Chevy Silverado: Problems & Solutions
17810121330
  • meangene1meangene1 Member Posts: 11
    First off,I had an ongoing ac airflow problem that turned out to be low freon.We retrofitted it to 134,the R12 in it smelled strange though.
    Any way I have a new question pertaining to my 90 Silverado 350 5spd.Has anyone had any experience with a lopey idle perf cam not being compatible with the map sensor on this throttle body engine?
  • junsterjunster Member Posts: 12
    This is almost always a engine ground wire problem just remove clean coat with a little silicone grease (alot cheaper bought in a fly fishing store for keeping the line floating than auto store) reinstall it I know that sounds way to simple but is a common chevy problem.
    I don't like to sell things for ppl but do a search on dogpile,com for TBI and you will find a company that sells risers and such but they also have a fuel pressure regulator that is ADJUSTABLE in half pound incrediments. The stock Chevy ones vary from 11 to 12 and most 350's run best around 13. You just click it up a half pound drive around up another half till it doesn't get better then drop back down one click. Makes the idle so much smoother and the acceleration difference is amazing. Highly recommend the riser with relief slot cut between the two injector sides to give balance and the injector pod riser. The extra 1/4" of space makes all the difference in free air intake around the injectors. I have a 93' if the 90' has the same air box on the passenger inner fender remove it. Buy a 2' long piece of white pvc 4" drain pipe. ($2) Cut the hose that went to the old box from the air cleaner about in the middle then warm it with a hair dryer to get it over the 4" pvc without spliting it. Shorten the pvc till the fit to the original fender inlet is good. (the 2" piece still in the fender) It's a perfect fit to the pvc. Top with a new K&N air filter element and you will have a much better breathing engine and minimum 2 mpg increase. No $75 to $175 air box upgrade bull and something fun to talk about at the next up hood meeting.
    Please see reply/msg #465
    I need to know what type/weight lube is working best for replacing the old goo?
    I was fiddling around with my elec door locks to put in a remote/hidden button to pop the lock in case of accidently locking my keys in the truck.(Happened at the skating rink picking up my son and a couple of his friends I opened my door and then reached in and started the truck one of his buddies closed the door on his way by that my alarm had auto locked when I started the truck. Ya idle for 2 1/2 hours with the wipers on. Lifted them but no way to turn off the truck. Remote for the alarm hanging on the keychain, thanks chevy for a good sized radiator) anyway I accidently shorted one of the lock switch terminals. I have had no elec locks since. I replaced the switch but nothing have checked every fuse I can find all ok. Are there some hidden fuses somewhere?
    probably the crank or cam sensor if it doesn't "see" them turning it shuts down the fuel injectors. Junster
    Hard to diagnose this online but when my fan was rolling but no air was really going it was the little wire with a coil on the end that fastens to the heater baffle under the center of the dash I just worked the buttons air/hewater buttons and watched via flashlight for something to move when I saw the wire going but hooked to nothing it became obvious. As far as How cold can be a worn air compressor can be in need of a recharge, can just be a slipping drive belt. Make sure the serpentine belt isn't badly cracked or worn so badly that the grooves are thru to deep in the cords. I'd make sure your getting the baffles open all the way and letting th4e air flow. It takes mine at least 10 minutes to really get cold.I have a 93" too. Junster
    the new Pioneer deh-P8MP is about the best head unit out there. I have a alpine top of the line head unit that plays mp3 and normal cds has no internal amp at all work strictly off external amps I paid $750 for it. I trade it in a sec for this new Pioneer. It was designed from a broad collection of pioneer user input on what the idea car cd would be. It plays cd, wav, wmp (windows format actually with media player 10 is a good format) and mp3. Its satellite ready but with almost all car stereos you need the sirius under dash unit for pioneer it's SIR-PNR1 plugs right in. when you look this unit up online you'll see its way different than the "normal" car unit. All the user interface is on the