Diesel vs. Gasoline
I have the '99 F-250 SD, 7.3L and 3.73 rear end. My mileage on a recent trip (LA to Reno) was 19. In typical LA traffic it ranges 16.25 to 17.5. The truck weighs 7060 with a full tank, cross bed tool box an me (230).
speedster121,
My truck is limited to about 91 MPH by the Ford computer. At 70 MPH the engine is turning about 2050 RPM. There's still another 1500 or so to go before the red line.
Rich
Considering all else as equal (rear end ratio, tranny, approximately the same size pickup, etc) what would my speed be when topping a long pass, such as the Grapevine or Dunsmere hill, while pulling my 7K lb 5th wheel with a; the new Ford V10, the PS, the Dodge V-10 and the Cummings?
I have heard all the drill on torque v horsepower and all but the bottom line for me is, how much faster could I top the hill with one of the above engines as compared to my present F250 Super cab, 5spd, 460?
Dodge V10
Ford PS
Your 460
Cummings (close on the tail of your 460)
new Ford V10
Burn the least fuel during same run
Cummings
Ford PS
Ford V10
Your 460
Dodge V10
Go ahead, rip me!
Diesels are penalized by not being able to run gas motors 14.7:1 air/fuel ratio, more like 20 to 25 to one, they smoke really bad below that.
Dodge 8.0L
Ford PS 7.3L + turbo boost - diesel penalty
Ford 7.5L (460)
Cummings 5.9L + turbo boost - penalty
Ford 6.8L (v-10)
I think the diesels will out perform the gas engines. Diesels run leaner but produce more power(btu's) per gallon. This should start it going!!
Markbuck's fuel usage rankings is what I would guess. I just took a 225 mile trip running empty this morning and averaged 11.7 mpg with the mph close to 70 most of the time. Remember that I have the 4.30 axle ratio and dually 4x4 with my Ford V-10.
my 28 ft fifth wheel.
better power with PSD.
better economy with cummins.
better truck with ford.
longer engine life and better rebuild's with cummins.
Crew cab with ford.
Dealer service - only you know
your call....
Had a '89 7.3 non turbo in a F350 2wd. Same rear end in both 3.55.
460 would out pull the 7.3 any day of the week.
7.3 would beat the 460 on fuel even downhill off a cliff.
Dodge's new Cummins ETH 245 HP 505 ft lbs
Are going to add a new twist to this topic!!!! never mind GM's adding an Allison 1000 auto and 6spd to match the Cummins 6 spd. Cant wait for these drivetrains to be available
wildman
http://www.62-65-dieselpage.com/news5.htm
Want a Ford get in line.
I wanted a Dodge but I bought a Ford. The vibration on the throttle pedal was really annoying and the IDIOTS at Chrysler discontinued the crew cab.
My Powerstroke pulles my 10,500 pound boat and gets 14.2 mpg while doing it.
My buddie has a 96 Cummins with 291,000 miles on it and has only had to replace 2 trannys. He loves it but it is not for me and it won't suit my needs.
Diesel is a labor of love. You like them or you don't. Remember it must "work for you"
what top speeds can be expected from the following combos;
psd+f350sddrw
psd+f250sd
v10+f350sddrw
v10+f250sd
cummins+3500
cummins+2500
v10+3500
v10+2500
all 2wd and assuming whichever gear ratio is best for flat speed. by the way, which ratio would that be?
abrams
Dodge V10 makes the most power.
The things don't handle that well above 100 anyway.
Buy a LS1 Camaro or a Suzuki Hayasuba if you wanna go fast. Camaro good to round 160, Suzuki good to close to 200. Both alot cheaper than a truck.
Wildman
i also asked about the top speeds of the diesels and about which axel ratio is best for quickness.
abrams
Of course, that is all out the window if the vehicle is governed. I've heard the Superduty with the PSD is governed to have a top speed in the 90s. I don't know about the V-10. I've not had mine above mid 80s. I'm sure you can do 90 with either axle ratio, but you will be pulling more rpms at the same speed with the lower one. I've got the 4.30 with my V-10, and I'm generating about 2,400 rpms at 70mph.
Still don't know why top speed on a diesel is important. Kinda like wanting to know how many bushels of manure a corvette can fit in the trunk.
Both have towed only a Lance camper and once in a while a jeep too. Anyone got any info regarding these torque converters?? as I have a V10 on order now and was going to switch to diesel, but Now I don't know. helppppp!
I have had my PS up past 95 several times (speedo limit) & is still pulling I suspect it goes to atleast 100. but that is really true comparing a corvette with how many tons of horse manure it will carry. I didnt get it to go fast just to be able to go the freeway speeds with a big load which it does very good.
Wildman
Well, some of this is just the ego stroking, image conscious factors at play with some buyers. I mean, personally, I'd be embarrassed if every time I pulled along side of someone, they rolled their windows up and held their noses. I had to shout at the drive-in window to be heard over that clattering diesel behind me. But some people like showing off. Some hither, others yon.
Wildman
Wildman, I consider the V-10 a powerhouse just for the fact I'm ordering one. Just kidding. I do think it's a powerhouse just for the fact you stated. The darn engine is almost never in anything under 7000 pounds, motorhomes,Super Dutys etc. I just think it's too hard to live with a diesel for four years to see a return.
It's true that to get your money back for the cost of the diesel in fuel saving would take appox. 100K miles. But it sounds like you'll be towing a trailer most of the time. I would think the diesel would drop fewer mpg's under a heavy load (trailer and equipment in the bed) than the V10, and that would mean even more of a savings in fuel! Plus, with the V10 towing a heavy load, you'll spend more time at the pump.
One thing to keep in mind if you go to the diesel. If you make a lot of short runs (between work sights) where the engine doesn't have time to completely warm up, then you might be better off with the V10. This kind of driving is hard on a diesel.
Has for the smell of the fumes at a stop light... Funny, I don't seem to smell a thing when in my truck...
Brett
But comparing the sound, either one, 24V or PSD sounds loud at idle. But when it takes off, the 24V takes on a quieter, mellow tone, where the PSD just gets raucous, or so it seems to me.
as I have said before if you like a diesel buy it you will like it more, if not stick with gas (Ford increased the HP on the V10 for 2000) Buy what you like and drive it. I don't mind the guy who has to roll up his window when he is next to my exhaust. (why did he buy a car that is so low to the ground?)
T4F
I haven't been into stoplight racing in 30 years so the acceleration factor is unimportant. I've had 3 daily drivers that were and are diesel. Once you own one and drive it you'll never go back to gasoline. The torque is awesome and makes the LA commute easy. (Not fun, but easy.)
Originally I fell into the mileage thing and bought the first diesel. (6.9L in an F-250) At the same time a co-worker bought the 460 gasoline. After comparing mileage for the first few tank fulls, we both lost interest. Yes, the diesel does better, but so what. If you want to do some stop light racing you buy gasoline power.
It seems that the diesel vs. gasoline debate has as much emotion as the Chevy/Dodge/Ford debate. If you don't like diesel, I hope that you enjoy driving your gasoline vehicle as much as I enjoy my diesel.
Rich
Happy test drive
