I will ask about disconnecting the battery (who know what that will do to all the other electrical components).
Thanks for the info, I'm sure it will come in handy.
But yes, there aren't any adverse electrical effects of disconnecting the battery. If there were, it would be detailed in the owner's manual under battery replacement.
The only thing I can think of that you need to be prepared for is the alarm going off when you reconnect the battery. Keep that keyfob handy!
Ken
-juice
I noticed that the base (X) Forester now has a fold-down rear-seat armrest, and am hoping that the base OB gets the same upgrade. That's about the only feature of the higher OB trim levels that I'd like to see flowed down to the base model.
I hope they DON'T re-align OB trim levels like they've done with Forester. I don't want a sunroof (for headroom reasons), and don't like that you'd have to get a sunroof on the '06 Forester in order to get useful goodies like alloys, limited-slip, all-weather package, etc. I fear they'll decide to "de-content" the base OB to encourage customers to step up to the OBL.
you figured out how to buckle your seatbelt? good for you!
That's it!
of course, a Subaru dealer should do this for free.
~c
According to the owner's manual, the shift points for the GT (balanced for performance vs.mileage) are 20 mph, 30 mph and 40 mph for 2nd, 3rd and 4th respectively. This is unnecessarily high for me even for casual driving because that translate to shifting gears when the engine is running close to 3000 rpm. How low, RPM-wise, can I short shift to gain some improvement in mileage?
FJ60
2005 GT Lmt Wgn 5MT
-juice
in normal driving you'll be best served to shift between 2,500 and 3,000 rpm. light throttle, say 20-25%, will get you the best gas mileage and revving to 3,000 honestly is pretty irrelevant compared to 2,500 assuming the same throttle input.
~Colin
So far I'm very happy with the car. I traded in a 3 year old WRX wagon with 96K miles. The Legacy is much more refined. The interior is a huge step up. Some other likes are the huge sunroof, the smaller steering wheel, and heated leather seats. Noise from the tires is a bit louder than I'd like, though better than the WRX was. Wind and engine noise are controlled extremely well. Even at 70 mph on a windy day, there's very little wind noise. Very impressive.
I haven't been able to push the car yet because of the break in, but I can feel the potential in there. Cornering seems pretty good too from what I've tried. I do notice that it feels significantly longer than the WRX was. I've been driving it around corners like it's a semi. Something I'll have to get used so. The size is one of the reasons I moved up to the Legacy, so this is just an observation, not a complaint.
This is the first auto transmission car I've owned (at 36 years old). So far I don't miss the clutch except when trying to start the car. Time will tell if this remains the case...
I think your left foot deserves a break. :sick:
Congrats.
-juice
Ken
Maybe a different technique will help - try slipping the clutch a bit on takeup and build the RPMS to 1500 or above while still slipping.
Krzys
You'll get used to it and just apply more throttle.
-juice
Subaru's have lots of quirks. Just get used to them and enjoy your new car.
tom
I also noticed that a lot of the switchgear isn't lit at night. Some of the window and lock controls, the vents and their controls, the gear selector and indicators, shift buttons on the steering wheel, etc... I also noticed that the radio and hvac displays are green, but all of the other switchgear is red. They contrast nicely, but it seems like they should match. I imagine these are cost cutting measures, but when you are trying to move upscale, people begin to notice these things.
Disclaimer: I'm still super happy with my new Legacy. I'm just starting to notice some of the shortcomings as well as all the important stuff that I really like.
Which model Legacy wagon do you have? On my GT wagon, the HVAC and radio control display is white so it matches the instrument panel layout. I wonder if the manual HVAC system has different colors.
Ken
Another question: The "security" icon light always flashes when I turn off the car. Is that normal?
Bob
I believe that's normal behavior for the security icon. I believe it was mentioned somewhere in the manual.
Ken
Dear Sir:
I have would like to bring to your attention a technologic anomaly in my Subaru that has severely compromised my appreciation of my otherwise excellent new 2005 Legacy Sedan GT. This anomaly has colored my purchase decision to the point I would not recommend this car or buy a new one until this problem is fixed, which is ridiculously easy.... in the production stage.
My concern? I discovered after I bought the car there is NO GOOD WAY to get an "auxiliary signal" in my case XM radio, to others -iPods and the like, into the Stock (and hard to replace) stereo system in this car. I have a portable XM unit and a 4 year contract with XM paid for.
