Visitor Agreement.
I'm also relearning the joys of being able to find a gas station whenever I need one, not coasting on diesel fumes looking for the one in a small town that has diesel.
I had my 7.3l for 5 years, so its been a bit of an adjustment. I'm certainly not regretting the decision. Next on the list is a Gale Banks Powerpack exhaust system, and probably a 6-8psi supercharger in a year or two. That should push the torque up well beyond the 500lb range and still keep the higher horsepower of the gas engine (nice for towing through E. MO for instance).
Our reasoning: Since we only plan on towing a small, light (<=7,000lb loaded, 5th wheel) once or twice a year for camping vacations, and round-town or occasional 900 mile round trip highway trip to the in-laws use otherwise, we don't envision putting more than 10,000 miles per year. Giving the 160,000 mile breakeven point finally calculated above, which seems to use the latest realistic numbers, that's a 16 year breakeven time frame for the PSD vs. the V10. Then there's the possibility of much more expensive repairs at about that time. The main factor, though, is that I also have to replace my car with a less used one, and the $3,800 is over half of what I'm expecting to pay for it, so the upfront savings will help out immensly right now.
I'm still second-guessing the 3.73LS, and wondering if a 4.30LS would be wiser. I'll be happy to report on some 3.73 mileages if and when it arrives, and if I've stayed with the 3.73.
I don't like the resulting crusing range though, especially when towing, but we'll have to live with it, or get an aux. tank. I also wish a 4.10LS were available for those of us for whom the choice is not clear between 3.73LS and 4.30LS.
Thanks for all the effort put into the discussion.
Both Ford and Dodge have standard warranties of 5 yrs/100K miles when you get the Navistar or Cummins, respectively. I know Chrysler's longest extended plan is 7/150, and I imagine Ford would have something similar.
It's up to you as to whether an extended warranty is a value. Some opt to put that money in a savings account, wait for something to break, and pay cash. Others like myself see extended plans as part of the cost of "doing business". Personally, I have the 7/100, just for the extra time - I figure in about 100K miles, the truck will be 6 1/2 years old, and if I still have it then, I'll be surprised. I sorta expect to replace my 96 Ram in 2001 or 2002.
Good point i was kinda wondering that myself. I also live in MN and have an older deisel car that doesn't start under about -10. This is with all the additives.
Tom
P.S. what town do you live in bunski
Here's how Dodge does it:
The engine air passes through an electric "grid" to heat it to operating temperature. The fuel pump also has a small electric heater to warm the fuel to help dissolve any gel or wax. Dodge recommends using the engine block heater between 40 and about 0 degrees and requires it below that. If it stays below 20, I also toss in a bottle of STP Anti-Gel ($1.99 for a 12 ounce bottle that treats up to 50 gallons) for extra protection. I have never had a starting problem in winter.
Your diesel has got about 100,000 miles on it.
Guess what, hard start.......
Diesel fuel combusts when the temperature of air inside the combustion chamber is above the autoignition point of diesel fuel.
If you know a little physics or engineering (Boyle's law), you will realize that high altitude, cold temperatures, low relative compression due to the fact that the pistons have shrunk away from the walls increasing clearance all lead to one problem. NO START!
Dem electric cords just don't seem to be around when you need them.
Buy a gas motor if you want max flexibility.
Diesel fuel, being an oil, is also non-flammable under an ordinary match. In a pinch, you can melt it down some if you have to with an application of heat.
Gasoline, being a highly volatile liquid, will freeze solid and can only be thawed by an indirect source (a hot-water wrap, etc.).
Throwing a bottle of diesel anti-gel in the tank is no different than using a bottle of gasoline antifreeze. My Ram has fired at zero degrees without the block heater plugged in - in fact, there's no place for me to plug it in at work, so when I leave at night, I rely on the electricals to get it going. Never failed yet.
I've never experienced a no start due to fuel jelling, typically my no starts are due to not reaching sufficent boyle's heating in the combustion chamber even after a few minutes of cranking.
I live at 7000' elevation in Arizona, 20% less air to compress at this altitude, and overnight temperature drops of typically 30 to 40 degrees. It was right around 0 two nights ago (mid-November). Even my buddy's Powerstroke gets finicky in the winter. The cummins' do the best, but only as compared to other diesels.......
I'm at 170,000 on my ten year old ford diesel crew cab (oil changed by me every 2500 miles). Drove to Florida last month, averaged 70 to 80 mph, used 1/2 qt of oil on the way there (2500 miles) and got 16.95mpg. Glow plugs are fairly new, everything else ok. Engine always started in FL without any preheat cycle just like a gas motor. Got back to AZ and had a no start last week when it was cold... Moral of story, old, cold, diesels don't start so good at high altitude.
