I have seen this feature on lower trim levels, and doubt they would remove it from the 2.5i to save costs. Check your lockout switch....
CRaig
I don't believe this is actually discussed in the manual (could be wrong).
-mark
Stanton
-juice
I've gotten used to it so I no longer "hear" it.
Ken
Hahahahhahaha..... Oh, some typos are just too funny..... :P
But now that I think about it, going from D to R while moving would cause any gearhead to, shift without the "f".
Sorry for the typo! I'm still a little jetlagged from my business trip to Thailand last week.
Ken
Usually a good time to flush the transmission
bwah-ha-ha
Bob from Long Island
Scatology? The study of dung? Is this dirty academic humor?
tom
I just did my first oil change last night on my 06 3.0R Outback. First off, the underbody trim pieces are a pain in the butt. It made me long for the simplicity of my 98 Outback.
Anyway, back on topic. When I filled the oil I put in the quoted 5.8 quarts of oil. I ran the car for a while to check for leaks. I then checked the oil level. It was barely on the low end of the dipstick markings.
I checked the oil again today after driving it. Still in the low area.
Is there some magic trick to accurately measuring the oil level on the new Outbacks, or at least the H6 Outbacks? I have checked it immediately after turning the engine off and also after it has sat for 10 minutes. Same readings.
I guess it's possible that the 5 quart jug of oil was slightly under filled, but I am reluctant to add more oil until I know if it is really low or not.
Any hints?
Karl
you need to check the oil level on a cold engine. when hot, a lot of oil is out of the pan up in the cylinder heads. to compensate for this, some cars have a dipstick with a hot side and a cold side. I'm not sure if that's the case on a Subaru but even if it were, I still recommend checking the level when cold.
I never check the level on any of my vehicles right after a change btw. I meticulously put in the oil and I know that there isn't any way for it to get out, so I have the utmost confidence that there is the amount in there that I just put in.
~Colin
FJ60
Doesn't your 3.0R have a swing away panel that exposes the oil filter? On my GT wagon, I only need to remove three quarter turn fasteners with a screwdriver and I'm good to go. The drain spout is past the underbody gaurd and exposed. I've also added a Fumoto valve to make oil changes easier and neater.
As for the oil level, it can be tricky. Do you prime the oil filter and take that into account? What I usually do is err on the conservative side and stop at some amount I know is below the engine capacity. I then wait until the next morning when the engine is cold to top it off.
Ken
I also prefer the cold engine overnight method Colin mentioned.
Yeah, it has a swing away panel but the fastener count is five. The 3.0 oil filter mounts sideways (horizontal) so you can not easily pre fill the filter. The drain plug is behind a cutout in the underbody guard, but the oil drips on the guard as it finishes trickling out at the end. It is just one more thing to wipe up when completed. I am considering the Fumoto valve. I'm just griping because it is not a 10 minute job anymore.
I haven't checked the oil when cold yet. My 98 2.5 seemed very insensitive to oil temp. It was very consistent in it's readings. I'll let it sit overnight and check it in the AM.
Karl
The Fumoto valve will get rid of that dripping at the end. Actually, I realized after my post and reading yours that the LGT also has the same drain plug/undergaurd cutout. When I was using the stock drain plug it would drip on a small section and pool on the cover.
The Fumoto valve allows for a much more smooth, laminar flow until the very end. Since it protrudes a bit beyond the stock plug, that last dribble and drips clear that little bit of undergaurd. So, now no more ratchet, no more cursing, fewer shop towels -- it's well worth it, IMO.
Ken
Do you have the one with or without the rubber hose nipple?
Karl
I've found smooth flow from the standard model to be quite easy to direct into my drain bucket.
Ken
Hey. This forum is back!!!! I searched for it for a couple of days and Edmunds would not acknowledge it's existence.
Thanks for the input. With the engine cold the measurement is much closer to showing FULL. It still shows it as being slightly under filled, but I know how much oil I put in so I am leaning towards just leaving it as is and not topping it off.
Karl
How much do the trailers weigh? Anyone know much on aluminum trailers?
I have no direct experience with my Subaru; I only tow my pickup truck up the driveway with it now and again.... but that is 3800# up a very steep grade!
I would also err on the side of being slightly underfilled vs. slightly overfilled (relative to the "F" mark).
Ken
I got an Accutire digital tire pressure gauge.
According to the gauge, my tire pressure was 31/30 psi front/rear while the manual recommends 33/32.
I measured once more with an old analog gauge and it showed 32/31.
So, I gave the digital gauge a chance and adjusted the pressure to 33/32.
OH MY, the ride became so FIRM. It used to be pretty SMOOTH and SOFT.
