Chrysler Pacifica: Problems & Solutions
My dealership will not fix this unless I find proof that other Pacifica owners are reporting the same problem. THanks!
The NHTSA doesn't give the content of the TSB 0200403. It gives just the symptom, not the cause and the fix. Would you have the full TSB ?
If, as you say, they "Retightened the Lower Control Arm which was replaced in the previous TSB", it looks to me that they have no clue how to fix it, and try different things. I won't bug them. They better have the time to find the real fix. I hope they will find it ...
I must say I didn't expect Chrysler to screw such a simple thing, like a play somewhere in the suspension. I expected "fancier" trouble. I would give an A+ mark to all the Pac designers, except the suspension designers. Those would get a D from me. I didn't offer an F because they still built the most stable SUV on the planet. It's funny, but that's why I bought the Pacifica ...
I've had two of your similar problems.
I. A "popping sound" also occurred when I turned the corners, off and on in our new Pacifica. After taking it in 5 times, the problem was finally located and the "control steering or bushing support rods" or something akin to that, had gone bad and was worn and rusted??? How could this be on a new car. No explanation was given.
2. After one year, the exterior of my car has multiple blemishes, and peeling. After car washing, more marks appear. Very poor pain quality and dealer will not fix.
Thanks for posting your problems! Good luck!
After the first 6 - 8 months ...
Please write your letters of concern to District Managers. Thanks!
oh well.. now my wheel barring is just starting to make noise and I am out of the 12k warranty (I have 47 k) on the SUV. the 75k extended I purchased doesn't cover wheel bearings ! uuugh.
do a search on this forum for TSB. someone posted a link that actually has scans of ALL CHRYSLER TSBs (so you have to scan thru and find the number of the TSB you want). its within the last 3 months that it was posted a link to a direct TSB. then go back one level and you will see ALL the TSBs, not just PAC TSBs.
We have roughly 26,000 miles on it and it's had it's share of problems. It's also an AWD model so we average 17 MPG. She mostly drives around town with the kids so I would guess hwy miles would be a little better but expect 17 in the city. We have performed all the recalls and had the transfer case replaced plus it took 7 tries to get the driver's door chrome trim replaced correctly. Service dept just tried to rush it every time until I would not pick it up until they took it to the body shop to have them do it correctly. Service Depts should never work on body moulding or anything in that arena. It's like tank drivers doing heart surgery. It takes more time though and it would mean a focus on QA.
The resale value of the Pacifica is also too low. It is a nice vehicle and loaded with a luxury touch but I expected a better value after just 2 years of ownership. If they give me 21K, and that's pushing it, I will still owe some on it that I will have to make up out of my pocket. This is a prime example of a good lease vehicle and I kick myself for not doing a lease.
Phil
I am the main driver and I agree there is a major blind spot that I am not comfortable with.
We've had a couple other problems to that were fixed quickly under warrantee, but the poor paint job is very obvious and they are not eager to fix it.
This is not good for a new car barely a year old!
Kara
Anyone have this problem? In the morning, the power sit & heat seat will not work until you drive about 1 mile, After 1 mile it start to work again. this is make me very upset for my brand new 2005 Pacifica.
Anyone have this problem If do did you got it fix? also can you tell me what parts is wrong?
Thanks for your info.
after they fix it, i will post it here
The "whine" occurs whether the climate control is on or off......
Like I said, it is faint but noticeable...My Pac has 21,000 miles on it now..
Any ideas would be appreciated, it will be awhile before I take it in as I have no other real issues to deal with........
Thanks :confuse:
################ Message ###############
Does somebody have a rumble engine noise when accelerating at 2500 RPM ? When pushing the gas pedal such as the RPM goes from 2000 to 3000 RPM, the engine noise peaks noticeably around 2500 RPM.
When in the 4th gear, the noise peak happens when accelerating at about 68 mph (2500 RPM in 4th gear). At higher speeds (around 75 mph) the noise disappears. To get it I must accelerate not too hard, such as the gearbox doesn't switch gears, so the RPM stays at 2500 RPM.
I get the noise when accelerating only (engine and muffler under load). If I release the gas pedal the noise disappears.
When test driving different cars, before buying the Pacifica, the same thing happened when I test drove a Toyota Sienna. It's like the muffler would resonate around 2500 rpm ... or something else.
