Vibe Maintenance & Repair Concerns
Anyone have thoughts on this?
The paint on the rear facia on my wife's VIBE is VERY thin. Her car is white with the mono paint pkg. I really wish I'd saved the $350.00 that option cost because it definately is not worth the money considering how fragile it is. The flat surface below the rear hatch scratches from the slightest pressure. it really needs the rubber guard to protect it. I was looking @ some 2004's yesterday and they all had one on them, not listed on the MSRP sticker so I guess they may have made it standard.
So far the sides and the fron facia seem to be OK but they also seem to have heavier paint with a nice coat of clearcoat with a high gloss. The rear facia is rather dull and the "grain" or texture of the plastic underneath is very easy to see, rather "pebbly". I am considering asking the dealer to repaint the rear facia to better match the sides and front. Since the car is white a good color match should be no problem, I hope.
Will be taking a 3000 mile trip over the next two weeks so it will be interesting to see if I pick up any more "scars" LOL !!
Will report back when I return.
HUD
But seriously, I love my Vibe, and I plan to have this one for a good 6 or 7 years. Even if it means a new bottle of touch-up every month!
I had no problems with the base Vibe in the snow (I live in Utah). I don't think it's worth getting the AWD--the Vibe needs all the horsepower it can get!!
The Pontiac web site now has specs on the '04.
Water was accumulating just over driver's side,
at the top of the windshield support in roof liner.
When you drive water falls onto your leg.
Dealer of course could not find leak source...
Twice this summer I have had same leak form!
Same spot...
Windows were up, moonroof shut tight.
Anyone have a similar problem???
Does anyone know how many grease fittings are underneath the 2004 AWD Vibe? I like to do my own maintenance and knowing how many grease fittings is useful so as I don't miss any of them.
Also, the sales' brochure for the Vibe claims that the gear lube in the differentials will last for 100,000 miles. Is this merely sales' hype? Or, do the differentials come with synthetic gear lube from the factory? If not, I am thinking of putting in Amsoil synthetic gear lube in both differentials of the AWD Vibe.
Thanks for your help,
Chet Kulus
I was at a Pontiac/Buick dealer last week because my father needed some work done on his car. I took the opportunity to ask about ordering a Vibe roof rack and installing it on a Matrix.
The service department representative told me that the roof rack had to be ordered in several pieces with a different part number for each piece. He thought it should fit a Matrix because it is basically the same car as the Vibe, but this particular dealer does not have a body shop and so it is a job this service representative did not want to tackle.
On the other hand, a salesman told me in no uncertain terms that the Vibe roof rack would not fit the Matrix.
I'd like the permanent roof rack rather than the removable one that Toyota is offering through their parts department at my dealer. Has anyone installed a Vibe roof rack on a Matrix as yet? Even if you haven't installed one, I would appreciate any comments about how feasible it might be.
I guess what I would do is buy the parts, if they are not outrageously expensive, from Pontiac and take them to the body shop at my Toyota dealer for installation. Obviously Toyota and Pontiac are not encouraging people to do this, probably so they don't blur the lines between the two cars.
The only thing I think could have caused this is that I used the window defrost to defog my windshield the very day before the crack showed up. This was the first time ever that I have defogged the windshield. Outside temperature was moderate around 8 celcius.
I went to my dealer and they had a look at it but called me later to say they would not fix it pro bono. I would like to hear if anyone else has had this problem. My insurance deductible is $300 which I don't want to pay and frankly, this looks to me like a manufacturing defect. I plan on raising a big stink with Toyota to get this fixed.
Anyone else out there with this problem and how did you resolve it?
Insurance companies usually waive their deductable if you have the windshield repaired. The don't want long cracks though. They want the crack to be smaller than a dollar bill.
Does anyone know where the air bleed bolt is located in the '03 Matrix cooling system?
Over 8000 miles on my Trix and I have had 2 problems now. I punctured a tire with a screw which caused a slow leak. Got that fixed for $20. And just yesterday when I used the hatch glass to put something in the back, I noticed that the rubber seal has a small tear near the latch.
Is there anyone out there with this problem and if you had it fix did it solve the situation?
Thanks...I have an appointment with the Dealer next week to have the Catalytic Converter replace. I will let you know the outcome.
The roof is leaking? Do you have the moonroof?
I also didn't notice any change in mpg. I even changed the plugs at the time (about 20,000 miles) and saw no difference. The car ran a bit smoother (more likely due to the plugs than the filter), but no real gains in power or mpg.
I ahve no experience with their oil filters, I used the OEM filters for my Miata....heard they were the best.
My question to you: if you do NOT have a sunroof, how is the roof leaking? Could it be the weather-stripping around one of the doors? If so, this should be easy for them to fix, as long as you can tell them where it is. Or they could just turn the hose on your car to see where water is coming in. Please clarify.
My clutch feels pretty weak and it does not like to be ridden in the slightest. The shifter feel is also poor (this from a Honda / Mazda man), but still better than a Subaru for what that's worth.
OEM tires are pretty lousy to. If you want to replace them, count on $500-600 or so for a decent set due to the odd size with the 17" rims.
