Visitor Agreement.
Yes, I'm old enough to remember when Detroit was pumping out the "muscle cars", and then losing a ton of money on warranty replacement engines. I had a few neighbors, a little older than myself, who were the heroes on Main Street, and tore up a few engines while earning their titles.
I fully understand that buying a car from someone like that might have been questionable, as those cars were flogged really hard. Yes, those cars probably had "diminished value", by virtue of the replacement engines...as well as the abused clutches, tired rear ends, worn brakes and suspension parts.
Let's suppose, however, that some average driver has a car that is subject to some fluke failure. The car wasn't abused or neglected, but some part that should have lasted the life of the car just wasn't made correctly. Say it's a crankshaft, and it was poorly cast, and it broke after 3 years and 40,000 miles. Is the car owner just supposed to junk the car and eat the loss? If the car is still in good shape, I doubt it.
If it were my car, and I really liked the car, I'd put in a new engine and continue to drive it. Sure, at some point in the future I'd probably sell it for something newer, but then am I supposed to proclaim that at some time in the past I replaced the engine?
If the car is a fully functioning, good running vehicle, what's the difference? You replace tires, belts, hoses, and brakes, don't you? If a water pump leaks, you replace it, and go on, don't you? The latest thing in fashion is the timimg belt. They supposedly last 70,000 miles. You replace it, you go on.
I'm not saying that you conceal an engine swap, especially if you're trying to sell a "numbers matching" collectors' car, but immediate disclosure of the swap?? On an "everday driver" kind of car??
Like I said, I must have missed something here.
With reman engines having failure rates 10 times higher than original engines, and being constructed from engine blocks (same goes with transmissions) of unknown origin, mileage and questionable integrity - we don't know if the blocks were x-rayed, machined, inspected or just cleaned up and filled with parts, some of which are not new. These factors make a vehicle with a reman worth less than one without a reman.
While there is a good chance a reman engine may last as long as you need it to, the odds are against you.
I've looked at cases from Ford, Chevy and Dodge where during a reman engine installation, the technician had two fresh remans fail in the shop before getting them out for a road test. I think about that every time I see a reman in a car.
Now, if I had a older truck or car and it made sense to drop $2000 on an engine (installed), I'd do it. For instance, I'm looking at a '67 Chevy truck right now and I'll probably put a GM crate motor in it. Bear in mind, the typical "crate motor" is built to better specs than the base reman replacement engine. A GM Goodwrench "Targetmaster" - not a chance.
Unfortunately, those engines used during warranty replacements are not built to great specs, just borderline.
Don't let the existence of a warranty fool you. It certainly doesn't mean the part is perfect, it just a requirement of federal statute.
Cool HRE wheels, too.
GM has a whole line of performance crate engines (called crate motors 'cause they're shipped in a crate and are pretty much ready to go) that are set for high performance applications. Also, everything in teh engine is new - everything.
An OEM-type reman does not fall into this category. A used block is used, it is usually x-rayed and then the components are checked for tolerances. These tolerances are BROAD. If the rods, crank and pistons meet these broad tolerances, they are cleaned up and reused with new bearings. If parts are bad, only those parts are replaced.
In many cases, you just get a used motor with new bearings.
It is a very RARE, ALMOST NEVER occurence when someone gets a real live, just like they put in at the factory, new motor. I see hundreds of cases, and over the last year, I can only recall 2 cases where a new motor was shipped in from the factory (one Ford, one Honda). All the others were reams just like I described - a good wash job, a rattle can spray paint coat and new bearings.
Now THAT'S an engine that should be disclosed prior to a sale.
When I do my engine, the only original thing will be the block, because I'm changing the rotating assembly. The block will be steamed, x-rayed and magnafluxed, so I won't worry.
We might do well to subscribe to: If it breaks, fix it and sell it-- then, go buy a new vehicle![:oÞ
"Crate motor" isn't a dirty word - "reman" is.
Having different size pistons in the same engine??
I remember seeing a rebuilt short block on a stand in a discount auto parts store a few years ago. It was a small block Chevy.
The pistons were stamped .080. I don't think I would want a block that had been bored that much!
