Chevy Silverado: Problems & Solutions
Bob
Thanks again!
check your fog lights to see if they have water in them. we just
purchased a 2000 chev 4x4 ext. and found that BOTH lights
had water inside.
obviously, it's a manufacturing defect by GM. Fog lights should
NOT fill up like swimming pools.
this could be a catalytic converter problem, oxygen
sensor etc..
you need to contact their service manager and demand
they go through the truck looking specifically at
fuel related issues....
otherwise they will ignore your requests until the 31st day
of your purchase!!
I would like to fix this problem for good I have tried changing fuel filters. Has not helped. The fuel pump is electric and can hearing it running. The fact it dies and seems to reset it self leads me to believe it is computer related sensors or something. If anyone can help me with my problem. PLEASE HELP!!!
I have an 89' Chevy Silverado. It is my pride and joy. It has a nice V8, and the interior and overall truck itself is in great condition.
Anyway, my truck is making an odd sound. You know when you first turn on a water hose, and you hear the first few drops sputtering out? That is the sound my truck makes sometimes. I can park my truck, and gas my engine, and hear it. I have several holes on the top of my muffler, but my friends told me that probably wasnt it. I am not to worried, I am just kind of wondering what it is. Its just tiny little sputters. Other than that, the truck drives great, and all is running good.
Any clues? Thanks.
-David
You hit it right on the head with "gurgling". I'm going to ask my uncle about that. That might very well be whats wrong....
Thanks alot!
BTW, does ya'lls ignition ever lock up? Its hard for me to turn the key sometimes. It might be because my key is so old.
-David
Dave
I just discovered that the sound can actually be heard outside the truck as well....By my muffler infact.
Any ideas?
I'm sorry for so many questions, but I do not know anything about trucks....
I love Chevy trucks but they need a recall on this as well as the anti lock break sensors which corroded at a cost of $600.00
That will make your trailer hitch plug power wire feed hot.
The GM garage is correct. Here's GM's explanation:
Engine - Knocking on Cold Start Explanation
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 01-06-01-028A
Date: March, 2003
INFORMATION
Subject:
Engine Knock on Cold Start
Models:
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models
2002 Cadillac Escalade (2WD)
with 4.8L, 5.3L or 6.0L Engine (VINS V, T, Z, U - RPOs LR4, LM7, L59, LQ4)
This bulletin is being revised to add an additional engine to the models section. Please discard Corporate Bulletin Number 01-06-01-028 (Section 06-Engine).
Some of the above vehicles may exhibit an engine knock noise that begins in the first 19,000-24,000 km (12,000-15,000 mi) of use. The knock noise is most often noticed during initial start-up and typically disappears within the first 5-30 seconds (may last longer in extreme cold temperatures). The noise is usually more noticeable on the initial start-up when the temperature is below 10°C (50°F) and may be more pronounced on the first cold start following a long trip.
This noise may be caused by an interaction between carbon that has formed on the piston, the piston motion and the cylinder wall. GM Powertrain Engineering, and an analysis of engines with this condition, has confirmed that the noise is not detrimental to the performance, reliability or durability of the engine.
THIS NOISE DOES NOT HAVE ANY EFFECT ON THE LONGEVITY OF ANY OF THE ENGINE COMPONENTS.
Important: At this time, attempts to repair this condition by replacing the engine assembly or pistons are not recommended.
Please share the information found in this bulletin with customers who inquire about this condition. In the event they have additional questions or concerns, please advise your Area Service Manager.
I have a 2003 chevy silverado the other day my abs light came on so I pull over to the side shut the engine off but I still here something underneith still running its some sort of pump and the only way to shut it off was by pulling a fuse I'm pretty good with tools now do I have to replace the whole thing or is something just stuck that can easily be fixed and how much is that part, thanks loaiza
I have a 95 silverado 350. I drove the truck home and it has been running fine. The next morning I went to crank truck and it will not fire. I have changed the ignition module, fuel pump, pickup coil, and had the ignition coil tested and it was good. The truck turns over and over but will not fire. I took a 12volt tester and I am not getting power to the module or the fuel pump. I have tested all of the fuses and everything else tested good. Any suggestions would be greatly appreciated as I am out of ideas as well as alot of others.
-David
I called my local dealer (some kid answered) he told me he didn't know, and they never got back to me.
Any help would be appreciated..
bob in pa
Ray T :shades:
Ray T. :shades:
Any ideas from anyone as to what I'm doing wrong here? The bottom of the horse shoe shaped shoe is worn down to the bare shiny metal and the sides look brand new.
Andre
Ray T. :shades:
Has anyone found the solution?
Thanks...
lj
kcram - Pickups Host
They should've done the reinforcing that they do on the crew cabs and SUVs (shaped ridges running front to back in the metal). Our 2003 Trailblazer had those and didn't deform when I leaned on it or act like a drum in automatic car washes.
She gets a new battery at Sam's Club.
A week later she is driving from PHX to LA. Stops for fuel. Again it hesitates on cranking, once started all the guages are going from "0" to full, all the dash lights and message center are flashing.
She stops and checks the cables ( they seem tight) and when restarting all seems fine.
Any thoughts?
Thanks, Mike
Ray T. :shades:
