Visitor Agreement.
Mine was surging and bucking when trying to keep a steady speed.
I took it to a local parts store where they scanned it for free. The scan indicated it was the EGR valve and it was running rich.
I cleaned the valve and verified that it was operating correctly. This did not solve the problem.
So, I did a little thinking about it over night. Running rich means one of two things, either the fuel delivery system or the air delivery system wasn't working correctly.
I saw the a note about the MAS or MAF and decided to check there, but all of the test voltages were in correct.
I then removed the cover for the air cleaner to check the filter. Wow! a mouse or chipmunk had climbed up into the air cleaner box and built a nest, it then proceded to eat a hole in the air filter. Leaves and debris were now blocking the air intake screen at the MAF restricting air flow to the engine causing it to run rich. I vaccumed the debris from the screen and the filter compartment and replaced the filter.
Everything now runs fine! I placed a 1/4 inch mesh screen over the opening of the air intake tube so this won't happen again.
Unfortunately the OBDII did not report a code for mouse nest in filter box!
Please let me know what could be the problem, and what is the solution.
This car has run 84K miles.
I was wondering if you had the part number for that distributor oil seal. I am having the same problem with my 94 Altima, and found oil in the distributor. Thanks! :confuse:
Did you ever figure out what was wrong with your Villager? I have a 1996 Mercury Mystique that does exactly the same thing and now it's so bad that it stalls at take off. Please help! Thank you!
I've run some fuel injector cleaner and replaced the fuel filter, but it still does it. Would my problem be similar to the Cherokee's, or something different. I've read where both electrical and fuel delievery were suspect on that year model, but I'm hoping it's nothing serious. It was in good condition when I bought it, with only 64,000 miles on it. It has a little over 72000 right now.
Thanks for any input.
Steve, Dothan, Alabama
Any suggestions?
Starts then immediately stalls - dash display is BLANK, but Windows, Locks, Radio, Fan, Warning Lights ALL work.
It's been happening more often. Used to happen every few months.
Sometimes if it sits for 20 mins it will start as if nothing happened.
Last week it would not start for over 2 hours, but started the next day.
Had the key-tumbler & ignition switch replace based on suggestion from repair center, but it happened last night AGAIN!!!!
Wife is on me to get it fixed, I'm not a mechanic and am looking for ideas.
Please help!!!
Any ideas?
Did you solve the problem with your daughters 94 Altima? I bought one for my daughter and just ran into the same problem. After changing the fuel pump $$$
You're at this point the best chance I have to figure this out.
Hope you can help,
FeeMen
Thanks for the help.
Second issue: Once the car reaches 55 mph, it typically maintains highway speed without difficulty. However, yesterday I drove it at 65 mph for 45 minutes, and it suddenly lost all power but didn't stall. I had to pull off the interstate and restart the engine.
Perhaps I have more than one problem. I recently had the throttle body cleaned, PCV serviced, injectors cleaned. What else should I check?
the garage has had it for 2 days & havent come up with anything yet !!
it seems to run ok while driving its just when you take your foot off the accelerator....it doesnt act like it will stall just spikes up & down....ive had the vacuum hose changed ( from the turbo-manifold )
any ideas........anyone
something that i can take back to the mechanic to try.........i want to go away for a few days on monday !!!
cheers
marco
$105 to find and fix the vacuum leak and install a new air filter.
It runs fine now.
It's driven fine the last month while my brother had it but then found out it needed the starter replaced, butno thing happened since. All of a sudden, it dies on me. The first time it happend, i thought i ran out of gas... the car sputtered and then just shut right down, the steering column even locked up (even tho it obviously doesn't have power steering!). I had it driven home but it kept failing and stalling out. I had the fuel filter replaced... it drove fine the next day...... and then the 3rd day it did it again.... a couple of "shakes" (does it make sense if i explain that it feels like air bubbles in the gas peddle....loses power....) from the muffler it felt and then just lost power. I was, however, able to drive it home fine about 10 minutes later. I now have it parked in my drive way.
Being a student, i'm low on cash and i'd like to take it in to a shop, but cannot afford to have it inspected as well, as the parts and labor. Your insight would be *greatly* appreciated. Thank you!
PLEASE HELP
Might be a good idea to verify coolant temp sensor operation with a scan tool.
Any ideas on what to dig into first? :sick:
I have a 2001 Astro van, V6, 4.3L engine, 45000 miles or so, just started giving me grief.
What happens, is when I try to start the van normally, it runs, and runs fine. SOMETIMES
Other times, I start it, it dies. I start it again, give it a little gas, let off the gas, it dies. Start it again, give it some gas, coax it to stay running, although idling low, low oil pressure the whole deal. Then I put it into gear, and it stalls. I have to two-foot drive it wherever I go after that. Turn it off, wait an hour go out again and it runs fine.
This last time, it actually stalled on me coming to a stop at a corner and it seemed like all the lights flashed on in the dash (which is normal when it stalls, I guess) but as well, the stereo flashed and reset all my presets, leading me to assume that power was denied the unit at the same time.
I am totally confused, had it put on the scan, no error codes.
Any helpful suggestions out there?
(as well, the door lock and the window on the drivers side have been giving me grief in that they decide when they want to operate, and I just had to replace the factory stereo with the remote CD because that quit working. ARGH - it's enough to make you think the damn thing is possessed.... :confuse: )
I took it to a dealer and they said I have a faulty air valve that needs replacing.
How serious is an air valve replacemnet?
Is it labor intensive?
What relation if any is this problem to the air sensor that was replaced two months ago?
I am wondering if this air valve problem could have been caused by the last repair.
Thanks for your suggestion. I checked all the vacuum lines already and replaced suspicious lines. I double checked by spraying carb cleaner around all line to check if any leaks may cause idle speed to increase with inlet of carb cleaner. On a previous model of VW there was an adjustment hole at the top of the injector manifold which can be adjusted with an allen wrench. However, on this Audi there isn't any access adjustment hole. Any suggestions? Gotoalpine
Last night I changed the oil and filter, installed new plugs, air filter, and replaced the leaking #1 fuel injector. (Over the last year, I had already replaced 3 of the 4 fuel injectors, due to leaking.) After all of that was complete, the engine initially did not want to start. I finally got it started, but it stuggled somewhat, and the check engine light was blinking. I rechecked my plug wires to make sure I had not mixed them up, and I'm 99% sure they are correct. I started the engine again, and it ran better, but the check engine light was lit steady. I test drove the car, and it stalled as I was slowing down and starting a turn. Today, driving the car to work, the light was still lit, and the car stalls at every stop. The check engine light has gone away, so I don't know where to look now.
I wonder if any of you have any ideas or have experienced similar performance??
Bruce
Engine starts with high idle at 2000-2600+rpms. When I shift from 1st to 2nd(or any others), the rpms increase to 3000 until the clutch is left out then back to 2000. When coming to a stop, I push in the clutch and downshift the rpms increse with each downshift and at stop the engine revs and goes to 2000+. Also, if I leave it in gear and slow down with the brakes it will go to low rpms under 2000 but as soon as the clutch is in, it revvs up to 3000. Also revving the engine and/or pulling up on the gas pedal seem to have no effect on the rpms; depressing the clutch pedal a few times seems to have no effect either when at a stop.
I have requested the parts replaced because they were not the problem. I do not know what to do and at a loss of $1000!
Does anyone think this is a throttle positioning prob or throttle sensor?
Items replaced:
Gasket IN, Gasket COM, Stabilizer, Changed oil & filter, IAC. PCV, Sensor AS, and MOD ( some kind of computer motor).
