If you're thinking about one particular model, ask and I'm sure someone that owns one will chime in.
There are just far too many models sold now to answer that in one shot.
-juice
We wondered about that when we discussed it, but it looks like OnStar will not revise the directions if you make a wrong turn (or a road is closed). That's a bit of a pain.
Also interesting is that FoMoCo had the best and the worst OEM systems. The Lincoln Zephyr took first, and two other Fords were among the bottom 5.
Proof we can't generalize and say "Ford's NAV is nice".
-juice
http://www.costco.com/Browse/Product.aspx?Prodid=11159739&whse=BC&topnav=&browse- =
I understand your wife's desire. But Bluetooth is fine for phone conversations when the microphone and speaker are near your mouth and ear, and you don't care about the additional battery power draw on your phone and bluetooth headset.
A Global Positioning Satellite Navigation System doesn't need the complication and additional battery power draw of a Bluetooth phone connection.
Your wife's phone calls will be much clearer to both parties of the conversation if she doesn't have to yell and try to listen over the distance to the dashboard or windshield where the Navigation System will be mounted.
My recommendation is a handsfree wired headset for the phone. Garmin's nüvi line of pocketable Navigation Systems is a great place to start your research.
http://www.garmin.com/products/nuvi/
Most online mapping takes you down the superslab whether you want to or not. I was just wondering if you could set some sort of preference.
: Add Your Favorite Drives
Nüvi sounds come from their built-in speakers. It is possible to route the sound through the car's speakers using an FM modulator or cassette adapter. But it probably will not be an elegant solution, such as muting a running radio program or CD as do original equipment built-in navigation systems that incorporate Bluetooth direct from the auto factory.
You may want to do some research here:
http://tinyurl.com/yhp8zv
My Garmin nüvi 350 lets me select the following Route Preferences: Faster Time, Shorter Distance and Off Road
It allows you to choose the following Avoidances: Traffic, U-Turns, Highways, Unpaved Roads, Toll Roads and Ferries
It also allows you to choose the following Vehicles: Car/Motorcycle, Pedestrian, Bicycle, Truck and Bus
Your judicious selections from the above choices should provide the results that you are looking for. I'm confident that the more advanced portable systems, such as the nüvis, provide similar choices.
Bluetooth audio would provide wireless audio without the noisy static of wireless FM adapters.
This technology already exists since Bluetooth stereo headphones are on the market and I don't see why the technology could not be applied to other devices.
No dangling wires required if you run the device on batteries and they could even have a USB power docking station built into the car to eliminate wires for charging/mounting the device.
Bluetooth Phone, Sat Radio, MP3, Navi, etc.
-mike
link title
http://crunchgear.com/2006/12/21/tomtom-releases-new-mapmaps/
It would be simple, flexible and inexpensive and eliminate the need to suction mounts and dangling wires everywhere or else spend $2000 on a factory nav system that you can't take from car to car.
The current Toyota Camry has something like this in front of the gear shifter, but it is a bit low in the dash for a GPS unit.
Not only is the Camry cubby in your photo "a bit low in the dash for a GPS unit", but tucked in there, the GPS navigation system's antenna would be totally blocked from the necessary direct view of satellites.
Anyone here with any experience with one of those systems? Is it as bad as it sounds?
Sure, nüvis contain WAAS-enabled GPS receivers by SiRF. But whatever the chipset technology, if the unit's antenna cannot "see" or acquire enough satellites it cannot navigate properly. Just see how long (if ever) a GPS navigation unit takes to navigate inside your home but not within a foot or two of a window.
A unit with its antenna "burried" inside of a car "cubby" will take forever to acqure enough satellites to navigate.
It just takes an extra minute or two for the initial lock if it isn't ideally located, not "forever."
-mike
It wasn't until later on the New Year's week-end that I opened it up. I checked the Web site of my favorite retailer (Crutchfield) and was shocked to see what this thing sold for! Remember, I had expected something kinda cheap and out of date. I turned it on, the boot splash screen shows the Hyundai logo for a few seconds and then displays the standard interface that I have seen at Garmin's Web site. There doesn't seem to be anything Hyundai specific except for the brief splash screen that displays for a few seconds.
