Jeep Liberty Diesel
16364666869224
  • tomwtomw Member Posts: 31
    Thanks MTBCRD!
    I went to Tarbox 3-4 weeks ago - the last 2005 CRD on the lot was just sold and they would allow me to test drive (which I very much respect - if they had I wouldn't consider buying from them because, if the tables were turned, I wouldn't want MY newly purchased car sent out on a test drive)!
    If I ultimately decide on a CRD I will shop at least two dealers. That said, how has your service experience been with Tarbox??? For me that is a consideration - I believe in getting service / maintenance where I bought, and I'm willing to pay a little more up front for a dealer with good service.
  • sailormonsailormon Member Posts: 48
    I thought I would put in my 2 cents worth. I have just over 4000 mi. but am in fl. right now. I mentioned getting good mileage with some additives but did not mention which. I use power service like others plus one I do not mention. I get close to 32 mpg with this at 55 mph,30 at 60-65 and 29 at 70 mph. My wife had her doubts and I stopped. Got 26 at the best going down to the keys, down 2-4 mpg. and lost 2-3 in town. In fact I just put it back in, went down the highway to get supplies and maintained 32 mpg. Some fuel additives work, but only those that are proven in fleets such as those in england or elsewhere. By the way, my wife stopped nagging after proving the results as well as the motor being quieter and smoother. I have hesitated to even mention this due to the flak others have recieved on other forums. I am testing a second at this point and it seems to be delivering as well. Both were well researched on my part and are not in the acetone catagory. I am hunkered down with my hands over my head, but will continue to use these because the results are real and measurable right away with the on board computer. I did not see results right away due to deep snow etc in mi. but got better after a few tanks and warm weather comming down south. Hope this may help as a couple were tested extensivly in fleets of diesel busses and trucks. Cheers BR the boatless sailor (due to a hurricane)
  • synlubessynlubes Member Posts: 184
    have 9000 miles no egr valve yet march 2005 build do run octane boost and blow its nose once a week
  • vtdogvtdog Member Posts: 163
    Don't want to sway you one way or another, but when I lived in RI (didn't like it, but that is another story) I bought a used cherokee from Tarbox. I got a good deal and the few things I needed fixed under warranty they took care of quickly without any hassle
  • anomiousanomious Member Posts: 170
    C'mon! Sailor... We all want to get 32 MPG!
    what's the magic additive?
    Thanks! LK
    P. S. You can tell me...I won't tell anyone! Lol
    Hey, thanks for not throwing bricks. I suggest you go to oxonica.com and start reading there and also look up the tests of the stagecoach group in england who tested the product with over 7000 diesel bus fleet for over a year. There are a few suppliers in the us.This I know works and is the one I talked about. The one I am testing now comes from a CA. company called H20 corp. gaspricefightback.com Both companies use nano tech to achieve results. I don't yet know if the H20 product works as well, will know by days end, after a trip upstate.
    On another site some cut into these companies, but would not try the products, but based their thoughts faith that nothing will work and all is snake oil. I don't recommend anyone try anything unless it is backed up by large scale testing. Also a one time testimonial such as myself is suspect because my engine may run better because it just likes the taste of the stuff. I did notice that at first there was no change, but then both companies claim there should be a cleaning out time before one could be expected. Will let you know how today goes with the H2 0 stuff. BR
  • mtbcrdmtbcrd Member Posts: 5
    I too get the feeling that Tarbox is a dealer you can trust. I think I've been treated well there.
    It took them a couple of times to figure out the egr problem when I had it. When I got mine they only had one tech trained to work on the crd, I think they have more than one now. For my troubles they did an oil change for the bubble, considering it cost around $80, I was happy. I've been there for all scheduled maintanence so far and they seem to be good. Best of luck in your search!!
  • actarusactarus Member Posts: 20
    Did they found the solution to your problem?
    I also have the same trouble code but my dealer has not found a solution yet.
    Thank You :cry:
  • dcxmandcxman Member Posts: 14
    Hi all,
    Have an 06 with 3000 mi. and am getting 21-23 so far at
    higher than average highway speeds.
    Question; Has anyone taken off the fuel filter cannister
    yet? Does it make a mess taking it off? Should we take it
    off periodically to check for water?
    Envirox? Where in the US is this available for sale?
