Chevy Silverado: Problems & Solutions
good luck
On a Chevy Venture van, the gauge was acting similar, but ended up being the sending unit itself as the problem-worse part is it's in the tank and you need to drop the tank-hint to GM-make an access panel in the vehicle!!
Ray T. :shades:
I put it in 4x4 than when it made that noise he said that was normal. I said there's no way but he said yep and offered to take me out in a new 2005. Sure enough when he put it into 4x4 it made the same noise.
He said it wont do this in the floor shift ones but only the ones with the buttons on the dash. Something to do with a different transfer case. :shades:
I like the truck in all other aspects but very dissatisfied with the service about the transmission. I hope this helps you with your decision.
Mike
Mobile, Alabama
I noticed that the bracket "flexes" a bit (you can push the a/c compressor back by hand and you notice a slight flexing-movement of the entire bracket). Is this normal? Could it be that some bolt or part of the bracket snapped at some lower point, and now the bracket is not fixed as firmly as before? Does anyone know how/where the bracket actually fixes to the engine block (very difficult to see, unless you start taking things to pieces)?
Bracket also serves as support for dual alternator.
Thanks for hints. Eug
thanks a 3/4 ton....
That was about a week ago and the oil has shown up again.
Does anyone know how hard it is to change out this seal? Or How much it would cost to have someone do it?
I changed the gear oil in the front differential a few months ago with the truck sitting on an incline - so I over filled it a little - I didn't think much about it at the time but now wonder if a small overfill could cause the seal to leak? When I eyeball the bottom of the fill plug (which is the correct oil level) it seems about the same level as the bottom of the opening where the drive shaft enters the differential - could this be causing my problem?
Tomorrow I will park the truck on level ground and let the excess oil drain out - but It seems like even if it is over full the seal should still not leak.
Ray T.
I have the same truck but never had any problems with water leaks from the third door window. I have had issues with the door seals however. They tend to come off the track their pressed onto and if dislodged will allow water in. Has the window seal been tampered with or torn? Is the catch pulling down tight when closing & latching window against the seal ?
Ray T.
Anyone with any suggestions, PLEASE e-mail me at: rheck53@yahoo.com
thanks..bob
I have also had the problem with the seals falling off their tracks and solved that by siliconing them into place with silicone sealant and then closing the doors. The leak that I have is coming from the rear window and today I isolated the problem...a crack in the plastic. I tryed silicone, but that separated, so now I am going to use that PC-7 heavy duty 2 part epoxy which will usually fix anything. I am going to try and inject it into the crack using a small syringe. I hope that solves it. Thanks for the feedback.
Phil Riley
I had a similar problem with a 1968 Chevy Impala coupe - it had very large - heavy doors & they would sag - my uncle (who worked for Chevy as a mechanic) showed me a trick -
Open the door - lay a piece of 2x4 (3-4 feet long) in the door opening - slam the hell out of the door.
Sounds ruff - but it works.
I assume when you say 1/2 way home you have been driving for several miles. It would take at least this long before ice would form.
You can test this - if you run the AC for a while - say 25% of the way home - then turn the AC off - but leave the fan on high speed for a while - then turn the AC back on. This prevents the ice from forming. One the ice forms & the air flow is blocked it takes longer to thaw out.
Have you ever had the fan do this in the winter with the heat on?
