Visitor Agreement.
Chris
Scroll through other conferences for fuel mileage.
Most people I've seen are getting anywhere from 17
to 22 mpg with the Dodge/Cummins 24v, and from 9 to 12 with the Dodge 488cu in V-10. The torque readings are really close between the two.
I'm sure you know that gas engines pollute with hydrocarbons and carbon monoxide also.
If you are in a hurry to get to speed gasoline, if you want to tow and get better mileage then diesel might warrent another look.
For what it is worth, the state people thought the Ford and Dodge turbo diesels were the best available. And they really had no clear choice.
The V10 can do the job just as well, just at a higher rpm...
There are a few important factors.
Compression ratio: The higher the C.R. the more heat. A diesel engine is a 'heat' engine. It uses heat developed from the compression af air. A high C.R. equals a greater expansion of the gases following ignition and a higher percent of the fuel's energy is converted to power.
Injection system: Diesels are designed using the injection of fuel at the last moment to ignite the compressed air.
Fuel differences: A gas engine always uses about a 14:1 air to fuel ratio no matter at idle or full throttle. A diesel has fuel injected near the top of the piston's stroke in an amount corresponding to the load on the engine. At idle the ratio might be as high as 100:1 (very little fuel), however at full load it can be 25:1 or 30:1. This is still less fuel than a gas engine. Diesel=m.p.g. The fuel pump system and all the electronics decide how much fuel to use.
Fuel BTU's: Diesel fuel has a higher btu rating than gas (130,000btu for diesel to 117000btu for gas per gallon) hence diesel fuel has more 'power'.
BTW-The diesel was designed and patented in 1892 by Rudolf Diesel.
Think of those little toy pin-wheels, and you are holding it in front of a fan. the fan is blowing and spinning the pinwheel one direction and you will use your finger to turn it the other way.
a gas engine is analgous to you tapping the pinwheel with your fingers, pushing it in the opposite direction its being blown. after each time you tap it, it turns the other direction, but the fan blowing it the other way quickly turns it.
a diesel is analgous to you turning the pinwheel with your finger, never lifting your finger off of it. you cannot turn the pinwheel as fast, as tapping it, but no matter how much wind the fan is blowing, you can steadliy turn it the other way.
Take one for a test drive...
Below is a press release taken off the Gale Banks Site RE: diesels for light duty Ford vehicles.
"Navistar International Corp. said it is negotiating an extended term agreement with Ford motor Company to supply diesels for selected Ford trucks under 8500 lb. gvw, as well as for sport utilitiy vehicles. Navistar currently supplies 7.3L diesel to Ford for it's F-series and Econoline vans as part of a 1981 agreement that was recently extended through 2013"
Still nothing official on the Cat in the GM . . .
Sorry the URL is:
http://www.dieselpage.com/articles.htm
the cat engine in the big ford's that your link went to is not that big a deal. cats are in practically every different brand of 2 ton and larger truck out there. The Cat 3116 has been in the 2 ton chevys for about 5 years now. those trucks are actually the best selling truck worldwide. ( a couple years ago, chevy sold over 1 million two tons alone, not counting GMCs, the majority of them with the cat engine.)
Cat would give the new pickups the same heavy duty image as Dodge, and while the Isuzu is a decent midrange diesel engine, there's no "American TRUCK" image with it.
By the way, if 10 cylinders provide more hp and torque than a V-8, while sucking up less gasoline, can the V-12 be very far off? Doesn't Ford have a V-12 in their experimental truck, the Powerforce?
The operating costs are extremely variant depending on where in the country you are and how you drive. I'm getting an honest 50% better mileage with my Cummins than my gasoline Fords, and I pay 99 cents for diesel, same price as reg unleaded, so I make out in that regard. It's true, if the fuel costs neutralize the economy savings, then a diesel is probaably unnecessary.
mharde and Brutus,
The 6 speed stick is currently due for the first quarter of 1999 for the Dodge/Cummins. Cummins had made it clear they are prepared for an immediate power increase from the current 235/460 rating. I agree that Dodge needs a tougher automatic.
don't tell too many people you can get diesel for that price, because folks around here would steal it from you.
regarding high torque auto trannies: parts in an automatic are much different than manual transimissions. manuals generally have solid steel gears throughout, which make them very tough. automatics have non metallic clutch packs, and those are what fail under the high heat and wear caused by high torque loads. they can make a trannies that absorb that kinda torque. but it would have to be very large and bulky, and hard to design a truck around. never fear. there are materials engineers making headways every day, and we are one breakthru away from some supermaterial that will make everyone's auto tranny last forever.
brutus
i don't think the powerforce had a v12 in it, but i think ford had some concept car that looked like an indy car that had a v12 in it. if you go to v12s in trucks, you can't drop your inches per cylinder too much, or you lose torque, that any amount of cylinders can't make up for, if they are not big enough. 10 briggs and strattons aren't going to put out 400 ftlb of torque. you reach a certain point where the tradeoff goes the other way.
a poke at the ford v10s from a chevy-- the 454 has the same torque and 25 more hp than fords new v10, while getting low to mid teen fuel mileage. not good for ford if their brand new motor is still outrun by a 30 year old block with 6 year old technology.
