Where did you get your touch-up paint? After less than 3 months, I already have a chip on the hood - probably from a rock. (And I have the deflector!) I sent an email to Darlene to see about buying some paint, but that was before I knew about her employment situation. If you know of another good source, I'd appreciate the info. I seem to remember years ago getting a little bottle with a Dodge I bought (talk about young & foolish!) and it was like a nail polish bottle. Is that how Subaru's is?
Cin
You should be able to buy touch-up paint from any dealer. Touch-up paint isn't too expensive -- something like $8 for a bottle. It's good to have a set around.
Ken
Cheers Pat.
It is Service program WXW-80.
It says for me to immediately contact my Subaru Dealer to replace the sensor at no cost to me.
I seem to remember people having trouble with this sensor though I have been lucky not to have had any trouble with the sensor.
Just thought you might like to hear about this...
~~~Pat
The Dealer replaced my woodgrain piece around the shifter today at no charge of course. But they gave my wife so much bull dropplings about the key. The 4.95 is the cutting charge for cutting the key. So the key itself cost 18 dollars. The service guy said they charge more than the other Bay Area Dealers because they use the new machine that makes the key specifically for your car. Basically the machine that uses the code. He said other dealers still use the old duplicating key machines. Now that has to be the biggest bunch of Bull Dropplings I have heard. It upsets me that they take advantage of people this way. Well, now I know to call Dealers and ask for the price before I go there for service.
Patti, it is not the money for the key. It is the principle. And I really would like to complain to SOA for this. Absolutely, insane that this dealer can charge double for the same service another dealer can do. There should be a limit! If anyone has the customer care number for Subaru please post it. I will call! Thanks
The link is at the bottom of the page but just in case you don't care to go there here it is:
1-800-SUBARU3
bit
Just curious, have you priced keys at other dealerships? When I buy from a dealer, I know I'll be paying a premium so I avoid them whenever possible for periodic maintenance (oil change) and out-of-warranty wear items (brakes, exhaust) -- just about everything but the Check Engine light.
I hope this bad experience with an overpriced key doesn't sour your opinion of your Outback. Do you like your Outback's ride, fit, and finish?
..Mike
Once again, my apologies.
Patti
It's always good to take an occasional look at your CVJ/DOJ boots. Inspect them for any rips or openings. It is pretty inexpensive to replace them (note - Added Security - Subaru's extended service agreement is one of the only one's that cover the boots). If you do not replace them quickly, you can get sand (Juice??) or other debris in the joint and the cost goes up to replace both.
Just my .02
Patti
Patti
-mike
Before I got rolling on my clutch case, he told me I needed a new clutch and if my flywheel wasn't resurfaced soon I would need a new one at $800 (long sentence
So if a dealer recommends flywheel resurfacing could the customer request a new one since it's covered under the Powertrain Warranty? Just for future reference and for others. My guess is a good service dept. would automatically install a new one under warranty anyway.
Dennis
Also, always check your warranty and maintenance booklet before you pay for a repair or bring it into a non-Subaru facility. You'd be surprised which components are powertrain and even emissions.
Patti
I doubt SOA would want to foot the bill for a new flywheel every time a clutch is replaced under warranty when $30 worth of light machining will do the job.
-Colin
________________
Head gasket failures unfortunately are not unusual on a Subaru EJ series engine.
Let me show you. (trying to make this understandable for all, sorry if it's overly simplistic for fellow gearheads out there)
(image copyright Cobb Tuning used with permission)
That's the engine block. Look at the two cylinders in the middle, that's where the pistons are. See the void area around the cylinders? Coolant occupies that space.
Now let's look at the SOHC cylinder head. (a 97 legacy GT is DOHC but the point I'm about to make is still valid, trust me)
the black things are the combustion chambers, dirty from carbon buildup. see the holes in the cylinder head around the combustion chamber? there are 5 large ones of various shapes around each combustion chamber. these holes match up with holes in the head gasket... but notice how different they are from the large void area in the block?
what happens is that the head gasket is the barrier between the combustion gasses and the coolant passages. the head gasket is pretty thin, but at combustion pressures (especially at high RPM) it's enough to put a lot of stress on the head gasket. the way they usually fail is that the head gasket allows combustion gasses to move past it and into the block. this forces an air bubble into the block and coolant out. the coolant that remains can't circulate properly due to the air bubbles, and very soon the engine is overheating.
My '99 Impreza 2.5RS is doing this very thing right now, and in the next few weeks I'm going to yank the engine to replace the head gaskets.
Now why the block doesn't match up with the holes in the gasket and cylinder head? That would eliminate this problem, right? Well, it would also greatly reduce the volume of coolant that could be in the engine block, which require a bigger radiator and more coolant flow (i.e. high water pump pressure) to achieve similar results.