I asked the local dealer to install "direct in" jacks as part of the deal to buy this car, because I otherwise liked the sound system, and part of my financial calculation was not needing to spend more on the audio. He agreed, in good faith. This is not a complaint about the dealer or sales staff.
When I bought the car in, I was told neither his service dept NOR the local electronic dealer, Crutchfield, could do this! He was right; there is NO aux signal route in, even "round the back". Previously I was using the XM via a cassette adapter in my 95 Legacy, but of course in new one, no cassette. I was then told my best option was a "hard wired FM modulator" which injects the signal directly into the antenna input, heard through the FM radio, and lowers the interference from outside stations. This is a "just barely acceptable" solution to audio buffs. I was not crazy about this but thought I could live with this. Then, guess what, I learn that this can be adapted to EVERY CAR in the WORLD except new Subaru's because of an "atypical" antenna jack!! I was then suggested a totally unacceptable alternative, a "wireless FM modulator". These are famous for and confirmed by me for rotten fidelity and much interference. Not useful in this day of digital audio!
So I am totally frustrated, to the point of having to recommend against an otherwise great car to those millions of us who depend on good music for our sanity. I have no idea how to solve my dilemma, but I would greatly appreciate a solution from Subaru.
This would be so easily accommodated, by an OEM radio with a tiny "auxiliary" stereo mini-jack on the face plate!
Then I could enjoy my daily commute on an otherwise fun and practical car.
Thanks for your attention to this matter.
Sincerely,
FYI, Subaru isn't the only car manufacturer that uses non-standard FM antenna connectors. Metra is reported to be releasing an adapter in the near future. Others have simply gone out and soldered on their own standard connector to make it work.
Ken
Last I checked, Subarus were on their list for "future interfaces."
Monster also has a product "iCruze" that is similar. I'm not sure if has an application for Subarus yet.
2024 Audi Q8 e-tron - 2017 911 C4S - 2025 BRZ - 2023 A6 Allroad - 2024 Genesis GV60 - 2019 Cayman
-Dave
Bob
-Dave
This issue is not Subaru's fault. Most factory radios have proprietary antenna plugs. The difference is that there are not enough 2005 Subarus on the road with after market audio accessories to motivate the standard after market outfits to design and mold an adapter. The Subaru antenna variance across models and trim levels further exacerbates the problem.
Good Luck!
Craig
btw, congrats on the new OBW
~Colin
I normally buy filters from an online dealer. Try and find one nearest to you in order to save on shipping time/costs. I'm in Virginia and buy parts from Liberty Subaru in NJ, I believe they discount 15-20%.
CRaig
Nav is not of interest, but mechanical goodies, like 6 speed are of great interest.
jim
To further the general Legacy community's knowledge about this car, I decided to test the actual cruising range of the vehicle... Ok, actually, I was trying to make it to my favorite gas station and I knew it would be close. I was able to go 387 miles on a tank of gas before I ran out on the freeway and had to pull over. :sick: I was about a quarter mile from the exit I was trying to make and could actually see the gas station I had been going for. Unfortunately it was a steep uphill offramp, so there was no chance of coasting to it.
My house was only 10 minutes away, so rather than test the Subaru roadside assistance, and be laughed at by the tow truck driver, I called my wife. She brought me gas and laughed at me instead. :P FWIW, I was only able to put 15.5 gallons in total. Either it stops running 1.5 gallons before it's empty, or the gas pump will not fill it all the way. I usually do not top the tank off after the pump stops.
After starting the car again, I had a CEL, :lemon: and of course the cruise light was blinking. When I got home, I did a little research, then went out and started the car and shut it off again. After 4 tries, the CEL went away. :shades: It would seem that if the cause of the CEL isn't present after you restart the car 5 times, it goes away.
It's been 3 weeks since any serious snow here, so I think it's safe to put my summer wheels from the WRX on. I'll get try them out this weekend and post a pic when I get them on.
That's too funny. I'm glad to hear that you were close enough to home to get some help. I agree that it would have been embarrasing to call for Roadside Assistance for something like that.
If it's not a serious error (like yours), CELs do go out after several on/off cycles.
Thanks for checking the 15.5 gallons!
Ken
