Thanks for the circumference tip; I'd never have thought of that! But your 21K remark got me: are you saying that these stock Geolanders are borderline at 21K miles? Jeez, there looks like loads of tread left on them and I thought modern radial tires were good for at least 40K! Am I delusional or just dyslexic?
There are a lot of factors that influence tire wear. Since most tire wear occurs in cornering, the biggest factor is how often does a substantial turn occur. I use the term: Turns per Mile.
Obviously, driving in the city is going to be worse than driving in the country.
Other factors include the inflation pressure (more is better), alignment (toe in has the same effect as cornering), weather (rain and snow covered streets don't cause much wear), pavement, (some are more abrasive than others)
40K is a good figure for all season tires, but high performance tires won't get that much because grip and wear are trade-offs.
Just a quick update to thank those who assisted with my somewhat early brake wear on a 03 Forester. Turns out the warranty is different in Canada than U.S., and brakes pads are not covered at all here. But thanks for all the advice, because I pushed a little, and since there was a problem with the caliper slide pin, Subaru Canada is going to pay for all the parts; brakes and caliper-- a significant contribution, and more than I expected.
I am sure the stock Geos are fine at 21K (the ones on my wife's Forester looked great at 35K). The problem is that they are worn down more than the new (formerly spare) tire you rotated in, and that difference can cause problems with the AWD system.
Definitely measure all the tires to make sure the new one is within 1/4" circumference of the others. You can get a pretty good idea by measuring tread depth and using calculus:
C=2*PI*R --> dC=2*PI*dR
So if you know the difference in tread depth amongst the tires (dR) you can compute the difference in circumference (dC). Or go in reverse: for dC=0.25", dR would be about 0.040", so the tread depth of the new tire shouldn't be more than 0.040" (forty thousandths) greater than the old tires.
I agree with earlier posts -- the most economical thing to do would be to get the new tire shaved to match the old ones if there is indeed a disparity.
That is great news. The circumstances were strange all around, so it is good to SoC do the right thing. Out of curiosity, did anybody every explain how/why the pin broke upon removal?
Spoke to the dealer about replacing the timing belt and the water pump while repairing the head gaskets. They want $470 for the job, which seems to me to be a rip off considering that Subaru is paying for the labor under the warranty job. Will speak to them later again today to see if I can get it down somewhat. Any suggestions?
Yep, sounds like they are hitting you with pretty much full freight for this, without benefit that they are already in there. Granted there is some dedicated labor for the water pump, but the front cover is already off, as are the accessory drive belts. If they are only doing one head, they might not have the full cover off or completely removed the timing belt, but again, this is only a matter of a few extra fasteners.
I don't know what subi parts go for, but I would suspect that the belt and pump should be under the $150 mark, plus maybe an hours labor.
that is an unbelievable ripoff! the labor should be halved (or more) on the water pump because the timing belt is already off. it takes minutes to change the pump and gasket.. four bolts. the timing belt is like $50-70 at most, and there is NO labor or consumables that aren't covered by the warranty repairs on the headgasket.
the water pump is $67 from subaruparts.com, another $2 for a gasket... yeah I don't have a clue how they dreamt up this $470 nonsense. that's insulting.
Hi everyone. I've been lurking in the forum reading the great posts here. I'm an owner of a 1994 impreza L wagon w/ 95k. Runs super, but recently we have this intermittent whirring sound (which goes up in pitch during accel) usually in 1st and 2nd gear. We topped off the man trans fluid and the rear transaxle fluid, but that didn't help. Any thoughts, sorry if this sounds vague. Found a previous post that mentioned a sound like a top being wound, that would resemble our sound. btw, sounds like it's coming from the front end of the car. thanks - julie
Hi Steve, Yes, good news indeed. Shows that a little polite grumbling can be well worth the effort.
They had no explanation for the pin breaking, Steve. But it is only because of that pin that the service manager could persuade Subaru to cover the parts for the brake job.
