thank you
could get their same contract via the internet cheaper, they beat that price.
Extended warranties are a huge profit for dealers, so there is bargaining room.
Since there is no observable detent on the main headlight switch at the vertical (all lights off) position off, this may why you have a slow battery draw down. Just a thought. ......Bob
My wife's 04 was doing the same thing. It turned out being the camshaft position detector. If you can, replace it yourself. You can order it online for about $30, and it's only held in place by 2 small bolts and the connecting cable. Took me about 20 minutes to do, and if you take it to a Crossfire technician, you will be charged a minimum of 1 hour maintenance fee, plus over $100 for the part.
My question is if anyone has driven this car through a winter, and if so, how did it do?
Help me, please...
that a Firestone dealer would carry Mobil 1 , let alone 0W-40. I would also ask about the oil filter. You want a fleece filter. And most Crossfires take at least 8 1/2 quarts oil, sometimes 9. Definitely check the oil level - and look at the quality of oil on the dipstick.
I would be concerned if they even changed the filter at all - you might want to look at that as well.
Next time buy an oil extractor and do it yourself. Everything you need to get to is
on top of the engine. Super easy.
Now is the time to sore my roadster for the winter. My garage is not heated. Please advise how to keep this car in top condition till the end of spring. What should i do with the battery and so forth. A detailed info will be highly appreciated.
Thanks in advance
Now is the time to store my roadster for the winter. My garage is not heated. Please advise how to keep this car in top condition till the end of spring. What should i do with the battery and so forth. A detailed info will be highly appreciated.
Thanks in advance
I too have an unheated garage that I store my 07 roadster in during the winter. I am sure there are many methods but I shall share my approach, so feel free to use/discard what you wish.
1#. I had an OLF completed
2#. Filled the tank with gas and added fuel stabilizer
3#. Parked the car placing the wheels upon 1/4 inch plywood to keep them off the cement
4#. Installed a trickle charger/battery tender – pulled electrical cord up toward windsheild
5#. Stuffed the tail pipes with rags and scented fabric softener sheets to deter mice
6#. Unscrewed the antenna and put in trunk (also put in a couple of fabric softener sheets)
7#. Placed an indoor denim cover (I was gifted this lovely cover – thanks Harold!!!)
8#. Placed fabric softener sheets on top of the cover and around the car on the floor
9#. Distributed mice bait along outside walls of garage (inside the garage)
10#. Placed moth balls along foundation of garage (on the outside)
I hope you find this response useful and I wish you continued enjoyment of your Crossfire – I know I sure love mine!!!
Cheryl
To the best of my knowledge none of the Crossfires have spare tires. I am going to speculate that they don't as the front tires are 18 inch and the back are 19 inch and if there were room for a spare tire, one would technically need two of the different sizes.
I believe I read in this forum that they are run flats (do I have that worded correctly? or is that flat runs?). I can't verify this but I am sure one of the forum contributors will clarify. Additionally, beneath the carpeted area in the trunk you should find a couple of cavities that contain a canister/applicator that is for use when you get a flat. Exactly what the canister contains is beyond me. Having said that, I am curious if tires that are filled with nitrogen can accept the contents of the canister? Perhaps someone can clarify this.
Something of note: My tires are filled with nitrogen and they came with a warranty. This summer I ran over a screw and took it to the dealership immediately. They repaired the tire and the fee was covered under the nitrogen warranty - a lovely surprise. (footnote- you have to take your car to the dealership where you purchased the nitrogen warranty or it will not be covered).
I hope this information is helpful,
Cheryl
The pluses about the car are so many that it would take too long to list.
the oil extractors. I know the big debate is that the extractors really don't
remove all the gunk on the bottom of the pan, etc. But since I learned that
all the Mercedes dealers are using the extractor, I figure that's O.K. with me.
The question is...how to disconnect the shield without damage?
You should be able to remove the battery at this point.
I purchased a new battery at SEARS. The replacement battery was shorter requiring a spacer to add height so the top retaining bracket would tighten. The replacement battery was about $130.00.
2004 Build Numbers "4X" 25,413 Units
000041 thru
025453
2005 Build Numbers "5X" 35,603 Units
025454 thru
061056
2006 Build Numbers "6X" 8,893 Units
061057 thru
069949
2007 Build Numbers "7X" 4,313 Units
069950 thru
074262
2008 Build Numbers "8X" 1,785 Units
074263 thru
076047
About 12 total SRTs were produced in 2006.
How did your ignition situation turn out?? I am having the same problem with min now...seems I have to push my steering wheel up and jiggle key...any advice for me??
Sam
Thanks, Sam
When I broached the ignition challenge with the dealership there were unable to duplicate the problem (as per usual - huge grin!) They did provide some advice that has been most helpful; press the brake pedal and turn the steering wheel while trying to turn the key all at the same time- the combination seems to work for me each time. I used to try your approach, but combining the brake pedal seems to be a critical piece - why - I have not a hot clue. I have been told by a friend (who owns a Crossfire as well) that the security codes within the key and the ignition have to match up and when they don't, the system ceases as in our case. I hope this information is helpful and should you happen to find an alternative fix, please let me know.
Sincerely,
Cheryl
today I received a "Back Glass Adhesion Extended Warranty" - 10 yrs 100,000 and if you didnt get yours... call the 800 number
ShaaSam
