Did you buy it at "Right"?
If you call Scion customer service and give them your VIN, they can tell you if the TSB applies to your car.
Apparently they fixed the problem during production, so later units are not affected.
The Scion, although aimed at the youth market, is much more upscale in terms of sound proofing, materials, finishes, and features. Although you can't buy a stripped down Scion, like you could an Echo, when they are similarly equipped, the Scion has more bang for the buck.
The trunk on the Echo was outstanding, however, and on the Scion there is nothing to compare; on the xA you get virtually no "trunk" space, while on the xB, the additional wheelbase length goes to front seat/rear seat room, and the "trunk" is also pretty small, though not as bad as on the xA.
Since the xA and xB are heavier than the Echo (that soundproofing etc.), they are geared lower and are both slower than the Echo and turn higher rpm at freeway speed. My xA stickshift has an annoying drone between 60-80, not surprising given it it hitting 4,200 rpm at 80 mph.
Handling is a lot better on my xA, but ride is horrible.
-juice
Heavy foot, automatic, AC on 100% of the time:
26 city, 30 hwy
what they thought of the aircon, if anything?
what they thought of the rpm or noise level, if they drove a stick? or for that matter with an automatic?
what they thought of the ride?
what they thought of the acceleration?
My current thinking on the xA is that if it got the Civic or Corolla drive train, it would be a sweet ride, but otherwise, like the Echo, it has to work wy too hard at freeway speeds to be any fun these days (it would have killed Austin Healey's bug-eyed Sprite, Sunbeams, and Triumph's, but that was back in the '60's....).
-juice
http://miata.net/garage/tirecalc.html
I put 215/45-17 on mine, they have the effect of a 3.7% change in final drive and fit perfectly.
Watch unsprung weight. Good wheels are light.
-juice
I ran a VIN check and took it for a test drive and there is nothing wrong with the car. My main concern in buying a car is getting a good value but now that the 2005's are out, I wonder if it makes more sense to put down the extra money for a 2005.
I need to make the decision ASAP and would appreciate any thoughts people might have.
The Mazda3 they liked cost almost $19 grand, that's steep.
As for taking over payments, I think you'll most likely have to get a new loan and pay the old one off. I'd do that anyway, to get a better rate.
I'd look at that car very, very closely, though. Buyer's remorse after just 4000 miles?
-juice
-juice
I know the spoiler is dumb but honestly, from a design standpoint, I think it really completes the car (as well as give it a more horizontal stance instead of looking so tall and awkward)
http://www.partznet.com/toyota/scion/accessories/XBREARSPOILER.ht- ml
There are painted to match aftermarket ones on eBay for $209 and a bling-bling carbon fiber one for $109
I'm sure it's not real carbon fiber. Usually it's just a paint effect they apply in layers using netting.
-juice
1. There is a slight high-pitched twirling or ringing like noise coming from the engine or transmission under light acceleration. The dealer said he didn't hear anything abnormal and that everything would sound different after 5,000 miles.
Has anyone noticed such a noise? Any comments?
2. The automatic transmission's shift from 1st to 2nd seems sloppy at times compared to higher gear shifts, which are almost seamless.
What are your observations?
Maybe I am overly concerned, but I just want to make sure everything is right with the car. Its a great car for me.
I have been reading this forum for months and am very much impressed with the car knowledge of many members. I would appreciate any comments.
As to the tranny, the ratio change between 1st and 2nd is the largest step, which could explain why you feel that shift the most.
-juice
Besides the obvious increase in interior room how does it compare?
Most roads around my town have rough pavement, with lots of patches and bumps. Not sure if the xB would be tiring to drive around town when you get to know all of the imperfections of the road and are wincing even before you hit the rough pavement or bumps.
