Visitor Agreement.
~c
Yes I'd like better low end grunt, but I happily swapped that for the different handling feel. With the few thousand left over, the Rex buyer can put in a new exhaust system and reflash and be much quicker than the FXT. The WRX will still find a market with the person who will mod and tweak. Just not sure how big a percentage of current WRX buyers they represent.
Nicholas
Engines aside, the WRX is about handling and sleeker looks and the XT is about utility and nicer amenities. Myself and others are addressing the handling issue, but I think we are in the minority for Forester owners.
IMHO, there are only a few (in terms of overall sales) that choose the XT over the WRX wagon. I see more STi's now than XT's and I hope it stays that way.
-Dennis
while faster in a straight line, that wouldn't help low-end at all.
~c
~c
-juice
-Dennis
p.s. - Colin - Are you saying you think the XT outsells the XT now, or if the WRX gets the 2.5?
By exhaust, I mean turbo-back, and those certainly do bump the low end. For example,Cobb's turbo-back and re-map:
http://cobbtuning.com/wrx/images/ae-stage2-dyno.jpg
That's essentially peak stock torque at 2500rpm. That's enough low end for me.
What's dyno'd Torque for FXT at 2500? Anyone?
I'd put $5 on the Forester XT outselling the WRX wagon by a wide margin
I'll somewhat agree here. I wouldn't be surprised if it did outsell the WRX wagon, but I'll bet that most FXT buyers will come from regular Forester sales or off-brand. There would have been a few Legacy cross-overs too, but that has been cut-off by the new Legacy offerings.
Just let me repeat my mantra. MOST Rex wagon and FXT buyers are different animals, so I don't think the bigger engine will pull many away.
OH and did I mention that I don't have a problem getting track time? BWAAAAAAH! But seriously, you'd have a truckload of bitter owners if droves of Rex types bought FXT's only to find out that SUV's are persona non grata at the local track.
Nicholas
I think we're getting carried away since this is "Suggestions for Subaru". :-)
-Dennis
Nicholas
For the record Volkov does not race or drag. Volkov is not planning to put in a Stage "whatever" performance package. (I am very likely to do the up-pipe though.) Volkov knows that his Rex isn't an STi, and that it isn't even as fast as the FXT. Volkov is very happy with his Rex wagon and has no regrets:-)
Nicholas
A good first step would be to make standard the internationally well-known four-pot front calipers. Many enthusiasts make this modification but are then forced into aftermarket wheels as their OEM wheels will not clear the bigger calipers. Subaru merely needs to change the OEM wheel offering to avoid this problem. In the rear the discs could be replaced by those from an H6 Outback or one of the higher performance STi variants available in other parts of the world.
Further something needs to be done to reduce the nosedive upon braking. The XT is improved over my first-gen Forester in this regard, but the dive is still noticeable. Some OEM equivalent of the anti-lift kits available in the aftermarket would be helpful here.
Ed
The X3 does have better OE tires than the Forester, though.
So anyway, my suggestion: push the brake pedal harder in the Forester if you want to stop faster. A corollary to this is to attempt to see which vehicle you can brake very gently in the easiest.
~c
That suggestion still doesn't address the nosediving.
As far as OE rubber the X3's is better but, to be honest, I didn't feel that it communicated that it was reaching its limits as well as the Forester and its so-so Geolandars.
Should I find myself in a position to pick up an XT I would strongly consider having the dealer keep the Geos and install 5 tires of my choosing (most likely Dunlop SP 5000s), even if the dealer doesn't offer me a credit on the Geos.
Ed
STi springs should address the nosediving. :-)
The XT definitely should have come with a performance/sport suspension package, at least as an option.
-Dennis
-Dennis
Ed
Again I don't want to spread misinformation. A lot of Impreza parts have been bolted onto Foresters and, despite their common underpinnings the Impreza parts, not having been designed with Forester use in mind, don't always deliver the desired results.
Ed
-juice
But now the pressure is on, Toyota has VSC and SAC on the RAV4, and I just heard a rumor that Honda will make ABS, VSA, and SAC standard on the 2005 CR-V.
If so, Subaru will fall behind. Time to rush some of these features to market. Stability control and side air bag curtains are now expected at the $18k price level, not just on near-luxury vehicles. Time to step up!
The current model was new for 2003, so 2006 is the mid-cycle redesign. I fully expect Subaru to have both by then.
-juice
Take the R1e as a starting point, but scrap the electric engine. Instead take the current 2.5 boxer engine and lop off two cylinders so that you have a 1.25 boxer twin. Then hook up the hybrid motor unit from the B9SC, and the AWD and voila! A micro Subie with all the Subie attributes: a boxer engine and AWD.
