Acura TSX
I don't think the base price will be 26,000. I would think it will start at closer to 23,000 - still 4,000 more than an LX Accord. With auto tranny, shipping, and maybe some options, or a higher trim level it may be 26k, then nav may put it up higher still. If it starts at 26k it is only 3k less than a TL, but 6k more than an RSX. I would think the price would be much closer to that of the RSX.
I'm guessing that the TSX will include standard leather, side airbags, and some kind of traction control, which - when combined with the longer Acura waranty - should put the base price right around $25K for a 6-speed, and $26K for the 5-speed manumatic.
The sticker price on the RSX-S is pushing $24K, so it's not much of a surprise to see the TSX in the $25-26K range. It's definately more car for the money.
If Acura puts a limited-slip diffy in the 6-speed, they will win me back as a customer.
My bet is on 2.4 liter I-4 with 200 HP for base version. Now, Type-S could be interesting. IMA boosted 240-260 HP, AWD? Possible.
As far as weight goes, TSX/Euro Accord with 2.4/I-4 should weigh around 3100 lb. The Type-R (which may be sold only in Japan at this point with 2.0 liter, 200-220 HP) may be under 2900 lb.
I doubt we'll see IMA or AWD... most manufacturers introduce these things at the higher end of the segment and then let the technology filter down (this is more relevant to IMA, since AWD isn't really a new technology).
Also, DualNote features ATTS on the front wheels, something that came from Prelude. Likewise, S2000 (Japan only) became the first car in 2000 to get VGS (Variable Gear Steering), not NSX. So, technology can start anywhere on the price range.
As far as my hopes go, I would love to see the RDX drivetrain in the TSX-S, even if that means a price tag approaching $28K. That could leave the base model to stay around $25-26K.
With all that:
TSX should be around 24,5
Type s should sell for 26
This wuold be perfect for a competitor to maybe the Max. G35, IS300
http://autoweek.com/specials/2002_paris/
I've tried to cross check this with the interior dimensions of last year's Euro Accord (supposedly slightly less than the new generation), but couldn't find any relevant info on that model, except for a uk site that put the rear legroom for that model at 37.9 inches, which is an obvious error.
Anyone have any other info on this?
RSX base(leather)/RSX Type-S: 21,450/23,670
CL base/CL Type-S: 28,700/31,050
TL base/TL Type-S: 29,480/31,830
In addition, the 2003 Accord EX w/ Leather (2.4L) is listed at $24,160. If the base TSX is going to have at least 180HP with xenons, fog lights, power seat, traction control, sunroof, and bose, it will have to list at no less than $25K. As a result, the TSX Type-S will be around $27,300.
Just my 2 cents....
We shall see.....
I guess we will know the price soon enough.
But use that same formula on a midsize sedan, and you got yourself a seller.
http://www.japancars.agava.ru/photos/infiniti/g20_5.jpg
length: 4665 mm or 183.7 in
width: 1760 mm or 69.3 in
height: 1445 mm or 56.9 in
wheelbase: 2670 mm or 105.1 in
front track: 1515 mm or 59.7 in
rear track: 1510 mm or 59.5 in
ground clearance: 150 mm or 5.9 in
luggage space: 459 LITERS or 16.2 cu. ft.
weight: 1300 KILOS or 2866 lbs (2.0 L econo) to 1490 KILOS or 3285 lbs (2.4L AT)
All thanks go to kiwic of France for providing this info and pictures on the vtec.net site. Here is the link to his photos from the 2002 Paris Auto Show: http://kiwic.ifrance.com/kiwic/a/
Note that the wheelbase is the same as the NA coupe. That relates to the key dimension I'd like to see which is rear seat leg room. Also, how do they get such a big trunk when the NA Accord sedan only has 14.0 cubic feet? Any idea as to whether the trunk has gooseneck hinges or struts? Anyway, that three inch shorter wheelbase has to show up somewhere (although it is comparable to the Mazda6).
Infinti needs to severely rethink the G20, or can it (as they did already).
I saw on another message board where the rear leg room is about 34.3 inches (like the 4th generation Accord) which is consistent with the wheelbase being about 3 inches shorter that the NA Accord Sedan.
Here are more pics: http://www.honda.de/np/14981.html
Enjoy....
I remember the G-20 taking high 8.x to 60, the automatic was slower though, and may have been about 10.
automatic and 5speed manual g20!!!
http://en.carpoint.msn.ca/Vip/Heraud/Infiniti/G20/2002S.asp
and the legendary 1.8turbo that would kick anyone's butt!!!!
http://en.carpoint.msn.ca/Vip/Heraud/Volkswagen/Jetta/2002S.asp
See it at:
http://www.thehollywoodextra.com
Follow the link to "Vince's car pages"
I sat in the car myself last week.
Very nice indeed...
when the integra sedan was around, it was in the same price range as the accord. i think of the tsx as an integra sedan replacement except it won't be based upon the lowly civic.
Acura refuses to build V-8 RWD cars in its lineup because it doesn't want to be another "Me too" in the luxury car game. But it changed its system of naming cars for that very same reason...
NSX: Neo Sport (I think)
MDX: Multi Dimension
How would TS, NS, MD sound? Better than TSX, NSX and MDX? I doubt. 'X' jazzes up the alphanumeric designation a bit, IMO.
Earlier, Acura used 'X' to designate prototypes (CLX, TLX), and I was hoping that RSX didn't turn out into RS and MDX into MD.
I don't care whether RL is renamed to Legend, and TL to Vigor or not, good car is all that makes sense.
The Japanese brands (Lexus, Infiniti, and Acura) seem to have this all screwed up:
RSX = Entry level two door sports coupe
TSX = Entry level four door sports sedan
TL = Mid-size four door sedan
CL = Mid-sice two door coupe
RL = Full size luxury sedan
NSX = Two seat exotic
MDX = Mid-size cross over utility
The "SX" may have something to do with "sport", but the R, T, and N don't seem to follow any type of progression. "L" may stand for "luxury", but again no progression, with the top of the line RL between CL and TL.
They should just stick to names for their very nice cars...
The TL/Accord and ES300/Camry are different. The TL is bigger, has a bigger motor (until recently), and has every feature you can get on the Accord and then some. There is even a larger gap between the ES300 and the Camry. The Passat/A4 and Accord/TSX overlap almost completely. With no S4 or convertible right now, the Passat almost completly overlaps the A4 line in terms of price.
I realize that the brand names are just marketing, but people are going to stop believing it. Acura and Audi already are probably considered by most to be the least "upscale" of the upscale brands. The extreme product line overlap is one reason, and probably the main one.
I don't ever remember the Jetta and A4 being associated with the same platform. The 1.8T engine may be common as is the transmissions, but thats about it. The Jetta/Golf/A3/TT are one platform whereas the Passat/A4/A6 are another...
Look at the IS300. It too is hard-edged and handles well. But it plays in a market above every Toyota-branded car. Yes, it doesn't sell very well, but at least it is for sure a Lexus.
Look at the RSX. Yes it is based on the Civic, but there is really no product overlap. The RSX is MIJ, a true 2+2 hatch, has a way more upscale interior, has a sportier suspension, and yes, it costs more--a lot more in terms of percentage.
I guess I just wish the TSX was more like a TL Type-R. Maybe the same motor as the TL-S, or bumped a few hp. Sportier interior. Harder suspension. Six-speed manual. Maybe even a shorter wheel-base. ATTS. Priced about $35K. That is what the Acura brand needs. The car being rolled out as a TSX should be the Accord Type-R.
I don't mind alpha-numeric names so much if there is at least a rhyme or reason such as BMW
Although Acura's naming conventions don't rhyme (at times), but they do have some meaning, such as TL: Touring Luxury. And just because European brands offer a 'progressive' naming convention doesnot make it interesting IMO. And then, is there a B-Class Benz? A huge gap between E-Class and S-Class. And then, there is the CLK versus SLK!
But honestly, I would have preferred "SL" (Sport Luxury) over TSX.
brizey
I guess the TSX is basically a sportier trim line of the Accord.
TSX is an Accord (JDM/Euro), and historically, Honda has delivered sport trims of Accord overseas (Euro-R, Type-R, SiR). TSX could be based on one of the performance tuned chassis, sportier handling than American Accord. The difference could be like that between Audi A4 (TSX) and Passat (American Accord).
