Idle or Stalling Problems - All Vehicles
Hi all! We've had a lot of questions about engine stalling and no-start problems lately, and the answers don't seem make/model specific. Let's put the questions in here, where owners of all makes and models can benefit from the answers. Thanks!
kirstie_h
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
it might be injector clogging, but I don't know anybody who has clogged any. I'd go with wear-out items, and both the regulator and the pump are in the range in which they could be tired out.
This article will help you have a starting place.
Then, read this article. What Do I Tell My Mechanic?
Reading these two articles will not only help you, but it will also help you to let us know the information we need to help you out.
So where its the heart? Need to see if it is beating properly. LOL!
ds
Anyway have any ideas?
I had to do it once on a 60s dodge, worked fine.
no guarantees on this tool, but it's worth a shot. nobody uses a "growler" on starter windings any more, they just shotgun parts. couple of whacks.. and if it starts, that is your wake-up call, get thee parts or a shop appointment.
do > NOT < think you can do this with a piece of metal. infinite amps of +12 volts on the exposed starter terminals. ugly results from fires to blindness may result from hinking around with metal "persuaders."
I replaced the Idle Stabilizer Valve (otherwise known as the Idle Control Valve.) ... at the recommendation of a local mechanic. This part is expensive, but the problem still exists. I can only start the car if I rev the motor to a high RPM while starting. Any help or advice is really appreciated.
2charlesc
Volkswagen lover
kirstie_h
Review your vehicle
The weird part: Our speedo runs all the way over. Our shop says this is caused by tranny fluid leaking, and running up the cable into the speedo head. However, after some of the stalling episodes, the speedo has worked *normally* for about 10 minutes/5 miles or so. How can this be? Everyone says we're crazy and the speedo it is *not* connected with the stalling but we *have* seen it work a number of times after stalls. Could the leaking tranny fluid be connected with both the hesitation/stalling, and the speedo problem?
http://www.troublecodes.net/Toyota/
FYI- it is the GLE/auto model and the check engine light has YET to come on.
I would appreciate any insight
We have 1985 Honda Prelude. Some time ago we experience some transmission (auto) slippage. Lately we start to have a problem that sound like fuel starvation. The car is idle fine but when shift in to Drive it go for 5-6 seconds and then start to chock. If we let go of the gas or let it idle for 30 seconds then we can accelerate again for 5-6 seconds and it chock again. When in neutral it can run into higher rpm for long time but not when we shift into gear. We replaced the fuel pump and the "sending unit" but it is still doing the same. The mechanics (two places) gave up. Is there any sensor / switch / connector or any other reason that can cause this? any connection to the transmission?
I had to do this to my sons 95 Alti recently. The cause is a worn oil seal on the engine side of the distributor. It cost about $3 from the dealer if you can find a parts man willing to order it for you. I had to go to two different dealers to find one who would.
This is a well known problem for the 1st and 2nd generation Altimas. The dealers like to sell $400 distributors for this problem.
I haven't had to rescue my son since I did this.
If this is your problem, I'll lookup the Nissan part number for you.
Also my check engine light has always been on, but the mechs always tell me it is just a sensor malfunction and nothing worth repairing or getting excited about.
Any ideas for a true fix on my stall problem?
The result? First, my car now has a high idle -- about 950 RPM at rest in Drive and 1100-1200 RPM at rest in Neutral (750 or so is normal, right?) -- so it always feels like the engine's cold. It also goes faster when I just let the idle speed push me along in the parking lot.
I took it back to him but he couldn't figure out what's wrong. So it still has those problems, and has now developed one more: on one occasion today, it idled all the way to 1700(!) RPM on its own and took me for a ride with it. When I left it in Drive without pressing any pedal, it gradually accelerated all the way up through THIRD gear and at least 22 MPH, possibly higher if I hadn't run out of residential driveway. Scary stuff.
WHAT'S GOING ON??? What could he have done to my car? Thanks for any reply.
In the meantime, don't visit All Tune & Lube in Mountain View, CA (Middlefield Road). Please.
My dealer changed the fuel filter and then told me that my problem was a leaking valve cover gasket that had allowed oil to foul the plugs, ruin the plug wiring, and ruin the serpentine belt. He proposed to replace the valve cover gasket, replace the plugs, replace the plug wiring, replace the serpentine belt, clean the jets, all to the total of about $600 (I said no thanks).
I had already replaced the air filter and PCV valve. Only a minute amount of oil seems to have leaked out onto the block (at one corner only). The plugs are nearly new and look normal (no oiling or white deposit, and the gap is okay). There is no oil on the wiring and the serpentine belt appears clean to me. Please give me your best guess of what my problem might actually be.
