was that the type of road I was driving (I80 between Sacramento and Reno) and the amount (2500 miles a month) were factors...that tread pattern was apparently ill-suited to that type of condition.
    With only a couple of thousand miles on the Michelins now, it's too early to tell if the problem will come back, but I'm hoping it was a fluke. I wouldn't say it's a "normal" trait of the Outback to eat tires like this.
    B
  • kenskens Member Posts: 5,869
    Ditto here on the tire wear. I've been through two sets of tires, now on my third, with my 98 Forester and all of them have worn evenly.
    I don't think cupping has anything to do with the AWD system.
    Ken
    ok I'm gonna try and not think about there being a service bulletin out to fix the clutch on the Outback I just traded in and concentrate on the new Forester.
    I'm getting used to some of the whirrs and humms of the new car but I'm having a hard time adjusting to the vibration I described earlier as being like a pad sander. It goes away some when I shift into park or neutral but in drive it's irritating. I get that tickling, itching effect in my arms and legs like holding a vibrating instrument, no jokes please ;)
    I don't care so much about engine rumbling but vibration can be tiring on long trips.I notice also that I feel like I could read a dime under the tires, meaing that I can feel the texture on the smoothest road. Is this common? I bumped the tire pressure up a couple of pounds as suggested.
    Before I head into dealer service any ideas? Would the not have balanced the tires before I took delivery? I don't want them to write me off as having an overly sensitive tush.
  • jfljfl Member Posts: 1,399
    The first thing I'd do is take it to a GOOD shop for alignment and balancing. Not all dealers do a good job prepping new cars.
    Generally, increasing tire pressure increases the transmission of road irregularities...with higher pressures, you'll feel every bump! (Better gas mileage though.)
    Hope they find solutions to the problems.
    Jim
    The OE tires on my Forester lasted 28k miles. No cupping, though I did have more wear on the outside due to aggressive cornering.
    Who, me? ;-)
    The new tires have 24k miles on them and are wearing evenly.
    Keep in mind alignment specs offer a range, not a set value, so perhaps they're not quite at the ideal settings for your alignment.
    -juice
  • nygregnygreg Member Posts: 1,936
    I have the same experience as Brian. The original Firestones on my 01 OB wore evenly until I picked up a nail in the sidewall. Replaced them with the Sport A2s. The Dunlops are now very noisy (cupped) and are wearing quickly. However, they still perform very well. I recently spoke with Tirerack about this and they said they are hearing many people complain about the A2s noise and have approached Dunlop about it. If they can fix the noise issue, this would be a great tire. I plan to purchase new ones before the winter. My dealer will install them for $78.
    Greg
  • otis123otis123 Member Posts: 439
    Original Firestones on 2001 Bean lasted 40K with no problems/cupping (and no tread on the outer edge). :-)
    Ralph
  • Well, my Legacy GT Limited is in the shop again today. First the clutch chatter, then the transmission gear clash, and now it's the differential side bearing. All on a vehicle with 30,000 miles.
    The bad news is that the bearing won't be in stock for a few days. The good news is that I caught the problem before the bumper-to-bumper warranty expires next week. I'm a little nervous about what happens after that. At least I have the powertrain warranty for a couple of more years to cover the really nasty repairs.
    FYI: I was able to determine the bearing was going bad by a low, intermittent growling noise that peaked around 45 mph. The noise persisted in most gears, and fluctuated with throttle input.
    -Ty
  • subearusubearu Member Posts: 3,613
    The OEM Firestones on my '00 Outback will probably get me to about 35k (about 5k more miles) before I'll replace 'em. The OEM's are wearing fairly evenly, with a little extra wear on the outer edges due to some aggressive driving. The alignment is right in the middle of the specs too. I'm not sure what I'll replace 'em with yet, but looks like I'll avoid the A2's for now.
    FWIW, we have OEM Dunlop SP4000's on our MPV and at 9k they are wearing very evenly and aren't noisy.
    -Brian
  • jlemolejlemole Member Posts: 345
    now at 20k miles on my 02 OBW, no problems so far. Tires rotated every 7,500 miles.
    Regarding the vibration, I've always noticed a little vibration when stopped, but in gear. I've even asked the dealer to check it, but he said everything was normal. I've chalked it up as one of those quirks of the boxer engine.
    Jon
  • fibber2fibber2 Member Posts: 3,786
    Just curious - is that the front differential (integral with the transmission case), or the rear diff?
    Steve
    John told me yesterday that his head was sent out to be planed. George (mechanic) reported to him that the #4 cyl head bolds were indeed loose, and it looks like the head 'scrubbed' as it cycled. The result is some localized divots.
    Steve
    So I guess the question is, did the bolts come loose during thermal cycling or were they installed incorrectly (not tightened)?
    Greg
    I'll second Jim's opinion on going to a good alignment shop. Dealers can do alignments, but they're not always very accurate.
