Toyota Sienna 2004+
I took it back to the dealer and they are going to have to order parts to fix it. One part should be here in 2-3 days, the other will take 1-2 weeks!
Obviously I'm not real happy about driving around in a broken van for the next two weeks. I've talked to the service manager and he has agreed to escalate, but I feel like they need to do something else to "make it right with me."
I don't want to be greedy, but I do think this reflects poorly on Toyota's quality - I definitely am not "completely satisfied." I know this is an abnormality, but when it happens to you it still feels pretty cruddy!
So, has anyone had this problem before?
Anyone have a good idea what sort of remuneration I should try to get for this major inconvenience.
BTW - this is my third toyota purchase and my second at this dealer, so I'm a loyal customer that I'd presume they want to keep.
Hey, it's a start, what else are they going to discount next?
The van had a pleasant ride in a straight line and road noise was pretty well controlled. I was able to push the van a bit in a few corners and it was clear than this van doesn't really like twisty roads. The steering is over boosted off center and the shock valving. trades handling for comfort. The engine has pretty good power once the electronic throttle turns it lose. The throttle delay from low speeds could take a while to get use to.
My only real beef with the van is the brakes are not confidence inspiring. They stop the van but you really don't feel like you have more brakes than you need. IMHO Toyota took the cheap route with the drums and/or didn't use bigger drums and discs so they could save money on wheels and tires. I personally wouldn't want one with drums because I am going to be towing a 1000-1500 LB boat/motor/trailer. My Tundra truck and rear drums and the brakes worked pretty well but the drums were really big.
I don't feel the van is unsafe with rear drums but it IMHO it falls short of what is should be in this area. I am going to drive a Honda Ody next then go back and drive a Sienna with rear discs.
I personally would take the XLE FWD, with package #12, with the exception of leather seats. I hate leather. Too bad you can’t get everything but leather. I just hope the '05 models will be better packaged. I also don’t need the automatic climate control (too complicated), I prefer the manual controls. Simple & easy.
Here is my list of changes I would like to see in the '05 models. These changes guarantees to have me as a first time Toyota customer:
1) Lighted switches for power controls of the windows, door locks & mirrors;
2) When opening the front doors, all lights should come on, not just the front;
3) The interior lamps are not bright enough (American minivans are brighter);
4) Sun visor extenders and secondary visors;
5) Rear sonar sensor for the XLE series;
6) I wish memory seats for the XLE & Limited;
7) Auto-dimming outside mirror for XLE (standard in the Limited);
8) Message center with important information. Such as bulb outage warning (found on Toyota Matrix);
9) Power adjustable pedals (found on the Camry);
10) Revised tail lamps and front grille; Bigger tail signal lamps (amber color preferred);
11) Good quality all-season tires (not run flat) and better brakes.
I would also like a few other minor changes, but it’s not that important. Since I’m used to Ford minivans, I like these things: Bigger fuel tank, message center which let you know which door is open, not just ‘door ajar’; Signal or puddle lamps on the outside mirrors; In my Windstar, if when turning off the engine the front or rear wipers are not finished off wiping, the ‘accessory delay’ feature will bring them down, so they don’t stay up until the next time you start the van; Baby sleeping mode; illuminated controls for cruise settings; etc.
Now, a short question. Please answer me on this one. I’m used to Ford minivans and sedans. But whenever driving a Toyota or some other imports, there are many changes which I almost can’t get used to. For example, the wiper controls. On the Ford’s it’s on the left side of the steering wheel, while on Toyota it’s on the right side. The same problem is with the column shifter sometimes, and headlamp switch.
But the main question is, how are the Toyota’s wiper controls designed?? In my Ford minivan, I simple have to turn the switch from off to the highest speed. But in Toyota’s cars (and same is for Ford Focus, Chevy Malibu, etc.) I can’t figure out how it works, you can pull the lever up and down, left and right, push & pull, turn the switch to higher intervals, and so on.... soooooooooo confusing. I’m driving them for weeks and still can’t figure out how it works? Where is logic? Is there any point Toyota designed it that way, and some American companies try to copy them?
Explanations please!
I may get an after market DVD system rather than the factory
would the after market dvd then interfere with this. so then i would have 4 wireless headphones, 1 set for each function??
Has anyone here put an after market dvd system in an xle or ltd--this feature is standard on both
the aftermarket all in one dvd system is much cheaper at say bestbuy rather than factory. but do you get additional benefit from the factory unit
thinking of the following
xle ltd with floor mats, rear spoiler NO RUNNING boards
get the nav and dvd system bestbuy (roadmate 700 and an all in one dvd with 7-8" screen)
also if you use the center console for the rear, can you just buy the folding tray for the front passengers--toyota makes these packages confusing don 't they
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Not to sound like an old TV commerical, but, "try it you'll like it"
Hopefully you'd be able to find a CE with pkg #3. You may or may not know that Toyota builds only a few models for each region of the country. If you want something else you'll have to order it and wait (typically 3 to 8 weeks). That is the situation we are in.
