Tacoma 4x4 or T100 4x4
I currently own a 90 4-runner that i have been
really happy with. but i found out that the
tacoma is built in the U.S. and I am concerned
with american quality. Since all of the G.M.
vehicles I have owned have been lemons(88 4wd
surbaban,87 firebird) The suburban after 1 year
the paint on the roof dissolved. G.M's answer
we are not responsible!!!. Needless Too say after
Litigation They did a half-a-- Job and also stole
my spare and jack. There answer was read the sign
in the shop. We are not responsible for any items
left in the vehicle. I promised that i would walk
before i ever purchased a G.M. vehicle again.
i understand that the T-100 is built in japan and
shipped as a whole unit. any Comments Would be
greatly appreciated. The reason For 4x4 is moving
too the north were i might need the extra
traction.
Todd Pierce
traction.
Todd Pierce
I purchased a toyota camry for my wife and I made sure that it was made in japan, since some of them were made in the states too. Well, our japan manufactured camry is a piece of crap. While not a full fledged lemon it certainly has not lived up to supposed toyota quality. My chevy truck on the other hand has been awesum. I guess it boils down to expectations.
You didn't mention how you plan to use the truck and how many people you regularly carry.
Obviously, one consideration is payload. The T-100 is considerably bigger than the Tacoma, but still not a Ford, Dodge or Chevy. A T-150 with a third (and fourth) door might be nice as my kids grow, but for now the Tacoma is plenty enough for a commuter/weekend do-it-yourselfer truck.
Also, a third door is not an option on either Toyota, so you may want to think about that if looking at extended cabs and/or carrying more than you and another person. An extended cab may also be a thought just because of keeping stuff safe and warm especially as you move north.
I have a 98 Tacoma Extra Cab 4x4 with the 4 cylinder and am really pleased. The V6 would be nice, but I can't afford the tickets all the extra horses would surely bring me. Good luck.
I have a buddy who just put in an order for the new Tacoma TRD 4x4. He test drove one, and seems to think it's pretty neat. He currently leases the same truck you do. I have my misgivings, but I have no experience with this truck. Can you fill me in on the things you don't like about it? Thanks!
I have a 98 T100 4wd and I do too have that same
problem with that darn seat belt. I suppose since
mine is still under warranty I should have then
take a look at it....As far as the ride..I'm very
satisfied.
jd
I also have the seat belt problem with hanging out the door, not retracting ( the least of the problems) I have had problems with the trasmission (5 speed) whining, the dealer replaced the throw out bearing and it is doing it again. For some reason the horn has had problems working (problem is always in the steering wheel) and some suspension bushings have been replaced to quiet a loud clunking noise. The engine check light comes on now and then and sometimes has a slightly rough idle (they have not figured that out). The center console has broken loose a couple of times. I would think the newer ones have been improved.
I had a problem with the steering column of a motor home I was driving about 15 years ago. It kept blowing a fuse at night. The fuse was for my headlights, and it only happened when I was driving. Turns out that the way I liked to adjust the tilt steering wheel somehow managed to pinch a wire and blow the fuse.
It will be used for highway driving and some lihgt construction work.I'd like to get something that will be good for years. What is your advise anyone?
Auto or 5sp?
I have a 98 Tacoma Extra Cab 4x4, 4 cylinder, 5 speed and am really pleased. I also get around 25 mpg at 70 mph on the highway and 20-22 mpg in a city/highway mix.
The 98's add dual airbags with side passenger cutoff switch and side-impact door beams. Other than that, I think the different year models are virtually the same.
Perhaps if you take a drive out onto a freeway for a bit of highway speed to blow-dry the brakes.
Another recommendation: Don't be so quick to put your truck back into the garage when you know the brakes are wet from launching.
Either that, or get a trailer...
Chris
I've owned other brands of vehicle - a 1971 Dodge Demon, a 1989 Dodge D50, a 1990 Chrysler LeBaron, a 1989 Nissan Sentra, and a 1995 Kia Sportage 4x4 - and I will probably never buy another brand of vehicle.
I've abused my Toyota, and aside from a little shaking at 90mph, it still takes it. Other than regular maintenance, its never been in the shop for repairs. IMHO, Toyota is the best manufacturer out there.
My only regret is not getting a 4x4 when my wife suggested it.
Just my $.02
Do you have a T-100?
oops! I just read above and see that you do. Was the ride quality realy that bad?
evergreen, alloy wheels, 265 tires, ABS, Cruise, Sport Seats, Xcab, 5 speed. It's the funnest vehicle I've ever owned. I really love it. I will keep this board posted as time goes on in owning this great ride. I'm only getting 21 mpg on the Hwy. Also this is my first truck to own and I've been driving an automatic for the past 10 years. It bothers me that I can't seem to find the perfect shift that has the gear box and engine at near the same rpm. Also any advice from other Tacoma owners on how to care for this vehicle or what to watch out for, would be greatly appreciated. Thanks.
just my 2 cents
The new Toyota T-150 will have four doors on the extended cab. See the T-150 topic.
The dealer said that they will not be out until the end of the calendar year. I know the domestic '99's are coming out, with most available within the month. Does anyone know if it's true about the late arrival of the '99 Toyota trucks or is it like I suspect that he is only pushing me to buy a '98.
the only concern i have is the 3.4l v-6 and its history of blowing head gaskets. i am told by toyota reps that it has been rectified, but have heard of a '97 4runner blowing its gasket. i know of the great powertrain warranty, but am still worried about it. any v-6 owners have any trouble? any reason not to get tacoma???
i appreciate your input.
About the only complaint that I have is that the
seat belts don't always retract, other than that
it's a great truck. Then again I only have 5,000
miles, so we'll just have wait a while.
Roym...... there was someone else in this forum who had a similar problem.
jd
P.S. Are Tacoma 2x4s as bouncy or are they more comfortable?