    Your tires should have been balanced even before getting to the dealer. I'm sure Subaru has a huge shipment of pre-balanced tire/wheels that they just slap on their vehicles and ship. It may be possible that the weight shifted a little. It's not unheard of for a wheel to throw a weight.
    I'll have to keep an eye out on the A2s. I recently put a set on my wife's Jetta, but it's too early to tell what the wear pattern is. A buddy of mine has a set on his Forester and I do recall him complaining about increased noise compared to the OE Geolandars. I don't think he's had a cupping issue, though.
    Ken
    is the key. See if there is a shop near you that has Hunter equipment, specifically the http://www.gsp9700.com/
    -Brian
  • blaneblane Member Posts: 2,017
    Dunlop Sport A2s --- handle well, but VERY NOISEY!
    At least they were, on my 1996 Legacy GT, before I sold the car.
    I'd say spend the extra $10/tire or so and get the SP5000s instead. The tread life rating isn't as long as the A2 but you get a quieter ride and better traction. I have them on my Forester and love them!
    Ken
    It sounds like a good idea to try the alignment before making any assumptions about other problems, I'll look for a place with the Hunter equipment
    jfl hit it on the head, the vibration is primarily when it's in gear. You don't notice it as much when speeding down the highway because the road noise takes over, so much as you do sitting still.
    I realize it's there in my older Forester too but the engine and I aged together and have achieved a symbiois :)
    By the way, I have to say that while I'm glad my wife picked out a Forester, because now I get to drive it, I'm kind of partial to my 98 model. Some of the changes from mine to her model, the flattened out door mounted armrest and the reduction in seat adjustments especially, I think those reduced the comfort level in the interior.
    It's harder to get comfortable if you've got long legs, the thigh support has diminished. And I keep rolling down the rear windows whenever I go to adjust the side mirrors.
  • ballisticballistic Member Posts: 1,687
    jlawton2 wrote: "I'm kind of partial to my 98 model. Some of the changes from mine to her model, the flattened out door mounted armrest and the reduction in seat adjustments especially, I think those reduced the comfort level in the interior.It's harder to get comfortable if you've got long legs, the thigh support has diminished."
    That's what I also found while testing an '03 X. The seat base is on the short side (front to back), and doesn't provide enough thigh support. This gets worse if you raise the seat, because instead of going straight up, it tilts forward while rising. This leaves the seat base too "flat", and aggravates the lack of thigh support. Maybe you could check your wife's '03 Forester to see how difficult it would be to unbolt the front seat and put shims or spacers in the front mounts to tilt the seat base farther rearward. I'd be interested in what you see. I also would like to raise the entire front passenger seat at least two inches. My XT won't have a sunroof (darn!), so there's more than enough headroom.
  • jason_elsjason_els Member Posts: 57
    I'd like to be able to change my oil and flush the coolant at home but it's always mystified me where people take the old stuff? I always heard you can bring it to a "service station" (do these still exist?) but we don't have any where I live. Do these places take old coolant too? I'd HATE to toss old coolant into the woods or anything like that and absolutely refuse to toss oil (it's illegal anyway). Any clues? I don't have any...
    At least in the city I live in, there is a city recycling center. Not only can you bring newspapers, cardboard, aluminum and steel cans, and #1 & #2 plastics, but there is an oil recycle center there as well. That's one place you can bring used oil (if you have something like that near you).
    Some auto repair shops (aka service stations) will take used oil and antifreeze. Some may charge you to take it, others will take it no questions asked.
    You can also look in your yellow pages and look under 'Recycling Services' or something similar and find other local places to take the oil and/or coolant.
    -Brian
  • snowbeltersnowbelter Member Posts: 288
    In NY State, any place that sells motor oil is required to accept the used stuff or direct you to a place that will take it in their behalf.
    I've read about raising the mounts somewhere else here. I'd better think of something because after I showed her the link to the Japanese versions my wife is making noises about giving me "her" car, the new '03, and trading mine in on a turbo for herself!
    I think she has her eye on something like the cross-sport version as her dream car. Any idea if we'll be seeing a version of these in the US in the near future. I would love that durable cargo area myself.
    JL
    Really?? What a well-kept secret that is! I'll have to bother the local gas stations IF I can convince the vacant-eyed piercing pillow behind the register to take the stuff.
    My thanks to you both :)
  • sugardogsugardog Member Posts: 41
    Any LUBESTOP will take it.
    Hope there is one in your area.
  • The side bearing on the front diffy is going bad. Still no word on part availability, but they predicted it would be at least a few days.
    -Ty
  • vickatvickat Member Posts: 43
    Deciding between Impreza RS and Acura RSX. Dealer didn't have manual Impreza on the lot. Could anyone, please, share experiences with Impreza RS clutch? Is it short- or long-throw? Is it hyudraulic? Is take-up point crisp? Is clutch forgiving (in case of late or early letup)? Does 2004 RS have "hill holder" feature? - many thanks, Vic
    That's a Forester exclusive for North America.
