Pontiac Grand Prix: Problems & Solutions
I have to do this and am looking for a little advice.
Also, from anyone who has done this job, do you have any idea how tough the job was? I'm going to a dealer to get the part tomorrow since the car parts store said they would order it (takes 10 days, I was told).
I have read that there are numerous occurances of this type. Makes it unsafe to drive, since you can't safely leave and lock the vehicle.
Maybe the insurnce company can help me since they are open for claims.
The only thing I have found is: If you let it set for 10-15 minutes and turn it on and back off the key will turn fully off.
I notice that the shifter indicator light stays lit when this event happens. That is what led me to believe it was a shifter problem early on. :mad:
This solved my leaking problems. If you can't find it I can send you a pic of my cars elbow. Hope this helps.
ok, here's my question : when replacing the oil and filter for the trans mission, i would like to go with synthetic, what brand/kind should i use. i have seen plenty of synthetic engine oils but i dont think i have ever seen syn trans fluid.
thanks,
steven
I don't know for sure but thought I would throw the posibility out there.
Earlier models had the light mounted inside near the roof .... a better idea, but must have taken more wire so it was a cost issue. The best idea yet, is to mount the lite OUTSIDE on the roof, rear panel or trunk lid giving you full access to the rear window. I often wish I understood the mindset of designers.
Your Pontiac was Correctly responding to you using a key that was Not programed for your car. Look up PASS-Key in your User Manual. Your original key has a chip inside that sends a signal to a decoder in your car that allows you to start it. PASS-Key is a theft deterrent feature of your Pontiac. You need to purchase a special key with the chip inside and then follow the instructions in your owners manual to program the new key to your car.
Hope this helps.
Kevin
once again any info will help me a lot. tks.
Also, they charged me $115 ($100 deductible plus taxes...Canada) under my GMPP(extended warranty) to replace the catalytic converter. Is this not covered under the 130,000km emissions warranty and should be replaced for free?
Thanks in advance for the help!
i am having the same problem also, i just took my 02 gt in and it was the catalytic converter also. mine will be replaced free of charge, due to my car being under the 80k mile warranty that is put on all catilytic converters by law. i am not sure though if they can charge for the labor. i will find out tomorrow about that.
My girlfriend has a 99 Grand Prix. When you turn on the AC - the day time run lights go out and the AC doesn't come on, but you can sometimes turn the headlights on with the light switch and the ac will work. Is there a sensor for the AC that could be causing the problem? The unit had been working fine, until she took it to have the oil changed. They told her she needed to change the transmission fluid, which they no longer drop the pan and change the filter and fluid, they just give it a transfusion, so to speak. Is it possile that they unhooked the wrong line, bleeding out the freon casing the the compressor not to function properly and drawing excessive current?
