Jeep Liberty Diesel
15859616364224
  • kyjeeperkyjeeper Member Posts: 31
    You said something about not fueling with engine runing I was told by one of three dealers I have been messing with that it wouldn't throw a engine light like a gas would. So with that said I have been fueling with engine running if this would fix my jerking since new problem I couldn't beleive it. I will try, I have been pumping knob above fuel filter still jerks always above 5o after you let off pedal I have had jerking at 75 after wide open acceleration it will jerk just about ever day maybe real bad once, when I take to dealer it doesn't do it as bad so they think its normal, one dealer said if he had another Jeep diesel he let me drive it and see. I think if they all jerk, jerk that no one would buy one. I am waiting on a return line from Turbo houseing. I have a oil leak. they said that it might be sucking air and it might fix jerking. If I do the lemon law with lawyers I will have to pay them big bucks I may and may not get back.I try to trade last time I was at dealer I would loose 10000 on mine and the Grand C. Limited was 10000 more payment would be 700 o 800 and 6 years to pay. I cann't afford.
  • winter2winter2 Member Posts: 1,801
    That is it! I am going back to school to become a maverick automotive engineer. Just teasing...
    Glad I could help. I have learned a few things in my years on this earth and one of the most important is to cover your butt. I spent over two hours going over my CRD the day after I received it. Besides a few misplaced and loose clamps, I re-routed some minor items underneath and made note of potential issues.
    I am a maintenance fanatic. I have been left stranded three times in over thirty years of driving; in two of the cases by dead batteries (sans warning) and one controller failure. Never had an engine failure except at very high mileage, 240+K on a Volvo B-18 4 cylinder with SU carbs. Threw a rod out of the side of the block. I have never rebuilt that or any engine. Pull any engine apart that I have owned from new and they look like new inside. Have only done ball joints once, same Volvo.
    My teacher was a neat gentleman who was a body mechanic as well as a fabulous engine mechanic. He taught me everything I know and how to make a piece of junk last forever. Can never maintain these cars enough.
    The jerking is absolutely a no-no and is definitely not normal. If your dealer says that it is, go elsewhere. The mechanic is either lazy, stupid or both.
    My CRD does not jerk at all and only did until I purged the air from the fuel system.
    Find another dealer!
    I know what you mean. Back when overdrive didn't have a switch to turn them off the transmission overheated and failed. I don't know it all but why don't CH just put in a new transmission & a new tork corvertor and controller and be done with it. It be better than paying me back mine 29000 Plus Lawyer expense. the funny thing is I love this Jeep :lemon:
    Is the Arco fuel ULSD?
    It is 15 PPM ULSD when sold in CA. BP/ARCO is no more than 30 PPM LSD when sold in other states. See the ECD-1 website for availability.
    http://www.ecdiesel.com/
  • bullheadbullhead Member Posts: 125
    I have 8,400 miles on my CRD. My check engine light came on the other day (Monday). The car ran fine with no problems. The manual said the light may go away after several driving cycles. After a few, the light was still on. I then did the one thing that has fixed every problem I've ever had with it: pumped the fuel primer button. The light went out after the next off/on cycle. My conclusion was also that the CRD shouldn't be fueled while running. I did Sunday night. Doh!
    Otherwise, I have had no problems with my CRD, either.
  • lightnin3lightnin3 Member Posts: 153
    The sales figures have nothing to do with the product.
    Diesels are not the "in thing yet in America".We are still a gasoline culture.
    Not until Gas hits $67/barrel of oil,and gas at the pump hits a high of $4/gallon like in Canada,then it will become accepted.
    Last summer I was driving around with an ad on the back of my wheel cover ,showing my mileage ,and people were stopping me to ask how I liked it.
    Now that gas has dropped,
    people don't care,because it is affordable and managable.
    But we will see the reactions again,when gas goes up next summer.Hopefully common sence and popularity will prevail.
    Peace and happy holidays..
    Lightnin3...
  • ke4itnke4itn Member Posts: 12
    After two weeks the issue with the J1850 code was resolved. It turned out to be a short in the wiring harness. The tech told me he found a wire near a headlight/radiator that had rubbed a screw head and shorted. He replaced the insulation and put silicone sealant on the screw head.
    When I get in it and drive less than 1/2 a mile its warm and heat gauge says half way.