Has anyone else experienced or heard of this offer? My initial impression is very favorable, and I am eager to learn how to use it. I guess my basic questions are as such:
1) Is this a generally well-regarded portable GPS device, or are there some major flaws I need to be aware of?
2) Other than this forum, are there any sites you can direct me to that would assist me in learning the true potential of the nuvi 360?
Thank you in advance, I hope to be a regular here.
You will find lots of great information about the entire nüvi line at this very active GPSPasSion forum:
http://tinyurl.com/yed9d2
Just be sure to view the English language version, since the site is in France. 95% of the forum participants are in North America.
As with any user forum, you will find some negatives along with the positives on the 94 pages. Be sure to read the sticky FAQs before anything else,
I agree that portable units are far superior. Even though I prefer the tomtom One because you can carry it around on foot and use it as pedestrian but, I would even take the tomtom 910 or 510, which plug into the cigarette lighter, over a factory installed unit any day of the week!
All the pice here: http://pbase.com/paisan/armada
talk about merging the old and the new.
does that monitor stay there all the time? I would think that would be an easy target for a smash and grab.
With the new screen it has a quick release on it so I pull it and stick it in the glovebox when I park.
CB is essential for not getting tickets, and on-road communications in caravans.
I need to work on getting the wires a bit more hidden on it but overall I'm pretty happy with it. Hopefully this weekend I'll get some screen shots of the GPS/MP3/DVD/Everything front-end system on the carputer.
-mike
but now you can just e-mail or IM each other. ;b
Your carputer setup is definitely [non-permissible content removed]
I park in Harlem for months, no issues with the screen being taken.
Then I am out at my parent's place in Staten Island which is basically all cops and mobsters, suburbia, and it get's robbed there.
Afterward I'm like, this is odd, it SHOULD have been stolen in Harlem, not out in the burbs!
Now I just stick it in the dash when I turn the car off.
-mike
-juice
This is not GPS, it's basically like having MapQuest in your palm. It has maps, can find addresses, and give line-by-line directions, all for no charge, and no service charges either.
Not nearly as useful as my GPS is, but when my wife has the GPS at least I have something. You still need 2 addresses and a compass, sort of, to make it useful.
I'll share more as I start to use it. I will today because I'm in the Miata and I don't have the GPS with me.
-juice
Can you change the Tom Tom voices from British English to American English or Australian English as you can with the Garmin nüvi series units?
How many gig you got on your carputer?
The directions were OK but I went a different route, Beach Drive is too fun to avoid.
The maps were helpful in finding which street to turn on once I was close, though.
The Pearl has more functionality with this application, but I have an 8700g so I don't know much about it.
-juice
I have a 250GB internal HD, but could put in any IDE Hard Drive available. Externally I have a 60GB USB 2.5" USB-powered HD, basically I plug that into a mini-usb plug which doubles as my BB charger.
-mike
Not very informative. I was hoping for a LOT more info on the models they tested.
-juice
Here's a couple:
http://www.gpsnow.com/
http://www.thegpsstore.com/Accessories-Garmin.asp
link title
Seriously car companies like DCX are starting to include these psuedo car/computers as a standard feature. You are a bit ahead of your time. I'm pretty impressed that you got 250 GB what do you do with all that space on your HD???.....are you surfing the web while driving??
-mike
-mike
Sadly, more and more automakers have custom sized opening. A big hit for aftermarket vendors, and a shame really.
Tribeca and Mazda5, for instance, won't take double DINs.
-juice
-mike
I just wonder if they will bother to make one for a small niche model like many Subarus.
I believe models with climate control have HVAC buttons in the are so they would need a creative solution like this to go aftermarket with the stereo.
My 98 Forester and our 02 Legacy are standard double DIN. I think even the new Foresters are.
-juice
* More than 410,000 new road miles and 500,000 points of interest
* More than six million new household and business addresses
* Improved road detailing for better visual representation
* Updated shopping centers, golf courses and more!
This is pretty cool should really improve TomTom capabilities in the US
http://www.tomtom.com/products/maps/?Lid=4&TT=rg60d3hldk5bhqpnun51esg953
