I would replace the belt and change the tires if you are planning to resell the vehicle yourself. The vehicle will be much easier to sell with those items done. However if you are trading the vehicle to a dealer there may be a lot less of a reason to replace them.
~Colin
Just my .02.
Mark
I bet mine is in worse shape, I have 83k miles on my '98. But it's 9 years old, while yours is just 3 years old.
-juice
Inspect the other belts to be safe. Do you see any cracking? Is the tension still OK? Do you hear any squeeking? If you notice wear on those accessory belts, go ahead and change all of them.
-juice
I first changed my timing belt ('96 2.5L) at 83.6K in August of 2000 when I bought it (I had put about 60 miles on the car at the time). The car was 5 years old and, other than all of the timing marks being fairly well faded from the outside of the belt, was in excellent condition. No drying, no cracks, etc. Keep in mind that I am the 4th owner of the car and it had many..... issues.... that presented themselves within a week after buying it, so I think it probably was not well loved in at least one of its previous lives. I purchased it in Pasco, WA, but it was first sold in Anchorage, AK (to give you a rough idea of the climates to which it was subjected). I next replaced the belt at 144K and again, it looked perfect aside from being well oiled (won't go into it!). I next replaced it at 192.5K and again, looked perfect. I have to replace my other belts once every two years at most and they look very worn when I change them out, so the timing belt does not suffer from the temperature extremes as much as the others. In fact, I always keep the prior belt as a "just in case" spare in the event that I have to work on the engine on the fly and somehow damage the current belt if I had not planned to replace it. Silly I know, but I really do have to dig into it that often! Hahah.... :sick:
Take the above for what it is worth. But, if you are going to sell it yourself, you should consider that if you leave it for someone else then that cost will likely come off sale price so you are paying for it one way or the other. The best option would be a weekend project - all the benefit and none (well, almost none) of the cost!
I would love to hear any info on the problem. (transmission losing gear at a stop, slipping into neutral, sometimes regaining it, if switched into third gear, sometimes if engine revved and then the car lurches forward, never a problem with reversing...)
Please help!
This looks like it could be the end of the road for Subaru and me.
Unfortunately, a lot of people don't do this and by the time they take it in the transmission has pretty serious damage.
~Colin
Eric
Dave
Eric
There has been a lot of discussion on Subaru piston slap in general in these pages recently. To find those posts go to the top or bottom of this page where it says "search this discussion". If my impression is accurate, there are mixed results on the success of piston replacement.
Sometimes the problem developes again. I think that's because the problem slap isn't necessarily merely due to the pistons themselves but also how they are situated and how they interact with the components around them.
If you search this site I think you'll find a description of that, which may or may not make sense to you depending upon how much you know about Subaru engines. In any case, you are probably stuck with the piston replacement but you certainly want to be watching for signs that the problem is recurring, keeping the expiration date of your warranty in mind.
Good luck, ~Cath
Karl
Looking at the slip, it looks like they ordered all 4 pistons, but only replaced the driver's side pistons since only the cylinder head gasket on the driver's side was replaced. I'm assuming they decided those were the only ones it needed. That was certainly the side the noise was coming from.
It's been 3000 miles since the job and the car hasn't sounded this good in 2+ years.
It's funny - for all the fight some of the dealers put up doing it, the warranty bill was only $1760.00 USD. Car was out of service for just one day.
HTH
Larry
I had the pistons swapped in my 98 Forester and it fixed the slap for good.
Ken
Dave
Ken
Car now has 64 k and tha slap is back but no nearly as loud.
My dealer tells me now that there is nothing he can do about it .
NO future repairs are authorized . He says live with it or trade it .
Going the SOA route now .
Mike K
Given what I've seen, and read about, its not destructive, but if you are selling the car to someone whose not familiar with Subarus, the engine sounds like a train wreck waiting to happen.
At that, its still no fun listening to that noise all the time, either.
