I've had my 300C since June of 05 & it just now ticked 74,000 on the digital odometer. Three years without a significant problem (biggest bug is that silly auto-trans inspection plug that leaks periodically). This is good & bad news -- I sprang for the 7 year 100,000 mile bumper-to-bumper extended warranty (although I got it at dealer cost).
The Conti tires suck, but Chrysler doesn't make those. Eventually there were a few rattles in the back end -- I found that the plastic fender liners can flex sufficiently to hit the exhaust pipes -- the home made fix is rubber stoppers stuck onto the metal underbody & the fender liner with industrial contact cement -- no more rattles.
With good winter tires the car is really good in snow & way more fun than front or all-wheel drivers. I have never been stuck & I have never "lost it".
The much-maligned soft plastic body parts are still in perfect shape & the car still could pass for new -- gleaming paint, tight body, smooth running, still-perfectly supportive seats.
My old 99 Concord LXi now has 237,000 showing & is beginning to give trouble -- I will replace it with another 300 -- maybe a Limited this time -- or even a yr-old 300C at a lower price than a new Limited. Whatever I buy to replace the Concord, the 05 300C stays -- it is an awesome ride, has been a tremendous value & is still like a new car.
I have a drop-in K&N in my wife's PT Cruiser turbo and it works well. I used a cone K&N filter in my old Mysitque for nearly 10 years and no problems after I learned not to put too much oil on it.
I have dual K&N cone filters on my Viper that seem to work fairly well.
I have used K & N filters for all my vehicles and NEVER had a problem with them period. Carbs or Injected, every one performed flawlessly and every one did increase horsepower and mileage. I have recommended these for years to anyone who will listen and THEY have had flawless performance. My latest is a 2008 Honda Ridgeline, 15.5 mpg to 19.9 in town, (63 Impala 383 Demon Carb, 2000 Mercury Sable injected, 2003 GMC Sonoma injected, 2008 American Iron Horse carb. also have them)
I agree that the cleaning may be an issue as folks are cleaning them way :too often. Once every 6 months, "clean and dry it completely, oil it lightly" then put it in. The thing will last 1,000,000 miles. My friend Dock just put one in his 300 and it's doing great...better mileage and more power.
Thanks for the opportunity to share info and experience. My personal experience with Nissan is .....Well (I am not allowed to use bad language) not very good. My Nissan Maxima SE 2001 (traded for the Honda) was a sensor/EGR valve eater with paper elements or K&N, premium fuel an all.
They say better mileage because a properly inflated tire will provide EXTREMELY MARGINALLY better mileage. This is based on the assumption that you have regular air in your tires, and DON'T check the pressure to make sure it is up.
32lbs nitrogen or 32lbs regular air will provide the exact same ride, and the exact same gas mileage.
SO.....check your tires frequently and fill with whatever is available.
Anyone have any experience with something like this? I had one once before on the trunk of my Mercedes when I put a large suitcase in the trunk and slammed the trunk shut without realizing the interference.
Brownie 12
Has anyoneelse had this problem and what was the repair. Dealer is holding car per-Chrysler because they can not figure what is wrong. With no key faub in or around car the windshield wipers stayed on and lights stayed on.
CraigSS@live.com
This might interest me...
- Ray
Torque addict
MODERATOR /ADMINISTRATOR
Review your vehicle
Good luck with your new car.
Craig
I've read some complaints from owners of 2005-2006 Chrysler 300C's with the 5.7L Hemi that they have experienced complete engine failures due to bent rods,damaged pistons,timing chain issues,etc.,due to engine lubrication problems. This has happened with mileage ranging from 40-100K+. Although it has been 8 years since these issues occurred, does anyone know if these engine failures still exist with the current 2013-2014 models?? It was also reported that transmission problems were also a complaint. I would like to purchase a new 2014 or 2015 with the HEMI but would like to find out if this situation is still going on before I invest my money. Thanks for your help!