    Just bring it up on search and a few jump up. The one I bought from had a lot of hype and little referance to the research. I contacted them about this and he explained the normal consumer didn't give a whip for facts, just wanted to be convinced. In our mailing he was above board however. Go to enviro max one or extreme research corp. There are a few others I think. Br
    i have a 2005 march build about the same milage just went to 425 75 16 tires to see if it might help it had 225 75 16 tie=res before also installed a aero turbine muffler will let yono if they work
  • clarkkentclarkkent Member Posts: 154
    You all talk about the +'s and -'S of the Diesel.
    Liberty, or MB or Dodge Ram etc.
    You all forget to factor in the cost of the FUNERALS for all those that freeze to death in their diesels when they jell up and quite running in the middle of the road when it get 20 or more below 0!
    I don't care what anyone says, they will jell up, even when your just tooling down the road, if it's -20 or below. Try all your additive it still will jell up.
    A gas car won't. And I know of no gas engine that won't go over 200,000 today if you change the oil and drive it right. Who keeps a car over 200,000?
    I have had 2 MB diesels. I would never have another.
    1. You have to paint your garage ever two years due to
    diesel soot on the walls.
    2. Dirty to fuel. Have to have gloves.
    3. Get diesel oil on your shoes sometime and get it in the
    car.
    4. Diesel cars stink, (smell bad)
    5. They make too much noise.
    6. They cost 3 times as much to fix as a gas engine.
    7. Hard to get worked on. (take much longer)
    8. Can't always find fuel. (getting better)
    9. Jell up in the winter. Very unreliable in cold country.
    10. Fuel is more expensive.
    I know diesels have gotten better, but so have gas engines.
    If I needed real pulling power in a truck, I look at a diesel, but in a car (in the USA) no way.
    The way I look at it you will break even with a diesel at just about the time it wears out. So why put up with all the disadvantages of the diesel for that.
    And look at me, it usually take a person 2 diesels to figure that out!
  • mdamickmdamick Member Posts: 277
    Currently at 27700.
    I have had the transmission TSB, the fuel filter assembly replaced and am currently waiting on some parts for the EGR cooler assembly (it has an exhaust leak in this area).
    Mileage has been as low as 17 & as high as 29.
    Average has been around 22.
    I use 8 oz Power Service on each fillup.
    I respectfully disagree on most of the points.
    1. I don't have a rocked garage-not an issue.
    2. Not that bad-just get used to it.
    3. Watch where you are putting your fuel and your feet.
    4. I like the smell of Diesel in the morning. The CRD doesn't smell like a Diesel unless it is below 20F and then only until it warms up.
    5. The CRD is as quiet as any gasser.
    6. Can't argue much with that one.
    7. Need to find a shop specializing in diesels.
    8. Never have had any problem finding a Diesel pump.
    9. I have had my Dodge Diesel for over 12 years. Temps way below 0 and have NEVER had a gel up. If you use anti-gel and proper blends of fuel it will keep going along.
    It currently has 210000+ and I plan on keeping it for quite a few more years.
    10. Current fuel costs are greater, didn't use to be. Still getting 50% better mileage than the Durango I was driving. I put on over 400 mi/week just going to work so I am still saving $.
    I am also looking at the long term fuel availability issues. The diesel will burn other things, the first ones used peanut oil-no engine mods needed. The fuel injected gas engine will not take to alcohol without being factory designed or carbureted.
    The big trucks use diesels because they stand the test of time. I think the CRD will too.
    Pros and cons of diesels in general is being thrashed out in the Diesels in the News discussion - check it out!
    Driving diesels aince 1968...5 Mercedes and now a Liberty... I won't waste time trying to counter your post. Please do go to the other forum..
    Thanks...LK
    tires were 245-75-16 my mistake
  • djc3djc3 Member Posts: 1
    Is a tow package available with the Liberty diesel? If so, what does it consist of, and is it a recommended addition if one is going to tow a closed 16' v-nosed 5' wide trailer and race car with deadweight of 3500 or so? It is easy to add an aftermarket Class III hitch, but I am concerned about the need for a factory-installed trans cooler or increased engine cooling capacity on a new 05 I am looking at. And, how will this vehicle do at towing this package?
    Also, are there any significant differences between the 05 and 06 models?
  • ttandjjttandjj Member Posts: 21
    Must have been smoking crack while writing this. Don't have to paint garage. Don't wear gloves when fueling. Not spilling diesel on my shoes. Libby smells like italian leather. Endearing purr of an engine. Haven't spent a dime to repair. haven't had difficulty getting worked on. Fuel everywhere. Live in the mountains of WV (gets cold), never gelatinized fuel. Fuel is 30% more but last 50% longer. Your problem was owning a MB (or 2). Nothing but a heap of crap.
