My apologies if this has already been covered, but can someone explain to me why the trip computers display rounded off numbers, rather than acual? More importantly, can this be reprogrammed and fixed?? Instant mileage in .5 mi increments just doesn't seem to instant, and the avg mpg in .3 increments is just plain silly!!
Thanks in advance to all!!
Oliver
I don't think 0.3 MPG really matters in the big picture. But that's just my not so humble opinion.
Karl
iPod your Subaru Outback (Idealog)
My OB is a '97 and I don't iPod (just happened across the link), but it looked like it may be of interest.
stopped to switch into this mode?
You can not switch to P or R while moving, but i guess you knew that allready
That's pretty funny!
Sport is turned on when you slide the gear selector from D over to the manumatic side. At this point, you are still in full Auto, albeit with a more aggressive engine/transmission behavior.
From here, you can either shift up (+) or down (-) depending on your current gear (manumatic mode). The one thing I don't like about this is that when you go into the manumatic gate (just Sport mode without going up or down), there is no indication of the current gear. The only way to actually know this is to change gear. This is annoying.
Also, you can actually shift gears in full auto (non-sport) via the steering wheel controls. The engine will return to full auto and the appropriate gear after a few seconds. This is handy on the highway.
-mark
Also, to make this a two part question - I know gas mileage has a lot to do with the weight of you foot, but all things being equal for someone who drives mostly on country roads around 40 -50 mph what would be the gas mileage difference between the turbo and the non-turbo.
Thanks in advance for any input.
In general, the OBXT will lean and push more through turns due to it's suspension setup and slightly taller tires. While it clearly outhandles SUVs and other vehicles with similar ground clearance, it's not going to provide the same handling as a GT. How much a trade off is acceptable really comes down to your personal preference.
When I drove an OBXT loaner while my LGT was in service, it felt like a bigger vehicle from a dynamic sense. Road bumps were more subdued but at the same time, the vehicle felt less willing to change direction.
As for gas milage, that's a hard one. I'd guesstimate that you'd see anywhere from a 3-5 mpg disadvantage with the turbo.
Ken
If you're after the handling of the GT, then the XT will probably disappoint you, and it would be prohibitively expensive, and a kludge, to attempt to mod the suspension. There's a lot more difference than just the ride height.
You're looking at a 4-8 MPG penalty with the turbo, depending on the type/mix of driving you do. I regularly get 20-21mpg on my OB XT with a large bias of highway miles.
Try the LGT wagon with the 5EAT trans in sport mode and manumatic mode. You might decide you like it. After preferring manuals for years, the 5EAT is the first auto trans that doesn't feel like a penalty to me -- it's pretty darn good. I do think the manumatic mode is kind of a joke, but sport mode rocks.
CRaig
The regular 175-hp version does a lot better on gas mileage than the turbo, figure 5+ mpg on average.
In one feld swoop, I replaced the OE 15mm RSB with a Legacy JDM OE 20mm RSB, re-aligned the front camber to -.4 degrees, and most importantly replaced the RE92's with Yokohama Advan ST's. The handling and ride have been transformed to a degree that I have never experienced with such relatively simple mods. I would easily wager that my OBXT has higher handling limits than a stock RE92 shod GT. I'm now driving it in the same manner as my old WRX with the SPD/STi suspension, and am completely content.
I wrote-up a long and detailed review at legacygt.com if you want the specific pro/cons.
Today i left my car at Subaru for them to check why my rear hatch make noise in bumps.
Wave only to fellow LGT owners (not too many around)
Give a thumbs up to STI (have to be crazy to own one in NE)
and Nod to WRX (got to show the kiddies some respect)
Rob M.
I would love to have this. I wonder if the dealer can program this? I'll check next time I am in.
Thanks for the information.
Should be a programming issue, but you never know. It could also be a difference from Japan produced vs. USA produced cars. Mine is from the Japanese factory as all european Subaru cars.
Karl
Neat -- I wish my Sport mode did that too.
Ken
There's quite a big population of Subaru owners in Northern California as opposed to the LA area.
What were you driving? Maybe I was one of the people waving!
Ken
I went to that website but I could not locate your review could you help me find it.
FJ60
Craig
I'm not going to take it to the track, but for street driving its limits and handling characteristics are in the felonious range. I would love to a comparison against a stock GT with RE92's.
I think it would take a bit of suspension/tire mods to make an OB feel as sharp as my GT with 45 profile tires (I switched out the RE92a's BTW).
But your post is interesting- I think the OB does have more rubber on the road than my GT so maybe it does handle as well? At least until I change my suspension.
tom
I agree with the understeer being safer for the masses. No argument there. But regarding the Subaru criticism for oversteering... ?? What's your source on that? I have never heard such a thing, and even the most aggressively tuned Subaru ever released, the WRX STi, still is setup for understeer. It understeers a lot more than a stock Evo, for comparison.