    Very good point. The reason is the diesel engine has a hard time getting warm at low idle. On our PowerStroke diesels that idle all day in the Arctic we install an idle controller. We keep the idle at 1200 RPMs to maintain proper heat in the engine. Low idling for any length of time is not good for a diesel engine. Give it a minute to get the fluids flowing and take off driving. If you are in extreme cold a heater keeps the crankcase oil warm.
  • jmopperjmopper Member Posts: 3
    The CRD has both sensors, mass air flow that measures the total volume of air coming into the engine, it is the hot wire type & in the air cleaner lid. Diesel engines have no throttle valves (like a butterfly in a carb. or throttle body) there is no restriction on the intake side of the engine, you add fuel & airflow increases. The boost pressure sensor measures how much boost is coming from the turbo & the computer calculates when to open the egr valve from comparing the two readings, also coolant temp. RPM & road speed come into play. I believe that DC is on the right track as my CRD is on it's 3rd. software update & although mileage still is not what it should be, my supposed egr problems have stopped & the intermittent stalling & idle surging is better, now maybe in the next update the mileage issue will get addressed! They definitly think these running problems that everybody seems to be having are software related or they wouldn't be on the 4th version in the first year! :)
  • siberiasiberia Member Posts: 520
    Thank you for joining the discussion, Jmopper. Those of us following this forum over the long run are aware that diesels generally have no throttle valves. This relates to the recent warm-up at idle vs. driving discussion. At idle diesels run a fuel air mixture of about 40 to 1 and at full power a mixture of around 18 to 1. At idle speed a diesel uses about 1/3 the fuel of a gasoline engine of comparable size so it generates about 1/3 the heat. However, it takes the same amount of energy to accelerate and move the vehicle at speed so warm-up is about the same as a gasser when driven.
    I understand when and why the engine feeds more fuel. The question is what happens when a turbo pressure (outlet) hose is leaking with respect to error codes and failed EGR valves, how fuel is flowed in that condition and how the OBDII tests the EGR valve. I find it hard to believe that 2 or 3 EGR valves can fail before 10k miles on one vehicle. In pictures it looks like a pretty substantial unit. Do you know how the CRD OBDII tests the EGR valve?
    If the problems are software related, how can some of us be over 15k miles with no problems and good fuel economy? The fact that DC is on the 4th version of software might mean that it is not the software (unless CRDs are running Windows). I hope it is the software. Maybe Version 1.06 will cure everyone’s problems and we can all join Caribou1 on his euphoric cloud.
    This is from an earlier post, Jm.
    I looked into buying a ScanGauge OBDII reader and queried the company about compatibility. I got the following response:
    The Liberty Diesel has been reported to have some problems with part of the data stream randomly stopping. We think it is a bug in the vehicle ECU. We will probably be adding this vehicle/engine combination to our "incompatible" list soon. Sorry.
    Software bugs are funny. Sometimes it is a processor bug and the software runs fine until it "steps on a bug." You can rewrite the software to avoid that bug and it runs fine until it steps on another bug.
  • supertechsupertech Member Posts: 32
    I finally have driven the wives CRD . The little bugger is breaking in. It has just over 7K with 0 problems. just did a 400mile trip threw NYC to pick up daughter from college. The mileage is improving! I averaged 28.4 on trip down at 70mph+ and on the way back in heavier traffic I averaged 29.4 at 60-65mph the temp was 30-40. I think 30mpg with cruise would be no problem. I use premium fuel with out additives tire pressure at 35psi :):)
    I went ahead and purchased a ScanGuage tool and plugged it into the OBDII on my CRD. I decided that if the data stream interrupts I would like to see the readings when it happens. I drove 40 miles of interstate and town and there was no interruption.
    Readings follow:
    Outside temperature was 22 F. The temperature gauge comes off the bottom mark around 110 F. I let the engine completely warm up before turning on the heater. The first major mark on the temperature gauge is 140 F and just below middle is 177 F (max obtained), so the middle is probably 180 F. After the heater ran a few minutes the temp dropped to 168 F. For the rest of the drive the temperature never got over 172 F with the heater on. The ¾ mark on the temp gauge is apparently 220 F.
    Maximum turbo boost obtained was 23.2 (37.5-14.3(static)). It only takes 6 to 8 lbs of boost to run 70 MPH. When getting into the pedal the high reading hits when the turbo first spools up right after the lag, then it tapers off as RPM builds. I didn't run it wide open from a dead stop to obtain a true maximum reading.