In addition, I have an issue with pinging when accelerating to near highway speeds. I use the mid grade gasoline (89), but this only moderately helps. Is this issue related to the engine idle issue, do I have sensor on the blink.
my v8 has an occasional ragged idle like one cylinder, and last time I chased that at the 28K mark I had a plug with a little abnormal wear. it's not unusual to have one cylinder made near tolerances in an engine, and as long as I'm not soaking up the plug with oil or anything, I'm just watching it. about time I wrench 'em all out again, it's vacation time in the boonies real soon now, and I'd like to be sure of a stable chariot.
Ping is about faulty combustion, combustion that is ragged, premature, uneven. So either we have a timing issue, which on modern cars is really a sensor/computer issue, or we have extremely lousy gas, so bad that even the computer can't compensate even with its generous "fuel map".
Put in some high octane, the highest you can find, and let us know what happens.
Excessive pinging is dangerous for your engine.
Have they considered looking at any service bulletins to see if any pertain to your problem?
Ask them if they looked into the service bulletins, particularly the one below.
And have they considered reflashing the PCM?
Article No.
02-22-1
11/11/02
^ DRIVEABILITY - SURGE/ROLLING IDLE - GEAR
DRIVEN SYNCHRONIZERS - INCORRECT
INSTALLATION - CAMSHAFT POSITION
SYNCHRONIZER (CMP) INSTALLATION TOOL
CORRECT APPLICATION
^ ENGINE - GEAR DRIVEN SYNCHRONIZERS -
INCORRECT INSTALLATION - CAMSHAFT POSITION
CORRECT APPLICATION
FORD:
1994-1997 THUNDERBIRD
1995-2003 TAURUS
1996-2003 MUSTANG
1995-1997 AEROSTAR
1995-2003 RANGER, WINDSTAR
1996-2000 EXPLORER
1997-2003 E SERIES, F-150
MERCURY:
1994-1997 COUGAR
1995-2003 SABLE
1997-2000 MOUNTAINEER
ISSUE
Incorrectly installed gear driven camshaft position (CMP) sensor synchronizer assemblies may be hard to diagnose. Vehicle may exhibit poor fuel economy, driveability Diagnostic Trouble Codes (DTCs) P1336, P1309, P0340 with MIL light on. Loss of power, surge, hesitation and runs rough on acceleration may also be present.
ACTION
New diagnostics have been developed for WDS to diagnose incorrectly installed gear driven camshaft position (CMP) synchronizer assemblies. Refer to the following Service Procedure to diagnose a possible mis-installed synchronizer assembly and proper installation procedure.
The Problem: The engine dies during the warm up phase. Specifically, it starts okay, but then dies repeatedly until it reaches full operating temperature. Some examples of when this behavior occurs are (1) after car has been sitting all day in my work place garage, I start it to return home and am going down the garage ramp, it dies; (2) when first accelerating from a dead stop.
I took the car to a GM dealer, and they identified a code problem with the Ignition Module and the Electronic Control Module (either/or), but they said they couldn't repair it because they don't carry these replacement parts for the '87 model of this car.
I'd welcome suggestions on what to do to repair this car, which has ~86,000 miles and has been carefully maintained. I'd like to keep it on the road, but at the same time not spend more than what is justified by the nominal market value of this car. Help!?
I've always wanted to drive a car with manual transmission and I finally got one.
As I drive along, I've noticed car can roll from 0 mph to about 5 mph by only pushing clutch half way through(without pushing gas pedal)
If I can use this method in a heavy traffic, it will be great but I am not sure it could damage my transmission.
Can anyone tell me how you drive in a heavy traffic or is it okay to push the clutch half way?
What I read anyway, was this...that in heavy traffic, he prefers not to step on the gas but just let the engine's idle speed push the car along by lifting and dropping the clutch pedal.
So in other words, as long as he isn't "holding" the car on an uphill, or resting his foot on the clutch pedal while the car is going down the highway at high speeds, I don't see any harm in his method of "creeping" along. Basically you do the same thing when you work the gas pedal a little in traffic anyway.
I don't see low speed engagement/disengagement of the clutch as much of a wear factor as there is no power being applied to the clutch disk. It's not the same as riding the clutch and partially disengaging it at highway speeds.
Then let us know what trouble codes you get.
It could be the ignition module, which, by the way, NAPA carries.
But I would also suspect the temp sensor.
Until we have the trouble code numbers, we can't even guess.
Let us know what you get.