BMW has been making 1100cc boxer twins for their bikes for some time, so I'm sure Subaru could do the same with their boxer too. Also the advantage of lopping off cylinders, rather than an all new powerplant, is parts interchangeability with existing Subies.
Consider the following scenarios:
• A 1.25L Subie boxer would put out 82.5 HP (165 ÷ 2 = 82.5)
• A 1.25L Subie (from the F-XT) would put out 105 HP
• A 1.25L Subie (from the Legacy GT) would put out 125 HP
• A 1.25L Subie (from the STi) would put out 150 HP
Then add the hybrid motor and you would have a micro Super-car!
Bob
tradition is its only reason for existence. it would make an awful car powerplant, even a hybrid. for your argument's sake 1.25L I'd go with the tried and true inline 3.
~c
I would not want to use a 2-cylinder engine in a car by itself. However, with an electric motor assist, it just might work -- at least in a vehicle the size of the R1e. If nothing else, it sure would be full of Subie "character."
Bob
Still, I think it's more out of curiosity. I'm not convinced Americans will buy microcars unless they are coupled to certain incentives (HOV access, tax breaks, free parking, etc).
So IMHO the laws must come first.
-juice
Bob
HCH is successful, Prius has demand outstripping supply. But the Insight doesn't sell well, probably too small.
Soon we'll have a Camry, RX, Highlander, Accord, Altima, etc. I would not bet against the popularity of any of those.
-juice
Bob
But seriously, a lot of my co-workers are just that, and most of them just take buses, bike, or even walk to work. Or the subway.
As for incentives - they now offer Metro Check here at work, so a lot of people signed up for that.
We'd have to see special parking spaces, or even free or subsidized parking, before there was enough demand, IMHO. And by the way, I'd consider a Smart Roadster, absolutely! But I'm a tiny minority.
There are other factors - any attempt to move upscale would have a bruised image if a tiny little city car came out. Note that Mercedes didn't put their name on the product.
Subaru should consider a fuel efficient model, but I'd look at a 2.0l Impreza TS, sedan and wagon. Especially now that there is an RS wagon. The TS could be the fuel miser.
Then look at hybrids, but my guess is putting that on an Outback or even the 7 seater would produce much higher demand than a city car would.
Segways have not caught on, for instance. They too need dedicated lanes (I'd propose Beach Drive) or some other incentives.
-juice
Bob
-Frank P
The Legacy is still a compact by EPA measures, though the 2005 just might creep into the mid-size class. Subies are already small, they need bigger cars more than they need smaller cars.
I do think they could do things to make the current fleet more fuel efficient, like the 2.0l engine, Direct Injection, AVCS, etc.
-juice
Bob
Any how, this is a topic for brainstorming ideas, so I'll shut up now. :-)
How do they appeal to college kids? Unfortunately I think price is the #1 issue. Styling is up there.
Mini Cooper buyers tend to be very old, IIRC.
It's a tough formula. The Echo bombed miserably (few, old people buy them), the exact same chassis and powertrain in a boxy shape is a huge hit - xB.
-juice
The BMW boxer engine enjoys all the inherent design advantages of a (Subaru) boxer engine. If the normally aspirated 4-cylinder engine in my Impreza worked as well a BMW boxer, it would be putting out 200 HP, which it doesn't.
Mark
~c
PS, subaru could easily coax 200HP naturally aspirated out of a 2.5L boxer four. they don't need to though as their company profile is turbocharged engines.
Suggestion for Subaru (back on topic): If Subaru could easily produce a 200 HP 4-cylinder, non-turbocharged boxer engine, they should do so. Such an engine, without the expense and complication of a turbo, would be most welcome. My '96 Impreza has an AT. While the acceleration is adequate at full throttle, it could use those few dozen more horses. Love that AWD, though - the power that it does have goes to the pavement for maximum effect.
-juice
http://www.subaru.co.uk/imggb/www/subaru_accessories.nsf/WebInter- netAccessories/0918F49DD635188680256DC00048D064?Opendocument
Thank you. :-)
SportShift availability would knock 2-3 Crew members off The Fence immediately.
-juice
If I want them bad enough, I guess I'll just get them from the UK. Just trying to through some money SoA's way. :-)
-Dennis
Bob
~c
Nicholas
If I did the gauges I'd either do the triple - even though it's more expensive or maybe this: http://im1.shutterfly.com/procserv/47b4dc05b3127cceb97a56cc0fe000- - - 00001610
Just saw this on Nabisco, and don't know how expensive the set-up is, but I really like it. Nice touch that you aren't looking down from the road.
Nicholas
Geeze, these 4X4's, Suburbans, run at 80+ with boat/ATV/snowmobile trailers. Of course, I'm getting better gas mileage.
MNSteve
-juice
Stock there is no need for a boost gauge.
I can see it now "i blew up my car cause my EGTs were too high, even though I knew the boost was at 18psi"
-mike