    Air inlet temperature (AIT) was interesting. On my gas burner the AIT was only a couple of degrees above outside temperature at highway speed. On the CRD the AIT ran around 85 - 95 F at 70 MPH. When I slowed down to 45 MPH in town the AIT climbed to 137 - 140 F. After a 3 to 4 minute idle it dropped to 95 F. It looks like the AIT is measured after the EGR inlet feed?
    Except for Inlet Air Temperature, all of the rest of the readings were nominal. Analog readings for tachometer and speedometer closely matched digital values coming from the CRD.
    I scanned for codes and the unit found no codes and came back “Ready” which means all tests were successfully completed by the OBDII system. I will be putting around 1k miles on the CRD over the holidays with the ScanGuage in place. Maybe something will turn up.
  • crd4me2crd4me2 Member Posts: 26
    Hi all,
    I'm a new member, but have been reading the Liberty forums for a few months now. I ordered a 2006 limited CRD Oct. 5th with a delivery date of 6-10 weeks. Well 10 weeks have gone by now and I'm told the Jeep is still "scheduled for build" :cry: . I'm also told the plant closes for a couple weeks in Dec. and so there is no one there to answer as to why the build hasn't started yet. I've searched the net but haven't seen anything about delays in builds. Has anyone here heard of anything that would delay this out to what now appears to be 15 weeks? Thanks for any clues...
    This delay is causing me to re-think my decision to buy and maybe I'll back out and wait for the bugs to get worked out?
    Michelle in New Mexico (crd4me2)
  • gormanpgormanp Member Posts: 9
    I have about 7000 miles on my 2005 CRD. I run on B20 almost all the time, have used several tanks of B100, without a hitch. Runs fine.
    Biodiesel - no war required
  • faroutfarout Member Posts: 1,609
    There is no shortage of CRD's in Missouri. There are 05 and 06 here for sale in a wink. Suggest you ask your dealer for a dealer swap.
    Farout
    Bio is NOT something you should use beyond B-5! Not a good idea to run B-100 at all!
    Farout
    Thanks Farout. I'll ask my dealer to look into that Tues. I've ordered a 'fully loaded' (minus sunroof) CRD, so not sure if we can find that or close to it without ordering - that's why I went that route. But I'm getting impatient so we'll check it out.
    CRD4Me2/Michelle
    "Biodiesel Fantasty Disease" (BFD)...
    (B100) - "Runs fine"
    Crappy supermarket gasoline runs fine too, but mechanics know it, over the long term, disagrees with modern, efficient gas engines. Cancer usually goes undetected at first, too. DC and industry experts have warned us on the biodiesel thing- so I'll gladly rat to your Jeep service manager when the inevitable problems develop.
    "Biodiesel - no war required"
    ANWR / Coastal California & Florida petroleum: No war required, either ???
    When massive quantities of additional wildlands and developable properties and scarce irrigation water need to be appropriated toward biofuels production, we'll just have civil war instead. I say use up stored energies first- and Save the Whales- until technologies less-backward and limited than biofuels mature ! Or are you thinking if only you get cheap biodiesel- and everybody else has to take the bus and keep their thermostats at 62 degrees (the most insidious, psychotic core-belief typical of those with the BFD disorder) ?
    In my 70F comfort and at 10F outside, I'm selfishly glad, like you, not everyone heats with my alternative energy source (inexpensive forest wood). But even my firewood won't be cheap and easily available without keeping America's enemies at bay; thereby keeping the petroleum-based energy flowing for the rest. To deny that fact would be to have FFD (Firewood Fantasy Disease). Is your BFD better now ?
  • tired_old_davetired_old_dave Member Posts: 710
    Recently, a Dallas/Ft.Worth, radio, tv, newspaper auto personality mentioned that Honda announced it had solved the decades old problem that prevented development of the gasoline compression ignition engine and achieved a 30% increase in gas mileage.
    I have not called in to his radio show or emailed him for follow-up. Did I hear correctly?
    Boise only has one gasoline pipeline (Chevron from SLC), so the supermarket gas here only differs in the additive package, unless they are trucking it in.
    We have a Biodiesel vehicles discussion for those wanting to get into that fun area ~ tax subsidies anyone?