I sure do appreciate the feedback. However, I guess I expected a diesel to start with the fuel that may already exist in the cylinders or in the fuel line past the filter. Heck, compressing it at what 20-1 can get it up to the needed temp real quick. Markbuck, good point on the piston shrinkage and loss in compression... hadn't thought of that. But My question was the plugging of the fuel filter with the engine running as you are cruising down the highway in negative 25 degrees of good old northern Illinois (for you bigfur... only said I visited Minn. Did not say I lived there. Could never get used to the purple gang.) Kcram, sounds like you have the answer as far as Dodge goes. I am surprised that none of the dealers down here know of the heater in the fuel pump. Also where do you operate your diesel? 0 to 20 is pretty typical for northern Ill where I'll be driving. Markbuck may be right. It looks like a V10 (with the lousy milage) may be the better option.
quality, fuel and air filters, and engine oil", also applies to gas engines. Take care of your ride, and it will take care of you.
Diesels are a little more sensitive with some of that, though. We don't have dual batteries for nothing - though we don't have spark wires to go bad
Just got my Ram back from the dealer a few minutes ago. All 4 filters swapped (fuel, air, oil, auto trans), fresh oil, trans fluid, t-case fluid, and diff fluid, new fan belt (I'm at 40K miles - I don't wait for it - ever), and an idle adjustment. It was down about 100-150 rpm - on a low rpm diesel, that's a lot. It was even affecting other components because they weren't getting either fan belt speed or vacuum. Cranked the Cummins, shifted into D, and got nothing but "smoooooth".
diesel in the cylinder or in the lines won't start it. that 18:1 compression does get hot, but all your cylinder walls, piston, coolant, oil----if all this is at 0° F when you crank it, than all the heat produced from compression goes straight into all the metal and fluid around the cylinder, and the cylinder doesn't change much in temp at all. only with glow plugs and block heating does the cylinder get hot enough to start without overcranking in those kinds of temps.
You all are absolutely correct on routine maintenance. I typically follow the severe maintenance schedule for any vehicle I own. My main point is that I believe that if you use a diesel for mostly around town, everyday use, you probably will only get 150 to 200k before you have to do major engine work. This about the same as a gas motor. It seems that alot of potential/new diesel owners are expecting to go 500k miles on their diesel motor. While this is possible when using the truck on over the road type trips, I don't think a diesel motor will last much longer in everyday driving than a gas motor.
The great thing about owning a diesel is better fuel economy, the ability to run WFO for extended periods of time without worrying about melt down, and the lack of computerizaton (at least on my old 7.3) which can cause gremlins.
The down side is slower warm up (due to diesel's greater part throttle efficiency), big nasty oil changes every 2.5 to 3k miles, two batteries to replace about every 50,000 miles, and of course hard starting when cold. I'm on my 23rd glow plug, 2nd glow plug controller, and you know; glow plugs cost more and are tougher to replace than spark plugs. I'm gonna buy a new truck in the next several months and it's gonna run on gasoline.
Last point, I bet there will be a ton of powerstrokes for sale at about a 100k miles that have been run on SI type oil changed every 7,000 miles. I won't be buying one of those used diesels......
How does one know that the new powerstrokes or 24V cummins are "good" motors? Do we have to wait till they reach 150 to 250k miles of around town driving? Is it 'cuz you spend $4000 to $5000 extra?
I think I spent an extra $3K back then (1989) for my diesel but I rationalized that the extra money would pay back since I could go "500,000 miles on the diesel"? Well, now I selling before 200K miles cuz a well rebuilt diesel is about $5000, which is more than my truck is worth. Plus I want a 4wd
kind of like the engineer that builds a bridge that falls down in 10 yrs. it was pretty damn good bridge.... that first 10 years.
Ran wholesale prices on Edmuinds and Kelley for my truck, and came up almost even. Edmunds said $21,185, Kelley said $22-even. This is after 30 months from a sticker price of $34K, or about 65%. I figure in 5 more years, I should be able to get $14-$15K for it in trade.
Then again, you still can't beat the feel of a diesel.
had a burnt piston replaced at 9000 miles and has
been burning/using oil (in my opinion) ever since. I know that it is leaking because my solid white cat now has black spots! It is also smoking a lot more than it (or the others) did in the past and the clicking/chattering that indicated the piston problem in the first place is starting up again.
I have had 2 others ('93 & '97) that did not do
what this one is doing now. But, Chevrolet tells
me (because my dealer told them) that this is
"normal". I'm intentionally not putting how much
it is using until I hear what everyone else has experienced.
What is an acceptable level of oil consumption for this size truck/engine?
Please respond soon as I am considering going the lemon law process with this truck because of this and another problem it has been displaying since purchase.
Sorry to possibly ruin your day, but the only time my Cummins has been below "full" is when some debris jumped up and punched a hole in my oil filter. Otherwise, in 40K miles, however much has gone in, has come back out at the change. You should not accept ANY oil consumption in a diesel for the simple fact that the fuel itself is also an oil, and actually helps lube the upper cylinder when the engine is at operating temperature.
Get an oil analysis at your next change - depending on what could be in your oil, you may have a claim of a bad engine.
Thanks for the reply. I also didn't think it should be using ANY oil! I also didn't think it should have a burnt piston at 9000 miles either. But it did and now I am beginning to believe that it has a scarred cylinder wall, too. Why else would it be leaking, burning, and chattering more than what I consider normal? It is using 1 1/2 to 2 quarts of oil every 1000 to 1200 miles. At first the service manager tried to tell us that it would use 1/2 to 1 quart every 500 miles when pulling a load. When we told him we haven't pulled anything in 5 months (~8000 miles) he changed to "it will use a little over a quart in 1000 miles."