The Sienna braking system needs a very healthy shove on the pedal to really haul the van down from speed. This seems out of character with the light nature of the rest of the controls but it does have its advantages: it is very easy to modulate and you can easily bring the vehicle to a stop smoothly with no jerking an overboosted system often causes.
The next time you test drive a Sienna bring it down from 60, hard. It doesn't matter which brakes (disc or drum) it has, you will be impressed that such a large box can haul it down so fast and hard.
Rear discs are not as needed as many here make them out to be, they are a useful feature but not so much better that most people would ever notice them.
It will be interesting to see if I feel a difference in pedal feel between rear drums and rear disc. I personally prefer brakes with a more linear feel. A low pedal tends to make me uncomfortable.
Wendy
Rotate the end of the control away from you to increase the speed of the wipers; rotate towards you to decrease the speed of the wipers.
Windshield washer: Push the end of the stalk.
Rear window wiper/washer: Rotate the ring on the stalk.
Simple and easy.
I would recommend all car manufacturers to make one design, no matter which one, so you can drive any car without having to get used to all those confusing controls.
Also I checked the Sienna yesterday at night, when I wanted to try out the rear seat folding, it was very dark in the rear area. There is definitely missing a cargo lamp on the roof to illuminate the rear area. The small cargo lamp in the side is almost useless. Besides, as I mentioned above, the interior lamps in the Sienna are not bright. Also the front lamps are theater-like dimming, while the rear is not.
I would also like a lamp in the glove box (I have it in my Windstar), and a lamp in the center console.
Toyota please listen. I want to buy a Sienna next (in '05).
Having to remove a hand from the steering wheel to grasp a control is completely unacceptable from an ergonomic and safety perspective. The motions are completely contrary to what one should be doing. If you are used to it, it may be second nature for you, but for most people it is awkward.
The system that Toyota and many others use where you keep your hands on the wheel and can just stick out a finger to flick the stalk is far superior. Ford even used to offer this on some of their cars such as the old Fiesta (a European made Ford). I have had cars with this control system since the 60s and would not accept any other.
Keeping ones hands on the wheel when a large truck blows a mound of slush and snow on the windshield and being able to clear it without having to grasp a control is far superior.
I understand that you disagree, but among the many reasons I would never buy a Ford or a GM product is the incredibly poor ergonomics of the controls. Truly driven by cost cutting and not looking at what is the best solution.
I was dismayed by the Sienna requiring me to twist a stalk control for the rear wiper when it could have been done by adding a push away motion to actuate the rear wiper or washer. VW uses a push away motion (again doable without taking ones hand off the wheel) to turn the rear wiper on and actuate the washer when pushed further still.
Drove a 98 sienna over 100K miles and this was my experience. Lots of hard braking since 30% of the time I was pulling a large RV trailer.
Ps. My towing experience. I would rate as "Excellent" or "10 out of 10". Drove my 2004 Sienna with larger RV trailer over 10K miles with same result.
In my Windstar, if I want to wipe off (a single wipe) I just push in the end of the stalk, without taking my hands off.
However it is, you still have to agree that it would be a good thing that all cars should share one simple and safe design. Maybe the government will make some new laws for that, who knows..?
Most people don't seem to be bothered by one way or the other, but for many people it could be a deal breaker.
Toyota does require twisting a secondary knob for intermittent and rear wiper actuation, a real failure in my eyes. There are many other human factor errors on the Sienna, but they are less grievious.
In my case both hands are on the wheel all the time. Especially in bad weather, I travel on a road where the opposing traffic is a mix of cars and large trucks and have had many cases where I get a load of muck thrown up. I've gotten to where I can anticipate the event and the wipers are already in mid sweep when it hits.
Yes, maybe a universal design could be of assistance, but as it is, a company that does a good job on ergonomics is a differentiating factor. Now if I could get Toyota to move the stalks down to the 9 and 3 position from the 10 and 2...
The spare tire can easily be removed and replaced on my son's 2002 Grand Caravan Sport. A full size tire can be had as a spare in the DC minivans.
I like the Sienna overhead console trip computer that displays the compass direction all the time and has on the right side the Instant Economy, Average Economy, Distance to Empty, or Outside Temperature.
However, the Sienna overhead console does not have all the nice items of my son's 2002 GC Sport but does have Toyota reliability where DC reliability has not been good for enough years to convince me.