Larry
Depending on whether you want to keep the car and how close you are to the expiration of the original Mfr's warranty you may want to consider getting an extended Mfr's / Subaru "Assurance Plan" before it's too late. If you lived in the states I could tell you the best place to get up to 40% off of MSRP but I'll bet if you do your internet research and call around you can find a decent discount.
~Cath
Is it a major defect -- expensive like cracked heads, new transmission, or something like that?
Is there anything I should be cautious of before buying -- manufacture dates, etc.?
Even then, from what I've read and heard, the slap does not seem to cause any serious damage to the engine. Someone here posted that they actually looked into their engine while it was being worked on for piston slap and the cylinder inside was fine. I've also had the same unique experience of being able to see my 1998 Forester's engine apart at the dealer and the mechanic said the cylinder walls looked new, intact with the original honing.
So, don't worry. The odds are very much in your favor that you'll be getting a very reliable vehicle.
Ken
Do you have any ideas what the problem might be now?
Thanks for your help!
Shannon
See post #6368
That's not a joke, there is a screw next to the radiator cap, when you open it, it bleeds out any air pockets in the cooling system.
Basically, the system does this and might be sucking in more coolant to compensate.
If you're not familiar with cooling systems, have a mechanic do it for you. I've done this myself, so it's not hard or anything.
When all this is done, mark the level of the coolant in the reservoir. Then drive it and check the level. A slight drop is OK, but if it keeps dropping then maybe the gaskets are still not sealing properly.
-juice
Oddly, I thought I would have cured my car's oil use problems when I re-sealed the whole thing back at 192.5K, but here I am over 10K later and I still need to add a 1/2 quart every 300 miles. There are no leaks, though! I have not seen that engine stay so clean for so long! *shakes his head*
Only this time, something else happened... The brake pedal at first felt overly hard, then sank almost to the carpet! I pumped it a few times and it recovered. I did a few slow speed stops and it made the typical corroded rotor grind, but seemed to stop OK. A booster problem, perhaps? I preceeded to work with care, but everything seemed fairly normal.
On the way home with the windows open I could hear a bit of a metallic scraping sound. I assumed it was the wear sensor. Side loads would make it happen, as would mild braking. But with slightly harder braking, all was reasonably quiet, but the brakes felt weak.
I know they are getting thin, and have new PowerSlot rotors and Hawk pads sitting waiting for a free moment to get installed. The need just got accelerated to first priority - parked until then. When I got home and opened the garage door, there sitting on the floor was a brake pad!!! Apparently, it was sooooo welded in place today, that about 3/4 of the friction material ripped off of the backing plate and was spit out!
That is a first for me folks....
Steve
Never heard of that happening before. Glad you caught it before anything serious happened.
Ken
I am hoping this abates as the rings break in. Really hoping. :P
Larry
~Colin
I wonder if it is possible to pull the pistons out the bottom of the engine without having to pull the heads...
Happened to me too about a year ago . Car sat for a week and when I got back in needed to give gas to let it go and bang them scrapping . Found the pad on the ground were the car sat . 02 outback with 64 k miles .
Mike K
Len
My 99 Legacy GT threw a back shoe at 85k. Was the original and pretty thin at that point. Rob M.
Is this a bad bulb or an earth problem? How do I get the turn signal out? I can see screws on top, but cannot budge the signal when I have removed the ones that I can see.
John
I'd start with checking the roof rack (if installed) to see if its mounted correctly. Specifically the cross bars need to be mounted fat part forward ala an aircraft wing.
Also check the windows for proper sealing ...
Are there any "signs" to watch out for with the timing belt?
Also, a common 'complaint' (I LOVE my car :shades: , just a pesky thing sometimes) is that the 4 cylinder upshifts too much and searches for the highest gear. This seems to be getting worse as the car ages. When driving around 40-45 mph, the car insists on having RPMs under 2k, I sometimes manually shift the automatic to a lower gear. Anything the dealership can do or is this just a Subie thing?