driver side and the passenger side is all display. almost all the functions are controled with the main volume knob. It rocks in 7 different angles to select the mode you want, to adjust just turn. Works same as the optional audio stuff on new BMW's. Pioneer tuners have been best for FM for the last 2-3 years at least and couple it with a truly high quality set of 2 way separates in your doors and you'll be glad you did. Good quality speakers are in the 350 to 800 range. Where the differences really show is after they have been in the truck a year or so. A set of MK quartz separates cranked countless times, doors slammed over and over. windows open in the rain overnight. yada yada. will still be singing. cheap speakers will have died and caused you plenty of greif they always fail right when your tring to really show off. I bought my amps and bass from ebay and saved about 60% off retail key to ebay is be patient bid once 30 secs before the auction closes and bid the amount you are willing to pay. If it goes that high no suprize over and you wait for the next auction, less and you can affords better quality wires. there are 2 amps a dual coil 10" bass in a custom box fit behind the pass seat. the head unit, pair of $750 door speakers a after market set of pioneer 4" in the rear door columns and the originals in the dash, in my truck. the wiring was $200. If you truly want a 200hp Cowboy jukebox on wheels. do it right. the first time you pull up along side some snot nose kid with a blaring cheap tinny stereo blasting the latest rap. and you roll down your windows halfway or so and then let him have a taste of Toby Keith that shakes his doors he'll flip you off go peeling away and leave you with the most satisfing grin you have had in a long time. sorry to rant Junster
    use a piece of 1/4" doweling about 3' long with the truck running at the knocking point put the end of the dowel on the block then put your ear to the other end you can't believe how clearly you can hear whats going on this way. move the stick around carefull of the radiator fan. and see if the knock is in the top or bottom of the block. Top is usually a partially collapsed lifter that pumps up when the oil warms. noisy bottom is usually a bad thing. at least you will know. top can be a loose rocker arm too esp if the noise is strongest right under one of the valve covers. You will be able to locate the knock with in 3-4 inches with a dowel. Junster
    Contact Chevrolet directly and tell them you are getting unsatifactory service form your dealer Chevy takes those calls very seriously.
    O2 sensor will just give you bad milage and a to rich mix. Check crank sensor and cam sensor if the ground wire dosnt help. Note: replacing the single wire O2 sensor with a 3 or 4 wire one is a great upgrade. My 93' works well with a 3 wire for a monty carlo. the extra 2 wires on a 3 wire are a 12v power and a ground. Heats the sensor up to the correct temp for reading the exaust residual gases in about 10 secs. The 1 wire most of the time never gets hot enough to work right. 4 wire ones have separate grounds for the heater coil and the sensor but the 3 wire is fine for the lvl of computing chey trucks do. Junster
  • madman3madman3 Member Posts: 1
    I have a new 2005 4door z71 pickup with only 4500 miles on it. The front brakes overheat to the point where you can't touch the rim and the front end will start to shimmey. This only happens after I drive over about 60 miles or so and when it's over about 75-80 degrees outside. The dealer says they can't duplicate the problem (imagine that). Anyone have a similar problem / solution?
  • baggedbagged Member Posts: 1
    i have a 93 chevy dually check engine light on and all it say is "43 esc" it runs fine but when under a load it bogs .. after it comes out of the load range it shoots out like a rocket i can figure out how to fix it ...ANYONE HAVE ANY IDEAS ???
  • jjtjjjtj Member Posts: 80
    If the brakes are overheating while driving, and not when they're actually being applied, I'd have them check for a stuck caliper or a kinked brake line. Sounds like something is applying pressure to the brakes without driver interaction. If this turns out to be the cause, I'd probably push for new pads & rotors too.. if the rotors have been heated that many times, they are probably warped & will cause a pulsation in the brake pedal (a personal pet peeve of mine!), plus your pads are most likely prematurely worn, maybe not all the way, but much more than they should be with 4500 miles.
