Visitor Agreement.
Steve
Have fun!
Lance
Steve
uncap the brake resivoir
yank the pads
clamp with a c-clamp the piston (with an old pad between the piston and c-clamp) back into the caliper
insert new pads and shims and anti-squeel grease
swing down the caliper and rebolt.
Note: make sure not to overflow the brake reservoir cause it'll make a mess of the engine bay.
-mike
-juice
to do the extra stuff, remove all caliper bolts and disconnect the brake line. clean the caliper with brakekleen or similar solvent. clean the guide pins particularly well and DO NOT lubricate them in any way unless the vehicle's service manual explicitly indicates it.
remove the piston(s) from the caliper and inspect the seals. if any are weathered or melted, replace them. thoroughly clean the piston and bore with solvent. reassemble and press the piston fully in place-- you won't need a clamp since there is no fluid in the caliper.
while you have the caliper off, measure the rotor's thickness and replace if below service limit. I just did pads all around and front rotors on a friend's 325 last week-- her front rotors were over 1/8" below minimum thickness. to replace the rotor, remove any fastening bolts (usually just one or two-- mostly they are held in place by the wheel studs and caliper) and then tap the rotor with a mallet until it comes free. replace, refasten.
reassemble the caliper, attach brake line, install pads. do them all then bleed the brakes.
-Colin
paint the calipers yellow = 10 hp
Remember, yellow = fast, stickers = fast. Do 'em in yellow and add a sticker and you're talking 15-20hp easy! ;-)
-juice
My question is: should I replace the battery, or not worry about it? The battery is 3 years old (original)- how long do batteries last?
Also, how often should I change batteries for the alarm key fob?
Thanks again Mike.
Mark
-mike
-juice
-mike
One other thing I just thought of: by having the battery be "dead" for so long, does that mean I reset the ECU? If so, does that make a difference?
Mark
Ken
-juice
-Colin
Ken
it should be fine to do just as Mike has suggested this time and then do the full service that I spoke of next time.
-Colin
Oddly enough my bleed valves were of different sizes between the front and rear calipers. Fronts were metric whereas the backs were much smaller and US.
Alan 98 OBW Ltd
It resembles a pump up garden sprayer with a pressure guage on the tank and at the end of the outlet hose is a fitting that mounts on top of the Master Cylinder. Fill it with some good brake fluid, pump it up to ~15 psi and bleed at each corner till you see the new fluid coming out and no air bubbles.
I also used the ATE Super Blue brake fluid which is a rich blue color making it easy to know when all the old fluid is out. They have a Gold version too for when you want to swap out the Blue.
Alan 98 OBW Ltd (no leeches, just ticks at cold startup
Just curious.
-juice
Doing it the traditional way and have someone pumping the brake pedal while you open and close the bleed valve takes a bit of coordination between you and the pedal pumper. For instance, he/she has to keep pressure on the pedal until you close the bleed valve. If the pedal is released while the valve is open, then there is a chance of air being sucked into the caliper/brake line. That would defeat the purpose.
With the bleeder, you pressurize the tank, open up the bleed valve, and sit back and watch it flow into a suitible clear jar. It should only take a few minutes per wheel before you see all new fluid, there really isn't too much in the entire system.
To expedite the process, prior to hooking up the bleeder, use a clean turkey baster device to suck out as much out of the MC and then top off with new fluid.
I plan on flushing both cars every two years and I kinda like gadgets like this.
Alan 98 OBW Ltd
http://www.speedbleeder.com/
-Colin
Neat idea though. I wonder how they would hold up with all the heat. That spring inside is a failure risk in my opinion.
Alan
in your defense, that's the cheapest pressurized bleeder I've ever seen. the ones in Griot's and some race catalogs I get around generally in the $200-250 range.
-Colin
With the Speedbleeder you would also have to monitor the fluid level in the MC and top off periodically during the process.
The Powerbleeder fills the MC as you bleed and maintains the same level in the MC. All the work is done under the hood or at the wheels. No need to get in and out of the car and track in engine/brake grime.
I think I've earned my commission by now. Please take my comments as just trying to offer good advice about a product that I am impressed with. I enjoy lending my friends a hand when I can.
Alan
www.scoobymods.com/forums/showthread/t-181.html
and ..../t-84,html
both are articles on changing brake pads.
There are also several build your own pressure bleeder articles on the web.
Jim
Kirsten is actually excited to give this a go....she is even talking about clearing out our rental garage to make space for a generator and small compressor :eek:
-Frank P.
If you have an auto shop / auto parts store nearby (Pep Boys, Autozone, etc.), I'm sure they would measure them for you.
DaveM
On my Escort I could barely see the thing, so then I knew it was time for new pads! Yikes! It wasn't squeeling yet though.
-juice
-juice
Was the Escort equipped with the "squeelers"? Some manufacturers saved 25 cents per car by not designing that feature in.
To make matters worse, while we were talking, another co-worker, Ed, approached us. Seems his in-laws in Virginia ('98 OBW w/80+k miles) just went thru the same problem.
It is starting to get tough listening to the disparaging remarks about Subaru in this office.
Steve
As an aside, only tear apart one side at a time. That way you always have the other side to look at if you forget how it's suppose to look. Or only one side to put back together if you have the wrong parts.
DaveM
Best of all, I was able to tell them how useful Edmunds is---IMO, the best of the consumer auto resources on the internet.
John
Colin won't let me
Now *that* was hilarious.
-juice
Forester has won their APEAL study a couple of times. That's more significant than the IQ, IMO, because I'd rather *enjoy* my car than have one that is perfect but not actually like it (i.e. boring).
-juice
Regarding the 98 and 99 head gasket issues... I'm very sorry to say that there's no way I'd own a 96-99 2.5L DOHC. They have major head gasket issues and I'm not sure that multiple revisions of them have helped. (dig around on nasioc, repeated failures even for people using the latest.)
-Colin
-Colin
