Laymans terms: Cetane~equal to octane with exception that you already have a compression ratio that will use all of the available latent energy.
The higher the Cetane number the better for combustion and thus power/fuel consumption ratio. Here in the US the standard is >45 while in Europe it should be above 50.
Now, it has no affect on cleaning injectors or the fuel system (high pressure pump especially is susceptible to fuel contamination). Suggest you use the best filtration and water separation elements possible to keep every thing in great running order.
Any other hints or suggestions would be welcome!
Lots of luck! LK
I change it every other oil change and do not worry about draining it.
Farm diesel is the same as regular diesel, it is dyed and does not have the road taxes applied. Quality is the same as regular diesel, farmers would not risk $100000 equipment by putting inferior fuel in it.
Get caught with it and the tax man will be very cross with you.
I am still getting 30-50% better mileage than with the Durango gasser I used to drive so the savings is still there.
By the way we now have about 1400 miles on our CRD, and we like the ride better than the 3.7 and the steady pace going up a steep hill with a trailer. Very impressive indeed .
Changing the filter is not hard-you need to remember that the plug on the bottom needs to be removed first.
I still think that $150 is still high.
I would replace it more often than caribou1 does. It is cheap insurance.
I have only had 1 tank of "bad" fuel in 11+ years.
It caused my Cummins to surge at idle and sometimes stall when coming up to a light. It was purchased at a local truck stop that goes through a lot of fuel.
As of the quality of the EU fuel, well ... Times are changing over here as well.
I'm not getting good mileage continuously with the CRD as I am with my old 2.0D Toyota. Common rail technology is much more sensitive to fuel quality and air temperature.
I'm trying injector cleaning with 'White Spirit' (petroleum distillate) as of today. I discovered that the diesel additive used to clean the nozzles was acrylic paint solvent + dye to give it a color! I've been using this stuff for 30 years to clean the injector of my heating furnace and found it is sold for automobiles. Recommended dose is 1/4 liter for a full tank.
Good luck! LK
service $46
parts $7
I have a 2005 with 8000 kms on it. Does the milage get better when the motor has more miles on it?
I posted a link to the API license for Amsoil for anyone interested in the area that the host directed further discussion to.
I don't think you can or should expect much better than that. The vehicle is quite heavy around 4,000 lbs and non aerodynamic. The dealers only promise 27 or 28 mpg. To be frank I think that's pretty good when you compare the mileage to the proliferation of gas hogs peddled to the American consumer today. I get around that, maybe just a little better, but I only measure it carefully when I go on a long highway trip. Then I get 28 to 30 mpg.
Does the mileage change much with colder weather? The days are beginnning ro grow short and the nights cold. How does diesel mileage change in the cold?
By "every other oil change", do you mean every 12,000 or every 24,000 miles. (I don't know what oil change interval you're using.) I'm thinking that I would agree with you, though. Somehow, I don't think that the neighbors are going to be too keen on me draining fuel/water in the street or in my driveway, and I'm sure that the grass wouldn't appreciate it! I'm thinking take it to the dealer every 12,000 (or 24,000) and let the service department screw with it (unless, of course, the "excessive water" light comes on).
As to the gripe about fuel economy, is the engine still green? Is the total mileage less than 10K? If so, you are doing fine. As to fuel economy, I have yet to break 30 mpg but generally exceed 29 mpg by a few tenths. I have 5500 miles on my CRD.
Its been very mild here with only one night of frost so far.
I bought it because I really do need a 4x4 to get to my house in the winter as I live half a mile down a private dirt road. The Jeep is replacing a Sierra 5.3L. I was getting 18 to 20 MPG with the Sierra. Hopefully I'll fall in love with the Jeep over the winter when it proves itself on my driveway.
Quite an issue and waiting period for parts?
Majority of driving is Highway.
Do yourself a favor. If your CRD came with Goodyear Wrangler ST tires, get rid of them before the snow begins to fly. Most anything is better. The Goodyears are beyond terrible.
Good luck with it! LK
- I am having my Bridgestone RIVO tires mounted this week - can't wait to get rid of these Goodyears -
LK
Spete! Revo's rule! You'll love them! The Michelin Cross Trail SUV's on my cherokee slide in the rain.
LK
Have you guys noticed any swetting of the turbo outlet hose going to the interchange cooler? Mine is really oily on the outside. It may just be getting old and needs changing. At last I found something to change on this rig
Based on the feedback I've seen on this forum I do it too.
After buying this machine, I've begun to see that the engine is not American made iron. It is not an engine that is widely used in vehicles in the United States. If you go into a discount store to buy an oil filter for this Jeep, chances are they don't have one. A dearth of aftermarket parts means that you have to visit your friendly dealer for parts. Dealers know that the parts aren't out there and will charge you accordingly. I believe a blown turbo would require many such exotic parts fabricated in a cave by Italian elves. I believe it would be big bucks to get the Jeep fixed. It's worth the 30 seconds to sit and contemplate your navel before shutting her off.
I'm going to be using the Pureone. Advance Auto Parts carries these.
SDF34 is the Amsoil filter.
LF580 is the Hastings.
Mobil 1 - M1-211
STP - S8316
Fram - 8316
Wix - 51516
Interesting oil filter dissection
Should be able to find these filters in parts and or discount stores.
I have had the engine light come on at 586 miles. The fix was a re-flash of the engine controller with a software update. Since then, I have not even had a problem. I have 5500+ miles on my CRD and am very, very satisfied.
Fine yourself a good dealer that has a CRD in perfect working order. As for parts, all I have had to purchase were some oil plug gaskets and an oil filter and they had those in stock. The only parts I expect to buy are those required for maintenance.
More that likely the part needed is the EGR valve. It is on national back order. Read thru this and other forms and you will see what I mean. Go to the dealer that has the Jeep you like and get best deal and have the service department read the codes to verified the cause. Remenber its under warranty and if you don't like them you CAN go els where !!!!
My homebuilt utility trailer with a 7' tounge extension also has it's axles quite far back. I know that I've put 600+ pounds on the tounge, driven steep loggong roads and driven 40-45 mph on county roads without much problem. It's not recommended to do so without precautions- as the weight rating is what it is. Keep your load over the axles as possible.
Just make sure that you're using HAVOLINE Synthetic 5W-40!
Go CVX!