I guess I should have learned my lesson with the '97 Chevy and bought something else. Chevrolet repurchased it because of a chassis problem and a rear end problem, not because of the engine, though. What really irritates me with them is that even though this is the third of these engines I've had, they are trying to tell me that this is "normal".
If anyone has experience in this regard, I would greatly appreciate the input. If this topic has been previously discussed, please let me know which discussion group to check.
Being new to this, I'm not sure if this is the correct discussion group to ask this question. If not, I'll gladly go to the appropriate one.
IMO, i don't think you will destroy your diesel, you just won't get as good mileage. but you're not burning much fuel anyway.
as far as warming up, i would let the truck idle a minute or 2 in the morning to get the oil flowing good, no matter how far you had to drive.
I had asked a similar question on the SD site 2-3 weeks ago. No one responded and I am very concerned about proper handling/warm up in the cool and cold mornings. The engine does sound better, atleast it seems that way, after the engine pushes up the temp gauge. I really do not like jumping in the truck and drive it away after only 30-60 sec of idle time even if I baby the speed down the road for a mile or so. What do you or anyone else think?
Mroffshore
I KNOW this will hurt your engine (diesel or gasoline), IF it does not reach operating temperature. My wife's mazda 626 got driven a total of 1.2 miles per day, 6 tenths of a mile to work and 6 tenths home. The problem is the engine never heats up evenly and then is allowed to cool. Therefore causing some of the bolts to the head to expand and contact properly, whereas some did not. Needless to say, the head gasket had to be replaced every ten thousand miles. My wife would never warm it up before driving it, "I was late for work" or "I just wanted to get home".
In Texas summer heat, you won't have any problems getting the engine up to snuff. On the occasional cool days in the winter, you can use thge engine block heater below +40 degrees, or you can idle for approximately 60 seconds at 1000 rpm before driving off.
the coldest it ever gets around here is the high 20's, low 30's. on those mornings, i'll let the truck idle for at least 10 minutes. the engine will never come up to operating temp idling, but it will get the oil flowing good before you actually start driving and stressing the engine. for 30 and below, it takes a long time for an 5 quarts of oil and 2 1/2 gallons of water at 30° to warm up to even 100 or above. then it still needs to get to about 200. for my truck (on a cold morning), i'll let it idle for 5 to 10 minutes. then, when i actually start driving, and i know my engine is warmed up, because it only takes another minute or 2 of driving for the water temp to come up to normal.
I'm pretty conservative, and maybe i baby the engine too much, but if I were ya'll, I would let the truck idle a little longer in the morning, and baby it for the first mile or so, see how long it takes to get up to operating temp when you drive. once your water temp gets there, your oil temp shouldn't be too far behind.
for your diesel, i would give several minutes in very cold weather, no matter how far you had to go. as far as the head problems mentioned, i've never heard of that, but letting your engine get warm enough so that the thermostats open at some point on the commute should alleviate that problem from ever happening.
If you are worried about the combustion of your diesel in colder weather, or damage to the upper engine, there really is no danger. once a cold engine is running smoothly, the only worry is getting the proper lubrication. the only thing bad about driving a cold engine, from a fuel standpoint, is that engines get lower efficiencies when they are not at operating temps, (also some losse due to cold oil in the tranny and rear axle). if you hopped you your truck and drove one mile every day without letting it warm up, you would probably get 3 or 4 mpg worse than if you let it get up to full operating temp and drive it.
if i missed any thing, let me know. hope i helped.
Thanks for the info! I just do not know enough about diesel engines and I certainly do not want to mess it up mechanically. I also heard that you really can't warm a diesel up fully by just idling. But a short idle as you mentioned will get the lubrication going.
Mroffshore
All motors should be routinely driven until their oil temp is higher than the boiling point of water to drive off the water formed during combustion. If not, you get acids and corrosion in the motor. Bad for long life
A friend of mine has a '93 Ford F-350 with a 7.3 non turbo diesel. If the vehicle sets for a week or so without any use, he finds it won't start unless he uses starter fluid to get it going. He has installed a new fuel pump but this has not resolved the problem. Someone suggested installing an electric fuel pump. Could one of you enlighten me on what the best approach would be to solve this problem. You guys seem to be up to date on most problems and sure would appreciate your input.
Rexallen
Check glow plugs for continuity - easy test with battery powered probe light or ohmmeter.
How many miles? Injection pump ok? ....
Pull the fuel filter sometime after a week. If it is full of fuel you don't have a problem with the fuel pump.
Why not take it to a real diesel mechanic?
Greg
best guess from info given is that fuel is bleeding off somewhere. the fuel pump is getting air in it. diesel fuel pumps don't like air. it brings them to their knees. either somewhere between the fuel tank and the fuel pump, fuel is bleeding off and air is getting in the line and into the pump, air locking the entire system.
