Vibe Maintenance & Repair Concerns
Will this fix our headlight sensor on/off on/off feature?
EL007-02 NOV 02 Lighting - Ambient Light Sensor Improvement
data from alldata.com
Nothing on Pontiac Vibe yet.
Anyone get any answers from their P-Vibe dealers?
This been out since Nov, 02.
Do we need to campaign the GM ppl to get their act together.
I hope the new sensor works for you - once GM issues a TSB.
For now, would leaving lights on be better to avoid burning out quicker because of too many on/ off's?
But the new sensor/TSB is definitely the way to go!
If you have the old sensor still, I would recommend turning on the lights all the time - not only will this be less hard on the bulbs and the charging system, but there is that little solenoid under the dash that has to turn every time the lights go on and off too...imagine if that dies, the pain it would be going under the passenger-side dash to try and replace it.
H4
9007
9003
Any one know
Anyone else have this?
Did it go away?
Didn't need no ramps.
Just had to realize the earl filter was black and in front of mah eyes.
8 minutes to change earl and filter.
10 minutes to clean my hands from the earl leaking from the filter.
Any thoughts on what i should do? i have tried holding the grates over the vents while driving and this doesnt stop sound. thanks
I do most of the work on my cars myself. I am somewhat of a preventative maintence "nut".
After its purchase, I looked the car over well, top to bottom, locating components, filters, etc. but I could not locate a gasoline filter.
After several inquiries to Pontiac Dealers, no one could tell me where the gasoline filter was located and even if the car had one. Finally after a lengthy call to GM Customer service and their subsequent call to a "friendly" GM dealer I was finally told that the Vibe's gasoline filter was inside the gasoline tank and that the only way to change it was to remove the Gasoline tank. They said that the cost of the filter is $60. and Labor to install it would be at least $200.
Hey what gives GM?!!
Gasoline filters plug up on a regular basis. GM should have Designed an inline filter that is easy to change. Considering that even GM admits that the quality of Gasoline in the U.S. has fallen in the last decade, gasoline filters should be easy and inexpensive to change.
What does anyone else think?
Just an alternative notion...if you are committed to changing it despite this, it can be done. The reason it is not a cheaper operation is because the vehicle's designer did not intend it to be a routine job.
Also, I heard somewhere that either the headlights or tail lights (or maybe other external lights?) are extremely difficult to change. Someone actually had said that it entailed removing a fender or something else?! I find this hard to believe, but any input on this?
Headlight Bulb, open hood, locate bulb, remove rubber cover, unplug socket, undo retainer, remover bulb, reverse for install.
Taillight bulb, open hatch, open rear quarter storage compartment, remove socket/bulb from lens, replace bulb, reverse for install.
The owners manual dosen't have the instructions to replace the actual lens units if they were to break, so not sure to difficulty there, but will keep eyes and ears open for info.
Has anyone replaced a headlight yet on their own?
What is good for this, aside from GM stuff from the dealer?
Is there a brand name, or something else?
I went to the Walmart, and did not see this.
Would Home Depot have this?
supposed to be lower S content.
Let us know the real deal.
I would get some, but have no BP stations on my normal routes to make a good judgment.
for now, my Vibe is smelly as I go up steep hills, and in constant stop and go's
Is it just me or the clutch pedal is engaging higher than other standards? Is it adjustable? In my old Corolla I used to keep my heel on the floor when operating clutch. Now I have to lift the whole leg which makes gear shifting less precise and rougher ride.
Reprogramming the Remote Control Door Lock Receiver
Important
The vehicle comes equipped with two transmitters. The receiver can be programmed to accept up to four transmitters. Additional transmitters are available. If the number of transmitters programmed exceeds four, the previously programmed transmitters will be erased in order, starting with the first transmitter.
To program a transmitter, there are 4 modes within the remote control door lock receiver.
Add mode: This mode is used for adding new or additional transmitters.
Rewrite mode: This mode is used to erase all of the previously programmed transmitters and should be used when installing a new receiver.
Prohibition mode: This mode is used to erase all registered codes and cancel the wireless door lock function. Use this mode when the transmitter is lost.
Confirmation mode: This mode is for confirming how many existing transmitters are registered before adding any transmitters.
To begin programming, follow the procedure.
Set the following conditions:
Ignition off and ignition key out of cylinder.
All doors closed except drivers door.
Drivers door is unlocked.
Insert and remove the key from the ignition switch twice within 5 seconds.
After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1 to 5 times to select desired mode.
1 time for add mode
2 times for rewrite mode
3 times for confirmation mode
5 times for prohibition mode
Remove the ignition key from the key cylinder.
After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode.
In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered.
In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times.
If the prohibition mode or confirmation mode is selected, registration procedure is completed.
If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode.
If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed.
If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
Registering new recognition codes for the add mode or rewrite mode.
Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds.
Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter.
If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters.
If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Any of the doors are opened.
40 seconds elapses with no input to the RKE module.
The ignition key is inserted into the key cylinder.
4 transmitters have been programmed at once.
One would think a dealer would have either already done it or have someone do it when the car is sold. At least I've learned over the years to go in with no expectations - then I'm not disappointed!
Thx again.
Easy to do. Lower the steering wheel, pull the instrument panel straight off. The connector is above the speedo. Pull down the retaining clip, pull the connector apart, tape them together to keep the wires from dropping, put the retainer clip back, push the instrument panel back on (watch the odo reset button) and you're done.
