After all the waiting and on my way home, I found my oil minder reset to 100% though I didn't order an oil change and the oil stick sure doesn't indicate new oil. So I called and they checked with the mechanic -- he reset the minder simply because he thought an oil change was done as well. He even put a sticker on my windshield saying the next oil change is 3 months/200 miles away -- yes, 200 miles is what you get if you do the math on the sticker. So they ask me back for a free oil change so the minder becomes correct.
So my question is how this minder system work? I thought it has some sensors for different purposes and gives alerts accordingly and intelligently. But now according to this incident, it remains 100% on the oil after a few days even though the oil is old and the last good reading was about 50%.
Any insights? Thanks!
I've had my 2008 Pilot for about 3 weeks now & have noticed an orange colored (dare I say rust??) on the "round" area behind the hubcap. Forgive me, I know I am not using the correct terminology. Picture this. Looking at the wheel and focusing on the hubcap. Then look behind the hubcap at the silver smooth plated circular "covering" right after the hubcap. It is not all "silver." I see orange-colored substance I cannot scrape off & to me, it looks like rust. It does not cover the entire area, just the small circumfrence of the area that seems to attach to the hubcap. I fail to see how this is part of the tire or hubcap for that matter.
I am not sure what is going on but was going to take it to service later this week. I can't imagine it being rust as this car is only 3 weeks old, but why on earth am I seeing this? I don't off-road, only city street driving. Again, this is a new 2008 Pilot (EX-L, 2WD)
Thank you in advance! I am not a car techie so forgive me for my description -- just a new Pilot owner. Loving the car, not loving this!
This would explain the rust on my lug nuts at least. They just have to use some sort of clay to clean it off the original chrome finish. The rust on your rotors or whatever is perfectly fine. Like someone else had mentioned...just typical surface rust. You could always call or e-mail the service department to complain though
http://www.ahm-ownerlink.com/hccd.asp
I have a 2008 pilot VP, with its first oil change coming due soon. i was wondering if there were any points (ball joints, tie rod ends, etc.) that need to be lubricated as part of the routine maintence?
Gerard
This seems like a flaw in the construction of the handles. Anyone else experience this issue? I'm sure there is a manufacturing process that establishes the quality of the seam, and wonder if they had a hiccup in the quality.
Also, I had my SRS airbag red warning light come on for the second time. The first time they checked it, they ran a check that cleared the light and didn't show an ongoing issue. I called for service next week, and was told it will be $40 to $75 to check this time. Not sure what's going on with that.
My third issue is I'm getting a maintenance required light. Does anyone know if the maintenance required light is triggered by mileage, or is it a sensor indicating a service issue? Don't recall getting this before on this vehicle.
Thanks for any insight on any of these issues.
Also, for those of you that have had Pilots for a while, do you wind up with a bunch of stone chips on the front part of the hood given how vertical it's "snout" is? I'm not a big fan of bug deflectors but maybe it's necessary? I just don't want rust to start creeping in w/all the stone chips.
I just got back from the dealership and they told me there is nothing I can do it is a characteristic of the vehicle. So do i just need to have them replace the fuel tank?? i noticed this was posted in Jan. Are you having any problems at all now with the new fuel tank??
Please let me know.
After that little incident we decided to get a bug shield. You can get them in clear or smoke color. We opted for the clear and you can't even tell we have one on from a distance. They are right around $42 and can be found on Amazon or at most part stores. The problem is that the '08 is still too new for most stores. Just order on-line and installation is a breeze.
I also purchased a touch-up repair kit at Autozone for like $15. It comes with some putty, sand paper, primer, clear coat, and all sorts of instructions on how to repair that chip professionally. It is a common misconception to just throw some more paint on it. You need to get in that bad boy and fix right from the start. Good luck!
It happened twice on the freeway & once on the city roads. I took the vehicle to the dealer but the dealer didn't find any problem. Anyone faced this ? What could be happening ?
TIA.
if they do not take me seriusly and offer a resolution, i will contact the attorneys of the California Lemon Law. i already sent them an email inquirying about my rights as a consumer. there were 3 attorneys that contacted me for more info. one of them was from the Consumer Legal Services. every state in the USA has it's own lemon law attorney contacts. i would also contact the Dept. of Consumer Affairs to report my situation, if the Honda dealer does nothing for me. i hope this info is beneificial for you, and to others !!!! :-) tiacia
As for the bug shield, I was really trying to avoid that. I doubt my wife will like it. But I'll check one out and see what she thinks.
Thanks again.
The maintenance reminder on a 2004 is triggered by mileage, nothing else.
i experienced the same with my honda odyssey (03) when i first purchased it. now, i'm not conciously aware of it at all.
it's not likely putting a new tank on the vehicle will do anything except ease your mind so that you may begin to concentrate on other matters...
... as the sound slowly drifts into the background of your perception and consciousness...
Every once in a while, under the right conditions our 03 pilot sloshes.
Seems whenever I do hear it, it is here at the house, in the garage and the radio and AC are off. . Really don't recall the noise anywhere else. Could be that away from the house, other worldly noises are more prevalent.
I think the noise that has been the most distracting (mechanically) is the rear brake assemblies making a "clunking" sound when we back up and the brakes are applied. Then when moving forward just a few feet they will clunk again when stopping. Then they are quiet, until applied again in reverse. Thinking that is the sound of slack in the brake pad mounting. OR, Recon it could have something to do with the 4wd rear axle.