I bought a 2004 Forester about 4 months ago. The car is driven almost every day, but there is only 2100 miles on it. My round trip drive to work is about 14 miles, with my round-trip to school about 5 miles, plus a few extra trips to shopping malls, the mountains, etc. Here's my problem: the car has been running fine; it sat on Thanksgiving. When I went to start it Friday night, it wouldn't start. My dad eventually got it started (after a few tries) and after that it was ok. i took it to a garage (not a dealer)--they told me the battery was good but needed to be charged. They put it on a charger for a few hours. I was told I need to drive more. The thing is, my driving habits have not changed for about 2 years now, and I have never had this problem before. Most people I've told this to have been skeptical of the "drive it more" response. This car does not sit days at a time, and it has not been cold here yet (I live in Philadelphia). Can anyone offer some insight? It sounds like a bad battery to me....I am worried about when it starts to get cold. i bought a new car so i would have a reliable vehicle. I've always heard good things about Subaru (and I owned one before). Nothing has changed about my driving habits--that's why I'm wondering if it's a dud battery. I'll stop rambling now. Any help would be appreciated. Oh, and thre are no after-market anythings on this car. It's the basic 2004 Forester X, no extras. Thanks.
What were the symptoms of it not starting -- was the engine cranking OK or was it clearly having trouble turning?? The reason I ask is that there are numerous reasons a car might have trouble starting, and people tend to blame the battery. If you have a hard time starting and have to crank it a lot, even a brand new battery will run down pretty quickly and need to be recharged. SO I would not jump to conclusions and blame the battery as the "cause" just yet!
Can you give us more details -- how did it behave when you first tried starting it and what did your dad do differently to get it started?
It would not surprise me if it was a fuel issue. I noticed that our Forester would have a hard time starting in the following situation: take a long trip, park the car for a day or two, and then try starting. This would occur if we got in and turned the key to start immediately. However, if I turned the key to on for a few seconds and waited for the fuel pump to pressurize the system (you will hear a whirring noise from the back of the car) then turned it to start, it would fire right up every time. So that became my habit.
In all those hard-start cases, you could smell fuel in the exhaust right after the car started, so I concluded that it was somehow flooding. And of course, if that is the case and you keep cranking the starter, it will start eventually but you will run the risk of running down your battery. I might wager that's what happened in your case. SO try letting the fuel pump pressurize the system for a few secinds before craking the engine over.
I tried it about 3 times, it would just crank and crank, but never turn over. My father just tried it a few more times, and after about 4 tries, he got it. My last car had that "hard start" problem, with the fuel smell and everything, but I didn't smell anything with this (though I wasn't in the car at the time). He said the lights , etc. did not dim like they usually do when a battery is going dead. This morning, it had a different sounding crank to it. when they checked the battery they said the computer came back with "Battery good. Needs charging." I have read some other posts, and it goes from everything like alternators to faulty wiring harnesses. I will try the method you described below to see if there is a difference. There is a woman named Cheryl on this board who seemes to have a similar problem. I am not irked about something on it breaking (cars are machines, they break). But I am more concerned about getting it fixed properly so I don't get stranded anywhere this winter. thank you for your help. I would appreciate any further thoughts.
SOHC is easy. DOHC is more challenging, but could be done by a skilled hobbyist.
I'd replace the water pump at the same time yes. It is less than $75 with gasket if you buy through one of the big parts wholesale dealerships on the web.
I've never owned the Geos so I'm not sure about how long they last. The Duelers on my Forester were only good for 28k miles.
Julie: my first guess is wheel bearings, because the pitch is speed dependent. Does it happen even when you are coasting? Could be the diffys but the bearings are more likely.
Bethany: the OE battery isn't very strong, I replaced mine with one with more than twice the CCA rating. It was $40 or 50 or so, so it might be worth just replacing it for the peice of mind.
Having said that my OE battery still lasted about 5 years.
Sounds like the same problem we had. Try the starting method I described, it's bullet proof in ym experience.
I agree with your dad that the lights would have been dim or the starter would have cranked very weakly from the get-go if the battery was the root cause. I think we can rule that out.
I wouldn't waste time with testing the starter or alternator; this clearly sounds like a case where it was cranking fine but not catching, and that is what ended up draining the battery.
Now if Bethany goes out to start the car and it barely cranks, then I would pursue looking at the alternator and battery. I'd only look at the starter if it made audibly sick mechanical noises or was seized up, or if it was apparent that the starter was not engaging the flywheel.
It did not make that painfully slow cranking noise where you know instantly something is wrong. I kept waiting for it to catch, and it just wouldn't. Is there something that should be replaced? Or will turning to "on" for a few seconds before ignition do the trick? Again, many thanks for all your help.
