Visitor Agreement.
That was about a year and a half ago and still no further problems. He's over 240K miles now.
Amanda Parker
Huskerfansam
I have had alot repaired in the past week. My car seems to be stalling when i stop at lights or turns, it's terrible. I bought the car two sundays ago and i am having stalling problems, the mechanic seems to say its the fuel injection pumps that are blocked. On thursday i am leaving it with another mechanic to finally tell me what the problem is. Anyone have any ideas?
The MAS had been intermittent, but getting more so as time went on. Intermittent problems are always hard to find. Its intermittent behaviour was causing other codes too, such as failed O2 sensor. When the MAS fails, the fuel injection system goes crazy, ...can't decide how much gas to feed the engine, injector pulse-widths all screwed up. Car runs poorly and burns too much gas, ...rear bumper was turning black. This also makes the O2 sensors unhappy. Soldering those broken leads fixed everything, and got rid of all the other aberrant codes too. If this ever happened to me again on this or any other OBD-II car, I'd check the MAS first thing.
Local mechanic charged me $81 to tell me nothing is wrong that he can see.
Any suggestions? Thanks! :confuse:
Chuck
1. Are you getting a fuel injector pulse (test with a noid light that you can buy cheap from a parts store)
2. If you are getting a fuel injector pulse, do you have fuel pressure in the fuel rail?
3. If you have fuel pressure and an injector pulse, do you have spark when cranking?
One of these is going to be "NO" and then you track down that issue.
It's very hard to guess if you have a fuel or electrical issue going on here...one or the other is phasing in and out.
Black smoke is not a good sign--certainly there is a problem with that. Let's run a read up the tailpipe and see what's going on.
I own the same car and I'm having the same problems. Did you find out what was wrong with yours?
driving along and it feels like I run out of gas. It has happened on the Highway
and side streets it dies and some times it starts back up other times I have to pull
over and stop the car, put it in park and restart. Most of the time it restarts right away
and others it takes a couple tries. This happens with different levels of gas in the tank.
I check and it doesn't have a normal fuel filter, it has a fuel filter/pressure regulator.
It states that doesn't require normal maintenance to replace only if diagnostics
requires to do so. I have just run some fuel injector cleaner through it and it is still
occurring. Do you have any suggestions on what could be causing this?
The manual states " The MAS is located on the air inteke duct. This sensor uses a hot wire sensing element to measure the amount of air entering the engine. The air passing over the hot wire causes it to cool. Consequently, this change in temperature can be converted into an analog voltage signal to the ECM (Engine Control Module which is located behind the center console, to the right of the accelerator pedal). which in turn calculates the required fuel injector pulse width".
If by any chance you have fixed the problem would you share the good news and remedy. Thanks .
Euphorbia
When driving and while sitting, my engine revs on its own accord. It "bucks" as I'm driving, and it has recently began to stall when I am sitting at a stop light. It started off as an occasional problem, but is now unbearable. I somewhat get the impression that the car is almost dying [lights dim, power steering slightly fades] and the car "revs" to save itself. The check engine light is on when I have my foot off of the gas, but a lot of the time when I am pressing the gas the light goes off. My car also seems to have poor gas mileage. I’ve taken it to one mechanic. They seemed to have no idea what the problem was and recommended that I try a Cadillac dealer. The dealer was the last place that I wanted to go, but I did. Now the dealer seems to be somewhat unsure of the problem. I am told that they are replacing a sensor [I’m sorry I forgot what he called it] and that it MAY fix the problem and MAY NOT. Any help would be greatly appreciated.
Remember also you will lose 3 to 4% of your horsepower for every 1,000 feet of altitude. So if you go to Pike's Peak you are down 40% or more!!!
(not turbo cars though).
Hope that helps!