    Dave, I haven't seen any news about a 30% efficiency pop by Honda. They are doing cylinder deactivation in some models like GM (Odyssey iirc). Some folks can increase their mpg 10% just by inflating their tires to the manufacturer's recommendation, so 30% shouldn't be that huge of a stretch. Doesn't seem to be happening too fast though.
    What might those problems be? DC sends each Lib CRD out with B5. Running B20 should not cause any kind of problem. As a matter of fact I spoke with the Mercedes service manager in Hawaii about running B100 in the E320 CDI and he said that so far they have not had any problems related to biodiesel. The biodiesel used in Hawaii is old restaurant oil. It was being dumped in the land fill. Can you think of a better use for it? If I had a dealer selling B20 biodiesel in San Diego I would be using it in my VW TDI.
    What is unhealthy is breathing the dust and smoke from a wood fired stove. I heated with wood for several years and wondered why I had a hard time breathing.
    Hi Steve...
    Well yeah! Chevron products are superior, so that cheap gas is good gas out of the gate. We have ARCO as base gas here and it's far from the best.
    Lots of fast food in Hawaii and importation of fuel is expensive. Large scale production of quality biodiesel makes sense
    Steve,
    Thanks for responding. I believe compression ignition means no spark plugs just like with diesel fuel. We caught the comment late and believe the first letter of this development began with the letter "M".
    About tire inflation. I saw a post(somewhere) where the jeep tire was inflated to 44psi. Tirerack will tell them the "tire will shred itself". A tire store manager told me we could get better mileage and ride by underinflating our 41psi rated P235/75r15XL ford conversion van tires from the 41 psi ford recommendation. Load rating per psi charts are available as well as for those who change down from a P rated to an LT tire[speed rating(or new lower max speed) and tire pressure increase needed too].
    I would like to hint at the other forums I lurk at for the uninitaited. They allow it but I know Edmunds doesn't.
    There are two good ball joint threads as well as two retirees, navy guys, using two aftermarket mufflers to replace our inferior gasser muffler.
    How far can I go without offending Edmunds rule about other discussion forums.
    I maybe getting lost permanently.
    Thank you for the nudge adjustment in a post long ago and allowing me to fix and repost it. I was wondering if caribou1 is lurking elsewhere too or staying here exclusively, like I have wanted to do.
    The Rules of the Road link on the left still goes; it's easy enough for folks to find other sites but we hope folks will stick around and keep building the knowledge base here.
    3% is a more realistic number for the tires; the 10% I was thinking of can result if you replace a dirty air filter. (link)
    I'll keep an ear open for that Honda story.
  • dacurdacur Member Posts: 10
    I also found out that the oil level was down a full quart and my antifreeze was down a half gallon. There was small (pea sized) pieces of ice formed on the inside top of the reservoire. What does that indicate? We'll be finding out soon I hope.
    Turns out my Dad's childhood friend is one of the top Jeep Liberty design engineers. He is going over my numbers and is going to try to help me with the economy issues. I faxed him the info yesterday and then on the way to go hunting this morning I hit a deer and messed up the Libby pretty good. Had to have it towed to the body shop and I have on idea when I'll get it back. Maybe I'll get a loaner that get's decent mileage.
    If nothing is resolved I will be contacting an attorney also because I purchased this vehicle because of the promised economy. They still have the "500 mile" per tank ad on their web site. What a joke. :sick:
    If nothing is resolved I will be contacting an attorney also because I purchased this vehicle because of the promised economy. They still have the "500 mile" per tank ad on their web site. My last tank before the deer was a mind blowing 17.38 MPG What a joke. :sick:
  • ungnungn Member Posts: 19
    17 mpg indicates a problem. With 4900 miles, mine does an honest 26-27 mpg on the highway at 68-70 mph (EVIC says 28 to 28.5) If I had the patience to run 56 mph/1650 RPM, I'm sure it would get an actual 30 mpg, but in Texas, you need your flashers on to run 55 to keep from getting run over.
    In town on my commute I get a solid 23 mpg (EVIC says 24.5).
    I'd have to be doing tire smoking power brakes at every stop light to get 17 mpg. Mine was getting 19's/ 20's in town when brand new with the A/C on, but I haven't gotten near that since summer.
    I wish 3.55 gears were an option (or std). I feel 30 mpg @ 70 mph would be possible with those gears.
