BMW 3-Series 2006
Regarding the Torque Wrench, the good old fashioned "Beam Torque Wrench" should be more than sufficient if all you are doing is Lug Nuts/Bolts. Sears sells this one for $29.99:
Sears Beam Torque Wrench
Regarding the size of the square drive, you definitely should get a 1/2 inch drive, I don't even think the 3/8 inch units go up to 88.5 lb-ft, and those that do (if any), are probably way expensive.
Best Regards,
Shipo
So, since I live in snow country (big time), guess which one I'm going to order. Yup, you got it, the 330i SP. Why? Because I plan on doing to it what I did to my former 530i SP (which was also worthless in the snow with the factory tires), and buy a set of winter wheels and tires for it. Said winter set will totally transform a 330i SP into a car that will almost be able to nip at the heels of the 330xi under acceleration, and yet it will be able to handle and stop better in most slippery conditions. Of course you could do the same thing to a 330xi (ie. mount winter rubber in it too), then it would reign supreme in every winter driving criteria except for braking at the limit (the "xi" weighs a little more which will negatively affect the stopping distance).
Best Regards,
Shipo
DL
Best Regards,
Shipo
Best Regards,
Shipo
The factory uses a calibrated pneumatic gun. I'd bet good money it is +/- 1 psi of the recommended torque.
DL
I hope this helps.
Best Regards,
Shipo
Best Regards,
Shipo
P.S. IMHO the rear light assembly looks most like a recent Civic, if anything.
mike
P.S. what car was that?
Then you simply write the destination on the internet where your pictures are. Yes, it means you still must place them somewhere on the internet. Then you press button "Img" again, and it will close html tag with this symbol.
If it seems complicated, then leave driving to drivers and programming to programmers:) No offence, just kidding:). Send me the pictures –I’ll post them
mike
Question is how different is changing brake pads on the e90's compared to a typical Japanese car? I've done it myself on my Acura so could I just goto the autoparts store, pickup new pads and put them on the same way?
I'm just trying to guage how much the e90 will cost me in maintinence once the warranty is out. I've been reading the last few pages here regarding the tire discussion and am relieved I can buy 3rd party tires should I need to.
Oil change requires synthetic oil on all BMW's, and should cost around $100 at a BMW dealer, or $70 at an independent garage. With synthetic oil, you can do it yourself for well under $50.
Brakes on the E90 are similar to other BMW's, or so the tuning guys say. There is an electronic brake pad wear sensor to contend with. The brake fluid must be changed every two years, regardless of mileage. Your best bet, once your warranty expires, is to find an independent mechanic who specializes in BMWs, and use them for repairs you can not tackle yourself. Once the maintenance plan expires, you should use the indie mechanic for maintenance items you can't or don't want to tackle yourself.
I think that, since the ride is tuned for stiff runflat tires, the ride with non-runflats would be overly soft--maybe not to the point of feeling like your father's Oldsmobile, but not a desirable trait, either.
The only thing I would bother having done at the dealership or a good independent shop is the biannual brake fluid flush.
Best Regards,
Shipo
Best Regards,
Shipo
This place is great. I always come here when ever I purchase a car to get other users info. Anyway my car is comming in on the 21st, cant wait.
Servicing. $100 for an oil change is not terrible! (well it is bu it isnt) The cars oild has to be changed once ever 15,000 to 18,000 miles. If that was at regular intervals that would be 6 changes. The car also holds 8 quarts of $5/ quart oil. So. Even well after the warranty runs out, the servicng should not be to bad.
The automatic transmission should be sealed so it never needs to be changed.
The oil every 15k
The radiator 100k
brake fluid every 2 years
steering fluid 100k (probable)
Differential 100k ????
Spark Plugs 65k (6 right, no double spark per cylinder?)
The brake's should last at least 40k
and you could take them to anyplace to get them changed.
Id get a computer reader for the car to make sure the dealer doesn't rip you off, BMW is a great car company, but cant say that about most service centers,
Anyone try out that bluetooth thing? I wanted to see how well it worked?
What type of mpg is everyone getting? How many miles do you get before the warnimg light turns on, or until you get to E. I drive 55 miles a day to work, and one reason why I got the car is that I beleive that I should be able to get over 29 mpg casue the car has such low gearing in the overdrive gears.