    How can you spill diesel on you shoes when you live in the "mountains of WV"? From what I've heard (in song and verse) people in WV don't wear shoes becasue they can't afford them. Get your Liberty with some of your food stamps or ADC checks? ;)
    PS If there had been no reference to what I was smoking in YOUR post, I would not have posted this. (but then when you have someone who doesn't appreciate the finer points of a MB, what can you expect?)
    To all others who read this post I apologize.
    I have just re-read my post. I apologize to all, even ttandjj.
    It was unprofessional. Sorry.
    I must thank mdamick,(a real gentleman.) He started his post " I respectfully disagree" If I would only think twice before typing.
    My original post was not posted with any disrespect toward the Liberty or diesel. It was just a report of the history I had with diesel cars.
  • raymcraymc Member Posts: 8
    Hi Sailorman do you have a name for a supplier of evoirox fuel borne catalyst
  • mbrady1mbrady1 Member Posts: 13
    I'm looking at several CRD versions from sport to limited. The window sticker diesel package range from $960.00 to 1,345.00 to 1,745 to 2,650?? They all list the exact same equipment in the description, so what gives with the price difference for the apparently same package?
  • whitgallmanwhitgallman Member Posts: 121
    I got the tow package on my '06 CRD. INCLUDED Heavy Duty radiator, 2" receiver hitch and 7 pin connector w/ a 7 pin to 4 pin adapter.
    Says with this it's good for 5,000# towing w/750# tongue.
    Looks like you need about a 10" to 14" extension bar to get the ball past the spare tire and a ball mount with about a 4" rise to get the ball to 20" high. (use up some tongue load with the extension)
    Is the 3,500# combined car and trailer? If so, OK. Folks on this site have commented about what they've towed.
    Differences between '05 and '06? '05 got a 7 yr 70k mile warranty. '06 got 3 yr & 36k mile. Seems like per the discussion here, a problem with the EGR valve may have been fixed and the engine computer programing may be improved.
    I believe as well that the '06 has stability control (but no Trac Loc), while the '05 is the opposite.
  • siberiasiberia Member Posts: 520
    I put 1,073 miles on my CRD over the holidays with a ScanGauge tool connected to the CRD OBDII port. This device is not approved for the CRD because of reported data stream interrupts from the CRD ECU. It works perfect on my other car.
    Anyway, the data stream interrupted many times over the 1k miles. It would seldom work more than an hour without stopping. Nothing special seemed to be causing the interruption. There seemed to be no correlation between interrupts and any driving conditions or computer readings.
    Here is the odd thing. Once during the trip in got jerking after an onramp for about 5 or 6 seconds and the data stream DID NOT interrupt! It was also a couple of miles after refueling.
    I never saw an engine coolant temperature reading greater than 173F during the trip. By comparison, my brother’s Jetta TDI runs at 190F. Doesn’t 173F seem a little low for engine coolant temperature on a diesel? Outside temperature ranged between 25 and 54F.
    It's pretty sad when someone replies to his own post.
  • faroutfarout Member Posts: 1,609
    I have noticed the same thing, and asked my dealer what gives. I was told the different packages makes the price . Hope this helps.
  • biodieselmanbiodieselman Member Posts: 41
    Just learned that the Dodge Caliber will not be available in the U.S. due to tightened emissions rules. I don't know if this rule will cancel the diesel for the Liberty. Does anyone have info regarding that????
    All of the diesel powered Calibers are going to Europe where the fuel is ultra-low sulfur!!!!!
  • winter2winter2 Member Posts: 1,801
    I do not think that DC would bring over diesels just for a few years. ULSD will be available this year in the next few months as I understand it.
    Emissions rules will be tightening over the next few years with the first notch being put in place next year. DC diesels should be able to meet these new rules with ULSD. PM filters are already being used in Europe with very good results. The only tough nut left to crack is NOx. There are some good viable solutions for this problem.
    I expect to see the Caliber here.
    Ty htt://enviro-bricks.myextremeresearch.com/index2.asp I think there may be a couple others, this is the one that has a lot of hype and tries to get you to sell the products. To busy for that myself. Also seems shipping is a little high for package. Just for the record, I tried the other product going up 41, lots of stop and go,with many waits at lights, with a few miles now and then at 55, ave. of close to 25. Don't have a clue if this is good or bad. Luck. BR
    does anyone no if the crd will get the tax break for clean burning diesel
  • jimi7jimi7 Member Posts: 17
    Certain packages/trim levels already include the tranny and transfer case upgrade that you get as part of the CRD pacakage, so the cost for those items is backed out of the price. Hope that helps.