    That is only off by 23% from the EPA estimate. There are people paying $50k for a Lexus hybrid SUV that are only getting 19 MPG when they should be getting 29 MPG Combined. That is 35% off of the EPA estimate. You will just waste your money with an attorney. Think about this. At least you can feel comfortable about going off road with your SUV. The Lexus RX400h is rated for highway only. With a 20.5 gallon tank you would have to drive lightly to get 500 miles.
  • caribou1caribou1 Member Posts: 1,354
    I try to keep track of any new 'sound' information from european forums and press releases, and I enjoy staying here for the time being.
    Just like winter2 wrote a few days ago, I like to keep things going especially when they are made by people who have faith in what they do (I'm not talking about DC dealers). Funny thing, I also blew a connecting rod on a Volvo 544 B16 in 1970!
    Now I'm in my 3rd winter season with the CRD, weather was -7C this morning and again the engine started with great ease. I have almost covered 15,000 miles without changing my oil, and it doesn't stick!
    POSTSCRIPT
    I grew up with wood heat and still use it. You're right- old wood stoves, other older "wood-fired" appliances; like older diesels, suffer from incomplete combustion and are often leaky. Technology, good equipment, and good fuel rule the day! ;)
    Select and use your biodiesel carefully and I'm on board with it. The militant biofuels crowd, usually anti-establishment folk at both extremes of the political spectrum, and Big Agriculture, promote them recklessly. My somewhat selfish agenda is to minimize bad fuel as the culprit in any problems the CRD may have. Wheat from the chaff. Plus, we all should care about the dispensing of bad advice to others.
    Maybe we need the government to further regulate :mad: the handling of commercial waste fat so it's conversion to engine-safe biofuel is more assured. :lemon:
    As soon as biodiesel becomes establishment, many of its supporters will find much fault with it.
    I've been filling B5 for 3 weeks, then normal diesel for another identical period, then back to B5, on and on for more than one year now. I cannot state that there is a clear difference except budgetwise. The only difference I noticed was a warmer exhaust temperature using B5, plus the WOK smell :)
    The Bio additive I've been using comes from canola oil.
    Next year I will start using recycled waste cooking oil up to 10%. I'm just curious, I take the time but I'm not over enthusiastic about the outcome. I think we should use the bio fuels where we use a lot of fuel, ie heating and industry.
  • patentguypatentguy Member Posts: 45
    I have over 9,000 miles on my CRD and have used B20 for about 40% of my fill ups. The "20" is from soybeans, not WVO or fryer grease. It is a highly refined fuel. I have not had any negative effects from using B20.
    You can make an argument that B100 is not fully tested and should not be used (based on the solvency issue), but B20 and below is perfectly fine for our engines.
    If I can buy US made fuel (grown by US farmers and processed by US refineries) than I will.
    For the record I just filled up with engine off and added some redline trying to get cetane number up to 50.I drove 378.6 miles on 17.882 gal price 42.90 at pumps and between 5 and 6 dollers for additive that is 21.172 miles per gal. I feel like I have the 4 EGR bad because Engine is noiser and lost of power. I have oil leak under turbo waiting of parts. I have one computor upgrade TBS-18-018-05,dealer said this was latest but but I think there is three or four I wish I had the number to tell dealer.This Jeep still jerks at speeds over 50 I am pretty sure its between 4 and 5 gears the tork convwertor jumps in and out like it doesn't have enought pressure to hold in.I asked lawyer about lemon law but he doesn't know what it will cost if dealer puts up fight so I am Kind of scared to get in to something I do know what it going to cost I feel like I have already lost on Jeep and stupid for ever buying it :lemon:
    I'm in dfw,tx and "ungn" is in tx. I would love to have his mileage. Different places for diesel with and without additives and mileage is everywhere. 20 around town and now 23.5 around town with additives, driving with a pack from dfw to houston on the autobahn last summer 22.5 mpg.
    14,500 miles and original egr. second new air cleaner. Mobil 1 0-40 every 6250 miles now. Bridgestone Dueller HL Alenzas at 35psi. Currently, happily blending CRC diesel plus and powerservice after injector cleanout with a full bottle of redline. Brakes not dragging, e brake adjusted, not part of the bad transmission filter group, original cooling fans. And yes I do winter2's recommendation of a first of the day idle to fill the torque converter.
    If all this sounds familiar, and more than one dealer has tried to help, then maybe you deserve a present from santa by trading in now for a " " and get a vehicle you can drive instead of reading posts and going to the dealer.
