Visitor Agreement.
I guess I'm worried that I might be making the wrong decision. My wife likes the new trucks features but I know and like the truck I have now.
How are the new 2000's? Are they as strong as the k series units? What kind of problems are occurring?
Anyone had both styles and can compare the two?
a tech advisor told me that they had just gotten a bulletin on it, and the problem is with the steering gear. Evidently the tooth angle is slightly off on some of them and it produces a squeal when the wheel is turned to the left. GM knows about the problem but is only going to replace them for the people who complain and let everyone else live with it. If you haven't had yours fixed I can even give you the part number your service dept. needs to order. I've had absolutely no other problems with my truck and love driving it with the new silent steering gear.
I can not find this vehicle anywhere.(Possibly because I am not sure what I am looking for?) I have looked at Edmunds and other places but without any luck!
By the way, I used Edmunds to research my fully loaded Tahoe with no trouble!
Please help if you can.
I'm not having anything done to mine!
Peter
Did the service manager tell you how they determined that the r&p needed replacement. I remember kansan having the TSB done only to have the power steering squeal. Dealer updated with new rack and the squeal was gone. If the r&p was machined wrong, is there any way of telling?
Thanks for the tip.
I certainly appreciate being able to go to my dealer with printouts of your posts with TSB numbers and so cut to the chase without a lot of maybes and mightbes. It is just that I am concerned that a peripheral problem will occur that I don't need or want!
Cheers, Al
People like you who share your experiences are certainly a great help to so many others! Thanks again.
Cheers, Al
The funny thing about the steering squeal was the truck had to have been driven 2-3 miles before it started to squeal and it seems that in wet or cooler weather it was almost unnoticeable. Now I'm listening for it, but the fix seems OK so far.
Thanks again to all those who responded with the TSB number and advice.
Cheers, Al
You may be experiencing an dry bushing or an oversized tire rubbing against some part.
Hope this helps, Al.
so more than likely it could be a dry bushing or somethin of that sort
btw i have a '99 Z-71
just got it back from the shop..put a new intermediate shaft in the steering column...feels just like when i bought it..very impressed, also put the blue grease on the splines and for now has taken away my driveline clunk so thats ok right now
right now my rear seat when someone rides back there bangs against the window and GM hasnt got a clue what to do..they told me it was a design flaw so until they redesign the back seat there will always be a bang against the window...
My '95 F-150 had loose steering, too! I like the GMC feel much better.
By the way, the internet response folks at the GM Goodwrench site said that using any rear axle lube other than the GM lube will void the warranty. They said it is a special lube that is not offered in the aftermarket yet. A straight GL-5 rated lube is not acceptable.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