  • whiteboy88whiteboy88 Member Posts: 3
    hey,
    it could be your ring and pinion,(differential), i had that problem with my 93 chevy 1500. mine went out on me. if it starts making a winding, or a siren noise, then it is your rear end.
    pour some gas in the carburator, let it sit for about 10 15 min. then try it. what prob. happened is the carburator is bone dry. hope it helps
    you could have a few chipped or broken teath on your fly wheel. i had that problem, it will start sometimes and others it wont
  • minniescarminniescar Member Posts: 7
    Originally i posted this problem in the wrong forum and ive worked on the truck more so i figure its better for me to post it here. Anyway i have a 97 silverado with a 350 vortec in it that has decided to die on me. Originally when you first started it up it would run then die within a few seconds and you could restart it and it would be fine, it did this intermitently. Then a week or so ago i stopped at a gas station and bought a soda then came out and the truck would die when you gave it gas. The truck flat out quit on me for a few minutes then restarted and would run like crap for a quarter of a mile then die again. Luckily i was only 3 miles from home so i limped home i never once got a check engine light to come on. I got out my book on the truck and started checking readings on all the different sensors and everthing checked out ( i did trip a few trouble codes while doing so but i cleared them.)
    At this point i decided to go for the basics , its eather fuel or fire so i replaced my fuel filter and since i didnt have a fuel pressure gauge i placed one in line where the filter normally went, The pressure read 20 when you first turn the key on the 65 when you started the truck , if you stomped the gas and the truck died the pressure never dropped from 65 so i figured thats not my problem. Additionally the whole fuel system was eitehr replaced or flushed by the dealership around 10k ago so i really didnt think it was my problem but hey i checked it anyway. I also changed my tps becuase i got a trouble code from it but it turns out i caused that trouble code by having it unplugged when i started it once ( oops ) Then someone on the web mentioned the MAF sensor might be dirty so i took it out and cleaned it which it really didnt seem to need it ( looked clean and shiny )
    Next i changed my distributor cap and button even though they too didnt look like they needed it. I noticed when i changed them that the distributor was loose so i thought maybe that was my problem. I adjusted it back and forth and i got no change so i got online and read that i needed to get the engine to tdc and line the button up with the number 8 molded into the base of the distributor ( not the number 8 contact but the number 8 on the base of the distributor cap ) I lined it up and locked down the loose hold down clamp and still no luck. The truck runs like absolute crap, it idles pretty good but as soon as you put it under load like shifting it into reverse it dies. If you step on the gas fast it dies, if you real slowly give it gas it will rev up in park allmost like normal but you have to be real slow on the gas pedal. Anyone have any ideas? Ive gotten to the point ive told my neighbor to look out for the flaming truck rolling down the hill towards his house because i feel like setting this thing on fire.
  • djmrobertsdjmroberts Member Posts: 1
    Have you figured out why your truck wouldn't go in reverse? I am currently experiencing the same problem. I have a 02 GMC 2500HD Crew Cab and I went to back up the other day, put it in reverse and the truck would go nowhere. Once the truck has cooled it will back up. Have taken to 2 shops (one transmission) and they cannot figure out.
    Would love to find the problem quick!
    Not sure of your mileage, but a fluid & filter service might be a good starting point if you haven't done this already. A dirty filter can prevent fluid from going into the valve body & cause problems like the transmission not going into the correct gear.
  • gmtruckguygmtruckguy Member Posts: 5
    I have a 2000 silverado, 4.3L V6 with 81,000 miles. And for the past 2 months or so, it starts up fine and the engine sounds good until you give it gas at all. And until the temperature is almost all the way to normal operating temperature, the engine feels like it misses alot and I can't figure out what is wrong. This happens mostly above 2000 rpm. About 6 months ago, I replaced spark plugs, fuel filter, distributor cap and rotor, and air filter. Recently, I took it to the local shop, who said it was the fuel pump. Had that replaced, no difference. My guess was either the oxygen sensor or crankshaft position sensor, but the check engine light should be on if it was either of those. any help would be great!
  • ducker1ducker1 Member Posts: 3
    I had the same problem with my 02 noticed it more when wheel was turned to the left. took in to dealer they said they took the steering shaft apart and greased and it was fixed. that occured at 22k i sold it at 57k with no more problems. I now have an 04 crew cab with 25k and its doing the same thing.
