When I start my pilot, put it in drive and press the accelerator I hear a grating metalic sound from the left front side of the vehicle. The sound only lasts about a second and I never hear it again. Have any of you experienced it? Mine is a 2005 Pilot EX-L. Also when I am backing out and step on the brake I hear a thump from the back of the vehicle.
Any tips, pointers will be highly appreciated.
Thx.
As to the thump sounds when backing up I am not sure but I believe this has been a common issue with Pilots. Not a safety issue, more of an annoyance issue. Like the gas tank noise some experience.
Wow, look at the new icons at the bottom. :shades:
Does anybody have any comments on using synthetic oil? Know there are issues on the Mazda rotary engine but that is different.
Of course if I bring it in to the dealer, murphy's law applies and it will work impeccably.
thx
Transmissions have always been Honda's weak point. Honda does not have a good reputation regarding transmissions.
Any experience? Opinions?
This is the famous "window scrunch" problem. It is caused by the door seal pulling away and returning when the body flexes. Most people seem to notice it more on the highway.
Honda had a TSB to replace the door seals. Most owners ended up with the same noise with the new seals. Some dealers temporarily fix it by lubricating the seals, but the noise always returns.
Some owners have added weather stripping to cause a tighter seal.
The only fix that I've heard that works long term is taking a TSB for the gen 1 CRV and applying it to the Pilot. Role down the window. With the door open, place your knee against the center of the inside of the door, then pull on the top of the window frame. This will slightly bend the window frame, resulting a tighter fit for the door seal, thus eliminating the noise.
Good luck!
am going to check it out today on the road without the front crossbar.
thx
bubba10
I'm starting to get concerned, any suggestions?
thanks, arlowe
Incredible that so much attention to detail goes into these cars yet the dealer who puts on the crossbars cannpt match that QI.
thx
bob
anecdotally, my '03 ODY front passenger-side had a tapping sound when going over very small bumps. the shop foreman took a little drive and identified it right away. i think the they dismounted the strut, deburred some weld points, applied some grease and re-assembled, and the vehicle has been quiet for the past 22K miles.
In retrospect the seats in our '02 GMC Envoy were much more comfortable than the Pilot. Before it fell apart at 30,000 miles we drove the Envoy all over the country and never got stiff. Not so for the Pilot. A contributing factor could be that the Pilot suspension is stiffer than the Envoy. There's no comparison in handling between the Pilot and the Envoy; the Pilot handles much better. However a stiff back is the price we pay for the better handling. Perhaps we need a vehicle with a very soft suspension. I'd really like to dump the pilot but I haven't found anything as reliable. I'm scared to go back to GM. The mileage on SUVs like the Yukon is abysmal. So we continue to put up with the Pilot until something better comes along. Hope this helps.
Has anyone noticed this. It doesn't strike me that it is coming from the windows.
rotorhead2
If they are installed correctly here are some things some of the guys in the subaru boards have done. Some older subies had the issue with noisy cross bars because the wind made them vibrate at certain speeds.
- remove them (maybe a short term solution to see if thats where the noise really is, unless you don't use the rack).
- move the front cross bar forward or back to change how the wind hits it.
- wrap a black rope or maybe electrical wire (single black wire) around it. I imagine about 6 or 7 times around as you go across (looks like a barber shop pole). This helps disrupt the air flow a bit.
--jay
Your guess could be very wrong. Vibrations can be caused by lots of problems, not limited to tires. You better go back to Honda a couple of times, and if they can't solve it you can use the Lemon law to get your money back. It seems it's a simple process.
What I couldn't find were the marks showing where to line up the crossbars on the rails. I just put them where they looked good, it shouldn't be critical.
Is there such a case where a "slow leak" would not be picked up by the tire pressure sensor? (I know it seems dumb, cuz the sensor would only check the pressure once the key is in the ignition. But, I did try turning the car on and off several times to get the sensor/light to go on- no success.)
It hasn't happend since, so I figured it was a glitch. Also, I thought that maybe if I gave it more time, 10 or 15 minutes, it would have eventually figured out which tire was low. (This seems like a stretch, since the other times the corresponding indicator lights came on as soon as the "key-in-the-ignition" cycle was completed - just before the engine cranks....)
Anyway, anyone else experience anything similar? :confuse:
P.S. I don't know anything about a recall for 2cnd gear. what is that about?
thanks arlow
On the wind noise and Cross bar comments i have a thought. I remember last year when my Pilot was in for service, Enterprise gave me a Trailblazer loaner. It had a Horrible wind noise so I moved the cross bars to a different location. The wind noise went away. No cross bars on my Pilot so that's all I can offer up here.
Just a thought... if memory serves me, both the cross bars were located towards the back and next to each other.
Drew
It sounds like a knocking somewhere under the vehicle or like someone is knocking on the side of the vehicle.
Anyone experience this or have any suggestions. It never happens when I'm close to a dealer visit so I always forget to mention it.
Drew
Peace
I have just brought in my '05 Pilot (11K miles) for the third time exclusively for intermittent starting problems. (We mention the problem at every oil change). My car sometimes cranks and doesn't turn over and sometimes turns over but immediately stalls. The last time the car was surrounded by thick black smoke and I just got the kids out and gave up on going out that day. The dealer still has it now and I had been trying to follow their insane rituals of turning it on to battery first to make sure that the car recognized the key and there was no blinking key symbol before then trying to turn it over. They want me to make sure now that I don't have anything metal on my keychain - like other keys!!! The maint. mgr. says they can't find anything wrong and they want me to accept that.
This happens two or three times a month - not only from a cold start but also after having turned over beautifully first thing in the morning then coming out of work to the parking garage after the day's warmed up only to wonder if I'll ever get out of there.... or if I will be pushing the thing off the third floor of the garage to a tow truck awaiting below (didn't actually have to do that - just a bad image that ran through my mind by the sixth try).
Did you get a resolution or do you live with it?? Has anyone else experienced these startup problems that were so common in the '02 - '04 that I have in the '05? Please let me know!