    Bob
  • gregmiscgregmisc Member Posts: 17
    Jason: Any AutoZone will take used oil but they don't take antifreeze.
    Jason,
    Same here in the Bay Area. Also, I can turn it in with the other trash recycling materials every other week. In fact, I just changed my oil this weekend and it's sitting in a plastic container for next week's pick-up. Handy!
    Ken
    Brought a bunch to a quick lube near me in several old windshield washer bottles recently. The owner/manager there suggested getting a 5 gallon Kerosine canister (white) at Home Depot and using that since it allows him to see the oil and is reusable, and easy to transfer. Works great. They didn't take antifreeze though and don't know what to do with it.
    Greg
    I put washers under the front seat track of my Miata. 4 or 5, actually, got about 3/8" lift for more thigh support. It can be done.
    Vic: you gotta try it. With AWD, any clutch is going to be less forgiving. The tires don't break traction so it's up to the clutch to cover up any mistakes.
    With experience it won't be an issue, I don't think.
    You can get all sorts of short throw shift kits, included factory, Cobb, Kartboy, etc. They're only about $100 or so for the lever, more if you want urethane bushings. Do both and the feel is more like the S2000 than the RSX.
    -juice
  • rob999rob999 Member Posts: 233
    FWIW -
    I got a galvanized, industrial-strength 6-gallon gas can at a garage sale a couple years ago that was too yucky for gas but perfect for recycling oil. Holds oil from 4-6 oil changes so I only have to make one trip to the recycling center about once every 8 months.
    the washers sound easy enough.
     I read a couple of days ago about a recall on 2001 Legacys to correct the possibility that the seat rails could break during accident impact. This got me to thinking if messing with the seat rails on the Forester , or any car, would pose any hazard or violate insurance in the event of an accident.
    any thoughts?
     "just call me "Mr. Paranoid")
  • ebony5ebony5 Member Posts: 142
    Last week I had the 60K service done on my 96
    Outback at Town Motors in Englewood New Jersey. The plugs did not have to be replaced(done by previous owners at 41k),but the water pump,Timing belt(recommended at 60k for the 96 model)and timing belt tensioner were all replaced. With a 15% discount special offered by Town plus $100.00 off from my Subaru credit card the bill came to
    $1003.92. I was given a loaner while the work was being done, but I only needed it for that one day; at 4:30 Greg the service adviser called to tell me my car was ready. I had called around to various Subaru dealers and with the discounts I think the numbers I received were competitive. I also mentioned that I used this message board and that someone(paisan)told me to say hello to Garrett one of the mechanics. So far so good, all in all the experience I have had at Town Motors have been O.K.
  • hammersleyhammersley Member Posts: 684
    Try the local wrecking yard - the one near where I work takes the coolant from the cars they salvage, filter it & resell it. If yours does the same thing, they may take it. Same holds true for the oil - perhaps they use a waste oil heater.
    Cheers!
    Paul
  • p0926p0926 Member Posts: 4,423
    I don't see how adding washers to lift the seat would be an issue. Unless of course you didn't tighten the nuts back down sufficiently (and the seat broke loose) or something along those lines.
    -Frank P.
    It seems extremely unlikely.
    I'm actually more concerned about the seat position relative to the air bag.
    -juice
    "I read a couple of days ago about a recall on 2001 Legacys to correct the possibility that the seat rails could break during accident impact. This got me to thinking if messing with the seat rails on the Forester , or any car, would pose any hazard or violate insurance in the event of an accident. "just call me "Mr. Paranoid")"
    I'd thought of that, and the modification certainly ought to be done with due regard to strength and crash consequences. However, I can't see spending ten years in a vehicle whose driver's seat doesn't fit the owner. Sometimes you simply have to choose your priorities.
    In a similar vein, Foresters place their side airbags in the outside bolster of the backrest. Because I plan to own mine for a very long time, I want to protect the driver's fabric seat upholstery with some sort of simple, easily removable seat cover - maybe of denim or some other durable material. I'm thinking that I'll probably have to cut the seat cover in the area of the side airbag and hold it together with snaps or velcro, so that in case of deployment the airbag can punch through and do its job. Has anyone else considered this issue?
    - jack
    Do Subarus(I have 96 Outback)require any special handling because of the AWD or any other reason when having the N.Y. State safety and emissions inspections. In other words can I take my car to a registered service station or should I schedule an appointment at a Subaru facility. There are service stations near to where I live and it would be much more convenient. Where I have my car serviced is in New Jersey and they cannot perform New York inspections
    I can't speak for NY, but here in Maryland, there are separate lines at the state emissions testing facilities for 4x4 and AWD vehicles.
    Bob