In my experience, that solves about 95% of the oddball starting issues people encounter with fuel injected cars. I definitely encountered the problem in several cars over the years (not just Subarus) and in all cases letting the fuel pump pressurize the system before cranking the starter remedied the problem. You should notice a difference immediately -- the car will start much faster.
Wow, you guys. Thank you so much. You've definitely given me some ideas on where to go. While it seems the original batteries are weak, I don't believe it is this weak, and it doesn't sound like a starter problem. I will try the fuel pump thing next time I drive it. I guess if cranking and cranking drains the battery, and then I drive a half mile to the garage, that could explain the battery needed a boost. Again, thank you. If that doesn't do it, I at least have a direction to look in.
Good Morning All! Here's an "opportunity" . . . we've gotten spoiled by the interior light in our '96 Jeep Grand Cherokee staying on until the engine is started. In contrast, the light in our '03 Forester begins going out after, what - 5 seconds? For one of the drivers in our family, that's just not long enough to get things settled and the key inserted while there's still some light in the cabin. Has anyone else out there considered this a nagging situation and figured out how to increase the "light on" time? Oh, and I have put one of those small LED lights on the keychain. That helps. Have a great Day, Lee
No solution, but some support: I have the same complaint about the interior light in my '04 Impreza. Goes out so fast that you really have to be quick on the draw to get that key into the (unlighted) ignition before you find yourself sitting in the dark. It's an extra step, but turning on the map light by hand would provide enough light to see to put the key in.
That's funny....I have had my Forester for a few months and the only complaint I have is the lack of interior lighting. I too find the light goes off too soon so I have to either open the door or turn on the map light....also don't like that the interior lights do not automatically go on when I shut off the car. I had this feature in my last car and it was great to be able to see to get your things gathered up.I actually tried to look up in the manual how to "activate" this feature.....only to find out that it doesn't seem to have it. Other then this (and it is minor), I really like the car.
I'm having a little trouble with my automatic transmission in my '99 outback, and would appreciate any suggestions. When I put it in "drive", I have to tap the gas slightly to get it into gear. It only happens in "drive", "reverse" works just fine. I thought it might be low transmission fluid, so I checked the level and it was low, but the problem persisted after adding fluid. Any ideas or do i need to find a mechanic?
I took delivery of a 2005 Impreza Outback Sport SE a liitle over a month ago. This replaced a '98 OBL with 160,000 miles. While I love the little Outback Sport, I'm a little upset at how easily the paint chips. I must have 2-3 around the car already, after only 1500 miles! My wife has a 2002 Forrester, and this too chips MUCH easier than my '98 OB ever did. Any reason for this besides the fact the Leagacy is made in US, and Impeza/Forrester is from Japan?
An assembly called the 'valve body' takes all of the commands (shift selector, computer, etc.) and directs fluid to all of the main moving parts. The fluid acts as both the lubricant and the 'drive' media. If it gets gummy, particularly from lack of changing, overheating, etc., these little valves can stick and not direct fluid crisply when you select a gear. Increasing the engine RPM increases the operating pressure, nudging things into place.
To begin with, try changing the fluid. Problem with doing it yourself is that you can only gain access to about 50% of the total contents without going to some elaborate (and possibly risky and messy means). I have heard of some success stories about having one of the shops do it that has one of those recirculator that flushes out everything. Some even have a light duty solvent that can clean out the varnish that is probably causing parts to not move freely.
Let us know how this works out. We need the feedback as a data point!!!!
Has anyone here purchased and/or used an OBD II reader or scanner? I would be interested in hearing about your experiences and recommendations, especially if you have used it on Subarus.
Well, I somewhat unintentionally redid my 'wash and store' trick, and it again locked up my disks.
We were away for 7 days over the holiday, and my OBW spent the week in a parking lot near where I picked up a rental to drive the family to the airport. About 5 miles away, we went thru an automated car wash, but everything appeared dry by the time we left it. Upon return, all 4 rotors were well brown. What I would have expected from a month of non-use, not a week. Got in, put her in gear and the tach hit close to 2k before a sharp "thump!" and the car shot forward. It is of course pulsing badly, as it will for probably a week until everything is shaved flat again.
Again, it isn't anything terrible, just consistently very odd. Never had brake pads that 'welded' themselves into place like these do.
I like the auto-off feature too. Juice, can you explain what do you mean by parking lights? I do not know what that feature is?