    And by this post you know that I too spend too much time with this vehicle and posts, I don't treat this vehicle like a 50's 60's euro sports car and do monthly, weekly, daily tighten this fix that etc. We own a malibu but this jeep owns us.
    I am generally concerned about the ball joints and the front end design of the liberty showing how failure results in separation whereas decades ago I drove an old cadillac with bad ball joints that would pop in/out over rr tracks and allowed me to to drive it until the money was available for the fix. Moog has one answer and somebody else said to moose the retaining nut just short of a hernia.
  • craigs1969craigs1969 Member Posts: 20
    Just bought a CRD and in the glove box is a bag with a metal object in it (with a piece of plastic sticking out of it). On the side of the metal thing is printed "McGard Patent" xxx. So I googled mcgard and found the website which introduces itself with "Invented in 1966, McGard's unique one piece wheel lock functions like an existing lug nut/bolt, but requires a special key (tool) for removal." Does anyone know how I operate this thing? Thanks in advance! :confuse:
    Locking lug nut and tool. I had to buy mine. Check your spare. You can buy additional lug nuts and tools with that number. Use your lug wrench but better buy a good socket and torque wrench and do your own lug nuts/tire rotations and avoid warped rotors.
    What happened to your rotors? How much torque should be applied to the lug nuts?
  • boilermaker2boilermaker2 Member Posts: 131
    Hi Bullhead,
    You'll find that Big Agriculture says alot of things to coerce the people and politicians. You could use "Big" anything and you will see strong-arm, mind-bending tactics.
    However little, or medium, agriculture is a little different. I personally know a few of the local B* distributors and the highest they will go in the winter in Central IN is B2. One is going to try B5. They love the stuff BUT they do not have an army of lawyers like the BIGS do. They also have a much smaller client base to where if one truck gelled at 7AM, 5 counties would know about it before lunch. There are a few sites in Indiana selling B20 but the locals consider it "risky." I am working to talk them into a summer/winter Blend of B20/B5.
    As for soy biodiesel versus Caribou's home brew, don't know. Don't care. What does matter to me is that the soydiesel has a specific quality criterion which allows it to be uniform and standardized. This is allowing to gain access to the market. The fuel/motor industry was/is very touchy (and there is still some fearmongering) about the quality and uniformity.
    Though they are putting in a Soy Biodiesel plant in 6 miles from my house, I assure you that I am getting no money or kickbacks. However a little B100 on the side would be nice... :D ...to blend with my petrodiesel.
    You can also read my other Biodiesel tome at post #2418
    Cheers,
    Boilermaker2
    I couldn't resist the subject line but I do need some help. Some recent posts about hoses falling off of turbos, lost mileage, etc made me pop the hood the other day and take a look. On the passenger, or shotgun side or the engine compartment, there is one very large rubbing hose with a nice light coating of oil. I changed the oil at 3k miles and was down at least a quart. I was down a 1/2 quart when I checked it the other night at 6k miles :mad: so I figure I am a candidate for the "snug club" :blush:
    First of all, when it comes to turbos, I'm terribly green. I've never owned one. Taking the engine cover off, I see more hoses, clamps and doo-hickeys than I can shake a stick at. Unlike more straightforward engines I've owned, this hose-covered monster looks like something NASA created instead of Detroit (Thank you EPA).
    So, would someone please give me and others, a specific rundown of what you are tightening, snugging and re-routing?
    You would approach hero status if you had your own site where you could load up photos and point things out (This doo-hickey is your turbo. Here is the clamp that will cause you a load of trouble. Etc.) Maybe Steve can help in this deparmtent. Either way, this would be a nice addition to this forum. After snugging, I think I have accurate enough records to show a before/after fuel economy change if there is one.
    Cheers,
    Boilermaker2
    Here's a problem I'm sure is not related to bad fuel:
    There is a vibration noise coming from around my CRD engine during its greatest vibration. This is almost exclusively during acceleration, but sometimes immediately after a high RPM downshift.
    This noise first occurred after my routine 6,200 mile service at the dealer. I'm hestitant to let them have access to it again to correct it- or do anything more, really. Except that the service was FREE, I would have done it myself. Luckily, the noise is not getting worse with time.
    Does anyone have experience correcting an irritating, high frequency 'rattle' associated with peak engine vibration? I've tried various things to isolate it at the top end without success.
    It sounds metallic in origin, but could be related to plastic parts, too. The metal exhaust shielding is a little suspect.