As far as differences and similarities between TL/Accord and ES300/Camry/Avalon goes, I always thought the Toyotas were much more similar than the Hondas.
BTW, Accord still uses smaller displacement engine than TL.
If good handling and a hard-edge feel are "Acura-ish", then shouldn't the S2K be an Acura
Perhaps Acura should get SSX! S2K is hard-edged, but also raw, not a combination of performance and luxury. I guess, the original idea in the mid-90s was to have a two-pronged approach to roadsters. SSM was supposed to be a Honda, while Acura could have gotten Argento viva. Same chassis, same drivetrain, different styling and different attitude (high revving 220 horses of SSM versus docile, and probably refined 190 horses in Argento Viva).
brizey, I agree with your comments, except this one. The IS300 is definitely not a Lexus. When people think Lexus, they think leather and wood interiors with a smooth, yet capable ride and handling. The only thing that the IS300 possesses that might make it a true Lexus is the high price tag! Its interior is more Toyota Corolla than it is, say, a Lexus ES300.
Honda will probably employ some kind of individual wheel drive system on the front axle as part of an AWD/hybrid setup, but it won't operate like ATTS.
When I said bigger motor, I meant it figuratively. More power and more torque.
Toyota vs. Honda:
The base 2003 TL and the top of the line new Accord are almost identical in terms of feature content. In fact, I think the Accord has more!
TL: Power = 225, Torque = 216
Accord: Power = 240, Torque = 212
The Accord has some new goodies that I assume will be available with the 2004 TL: Telescoping wheel, for example. Add it all up and I think I would take a loaded 2003 Accord over a base TL, even if I was thinking entry level luxury.
The ES300 makes more power and has a much more luxurious interior than a Camry. It also has more features. The ES300 is MIJ; the Camry is MIK!
IS300:
I know the knocks against the IS300. Cheapo interior, boy racer tail lights, etc. But at least no-one cross-shops it with a Toyota. And its price, like it or not, keeps it out of many people's price range.
When you buy a TL (I have a '99), you have to take a hard look at a loaded Accord (I did). When you buy an A4, you have to take a spin in a W8 Passat.
VW is guilty of the same with the A4/Passat deal.
Until said overlap is gone, Acura and Audi will not have the prestige of Lexus, and heck, even Infiniti.
This doesn't matter to many when it comes down buying a car, especially those who do careful research. But my guess is that many people who buy a Lexus would not consider an Acura. They are cross-shopping with Mercedes and BMW. Acura does not fully play in this space, most likely consciously.
My gut says that the TSX will only steal sales from TL's (cheaper than a TL-S) and Accords (sportiest Accord). It is nice to see a company offering a new trim line, but I don't think it will bring in net sales.
The G35 may have lines similar to the Altima, but it only shares an engine class otherwise. I doubt many people cross-shop them. One is a FWD family car with a little extra sport. The other is a RWD ELL that is relatively affordable. The price gap is pretty large.
The other element in the equation here is the dealer. My guess it is the Acura dealers looking for the TSX. There is a hole between the RSX and TL price-wise. The problem is that it is neatly filled by a Honda nameplate, the Accord. So what do they do? Call an Accord a TSX and sell it at Acura dealers.
The Honda dealers don't need any Acuras. The top of the line Civic and a bottom of the line Accord are not that far apart in price.
If "T" in "TL" or "TSX" stands for "Touring" fine. But, is the "R" in "RSX" the same as the "R" in "RL"? Moreover, how do "RSX", "TSX" and "NSX" relate? What about "MDX" and "DNX"?
You have two "T_"s, two "R_"s, and one each of "M_", "N_" and possibly "D_" for prefixes. Suffixes consist of three "_SX"s, plus one "_DX" and maybe a "_NX".
Makes perfect sense. They should just admit that they think the letters sound cool together...
the a4 is a stunning success for audi. in the way the car drives and looks you would never guess it's based upon the same platform as the passat. except for the interior, i predict the same for the tsx.
i admit the acura name could have higher prestige, but the audi name doesn't suffer from this (especially in comparison to infinity).