The features that would have been cool but not required are: (1) If the glass part of the hatch could be opened without opening the whole door. (2) If the hatch could open (not unlock) with the remote.
I have a 2001 Subaru Forester that has a dim driver's headlight and the bright indicator is dimly lit. After the car warms up, sometimes the bright indicator goes out and the light goes back to full strength. I read that this may be a bad ground, and if I have to replace the wiring to the headlight, does anyone know what part do I need to order? Any other thoughts as to what this may be? Thanks.
My '01 Forester got paint chips pitted out all over it, particularly on the hood. When I got my '04 Forester, I made sure to get the acrylic hood protector immediately and after 6 months and 9K miles, I don't have a single chip. *whew* I recommend the hood protector and a good coat of wax and a bottle of touch up paint. elissa
I've recently learned that EPA requirements have changed paints on modern U.S. manufactured cars, making them harder but more brittle. They're better at fending off things like acid rain and environmental fallout, but, unforunately, more susceptible to stone chips.
The Europeans are still using high VOC formulations less friendly to the environment, resulting in paint much softer and more resistant to chips. Rumor has it that MB is about to change their paint, though, going with a unique formulation that is supposedly harder than anything on the market right now.
I'm not sure what regulations affect Japanese, Canadian, and Mexican built vehicles. My guess is that they use the same formulations as their counterpart U.S. built vehicles.
Mercedes is using that new paint formulation on 2005 models. My father bought an '05 SLK so I'm waiting to see how resistant the paint is to damage.
My last three cars, one German and two Japanese dating back to MY 2000, have had paint that chipped easily. When I got my Impreza I had the clear paint protection film applied to the front bumper and leading 12" of the hood. Best investment I ever made. There are a few small nicks in the film but overall after 14 months on the road the front end looks almost new.
While rare, it is possible to have a bulb with an internal short. So you might try swapping bulbs first to make sure that it is the wiring and not the bulb.
Assuming bulbs are OK, inspect the bulb connector for signs of rust or frayed wires. Plug and unplug a few times to see if it improves the situation.
From here it can get tricky, depending on how the system is wired - what 'logic' it uses. Forester is a single bulb per side system? Then the bulb and connector has 3 wires. Some systems control power at the column switch and have a ground near the headlights, some control the ground and have 12v routed to the lights all of the time. A volt meter is your best friend in understanding how the system works and what might be wrong.
Parking lights switch is on the top of the steering column. They leave the lights on but at a very dim setting. So if you park in pitch darkness and want to be able to find your car, you can leave them on for a while without killing your battery.
My paint has held up pretty well for a '98. My little nephew once decided to "draw" on my paint with his toy Power Ranger and the white marks polished right out.
Solvents are gone and newer paints are water based, I definitely think they're less durable than before.
Well I took it in and ad a full transmission flush done. The guys said it was long overdue due to the fact that the fluid that was in the tranny was black like motor oil, while when it's new it's bright red. the problem is still there, it still lags when i put it in drive although not quite as bad. i probly just waited too long to change out the tranny fluid. I'm not sure that he paid a whole lot of attention to the valve body but he did mention that there is probably a "varnish" on it that is causing part of the problem. Unless you have another suggestion, i'll probly have to take it in again and have him focus on the valve body. I really appreciate the tip, thanks again.
Brent
Hope this helps.
Craig
Steve
Steve
~Colin
Steve
Cheers Pat.
I trying to decide whether to let the dealer do it or tackle it myself.
Also, what are the other things to replace at the same time...water pump?
Thx,
Jim
Craig
Bethany
~Colin
-juice
Craig
Bethany
I agree that you should be able to rely on it to start every time.
-juice
Craig
Craig
I always prime the fuel pump, it's part of my morning ritual. Keys in, turn and listen for the "whirr", then start it up.
It's amazing how much pressure fuel pumps operate under with modern fuel injection.
-juice
Thank you so much.
Craig
Have a great Day,
Lee
You could just leave the door slightly open until you start it, also.
-juice (always in search of the simplest solution)
* the lights fade out gradually
* parking lights
* auto-off headlights (keys removed)
I miss those when I drive other cars.
-juice
Ryan
Steve
Thanks for the input. It sounds like i'll have to take it somewhere but i'll look at it and let you know what I find. Thanks again for the input.
Steve
elissa
Steve
-juice
Ryan