Chiming in a bit on the Outback versus Legacy GT comparo.. the main difference is not suspension geometry at all, as I think you'll find they are the same for any given generation of Outback and Legacy other than ride height, which solely lies in strut length and springs. (They both went to rear multilink in 2000, right?) Ride height is something, but I think the key difference that won't ever be eliminated / mitigated is weight if you're comparing the Legacy sedan with an Outback. If you are looking at Legacy wagon vs. Outback... um, I think ride height is about it.
~Colin
-juice
I would be delighted to have a lower version of my VDC wagon....which was made truck height to keep CAFE problems away. One partial solution, though it might put miles on the odometer faster and uncalibrate the speedometer, is to put on 215-45 tires like on the GT. There might be a software fix for that problem.
Do you still have the "click" noise when stopping? My 2005 Outback does the same thing.
Hence my comment regarding safety for the general public. Maybe I didn't tie that in too clearly.
But I can start referencing everything I say in the future if you really want Colin.
tom
We discussed this over on legacygt about 1.5 years ago -- I believe several parts that are stamped steel or cast iron on the Outback are lighter on the Legacy. I seem to recall that, in some parts of the world, the Legacy GT even had a couple aluminum pieces as an upgrade from the base Legacy.
Another funny and REAL story is about the Beetle. One of my friends from mainland China told me it is THE car for concubines. Lots of rich Chinese men buy the Beetle for their mistresses, he said. So, he will NEVER let his wife drive the Beetle so that he won't give a wrong impression to his Chinese community's people.
That may also apply to concubines, I'm not sure...
But how can you shut off the honk honk when you enter the forums?
Doesn't the GT also have tighter steering than the XT? Or would that be changed with the suspension changes? I was thinking you might also have to replace the steering rack or at least some bushings.
No, I don't know much about what I'm talking about. I do know that the steering of my GT is a lot tighter than that of the standard Legacy. Not sure about the Outback XT. :confuse:
Cheers!
-Ian
tom
I'd been advised in some of these forums to practice in an isolated spot and appreciate the advise. Hopefully I will be better off in real world situations now.
CRaig
The forecast yesterday said we could expect 50cm of snow and some winds the upcoming days in northern Sweden...
Have you had a chance to post any pics of the Hidden Hitch you installed on your OB XT?
- Joe
For example, when driving and making an emergent stop at 100km/h, the front of those cars with soft suspensions might go more downward toward the ground while their rear might go more upward, resulting in longer stopping lengths or even improper stopping (their front touching the ground and spinning...).
I'm wondering how valid his arguments are and how the Legacy and the other Subies stack up to those European cars with hard suspensions.
Comparing cars per class makes sense, or even across price range, but to generalize about the nationality of a make and its driving characteristics has little basis in reality.
It would be far more appropriate to compare a Nissan 350Z vs. a BMW Z4 vs. a Corvette and discuss traits than to generalize about a Japanese car vs. a German car vs. an American car and their very general qualities.
Anyway, car design, manufacture and marketing is so international now, it is hard to distinguish. The Acura TL I own is a Japanese car, designed in California, assembled in Ohio, with parts from America and Japan, and it has a stiffer suspension than my old German designed, German manufactured VW Passat with parts from all over Europe.
All cars sold have suspension systems designed to minimize dive under hard braking.
Sporty cars have bigger tires, brakes, and stiffer suspensions and do generally better in such tests. But there are just as many Japanese and American cars so configured as there are European. Most all of them stop from 60 in 115-130 feet or so.
An interesting tidbit -- Subaru's active AWD system will shift power forward on braking to minimize dive.
Craig
I would guess your car guru friend is more of a car snob.
tom
Given that I am pretty mechanical, is this something I can install myself? Is the wiring already in place I just have to connect the switch and the lights to the harness? Also, does anyone know of a good source (online, perhaps) for these? Does anyone have them and love them or not care for them?
I miss not being able to see right in front of the car when driving slowly in bad weather. I really like the long range of the headlamps (even if the cut off pattern took a little getting used to), and I think the high beams are great, but having something that fills between the car and bottom of the headlights in bad weather would be great.
(If this is in the wrong Legacy discussion, sorry in advance)
--LEB
The kit should be super easy to install for someone like you.
The switch is something I don't know about. On my 05 Outback, the fog light switch is on the turn stalk, next to the other light switch ring. Previous Outbacks and Legacys have had the switch on the dash, near the driver's knee. I have no idea what they do for a switch on the accessory lights for an 05 Legacy.
Good luck!
Craig
If it's a case of missing LEDs to save a few manufacturing pennies.. then I was thinking of cracking open the switches and adding the necessary LEDs, or drilling an LED into the door panel from above to shine down on the window console switches.
Regards
Scott