    Really don't know how they could have messed things up on such a minor service, which give me even greater pause. Again, the vibration is normal, but the feedback from some under-secured part isn't. Thanks.
    I'd suggest getting the factory service manual, but I have one for my van and the drawings in there are often indecipherable to me. Some photos would help a lot.
    Pic posting instructions are in the Help link on the left. You'll have to have a hosting site since we aren't set up to let you upload photos here.
    I've experienced something similar last year. Only when the weather was cold, the metal propeller of the main engine fan had excessive play on it's mount. This is the fan clutch that needs be checked for radial play. The new one I have now vibrates less but I can still feel it at 2100 rpm.
    Hi boilermaker,
    What you call Caribou's home brew complies to the official DIN 51606 specification agreed by most automobile manufacturers. Pure soy, canola, sunflower and burger joint waste oils become even once they are transesterified.
    http://www.biocarb.ch/ is where it's made, just down the road from work ;)
    :blush:
    I'll stand corrected even though I can't read French (went to the link).
    What I was talking about was the "home brews". There may be recycling oil plant in CA but not here in the midwest that I'm aware of. I was referring to the garage brews which scare the death out of the auto manufactures do to quality control. There is one registered company that does more that soy. They can be found registered at.
    Hope you didn't feel singled out. The intent was not there. Either way, you made me re-read my post and research a follow-up (as opposed to a rebuttle). :shades:
    Cheers,
    Boilermaker
    Nothing has happened to my rotors. Until the bridgestones, I used discount tire-no problems. The alenza's lug nuts were all over the board from the bridgestone dealer. I had to stand on a breaker bar to get one lug nut use. Lots of cheap rotor complaints, wheel shimmy complaints, can be found to be airguns used by ? on lugnuts.
    Do what the host says, buy a shop manual. I bought early from DC. Wrong. Then I bought a cd from canada on ebay based on a post from anomius, I believe. Look up that old post and buy the good cd on ebay if it is still available $57 ?
    " I couldn't resist..." either.
    Caribou1 dropped that info in a post long ago and nobody followed up on it. I believe it is the intercooler hose that has a plastic sleeve over it. On the surface of the rubber hose under the plastic sleeve, I have oil sweating?
    Wiped it once because I had a defective ps resorvoir cap that was wobbly and blew out aft+4 if i filled it to the cold max level. I ordered a new cap after looking at other jeeps and the new cap was less wobbly and seems to be holding the fluid in. The parts manager couldn't believe what he was seeing. We know from checking new vehicles that our crd isn't the only one.
    There are good pictures. Read the conversation between Steve and I. You need to, get lost, go to a forum, research unlimited.
    I believe that is all I can get away with.
    There is one thing you could do if you can't read the language:
    - Try using an on-line translator, and at least you can get the feeling of what's going on. I have to do that very often for work. It's just a 'copy - paste' operation.
    There are many other countries that have interresting web sites and we share the same terminology:
    JEEP CRD,
    BOSCH CP3,
    CRD PROBLEM%,
    etc.
    It seems eastern europe will be leading the bio-fuel demand because they are 'arriving', rapidly catching up and getting the most recent technologies. That's one of the nice things for us all: there will be great pressure on the automobile industry and refineries to produce and use cleaner fuel. We may even find bio-gasket kits for our Jeeps
    :confuse:
    Thanks for the info. The dealer has been in touch with the engineers at Star, and they say I am the only one with this problem! I find that either odd or just my luck! Star has said they are writing a new program for this. They have re-flashed my computer 6 times now. I will say my dealer is trying to do their best, and I think Star is attempting to solve this issue. But to me it seems like it ought to be a easy problem to fix.
    After reading some of the issues others are having with their CRD's. and how much they are spending foe fuel additives, cetane boosters, anti-gel, and this Bio diesel, and tightening clamps, and air filters, and a host of things that I wouldn't put up with. If someone wants to spend this much time with a CRD Jeep, you might as well see if you can claim it as a dependent at tax time!
    I intend to change oil at around 9,000 miles. I check my oil about every three fill ups or about 1,000 miles. When I change oil I will use the 5/40 Mobil 1. I am using the engine heater when it's suppose to get to 25Fh. or below. I think the CRD is a good solid 4X4 and that's what I expect. I really believe the old motto "IF IT Ain't BROKE Don't FIX IT !" I Wish you a Merry Christmas.
    Farout