    No tax credit for ANY currently available diesel passenger car, suv or truck.
  • cubejockeycubejockey Member Posts: 8
    Anybody hear about Ford's new Reflex Concept Car? It runs on a 1.4L Turbodiesel Hybrid..
    There might be some talk about it over in the Hybrid Diesels? discussion.
    27 mpg per the EVIC (which has been w/in .5 mpg of gallons/miles calculation IMO) for 330 mile trip, 260 miles two lane highway with plenty of towns with stoplights along the way, and remainder city driving. :)
    I'm beginning to question the affect of temperature on the CRD. Temps. during my trip were 40 to 46 F. During times that temps. are less than 40, my mileage seems to suffer greatly. Prior diesels that I've owned were lest efficient in winter due to winterized fuel and cold temps, however, none of them had a mileage decrease as high as the CRD.
  • jkinzeljkinzel Member Posts: 735
    Have you ever looked a diesel truck on the highway in the winter. Most have a canvas cover over the grill to keep the radiator from cooling the water too much so the engine runs at a warmer temp. Try putting a piece of cardboard over part of your radiator and keep an eye on your temp. see if it makes a difference in mileage.
  • caribou1caribou1 Member Posts: 1,354
    The older diesel engines did not have the mass airflow sensing. I still have one that's almost 10 years old and it gives the same mileage all year round. The older diesel also starts better in the morning. It's a Toyota... :surprise:
    When you say "older diesel engines", how old? My experience with diesels is limited. At a company I worked for in the 70's we had diesels. They started easy enough in cold weather but they were useless until they had run for 10 or 15 minutes. My CRD turns through 4 pistons and it's running and almost immediately driveable. In the summer I sometimes hear the starter and it's running - maybe 1 or 2 pistons.
    However, my coldest start was 12F(-11C). Does starting get substantially worse at -20F(-29C), say?
    If you plug the engine in to keep it warm, then starting should be a non-issue. If you do not plug it in, it might take several attempts to start it.
    My old 1981 Isuzu diesel car did start at -20F on the second try and was never plugged in. Pre-heat time was 3.5 seconds each time. It had been sitting in -20F cold for three days before I started it.
    The coldest my CRD has seen is +9F and it started instantly and it was not plugged in.
    I have started the CRD at -8 and -12F after overnight rest without being plugged in. Drove away after about 30 secs, got heat in 5 min and was warm enough for overdrive in 10. Did not use any additives (other than winter blend diesel)and car started after only a couple of seconds on starter.
    Starting sounds about right at that temperature and the way you describe it.
    mine started at -5 degrees sounded like the rods were coming out no heater my first diesel
  • sebertsebert Member Posts: 2
    I recently purchased a 2005 CRD with a build date of 2/14/05, reading this forum it appears I might want to go back to my dealer for a several updates. Is this a good idea? I have 1600 miles so far no problems, good mileage (20 in town 27 on the highway). Is the adage "don't fix want is not broke" the way to go or could I head off problems with a preemptive visit to the dealership?
  • craigs1969craigs1969 Member Posts: 20
    I too have a build date question. Where do I find the build date?
  • biobobbiobob Member Posts: 11
    Does anyone know where to locate the 'fuel-water separator knob' on the Jeep Liberty diesel? I got some bad diesel, and I think I'm going to have to replace the fuel/water separator filter. The manual refers to pressing the 'fuel-water separator knob' 20 times, etc. I know where the manual hand prime pump is located, but I can't find the 'fuel-water separator knob'.
    The engine is running very rough, and the ETC (Electronic Throttle Control) warning light starting flashing. The engine is very slow to start.
    Other than the bad fuel, I have run a B20 blend of biodiesel, and it runs great. That's why I chose the diesel, was to run biodiesel, help the farmers (who grow the soybeans that makes the biodiesel), and tell big oil to 'stick it'. ;)
    The build date should be with the owners manual, tire data lemon law bundle of paperwork. It will have a big UPC code and in the bottom right had side there should be a date, I believe this is the build date.
    the build date is also on the driver door just inside on the post my crd has build date march 2005 havent done anything nine thousand miles
    Hi! I got a tank full that did the same thing. I went home and put 12 oz. of Power Service stuff in the tank and then it ran ok. Same knob! I don't think the filter is bad.
    Good luck! LK
