Acura TSX
ATTS is dead. The LSD (cheaper, lighter, more effective) in the CL-S 6-speed nailed the coffin shut.
Nope. ATTS has returned, albeit in a prototype, serving the same purpose and more. DNX/Dualnote is equipped with ATTS.
ickes_mobile
I don't think alpha-numeric names are "interesting", but at least the Germans are logical about it. If anyone can figure out the Japanese system, great
I think there lies the problem. You're trying to figure out the "Japanese system" (not sure what that means).
I'm sure use of alphanumeric names has also to do with them being 'cooler', and it doesn't have to follow a set of rules. Mercedes' SLK (not S-class) versus CLK (not C-class, or is it?), or BMW's M3, M-Roadster, Z3, X5 etc. retain numbers in most cases (not in M-Roadster though), but what does "X" or "Z" indicate? It doesn't have to mean something. For a while, BMW 323i had 2.5 liter I-6, 540i had 4.4 liter V8 and what does that "i" indicate?
There is no Japanese or European system, it is just a way they have chosen to market their product. Another good example, not relating to car names, but at equipment level.
European automakers seem to like the sound of 'ic' in their new feature list. These are also catchy words that may or may not make sense, but sound cool. "Distronic" (Acura called it 'smart cruise control' in TLX concept), "Parktronic", "tiptronic", "Airmatic" (suspension) are some good examples.
http://www.honda.co.jp/factbook/auto/ACCORD/200210/img/05_09.jpg
Another example: I read in the MT 2003 new truck preview that the new Lexus GX470 slots between the bigger LX470 and the RX300. Now obviously, Lexus got it partially right in that the nubmer part refers to engine size, but how does "G" slot between "L" and "R"?
Like I said, they just think it sounds cool...
http://www.vtec.net/news/news-item?news_item_id=44297
http://www.honda.co.jp/ACCORDwagon/
I really hope this make it to the States.
Why does it have to?
Features or names, its all about marketing.
Picture: Euro-R
Engine: (K20A) 1998 cc, DOHC iVTEC
Output: 220 HP @ 8000 rpm, 152 lb.-ft @ 6000 rpm
Transmission: 6-speed manual
Curb weight: 3058 lb.
Tire: P215/45/R17
Pictures: 24-series & Power/Torque Curve
Engine: (K24A) 2354 cc, DOHC iVTEC
Output: 200 HP @ 6800 rpm, 172 lb.-ft @ 4500 rpm
Transmission: 5-speed SportShift Auto
Curb Weight: 3120 lb. to 3190 lb.
Tires: P205/55/R16 or P215/45/R17
P.S.- I like the Mercedes-Benz-ish turn signals on the side mirrors. Will all Acuras come with this feature from now on?
When I see it on another production vehicle, I'll be convinced. However, given Honda's current focus upon hybrid and weight-saving technology, I still fail to see a practical application for a system as heavy and complex as ATTS when a wheel-specific electric motor could be used instead.
Acura should bring back the Vigor nameplate for the TSX, and dump their silly - and arbitrary - alphanumeric naming system.
And why couldn't they come up with a name for their first cars/prototypes. X170, X190, S360, S500, T500, S800, CVCC... silly moves. Wait, they did manage to convert CVCC into Civic!
They should do it with their motorcycles too. GoldWing, Valkeryie, Shadow sound so good, who cares about CBR1100?
http://auto.ascii24.com/auto24/issue/2002/1011/npr_kt1011_03_15.jpg
Apparently, Honda was saving it...
Honda can't "sell" typical Honda buyers on the benefits of ATTS (which might explain why they've stopped trying), and the only people who recognize the benefit and want it (enthusiasts) would still prefer to have a mechanical LSD.
Without a doubt, ATTS is some nifty engineering. That said, I have serious doubts as to whether or not Honda/Acura will be able to make it affordable (and reliable) enough to see it incorporated into multiple, high-volume models. To my knowledge, the only other production car employing a similar system is the Mitsu EVO VII, which has that cool Active Yaw Control in the front. But again, the EVO is a low-volume, near-boutique car, and I don't see Mitsu using AYC on any other models, either.
On another topic, the Acura "A" is also a play on the Honda "H"--I remember that they wanted to show a familial relation between the two car lines.
Then what's the H?!
ATTS is definitely cool, I have it on my 2001 Prelude Type SH, but Himiler has installed a (Quaife?) mechanical LSD on his 2001 Prelude for less than the $2500 premium that Honda charged for the ATTS in the Type SH model. In addition to handling enhancements, himiler also enjoys easier launches, and additional benefits in inclement weather.
BTW, if Honda couldn't sell ATTS to himiler then...
http://www.carkeys.co.uk/roadtest/RT000061.htm
I'm not sure who got hung up in the argument, but here is how it started...
"ATTS is dead. The LSD (cheaper, lighter, more effective) in the CL-S 6-speed nailed the coffin shut."
And I said... "ATTS is part of the hybrid system in DNX/Dualnote... Use of ATTS in a futuristic prototype only indicates that it wasn't dumped..."
I'm not sure what frustrates you about this, but thats alright. We should be discussing TSX here anyway.
I think I know what himiler meant. If you look closely at the Honda "H" and the Acura "A" (the calipers), you will notice similarities. move the upper arms of the "H" closer and it will look very similar to the Acura "A". Also, both H and A sit inside a squarish rim (less noticeable in Acura).
One that has received some treatment recently! :-)
diploid,
Supertruck!
http://auto.ascii24.com/auto24/auto24.cgi?source=issue/2002/1011/npr_kt1011_04_11.html
Here are a few pictures...
Exterior-Side View
Exterior-Top View
Exterior-Front Profile
Interior-Top view
Interior-Cargo
The Mazda6 wagon is more well proportioned.
For instance, the Infiniti G35 Coupe looks Fantastic and well proportioned, while the G35 sedan with quite a bit more overhang (when compared to the coupe), does not look as good.
Later...AH
If you want to talk about a good looking wagon the crysler/mercedes pacifica/gt looks fine. too bad its a crysler though
(The RSX goes from 24 to just over 30K). I was really looking forward to the wagon and hoping Acura would bring it here as well but after seeing it, I'm not so sure. What's with the "Caprice-like" rear overhang? And, although a sport wagon should be sporty, if you're going to get people out of their gas-sucking SUV's, you'd better raise the hip-point and make it taller...
say halfway between the height of a traditional wagon and an SUV. I copied a photo into the "Paint" program and stretched it vertically about 120%.......seemed to improve the hearse-like looks, though the overhang still looks too long. The one-touch folding seats are nice (but the Mazda 6 has them too) but who needs a power tailgate with struts hidden in the roof, making the inside roof lower and taking more height out of the cargo area? The Mazda 6, while vertically challenged as well, looks a whole lot better and will come with both a 4 and a 6 as well....seems to be the better choice at this point.
Pet
1992 Vigor LS 5-sp
"Styling, though, is tame." and "...the Accord is absolutely middle of the road dynamically."
They do say the five speed is a "honey" and that both engines are "crisp and smooth".
