Chrysler Pacifica: Care & Maintenance
Thank you for the information on the rear seat headsets... Now if I could only get
the mirrors fixed...
Ed
Service seemed interested that I make routine use of the auto-stick. I use it to keep the car in a specific gear while climbing or entering the highway as well as to down-shift to slow down without breaking.
Lately, I've been putting in 87 octane gas and using SNAP or STP Octane boost. Other times I've used both mid grade (which is called for in the manual) and premium gas.
Anyone else out there have this difficulty? :confuse:
I have three on the shelf, that's why I'm asking.
1. The Fram filters do not contain as much filter material as the OEM filters.
2. The bypass spring in the Fram filters is weaker than the OEM filters, so they have a tendency to bypass before the OEM filters do.
3. The wall thickness of the Fram filters is less than the OEM filters, so they have a tendency to burst before the factory filters do.
I believe Edmunds has a thread on this subject.
The cool thing about Fram is that they are rubberized so you can screw them on and off without an oil filter wrench.
Buy the Fram and drive , I say........the number, I believe is PH 16, it will set you back less than $7.
http://www.oilfilterstudy.com/
Search for filters in bobistheoilguy's website. Just add the usual com.
http://img.photobucket.com/albums/v631/bigodave/FramPH8A.jpg
http://img.photobucket.com/albums/v631/bigodave/PurolatorPureONEPL30001.jpg
http://img.photobucket.com/albums/v631/bigodave/PurolatorPremiumPlusL30001.jpg
It's the crappiest I ever saw. A nightmare to use, potentially impossible to remove at the gas station. I put it in garbage yesterday after paying CAN$ 25 for it to my beloved dealer a couple of months ago. I got from the general hardware store (Canadian Tire) a perfect one for CAN$ 20.
Happy fueling !
Hey , you know what? Tell Bob the oil chimp this........If you change your oil EVERY 3,000 miles, you can use a paper coffee filter if you want to............Enough said on this subject........................... :mad:
So - agree to disagree.
Mine stalls more frequently in the rain/high humidity, and the problem usually only happens when the engine is cold. It just doesn't seem to hold idle or low revs. That also explains the stalling during turning and stopping that many others reported. I now only use "top tier" 91 octane gas, with moderately improved results.
I am sure it is the same size that would fit a 2005 Pac, but I am just looking for some confirmation. Any one happen to know? I've been looking for info for 3 days online and can't find out.
I did some research and they seemed to have the best price.
I also got a K&N for my 2006 Odyssey EX-L from them.
www.bobistheoilguy.com/airfilter/airtest1.htm
The filters in this test were tested for both flow and filtration. The pressure drop across a filter is a good indication of its ability to rob the engine of needed airflow and hence power. Obviously the air filter with the least pressure drop is the highest performing.
I too am a scientist and like the test, but have problems with it. I would never assume anything as in Obviously the air filter... The highest performing filter is the highest performing filter on a car. You would have to run performance tests of some type on different cars to make this statement.
The test goes on to say that the regular paper filters filter better. The question is "are the premium filters good enough". How good do you need? Again, this can only be tested on a car presumably by the rate of engine failure caused by particulate from the intake and no where else.
None of this is easy to do scientifically with stastical confidence.
After the dealer fixed a faulty check engine light on the 3rd try a new problem showed up. While driving the fuel gauge will shut off, causing the warning chime to sound. A few seconds later the gauge will work again, showing how gas is left. Sometimes it does it about 5 time in succession, other times it will be fine for a couple of weeks. Recently it is doing it every drive. Dealer charged $85 to tell it will cost $600 to replace the sending unit in the gas tank. Any others have similar problem. The cost of the fix seems high for a car less then two years old.
It's weird you have to pay US$85 for diagnostic. I always predicted that these extremely complex cars will cost a fortune to fix when they become old. In 16 years I never paid one penny for diagnostic, when fixing my 1989 Volvo 240 wagon.
Why ... why ... why ... they don't make them anymore ?!?
This is the first Pacifica I have owned, & I can't find anything in the owners manual ( unless I missed it) so what service needs performed? Do I need to take it to a mechanic to get the light to go out, or can I replace whatever needs replaced & the light will go out? I am moderately mechanically inclined & could do alot on my own.
Thanks for any feedback.
The dealer charged us $70.00 to perform a software upgrade.
that fixed the problem at approx 29000 miles.
Go for a second opinion with another dealer.
best of luck,
Norm E.
