Just a thought.
Best Regards,
Shipo
I've got a call into the VW dealer and they are checking with their lead technician and will call back. I'm hoping that since there were no problems before the engine issue, and since they just completed the repair this week, they will take care of this repair.
Of course, I do understand that there is always a "wear and tear" issue which is not covered. I'm not someone who will rant and rave over something that the dealer really has no control over and is not responsible for. It could be some other type of problem as well. I'll just hope for the best.
Regarding the thermostat, I have no idea whether they used your old one or put in a new one with the engine. Either way, these things do fail from time to time and are generally a very cheap fix.
Best Regards,
Shipo
By the way, I heard from the VW dealer a little while ago and they said that they want to take a look at the car since there should not be this type of heating problem. I told them that their was no heating problem before they replaced the engine. They are even going to give me a rental car when I take it in next week.
I just hope that their goodwill extends to this repair as well, especially if it is not an unrelated part failure. We'll see.
Your experience is definately more scary.
According to dealer it is $200.00 fix.
I think one can find directions on Internet how to do this oneself.
Krzys
I just purchased a 2004 Passat Wagon GLX V6 43K miles. I have felt/heard the same "kerplunk" when stopping as you describe in your 1/13/07 post. Does not happen every time I stop. Did you ever discover the cause of the problem?
MDF
Any suggestions?
www.getcoolparts.com has 'em for $35.28. Buy a couple of other items and get the total above $50 and the shipping will be free.
http://catimages2.sophio.com/webapp/wcs/stores/servlet/imc/images/full/339711892- 5.jpg
You can replace the rubber inserts and they sell those, too. $21.15.
http://catimages2.sophio.com/webapp/wcs/stores/servlet/imc/images/full/000824992- 7.jpg
Help Please !!
Regarding your question: Do they not work at all or do they work for a while and then blow a fuse? If the latter, does the car have heated seats? If yes again, try the having the seat heaters disabled and see if that makes a difference. I remember hearing that some of that generation of Passat had an insufficient electrical system to support all of the peripherals operating at the same time, and the seat heaters always seemed to be the primary culprit. I had a 1995 Passat GLX (loved that car by the way, great engine) and never blew a fuse on it, that said, I hate seat heaters and so I only tried them a time or two just to see if they worked, and then left them off for the next four years.
I hope this helps... Keep us posted on your progress.
Best Regards,
Shipo
I want to thank you for the information. She is going to call the Garage first thing
Monday AM and have them disable the seat heaters...and see about replacing the wiper motor and the heater...They have no idea why they don't operate...it reasons
out that the seat heaters shouldn't be used and that they're the culprits that started
this mess...post again when we have something new...Thanks again : )
Hot oil smells like hot oil. Gasoline smells like gasoline.
Are you losing coolant? Watch the level carefully and see if it's dropping.
Fuel FIlter
Spark Plugs
Air FIlter
Cabin FIlter
Oil Filter
Also, anybody have a link to a DIY site for 03 Passat's with pics?
You can't go wrong with Mann filters. I'll let others comment on the other parts.
Fuel Filter: I used a Bosch.
Air filter: Mann C26168.
Cabin Filter: I used a Bosch.
Oil Filter: Mann makes a nice product.
Order the whole kit from a place like getcoolparts.com or stpshopanddrive.com and get free shipping.
Just a shot in the dark.
Krzys
Here is another question:
Does anyone know of a place to get the Volkswagen Passat Bentley Service Repair Manual 98-05 cheap? I think the best I found was on amazon for $81 with free shipping.
I also checked ebay and it was pricier, but I found a lot of other repair manuals. However, I am worried they may by rip-offs. Here are two examples:
VW Service Repair Manual Passat 2000 2001 2002 2003
and
VW PASSAT 1998 - 2004 2005 OEM SERVICE REPAIR MANUAL
Anybody have any experience with these? Are they legit? Are they any good? Any other feedback on them?
I just wanted to report that yesterday I recieved a recall notification about the possibility of my '06 Xenon headlights subject to condensation. VW is driving a campaign to fix the problem. The recall also mentioned that cars equipped with the park distance control may be faulty and they will fix this problem as well. Letter says fix should take around 2 hours.
I hope someone can shed some light on this intermittent electrical fault on my 2002 Passat TDI.
The problem: The heater, rear demister, indicators and headlights don't work.
The hazard lights work okay..., the radio is fine..., the drives fine.
The main dealer has no idea what it is. The fault happens at any time of day, not just after raining, or when its cold, just whenever it feels like upsetting me. I've changed fuse 25 (30amp) as that seemed to be the most likely, but the fuse was fine.
Any advice welcome.
cheers
Nish
A friend of mine accidentally broke a thin pipe, which leads to 'blue can' on the left side under the hood. The car model is 2001 Passat GLX V6.
Can anyone here tell me what the 'blue can' is and what the system belongs to?
Thanks in advance.
SDD
If you can get a Haynes Manual that would be good. I haven't got one for my Passat, but i have had them in the past, and they all worked out fine.
cheers NishW
thanks for advise.
Best Regards,
Shipo
Or, if there is any linkage that I can adjust???
I got this 2000 V6 GLX 5-speed 1-month ago...
Car has 224K Km on odometer; but the engine + transmission was a recycled one; clutch, startor + battery are all new (I believe it has been stolen & insurance company replaced the above parts..I have the receipt on hand)
It only has 7000km after that.. Paid Canadian $5K for it.
Is there any way to check the year for this second engine???
(called dealer with VIN #, no record for timing belt changed record)
Car is running strong & only 1 code pop-up :P431 (the oxygen sensor after
catalyic converter) I will replace this later on. not a big deal.
As finding out the history of your engine and tranny, I have no idea how you would go about doing that.
Best Regards,
Shipo