Another noise is a very quiet "scrapping" sound from lightly applied brakes, after sitting a couple of days. Pretty sure that is from the light film of rust that forms on the rotors. Notice it when backing out of the garage and gently applying the brakes. Then no more until it has sat for a couple of days. Our CR-V does it too.
Pilot also has a faint wind noise at highway speeds. I'm beginning to think it is from the Vent Shades over the windows. Seems that no matter where I am in the car, the noise comes from some where else. :confuse:
There is also more road noise than desirable. Hopefully new tires will help with that, if and when these ever wear out.
All these things have been going on since new in 03.
Overall, I'm probably more "pleased" with this car than any I've ever owned. That involves 60 or so cars, over a time frame of 52 years of driving. It is not as exciting as the GTO in 64. And it doesn't get the mileage of the Dodge colt (40 mpg) in 70, but it will haul 8 people when necessary, the seats are the most comfortable, and ample power when needed. Good visibility, really comfortable for 5 people, decent handling, 18 mpg local and 24-27 mpg road. It will tow a bass boat or a utility trailer. Versitale interior for hauling. It does everything we need it to do.
What I don't like is what I'm reading about Honda's apparent lack of interest for those that are getting poor mileage in the newer Pilots and the Fits.
Kip
So I finally decided to take action especially after catching the repair shop in a few lies, so please respond if you have any similar problems,mybe you;ll get help too!!!
Its a real shame when you pay so much and you can't have the right to get into your vehicle feeling safe and secure
Feb 2008 for nearly $30k. A day later, replaced a defect door
trim, and about 30 days later spotted many rusty parts underside
the car. Some of them appear to be very rusty and must have
started before I bought the car. Contacted both dealer and regional
Honda office. They claimed that surface rusts are not covered
by the warranty and rudely declined to fix it. Already filed a claim
with BBB autoline. Any advice on how to fight further on this?
Before you decide to buy a Honda, it might be a very good idea
to check out the underside paint carefully. Don't expect after-sale
service, which is non-existent in our case. We never expect this
poor paint quality. We also have a 1999 Camry. Even today, it
shows no underside rust at all. If I am not the only one who
is just bad luck, Honda paint quality is really in question.
I still have a piece of crap Chrysler Pacifica till tomorrow, when I will trade it for a new 2008 Pilot.
I am looking forward to chatting with you all ! I love cars, but the Pacifica was not worth my love ...
It's a pity because during the first 2 years it was a dream car.
Rodut
Be careful with the Honda Pilot. The Pilots tend to make a knocking sound at the very back each time you hit the breaks. It comes from the gas tank, and you can hear the gasoline swishing. These noises are heard from within the car. I did not hear those noises until 1-1/2 weeks after I bought it. Honda claims this is normal, therefore is not able to do anything about it.
Also there was an issue in the past regarding the odometers of 2002-2006 Pilots. Scott Stiurgis, an Arkansas attorney, filed a suit against Honda for the odometers collecting miles quicker than normal. Now they are seeking to investigate Nissan.
If you decide on a Honda Pilot I hope you end up with one of great quality !! :-) TiaCia
But, I wax irrelevant and somewhat rambling, for which I apologize......
Honda: Note to self; get RID of the knock & slosh, before I need to buy another wagon, please! :surprise:
When I was hosting Vans the complaints about the sloshing Odyssey gas tanks were numerous. The noise was blamed on the flatness of the tank, and the sound was noticeable even after Honda put baffles in the tank.
That said, most people said they got used to the noise and tuned it out after a few weeks.
The first year models were especially bad iirc (Road Tests: Long-Term Test - 7th paragraph).
The other factor that suprises me is the Consumer Reports Magazine does not mention this Honda imperfection, forewarning consumers. In fact the Pilot was highly rated, and I put my trust in those claims.
I'm sure I will get opposition, again, for referring to the knocking and swishing as an "imperfection" Go figure. Thanks again, NYBanker !! Have a Great Weekend !! :-) TiaCia
I can't hear the sloshing noise / thump YET, probably because I barely touched the gas pedal / brakes with the tip of the toe ! Also the dealer delivered it with only 2/3 of the tank full (?!), which could make the gas tank knocking sound dissapear (I guess ...). I will see later.
Questions for you guys:
1) Don't you thing that the steering wheel is too light at high speed (turns too easy at high speed) ? I was used with my 2001 Accord steering, which is way harder at high speed, which gave me a feeling of safety and accuracy on the highway.
My Pilot's steering wheel turns easy at high speed, and harder at low speed, which is the opposite of what I thought I should have (hard steering at high speed, and light steering at low speed in the parking lot). How is your steering at high speed vs. low speed ?
2) Do you get a slight steering wheel vibration (no body vibration) at exactly 75 mph or more ? Fortunately I always drive a bit slower than that, so it doesn't bother me, but I was just wondering if you have it.
:shades:
I have always driven a 4-cylinder Toyota or Honda. This is the 1st time I have a 6-cylinder, therefore I thought the more-power-factor is what caused the steering wheel to need more control when driving at high speed. I have actually gotten use to it. Thanks for sharing :-) TiaCia
This machine can fix vibration that other machine CAN'T
http://www.gsp9700.com/
It has demo & locate shops.