By the way I got mine with Sparkling Graphite, with the terra interior. and burl wood ( i liked the aluminum but it only looks good with the black interior, i think)
Well looking to hear from ya all.
DL
DL
I plan to buy 17x 8.0 wheels for my 330i. Using 225/45 R-17 Snows.
I have chance to buy "BMW" wheels @ half price (recondition) ones like new?
Would u know if 17 x 8.0 from 1999-2004 330 series would fit? believe offset is 47mm.
Or long as 17x 8.0 will fit & offset doesn't make a difference?
Thanks for advice, much appreciated.
Short of "Buying and Trying" I have no idea how to find out if they'll work until the aftermarket folks (such as http://www.bmwwheels.com) update their compatibility charts.
Sorry I couldn't be more helpful.
Best Regards,
Shipo
i have about 450M on the car so far-so a little early to really tell what MPG but averaging 25 in town and 30ish on the highway--taking a trip this weekend to philly so should get a good read on highway mileage-
325 SP, AS, Sparkling Graphite/Blk/Alum
cheers
KB
If you wish to put more pics - ll be happy to host them in my album for you.
mike
As I write this, you have time to delete your message, but if you miss it and want me to, just drop me an email. You can change your profile and repost.
Anyways, I got a great deal on the parts and confuse the general public on my 325i/330i project
DL
So far I've seen about 20 on he roads around San Diego. Can spot them from a distance - bimmer colors and the shape really stick out on the road. At first I thought it looked kinda like a 5 (not nearly as sexy). Now I'm seeing them as similar but very, distinctively different.
If I'm in my bimmer I flash them and give them a thumbs up. The owners seems to appreciate that. Weird, as I didn't use to be so demonstrative.
DL
Just in case you don’t see images on this page – simply go to this album
http://public.fotki.com/mvs/public/bmw-1/planoml/
I hope the pics are a trip down memory lane for some, and something to look forward to for those planning. This was my first ED. If you can put up with the 6-8 week wait for the car to reach home, I encourage everyone to do it. Picked up the car in Munich on the 20th, went through Austria, Italy, and Switzerland; for a final drop off in Paris on the 27th. Came back on the 30th. Everyone we met, was very nice and helpful. Following are some notes on the pics:
1. Neuswanstein-Germany
2. Lake Como-Italy
3. Interlaken-Switzerland
4. Berner Oberland-Switzerland
5. Paris
By the way-it's a 325i, Sparkeling Graphite, Black ette, Aluminum. Got step with the promise that we could switch as soon as BMW comes out with a DSG styled tranny.
Nice pictures, car fits in nicely. Got a question for you guys who got one already. How many miles do you get on a tank of gas? are you gettin 350 ish or more. Becasue if I did my calculations right the car can get a thoeretical 455. now in real world you might not break the 400 miles mark. but my current cars ((Jeep Wrangler) yah we can have a big conversation on how a wrangler switched to a bimmer. and if those jeep heads found me turning to the Germans, oh man I dont want to think what they will do to me ) But any way my current car gets 277 when the theoretical is 324. but that is a different story. I get on the books 17 mpg highway, and the best I ever calculated was 16.99 so pretty close. dont want to know what I get in the city. Anyway the warning light comes on with 1/4 left.
The only reason I ask is becasue I drive 110 miles a day for work, and am trying to fgure out if i can fill up on Monday and be set for the rest of the week. but unless I do something special I dont think that will happen. but on the bright side I should be doubling my fuel economy, the bmw and the jeep arent to different in price when you factor in gas. Also the bmw's insurance is 200 less per 6 months. They are som many pluses with this car. I might even regain my hearing. driving at 75 mph, it reaches 80 dB (with the top up)
Has anybody found anything that they do not like about the new 3 series. At first glance the onl thing i did not like was that the hood of the car contained the upper part of the radiator grill, but after looking at the car I didnt care.
What do you people think of the back seat of the car, im a tall guy, 6-2 its ok for small people i guess.
Oh yah I love the regular steering wheel, it is nice, but I do not like the sport steering wheel, why did they have a big hump in it? Well those are my only gripes.
Also about Servicing I hear BMW service does not cover rotating tires every 5k miles. and they do not recommend it. Can you get the tires rotated with their pressure sensors in them?
how many keys does the car come with?
DL
Where did u buy your 159 wheels from?