I'm wondering
(1) how accurate any Accutire digital gauge is
(2) if the tires deflated over the past 3 months (I replaced one tire due to a severe damage at a very low mileage).
(3) if the dealer intentionally deflated them for smooth riding.
Your tire pressure will even vary up and down 1-2 PSI within a couple days if the ambient temperature fluctuates or the tires are in the sun/shade. If you haven't been noticing that all along, then I suspect it's merely a psychological effect now (since you knowingly changed pressure this time). To be honest, +1 or +2 psi is noticeable, but not enough to dramatically alter the ride.
So I would attribute it to #4 (not shown on your list), which is lack of data! Check your tires more frequently.
Craig
-juice
Did you order the valve from their website or somewhere else on the web? After reading the posts, I'm looking into the valve myself.
Contemplating this change but looking for some feedback.
-Ian
I had mine installed about 3 weeks after buying the car. I didn't have any real complaints about the stock shifter, but liked the idea of shorter shifts. The STi shifter still doesn't give really short shifts, more 'medium'. I think if I replaced the shift knob with a shorter one the shifts might feel shorter. It's a little crisper but takes more effort, and it's still not as sharp as say, an RX-8 or Honda S2000.
Overall, I like it. I paid about $350 to have it installed at the dealer I bought my car at, part of the 'option to purchase' when I made my deal.
I suppose you could test drive one at the dealer, some LGT's come with them installed. Or if you're ever in Seattle come take mine for a spin. I work right by REI downtown (Pill Hill).
tom
I guess I'm hoping for a little crisper shifting. I've read about others over on LGT.com going with either the Kartboy or Cobb and going as far as replacing bushings and even the transmission mount. I may have them install the STi tranny mount at the same time.
Thanks again for your input and test drive offer.
-Ian
If you search through various owner's forums, you'll find a bunch of coupon codes that will save you some small amount of money.
Ken
How valid is his argument?
I 'had' the Legacy GT on my list, but if you read any Legacy GT forum, you'll find that the 5speed automatic shudders constently when applying light throttle (ie: cruising). I test drove an '06 LGT Limited with the 5speed auto (wife + children soon + toodling around town = auto req'd) and found teh shudder to be rediculous!. How Subaru can sell a car that feels like it has a clutch that's engaging and disengaging several times a second (I know an auto doesn't have a clutch, it's simply the closest I can get to explaining the feeling) is beyond me!
It's sad, because otherwise I'd be negociating for an LGT, instead of saving a bit more for a S-Line.
I rarely encounter this in my OB XT, I'd say it happens less than 1% of the time. I love the car, and am far, far, more irritated by stuff like door dings than this particular issue. Who knows, perhaps it affects other people/cars more than me.
Craig
looking at similar OB to buy in canada, 2.5i 2006. is yours a legacy or OB, and where did you get it? the msrp is very high here compared to US prices.
It sounds like either a bad test drive or un unhappy Subaru customer.
Go test drive one yourself. If you don't like it, buy something else. The GT is a great car, there's nothing in it's class in that price range or above, IMHO.
Good luck
tom
I could make mine do it when the car was cold, and the A/C was running. Eventually it seems to disappear. Mine did at about 5k. 16k now, and smooth as silk. And no regrets! Rob M.
The Canadian msrp is higher indeed though Subaru puts heated front seats and some minor options as standard (less than 1K, I guess) in Canada.
People say the American msrp was higher a few years ago.
I heard Subaru dealers usually give 2 to 6% discounts off msrp in Canada.
I got my Legacy around 3% off. That means I got ripped off compared to happy American Subaru owners (I envy you, guys down there buying Subbies under invoice).
Before you go to a dealer, check out the following Canadian sites:
http://carcostcanada.com => dealer invoice prices
www.cybercars.ca => dealer invoice prices
Ask for real deal stories here.
Even though I adjusted the pressure to 33/32 (front/rear) at a gas station (a little warm tires), it became 32/31 next morning (cold tires).
I'll check tire pressure more often.
It just sounds to negative to be a real issue.
I agree with you Rob, definitely no regrets!
Dang, you're at 16k. I'm just passing 13.5K!
tom
You guys need to enjoy your GT's more! I'm nearly at 25K!
Cheers!
-Ian
The service writer told me that they don't have anything in writing but Subaru does not recommend the use of synthetic oil in cars with variable valve timing. He stated further that it is too thin to activate the solenoids.
I can understand specifying a particular viscosity for a hydraulic VVT system. But what would that have to do with synthetic?
The guys on subaruoutback.org suggested there was a discussion about this here?