-Colin
Click the link below for some places:
kens "Subaru Crew: Best Service Facilities" Mar 23, 2001 8:40am
Ken
Are the failures happening on stock or modified engines? Or both? Would it have anything to do with the engine not being able to handle extra power coming from aftermarket cams? I guess a few extra hp shouldn't matter though.
Dennis
-Colin
We feel better about absorbing the extra cost for replacement than having issues down the road when the car is out of warranty.
Patti
-Colin
(still planning to resurface his flywheel when installing his aftermarket clutch)
The clutch is a gonner.
Do I have to have it flatbed towed ?
Mike
-mike
While doing so, I was chatting with the various sales staff, ant they mentioned to me that so as to not void the warranty to ONLY use Subaru Perculator Oil Filters.
I can not expect my neighborhood lube garage to have the Subaru brand filter, and franly I am a little embarrassed to bring in my own filter (ie; like bringing your own food to a resturant to have them cook). What do others do other folks do that have their oil changed at non-Subaru dealers???
Also, I thought that to 'help' the Oil Change 'kids', what about the idea of spray painting the oil plug florescent orange. OK, sounds like I'm paranoid right? -- but I would rather be safe than sorry?
You thoughts are appreciated. Thanks.
Due to business travels I will not be able to pickup my vehicle until next week Friday (ugh). My questions are:
1). Does the O2 Sensor Recall affect my new Outback (ie; is their a date of manufacture period which the 'bad' sensors were no longer being used in the build process?
2). Can / should I ask for the replacement BEFORE I pickup my vehicle;...saves time and a trip back as the nearest Subaru dealer is 35+ miles away?
3). Do I have to have a 'Recall card' or documentation to have the O2 sensor replaced?
You thoughts....
..Mike
-mike
Ross
-mike
-mike
As you can see, I am anxiously awaiting my FIRST Subaru,(acutally my first non-BIG 3 Car) and am trying to learn everything I can.
Reading through the Subaru Web Site, I unfortunately just found out the the cigarette
lighter can not be used to power my cell phone on my 2001 Outback (I pickup the vehicle this week). This is somewhat disturbing as I travel for business alot, but I know this must be a common issue and someone must have bridged this before me...
I have a US Celluar contract and Audiovox Car Phone. What solutions have been used, as well as where have people gotten their solution?
My thanks in advance...
Mike Zak
Plover, WI
Recently, there was a fellow that was blowing that fuse repeatedly when he charged his cell using that outlet. Turned out it was the cord unit itself - he replaced it with the correct type for his phone and no more problems.
I think some others may have even used a radar detector there too.
So, you should be able to use your phone charger in your new Outback.
-Brian
-mike
Since different accessories and different brands have varying amounts of current draw, I would suggest that you try it and feel the area of the dash around the socket. If it feels more than barely warm you might want to then find a different solution.
Frank
Are U talking about me?
Rgds,
Jack
-Brian
..Mike
Enquiring minds...
Theo
Edmunds is aware of this lack of search functionality. There's a thread under News & Views (don't know it's name) that discusses this and other WebX issues.
Anyway, I was just joking around. Apologies for giving you false hopes.
..Mike
I've been driving an Isuzu Trooper for a week while my vehicle was being repaired. While it isn't my cup of tea, the overall driving experience has been pretty good. The Trooper has a pretty tight turning radius and accelerates fairly well for such a big vehicle. The high seating position was kind of fun. You actually look down on most vehicles on the road. The one major shock of driving this vehicle was the cost of filling up -- about $35 for a tank of gas!
Ken
-mike
How Can The Dashboard Light Be Turned Off?
After fixing the problem, the service technician will the turn off the dashboard light. There are also situations under which the vehicle's OBD system can turn off the dashboard light automatically if the conditions that caused a problem are no longer present. If the OBD system evaluates a component or system three consecutive times and no longer detects the initial problem, the dashboard light will turn off automatically. As a result, drivers may see the dashboard light turn on and then turn off. For example, if the gas cap is not properly tightened after refueling, the OBD system can detect the vapor leak that exists from the cap not being completely tightened. If the gas cap is subsequently tightened, the dashboard light should be extinguished within a few days. This is not an indication of a faulty OBD system. In this example, the OBD system has properly diagnosed the problem and accordingly alerted the driver by illuminating of the dashboard light.
..Mike
-mike
If they're (the EPA) gonna make these systems so damn picky, they ought to make them more user friendly.
Mr. Bear, your gas cap is loose. Please tighten.
Mr. Bear, you'll need gas soon if you continue driving at 85 mph...
-Brian