  • isaacintxisaacintx Member Posts: 1
    I recently got a hold of a 1984 Chevy Silverado, and I am wanting to install a cd player to it, the previous owner had replaced the old cassette deck with a new cassette deck(why i have no clue) but he did the wiring all himself and i cannot find the remote or ignition wires that would normaly hook up to a cd deck, the only wires i have been able to find are the power and ground wires, my friend said that in order to power the cd player i need to find the remote wire, i already tried to just use the power and ground, but nothing works, so can someone tell me where i can find the remote, or where i can add a wire that would be a remote wire, i would really appreciate the help. :)
  • aeh4543aeh4543 Member Posts: 1
    My husband is currently on the road, on his way home from California to Michigan. He's been on the interstate since 0700 PST, and it's currently 1740 MST. He started having problems at about 1700 MST. This problem has occurred before today, but obviously he has not been able to solve it yet.
    The current problem is that the truck keeps losing power (it has only stalled out once so far) - he cannot seem to go past 25 mph. When the engine temperature reaches 220 to 230, the vehicle will start backfiring when the accelerator is taken past one quarter open throttle (when he pushes the accelator more than 1/4 of the way down, the truck starts backfiring and losing power; the more he pushes down, the worse the backfiring gets).
    So far he's been able to deal with this by pulling the truck off the road and allowing the engine to cool off for anywhere up to an hour.
    Considering that he has over 1500 miles to go, I'm trying to find a fix that will at least get him home (and we can take a more in-depth look then).
    Any ideas?
  • chevy_beastchevy_beast Member Posts: 2
    The brake light wont come on except the cargo light, and i cant seem to find out why. I am thinking of bypassing it by tapping into the cargo light and seeing which one of the wires running to the taillights operates the brake lights. Do any of you guys have any suggestions. This truck need brake lights. Or else i cant pull the cabinet shops trailer.
    The hazards all work, blinkers, running lights. All of it. No bulbs are burnt out, and no fuses gone. I also changed by brake switch, And no luck there.
    It would be appreciated
    Ray a New member. :confuse:
  • mm1422mm1422 Member Posts: 3
    I am looking into getting a leveling kit installed in my 2005 Chevy Silverado and wanted to ask if anyone had any suggestions, recommendations, or anything else that would be useful.
    You want to bring the front up? or the back down? Knowing that will greatly increase the odds of a correct reply.
  • noobie1noobie1 Member Posts: 326
    220-230 deg. is not normal operating temperature for that vehicle. More likely 205 deg. is. Often, especially with engines with lots if miles, pre-detonation (misfiring) occurs when running that hot. I suggest he check into a garage to have the cooling system tested. It could be something as simple as a stuck thermostat.
    -David
    I have a 95 K5 2 door.When the wife backs out in the morn and hits the last part of the driveway which drops on the right side-there is a clunk that sounds possibly like either a suspension part or maybe an axle as it is 4wd,
    My parking brake cable broke on my 2000 Silverado today.. the little lead looking piece on the end that holds it in the hole broke off. So, I took the kick panel off, then you gotta take the fuse block out, then the release cable, etc. etc. The cable won't be in till Monday, but I can't for the life of me see where that cable attaches to the pedal.. it's real close quarters, you're on your back, under the dash, with the drivers seat right next to you. Anyone ever done this job?
    Jason
    Mine took about 7 minutes to replace. Removed two screws, remove the old cable assembly, run new cable and attach where old cable existed. Replace screws holding the handle. Was surprised that the part was under $20 as it includes a new handle and cable. Then again it is cheap plastic.
    Are you talking about the parking brake release lever? My parking brake pedal is metal and is a pretty good sized assembly.. plus you can't easily remove it from the wall of the truck, even with the 3 1/2" nuts removed.
  • 94_chevy94_chevy Member Posts: 6
    hey
    i have a 94 Chevy 1500 Silverado and my speedometer and tach are not working but my battery, gas, oil pressure and the other gauges work, does anyone have any ideas to fix this problem
    thanks Aaron
    You said the parking brake cable. If you ask the parts dept. for the replacement parking brake cable, they will give you the cable and the release lever as a single part for replacement.
    Now I'm assuming you're talking about the small cable on the pedal side? I'd have to look that up in the shop manual. If I can find the thing somewhere around here. Is that the cable that you're referring to?