And yes, remans sometimes have different size piston bores, which can, and will, cause stress on the crank bearings over time, causing premature failure. That's why I hit cars with remans so hard and why I'd never buy one. A crate motor, with all new rotating assembly on a checked-out used block? Sure, but it still would devalue a newer car.
My '86 Mustang? I don't think having a crate motor (actually a rebuild using my block, plus aluminum heads) will hurt its value.
He bought a snomobile really cheap. It was a twin cylinder 440 that actually ran pretty well. He couldn't figure out why he got such a good deal on it. One day, for some reason (I forget why) he pulled the spark plugs and looked in the bore. Didn't look right, so he pulled off the head. The cylinders had 2 different pistons in them, and one had a hole in the top patched by a BOLT AND WASHER plugging it up. And this was in the mid-seventies before anyone had heard of McGuyver.
He ended up replacing the holed piston selling it off to someone else.
Dave
Harry
I strongly considered this option for my Mustang, but I'm doing a knife-edged crank, Crane cam, Carillo rods and a gear drive (instead of a timing chain), so I would have to change way too much stuff.
I'm thinking about it now because the last vehicle I owned and sold was severely cut in price because the inspector they took it to used a "paint spectrometer" on it and noted that it had been repainted. What really happened is a year before I sold it, the car was hit on the front fender by someone. Because of this, the front fender and hood was replaced but there absolutely NO other damage (total repair was under $1,500). Of course they dinged me $6k.
This was in 1999 and the car was sold in 2000. I had never even heard of "diminished value" at the time but now I hear about it all the time. I have a friend who's Tahoe was creamed a month or so ago and we were talking about it. I would like to give him some info but don't know enough about it.
The older and higher mileage vehicles usually have lesser DV. However a 10 year old "virgin" will usually bring more than a 10 year old damaged one.
I saw on one of these threads months ago that GA had passed legislation requiring ins co's to reimburse for 'diminished value'.
I had a recent theft claim, and it took a 'claims trouble shooter' on staff with my insurance agency to get the adjuster on the right track. So, I'm thinking your insurance agent may be of help. Settling a claim is like buying a car, I think, with a lot of hooey sorting through called for. LOL, the claim form on my 'total loss' was fishing for 'diminished value' with questions about previous repairs; so, I feel certain that adjusters understand the concept. Whether or not they will voluntarily compensate you is a totally different question.
Since you lease, my guess is that you'll face the argument that you have no actual 'diminished value', i.e. no actual loss; and I've got no idea how that would play out.
He got a check yesterday from the other insurance for a fair "diminished value" settlement and is quite pleased.
Furthermore, according to my insurance broker, this diminished value is not a litigious issue, at least not against the insurance company.
I'm not sure if there is case precedent of someone selling the car right after the accident, thereby crystalizing the diminished value, and then suing the at-fault party.
Ten Grand ...? and it wasn't totaled ..?
Obviously I don't know the miles, what type or model Civic it is .. but the super clean, super nice 20k 00 LX's, are hardly breaking the high $9's at the auctions .. this pup "may" be worth $5/$6,000 on a trade and "maybe" $8/$9,0 "asking" on the retail side .. whooof $10 grand ..? - I'm sure there's gotta be some frame damage some place, besides that, a dealer will spot the work with their eyes closed and a private buyer probably will too - plus this has to be declared at trade or at sale time .. ouch, this is a nightmare waiting to happen - sorry.
Terry.
In some states, compensation for deminished value has become routine (GA for one). You might wanna check with your insurance agent.
Terry.
The frame was not damaged but there was significant repairs to the car overall.
The car is now finished (using a very reputable repair shop and only Honda parts) and I am trying to figure out how to price it.
I know what the Blue Book says but I am assuming I should take off some $ b/c it was in accident...but how much.
I plan on giving whoever buys the car photos of it right after the accident.
The Odyssey may be fixed "perfectly" but it's still been wrecked.
Most people wouldn't want it unless thye could steal it.
Maybe some of the others here have a better grasp of this than I do but it would be hard to apply a hard number to this.
-Ryan
Terry.
Terry, what are you doing posting at 04:11??? You know how we worry.
-m