I'm betting Toyota thought of that too....?
30 ft Airstream, 7200 lbs, with '98 Sienna 16 mpg. 30 ft Airstream, 8200 lbs, with '04 AWD Sienna 15 mpg.(Canadian gallons)
I was simply explaining to you the benefits of a great and logical design. I like to be thorough in my explanations. I can sum up the features of the Toyota stalk in a few lines the same way.
Here goes:
"To turn on wipers flick down with index finger. For mist on windshield flick up. To wash windshield pull towards you. To adjust intermittent speed rotate ring."
Also were you using premium or regular fuel when you were dragging the trailer?
I know Circuit City has headrest screens with different sizes
Go to www.circuitcity.com > Car Electronics > Auto Video
However, if you get the XLE and add DVD+NAV, you may regret it down the line. You may keep on wondering if you should have gotten the Limited. You may be thinking later, "what's a few grand more since I'll be keeping this vehicle for a long time?"
I know my local dealer can get me $3K off MSRP if I get the Limited, but only $2K off if I get the XLE.
We originally wanted the XLE #16 but for roughly $1000 more we're happy with the Limited.
twinmom, looks like you could afford it or you wouldn't be pondering. if so, definitely go with the limited. i might add go with the factory NAV/DVD(package #6, HO). after market will be cheaper for sure. but will that worth the trouble? will it function and look as good as factory installed? and if you mess with the interior paneling, drilling holes, splicing wires, would it void the warranty?
by getting the limited, you're getting many useful features such as high intensity discharge headlamps, automatic day/night rearview mirrors, power moonroof, sonar audible parking assist, (by getting NAV you are also getting rearview video on your NAV screen when backing up), front & rear & center side impact airbags, heated front seats, dynamic laser vehicle to vehicle distance and speed control, stability control, retractable side sun shades, traction control, windshield wiper de-icer...
many of those simply aren't available options on the XLE model. although i was fortunate only paid $35,592 for a limited FWD with HO and CF (MSRP $38,846), i would still buy it even if the factory asked for $45,000. it's just that good! look at what other $45,000 vehicles are offering, and compare their quality too.
as for financing, i'm not up to speed, i paid cash. check with your credit union, do searches on the net, etc. there're many very useful posts here regarding that. do a search you shall prevail. one last thing, don't forget to get the factory extended warranty also. anything goes wrong just one time would pay for the price already. for the best price info, read weedshasta's post on that subject. best of luck!
Anyway, with the XLE AWD gk cf package you gets leather heated seats, all the air bags, the integrated sun shades, and stabilty control/traction control, and AWD. If you can live without the AWD there is a similar package for about $2k less ($30.5k). I think its the XLE option #12.
The only things I really wanted from the limited were HID lamps and parking sensors. I tried the laser cruise and hated it and did not want a moon roof. The auto-dimming mirror was also nice but overall the Limited package cost a lot more for stuff I did not really want. So for me the decision was easy. If you want the other suff then the Limited is the way to go. Definately make a list of all your MUST have stuff and try it before you buy it.
The aftermarket is pretty active now so HID lamps are $400 with quality ballasts and bulbs and front+rear parking sensors are $250 (or less). The HID aftermarket retrofits are currently illegal but that does not seem to stop people. I already know 1 LE owner and 1 XLE here who did it and they are pretty impressive. If you have someone install both it will be about $250 labor (mostly for the sensors). If you want DVD/NAV its usually better to aftermarket too as you can get bigger/better screens for less money.
Make sure you try it before you decide. I really hated it. It really does too much thinking.
1) I70 near Kansas City with light traffic but lots of trucks.
2) Two lane roads south of St. Louis.
On flat roads with no traffic it works OK but thats not when it would be most useful. Regular cruise works just fine in that when nobody is around and/or traffic is really light. In the first case a car, or usually a truck, will pass and pull in front you but accelerating away. Nothing needs to be done but the laser assist applies the brakes anyway, sometimes pretty aggressively. Its not dangerous or in anyway unsafe but it is annoying. Also while on I70 a couple of times it applied the brakes on flat land with nobody in front of me for no reason. I could not explain that at all. It was certainly not scary but you could tell the sales guy was kinda puzzled too. I dont expect it to read my mind but I just was not impressed by it.
In the second case on 2 lane roads that curve it seems to get really confused. 45mph speed limit through some wooded areas some gradual curves and some sharper. It applies brakes at weird times and other times it brakes really late. I'm not sure what its doing. In this case I was not able to get the speed set just the way I wanted. I'm used to using cruise on those roads.
Its not like I dont like laser assisted cruise at all. I just dont like the current version in the Sienna.