#################### End of message ####################
People with FWD 3.8 liter Pacs and people with AWD 3.5 liter Pacs reported no noise. People owning FWD 3.5 liter Pacs reported having the noise.
Are here other FWD 3.5 liter owners ? Do you have that noise ? I can tell ... I am rather disappointed ... suspension rattle, engine rumble ... Nothing broke yet, but this is not a "luxury car" as they claim. All these noises were there when the car was brand new ... they don't have test drivers in Windsor ??? I would bet there are thousands of Pacs having these noises.
also it pulls to the left constantly and you have to keep right turning pressure on the steering wheel at all times it has been like that since it was new.
i am just preparing for another session with the service manager and was wondering if you share these problems?
I have not noticed any suspension noises, the ride is quite composed over rough surfaces, we have numerous areas of sorry asphalt in Houston. My former Honda was punishing at times in this regard................
About the suspension noise, all the four Pacs I drove had it, so probably yours has it too. The difference between me and 99% of the people on the planet (my wife included) is that I can hear what others can't hear, and I can see what others can't see. I am too picky I know, but this is how I earned my living. I am a Test Engineer.
Just so you know, if some of you go in for the "Headlight harness recall", when you get your car back check if those small reflectors inside the headlamps are still centered on the bulb. The smart guy who replaced my bulbs probably hit the small reflector when inserting the bulb, and bent it, so now some of the light from the left headlight goes to the forest, not forward.
I think the problem is that Pacifica is a so called "luxury" car sold for CAN$40,000, but is manufactured and serviced by people who manufacture and service CAN$20,000 vans. This is a obstacle so big that it's possible Pacifica would never be not even close to offers from Volvo / BMW / Lexus. I am not mad at the car (yet), but those guys could make me hate it.
The keyword is "PASSION". If the guys work for a pay cheque, Pacifica will never become what was supposed to. If they would work for PASSION, Chrysler could become a manufacturer as great as the big players. Unfortunately passion cannot be taught in schools. I have it because I was obsessed with cars since I was a child. Those mechanics work for a pay cheque.
Thanks in advance.
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Mazda Mania Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
sorry about the all caps post ( job habbit)
update on the car , they sent me a hold harmless agreement stating they will repair it the car and pay for my loaner if i sign it agreeing not to sue in the future. that was after I alredy picked the thing back up.
On my 05 Limited, when I start reversing and get closer to an object, the BEEP sound comes in loud and clear, as the OEM system will partially mute the audio sound system when the BEEP is active. It's pretty neet actually. Maybe they can engage that particular feature with the kit you purchased from them?
Good Luck!
IngeniousGuy
We purchased our 05 Pacifica from a dealership 20 miles away and purchased an extended warranty, but when we needed to take it to repairs, we were told we could go to any chrysler dealership. We did take it to one place 3 times, but it still has not been fixed.
My question is: do i have to take my car to the dealership I bought it from in order for the lemon law to apply or is it any dealership? Thank you! :lemon:
Getting Some Lemon-Aid From Your Lemon Maker
/Gerald
2005 Touring FWD
Thanks.... Paul
I was driving up to the Sierras today and did some passing of other cars when the single lane temporarily opened into some short passing lanes. To do the quickest possible passes, I downshifted manually to 2nd gear and used plenty of throttle (not all the way to the floor). In two attempts, when the engine reached 5300 - 5400 it started cutting out, jerkingly, as if there was an RPM rev limiter in action. When I upshifted to 3rd, the engine pulled fine. The conditions were; 4 people in the car and uphill passing at elevations 3-4000 feet. Felt like the car was running out of fuel at that RPM.
I tried the acceleration later when I returned to about 1000 feet elevations, same four person in car but, on level ground. No problem at all, engine pulled all the way to 6500 PRM.
Looks to me that under very heavy loads there is a fuel shortage and cut off. Anyone had this happen to them? It is potentially dangerous as it leaves one stumbling when attempting a pass...
Otherwise, car has plenty of power for hill driving and passing.
Mine is a 2005 Touring with 18,000 miles on it.
Thanks for any reply.
Paul
The warning light is very visible and the alarm is loud without being irritating. While some of the aftermarket kits are very good, you may have a hard time getting someone to install it. I was going to do ours with the help of a friend, but I figured that I would let the dealership be responsible for any damage that resulted from drilling through the bumper.