Regardless, I'll take the Ford V-10 over a 454 anyday. The Ford V-10 is smoother running and more quiet. Like you said, the 454 technology is older. On the other hand, if GM makes their new V-10 like they make their V-8s, it should be one heck of an engine. The 350 and the 454 have done Chevy proud.
"No."
"Happy Father's Day to you, too!!!"
Meanwhile, everybody in the free world seems to get their jollies talking about these trucks as if they are actually a member of the family, just like dear old dad but they use gas instead of belching it out. I understand the select few that have monumental loads to pull, but when is everyone going to wake up and stop feeding these companies our hard-earned money for nothing? Trucks are now about as yuppified as cafe latte and bagels. Instead of "working", you're supposed to be able to go to the golf course and carry your buddy's autographed clubs with you. I really need a four-by to do that!!! GM, Ford, and Chrysler are doing what any company should do...exploit a gimmick. Even Toyota will sell a few T150s because of a gimmick, and eventually the gimmick will fade and we'll all be stuck with goofy-looking trucks again. Wow...pass the keys, Dad...
Is it safe to come out and play?
Well said rite3.
Heres the skinny on the PowerForce:
http://www.fordunleashed.com/Powerforce/Powerforce.htm
At the Chicago Auto Show, Ford Flexed its muscle with the new Ford Powerforce, a Triton V-10 powered four wheel drive Super Duty concept truck that literally towers over other pickups. Powerforce is longer, taller, wider, and has more interior space than any pickup on the road today.
The Powerforce, outfitted with Ford's high-performance Triton 6.8 liter V-10 over-head camshaft production engine, which delivers 265 horsepower at 4,250 rpm and 410 foot-pounds of torque at 2,750 rpm. It features an 8-foot cargo box and stands an impressive 81 inches tall on custom 19-inch two piece aluminum wheels and 35-inch off-road tires.
The monstrous Powerforce is planned to be Ford's 1999 heavy-duty F-350 workhorse pickup which will be on sale a year from now, minus a few of the innovative gadgets. The exhaust comes out through meaty chrome stacks behind the passenger cab, just like on a semi-truck. And the so called bull bars on the front look ready to knock down anything in the way. Power rotating running boards make entry and exit easy, even at Powerforce's height. Further more, a power lift tailgate aids in loading and unloading cargo. A remote key fob opens the tailgate and lowers it to ground level so large objects can be lifted to the bed.
cdean,
Not trying to make that particular Ford/Cat alliance a big deal just trying to keep another truck buyer from holding onto a false hope. Theres 2 great motors on the market currently and if your a diehard Chevy fan Chevy's got one. I too would love to see the Cat motor in a light truck, But who knows when and if that will be, or who the manufacturer will be. Only Cat knows...
A long time ago you said it would take 80,000 miles for the cost difference to be made up for the diesel. What was your calculation? I'd like to use it to determine if the diesel is better or not for my area (fuel price, etc).
Ryan
Then again, if you put all your fuel on a card with 18% interest...
All kidding aside though, point well made. The diesel is not the economical choice you might originally percieve it to be. In fact, with the addition of some headers, etc (Gale Banks type) you could bring the torque of the gas engine up to diesel levels (which we already know the transmission can handle) and still save money.
Hmm.
The shear joy of the torque! The diesel is so much easier to drive because of this. I could start in Grapevine, CA at zero MPH and crest the Tejon Pass at 85 without even trying. This was with the '92 7.3L and no turbo. The only things that would ever pass me were god old detroit cubic inches or $50,000 so called luxury cars.
There's nothing to go wrong in a diesel. On my '92, an alternator and auto trans (under wty) in 130k miles. The engine is so simple. (I don't know about the computer controlled '99 7.3L.) The diesel did not, not start. I've had a lot more problems with my wife's '91 H with 100K LESS miles.
I think that the economy issue is almost a break even at 100k miles when the increased trade in value is considered. My dealer said that he can move a 100K mile diesel much quicker than gasoline.
Rich