  • dave50dave50 Member Posts: 22
    I have a 99 4.3 astro that had a similar problem. The mass air flo was causing alot of trouble well before it sent a trouble code. It's worth a try, take it out of the intake tube and clean it up good with carb cleaner and wipe the sensor wires with a clean cloth and cleaner. It did miracles with our van. A mechanic told me to do this. Good luck.
    That's the one.. it goes from the pedal, out the floor and then back to about the end of the cab where it hooks into another cable section that then goes to the rear brake.. I ordered the cable as the front cable.. hope this makes sense. Thanks for the help.. Jason
  • falcon241073falcon241073 Member Posts: 4
    I have a 1992 C1500 with a 350 ci engine. It seems to be burning oil. About a quart every 400-600 miles. I only notice smoke coming out of the exhaust every now and then. I will hear a slight rattle sound and then a puff of whitish smoke will come out of the exhaust. Someone told me it was "Blow by" in the engine. What can I do about this. I have, at the recommendation of the guy at the parts store, tried Lucas in the engine. I check my oil at every fill up and have switched to a thicker oil, 10-40.
  • marxazmarxaz Member Posts: 1
    My wife and I changed the transmission fluid and filter on our '99 chevy k1500 and now drive don't work right.It acts like it is starting off in 3rd gear.I put in first,second and so on and they work fine but like I said drive won't.Has anyone had this problem if so please help
  • plima20916plima20916 Member Posts: 3
    I just bought a chevy cheyenne with a 350. It has 170,000 miles on it. Once in a while the thing does not want to start. Usually when it's hot. I'm not sure what's going on. Is there some sort of sensor that I can replace? It will fire up no problem for most of the day then WAM! It won't start. Any suggestions would be greatly appreciated. thanks
    Not sure without being there but it sounds like a loos wire. Might be a ground wire on the sloinoid or starter. Is the starter turning?? Any noises at all?
    Did you remove the valve body? The bolt lengths are critical and caused me not to have reverse along with other issues. You may have disturbed a wire connection on a solenoid. I wouldn't panic yet. I would stop by a chevy dealer and ask to speak to a tranny specialist. He may be able to pin point the trouble.
  • mt_huntermt_hunter Member Posts: 3
    Hello all I am new to the forums. I just traded in my 96 explorer for a 2003 2500HD chevy silverado LS. I am very pleased with its performance. I live in MT and intend to do a lot of hunting with this truck. Well here is my question:
    When I bought the truck the horn didn't work, the 4x4 light on the sterring wheel dash and tow light do not come on. I did look at the owners manuel and did figure out the horn problem. I changed the fuse and it works great. Does anyone know where or what fuse the tow light anf 4x4 fuse are. I tested it out and they both work. I took the pick up off roading and the 4x4 worked great. It is a 4x4 on the fly. It s on the left of the sterring where dash. That works great but I can't get the town lights or 4x4 light to work on the dash....Please help.........
    Bring up the front so its level with the back. What products are good and where can I have this done?
  • chevy99chevy99 Member Posts: 3
    Recently my ABS kicks in at time it should not. It tends to happen more when stopping at slower speeds and when on an incline. A friend of mine had a similar problem and it turned out to be the ABS sensor. Any ideas would be great. Thank you.
  • giterdone166giterdone166 Member Posts: 1
    There is a bolt 18mm at the rear of your torsion bar which is the long bar under your front doors and you can turn that bolt clock wise to lift your truck 2 inches FREE! it rides the exact same and everything. and if that is not enough you can buy new torsion keys which can lift up to 4 inches to level at installed at any 4x4 shop but with torsion keys you are looking $400+ because you have to get new shocks and also labor.
    check and make shur the grounding in the taillights has contiuity.
    Thats the green wire right?
  • steve4223steve4223 Member Posts: 1
    Justin,
    Did you resolve your problem? My 2001 Siverado 5.3L started doing the same thing today. I've got 58,000 miles and after it has sat for 30mn or more, it takes several seconds to start, but once it's been running, you can shut it off and it will start right up. I was thinking leak in the line, causing it to lose pressure, but advancing the key for several seconds before starting didn't seem to have any impact on the slow start.
    Hoping you've got some light to shed on the subject...
    Steve
    can no one help me? Any one got any thoughts??
